查看: 8807|回复: 120
altium designer 20.2.4 下载
发表于 2020-9-28 16:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 zysblog 于 2020-9-28 16:37 编辑 , q9 x4 f! N6 o, F8 q/ d
* i# }# ^( S7 c! I
altium designer 20.2.4 下载:
链接:https://pan.baidu.com/s/1XcWbhU56ezwf1uLgyixpow
5 d' t5 {, x5 k9 Y3 I9 ]5 \
游客,如果您要查看本帖隐藏内容请回复
5 V1 C# @0 _: i0 a* ]/ C6 c  _
推荐
发表于 2020-10-2 13:44 | 只看该作者
Version 20.2.4 (Update 1)
Build: 192 Date: 24 September 2020
Schematic
37426
Crash occurred when Fonts were not selected for Pin names or Designators in the Schematic Library.
38385
Placing a specific violation ERC on a net also suppressed all other violations on the net. (BC:13511)
PCB
40257
Output option of "Merge Net-Tie Nets" failed for specific Footprint rotations and gaps between Pads. (BC:14014)
40440
Crash occurred during Differential Pair Routing when the Routing Layer rule was not defined for the layer.
Draftsman
40267
The total board thickness of some placed Board Assembly Views did not match when compared in the Layer Stack Manager and Draftsman document.
40313
Error message appeared during PDF exportation when file was previously opened.
Platform
39450
Local files did not recognize that a project in Altium 365 had been updated.
39695
Symbols did not appear in the preview pane of the Explorer panel.
40389
Opening Output jobs resulted in unresponsive software. (BC:14219)
40399
LayerType settings were not saved after editing a managed footprint.
Data Management
39982
Removed 'Output Jobs' type from Edit Folder dialog for Altium 365 Standard users.
40160
Improved hard-deleted projects handling by removal of the link from Version Control and link to the server project.
40382
"Unable to cast object of type" error message when editing PCL for cloned component.
40617
Project templates still appeared in the Create Project dialog after they were soft-deleted.
Version 20.2.3
Build: 150 Date: 1 September 2020
Schematic
38891
Probes were not recognized in the software.
39554
Move Selection by X, Y in the Schematic Library Editor resulted in the Properties panel not displaying the updated properties of the moved objects. (BC:13981)
PCB
35894
Error message when releasing a project where the drill symbol limit was exceeded. (BC: 12985)
37104
Width rule was not applied to the substack. Use the 'Show values for layer stack' control in the Routing Width design rule to set the width for each substack.
37190
Running DRC on a design returned inconsistent error counts related to the Return Path rule. (BC:14040)
37466
Copper features incorrectly displayed in CAMtastic.
38101
Added control over Gloss Effort to be applied to pushed traces.
38472
Broken Impedance calculations after routing on a PCB with hidden net connections.
38757
The Solder Mask Expansion and Paste Mask Expansion settings were changed after moving pads or making other updates to a pad in a PCBLIB document. (BC:13681)
38798
Crash occurred during placement of Layer Stack Table in PCB.
38992
Invalid Width values for a layer that was not set in Layerstack resulted in an invalid error.
39005
Regions with less than three counts of vertices were still present on the board and PCB List panel when the InPolygon to IsRegion clearance rule was used.
39014
Pad was displayed under Keepout area in Generated Gerber Output when “Include mid-layer pads” checkbox was disabled.
39191
Length Tuning rules were not properly saved after closing and reopening PCB.
39192
The 'Prefer Generic 3D Bodies" mode has been added to the Advanced Settings dialog as a legacy option. (BC:8872)
39202
Via Propagation Delay is now calculated in proportion to the length of the Via used.
39217
The Solder Mask Expansion and Paste Mask Expansion settings in the Pad and Via modes of the Properties panel did not reset to the previous state after using the Undo or Ctrl+Z commands. (BC:13779)
39705
PCB incorrectly activated and zoomed in on placed Comments when switching between documents.
40020
Snapping objects did not work for Embedded Board Array objects. (BC:14150)
Draftsman
36791
Dimensions, images, and fabrication views were missing during PDF output. (BC:12807)
37346
Generated Output PDF Views did not match the Draftsman document.
37955
A compatibility warning was incorrectly displayed in the same version in which the document was created.(BC:14123)
38634
Added "Draftsman.UI.SoftwareRender" option in the Advanced Settings dialog to use software rendering in Draftsman documents.
39587
PDF Outputjob files did not print solder mask polygons with cutouts correctly.
39849
Objects could scale and shift incorrectly after zooming and scrolling, which could not be fixed until the file was closed and opened again.
40021
Variant components defined by alternate parts were incorrectly presented as 'Not Fitted'. (BC:13900)
Platform
37838
Software crash upon startup.
38344
Access violation error occurred after changing any part of the path in the Script Report of an OutJob document.
38368
Removed obsolete file extensions from the Altium Designer installer. (BC:6183)
38377
Some parameters, such as ItemAndRevision, were not being interpreted for OutJob file names.
38968
Preferences located in the %APPDATA%\Altium\Altium Designer folder were not deleted unless admin rights were used.
38999
The Default Prints and Search Paths tabs on the Project Options dialog are now hidden by default.
39092
'File In Use' dialog appears stating that actions cannot be completed if Autocad Fusion and Altium Designer are running simultaneously. (BC:10103)
39397
Added editing support for 'Shared with Me' projects in the Comments panel.
39427
Performance degradation when using File > Recent Documents/Recent Projects/Recent Project Groups commands when files from these groups were located on slow servers.
39746
Software displayed a Warning message that Network Activity is disabled and blocked startup when "Altium Portal" checkbox was disabled in System Preferences. (BC:12850)
Data Management
30525
During project migration via the Item Manager, Component parameters were replaced by Symbol model parameters.
37863
Added the ability to save the component selection after using the Refresh command. (BC:13295)
38247
The "Rename" option has been added to the Projects panel to rename files. (BC:4530; BC:1708)
38310
Fixed regression that caused an inability to connect to AltiumLive after disabling the 'Data Management Server' option from the System - Network Activity page of the Preferences dialog then restarting Altium Designer.
38583
Added 'Include Standard (No BOM) Items' option to the Pick and Place Setup dialog.
38591
Component Synchronization did not support views and did not show all tables. (BC:13599)
38776
Inaccessible Excel-based DBlib components when Excel file of current library was opened. (BC:13387)
38820
Parameters were incorrectly overlapping when made visible after placement from server to document.
38892
Added the ability to Rename managed projects. (BC:10422)
39023
Memory leak in Draftsman.
39065
'Exception has been thrown by the target of invocation' error message as a result of the enabling of FIPS when using Components.
39073
The ActiveBOM document is now named using the naming rule provided by the project template. (BC:13744)
39162
A 'Connection' dialog has been added to connect to available workspaces.
39280
Content Vault was not accessible when not already connected to a workspace.
39382
Added the ability for managed Items to be used as New Document Defaults.
39451
Version Control's 'Commit Whole Project' command did not warn the user of unsaved files.
39552
Resistors were displayed without reloading the entire list in the Explorer panel.
39735
"Navigate to" command from Search in the Explorer panel did not work. (BC:14026)
39781
DBLib column values created from Query Expressions were displaying the incorrect Design Item ID.
39927
Error occurred during Project Releaser due to missing template or insufficient user rights.
BOM
35692
Exception error after signing out of Altium Live account and opening BOM document.
39242
Component revision state for managed components was not available in ActiveBOM for unmanaged designs.
Import/Export
36186
When importing files using the PADS importer, PADS Logic library files were not imported.
39196
PCBs imported from Eagle resulted in the creation of duplicated Mechanical Layer Pairs listed in the View Configuration panel.
Simulation
39446
Case models of digital elements were not found.
推荐
发表于 2020-10-9 13:38 | 只看该作者
[url=]Undo[/url]
[url=]Redo[/url]
1 P* {. C( a: O; b
[url=]全屏[/url]
[url=]常用[/url]
纯文本
/ N- {; R6 t( J
' [) T, d! i9 c4 G4 Y9 |
[url=]Tahoma[/url][url=]2[/url][url=]Hr[/url][url=]B[/url][url=]I[/url][url=]U[/url][url=]Color[/url][url=]BgColor[/url][url=]Url[/url][url=]Unlink[/url]
7 J) m# v; ?4 `; t, p% A3 P$ i
[url=]Table[/url]
[url=]Removeformat[/url]
9 C& w& z9 @* Q5 q1 W1 [! P7 o
[url=]Autotypeset[/url][url=]Left[/url][url=]Center[/url][url=]Right[/url]
[url=]FloatLeft[/url][url=]FloatRight[/url][url=]Orderedlist[/url][url=]Unorderedlist[/url]
4 x" Z7 k( X! C1 p2 T3 V( V8 A0 X
[url=]Undo[/url]
[url=]Redo[/url]
0 V# Z. `. `% D" z% l
[url=]全屏[/url]
[url=]常用[/url]
纯文本
1 F% V2 b7 U1 e9 L% J  l
. Q& o! m# y; G+ f' e
[url=]Tahoma[/url][url=]2[/url][url=]Hr[/url][url=]B[/url][url=]I[/url][url=]U[/url][url=]Color[/url][url=]BgColor[/url][url=]Url[/url][url=]Unlink[/url]) v; X; ^$ L9 l  I: g
[url=]Table[/url]
2 ]* e+ R6 n/ a+ G* @
$ l; Y- ~- ^' T; u: {/ F* j
. W  K+ k8 y8 F$ J$ H$ n
, b. {% m/ X0 O
' l3 E$ X# N3 A% |4 D2 t# h
& T; E& T( z4 x. d" X. v3 j
0 H& u9 h: ^% W6 U) w& K7 s8 ?
    郁闷
    2019-11-15 15:14
    推荐
    发表于 2021-7-16 21:08 | 只看该作者
    Version 20.2.4 (Update 1) Build: 192 Date: 24 September 2020 Schematic 37426 Crash occurred when Fonts were not selected for Pin names or Designators in the Schematic Library. 38385 Placing a specific violation ERC on a net also suppressed all other violations on the net. (BC:13511)
    郁闷
    2020-11-23 15:19
  • 签到天数: 104 天
    [LV.6]常住居民II
    发表于 2020-9-28 16:51 | 只看该作者
    发表于 2020-9-28 17:01 | 只看该作者
    又更新了,有什么新改进?
    发表于 2020-9-28 17:17 | 只看该作者
    altium designer 20.2.4,有什么新改进?
    无聊
    2025-10-26 15:02
  • 签到天数: 1765 天
    [LV.Master]伴坛终老
    发表于 2020-9-28 17:40 | 只看该作者
    要查看本帖隐藏内容
    2022-4-28 15:18
  • 签到天数: 14 天
    [LV.3]偶尔看看II
    发表于 2020-9-28 17:57 | 只看该作者
    不错,谢谢楼主分享
    奋斗
    2025-10-24 15:55
  • 签到天数: 1246 天
    [LV.10]以坛为家III
    发表于 2020-9-28 18:52 | 只看该作者
    好快啊,20.2.3刚弄没几天
    无聊
    2020-8-17 15:47
    发表于 2020-9-28 19:20 | 只看该作者
    111111111111111111111111
    2022-7-25 15:55
  • 签到天数: 9 天
    [LV.3]偶尔看看II
    发表于 2020-9-28 20:41 | 只看该作者
    曾经最美的AD
    % K$ J5 P* g) e+ l& K9 x
    发表于 2020-9-28 23:19 | 只看该作者
    找来看看新功能。
    13#
    发表于 2020-9-28 23:31 | 只看该作者
    性能不知道有没改善
    14#
    Thanks for sharing.
    GMT+8, 2025-10-27 03:24 , Processed in 0.171875 second(s), 24 queries , Gzip On.
