查看: 6071|回复: 6
WIN7下安装 PADS 和ORCAD冲突问题,求救
发表于 2010-11-4 14:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
; l9 @8 e5 k# A
2 v4 E9 _. J5 O% ]7 H* X
  w" k( }' M) T- _6 ?/ D( X9 {! q1 q! g7 i  r! _1 _7 b- n
2 L+ j  E" F  X/ P8 Y4 W
2 ]* h& q1 u6 y1 v. j' @- c6 X1 W* V; Y$ w7 U6 J, \2 h3 J6 C, z  F- i9 v
The following FLEXlm errors were found:7 K% V1 g" T& ]  z& R% l
    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.
& `% q. U. [, E" ~0 C" _ The license key and data for the feature do not match.
; J( p- X' D' n0 c. d5 t This usually happens when a license file has been altered.
( U# V5 N# {# M0 j. s6 YFeature:       mgc_s
6 {5 d: G3 i# ZLicense path:  C:\flexlm\LICENSE.DAT;' s6 u+ X+ u: n" E. O2 c; ^
FLEXnet Licensing error:-8,130
6 y& k7 }" ]; nFor further information, refer to the FLEXnet Licensing documentation,
' j/ ^8 ], u& @: I8 Mavailable at "www.acresso.com".
( X) g5 b3 ^; r    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.
) [# e6 M( m' Y+ ?0 i The license key and data for the feature do not match.
1 u' C& |8 b2 o; ]( A" x9 y8 _ This usually happens when a license file has been altered.; z- M1 J0 T: ~# I4 w: j& q1 l4 c* F) e
Feature:       mentorall_s2 I, O! T; J4 `
License path:  C:\flexlm\LICENSE.DAT;; T2 q8 Q9 d' ]9 \$ G1 |
FLEXnet Licensing error:-8,130) r7 N9 Q6 f7 z' \- p4 M; R
, a9 f$ {; v4 P- h! n8 O5 e, p& Tavailable at "www.acresso.com".
3 x" N6 z9 j7 C" I& o( x: ?    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.
+ T0 B( m& v* f" Z$ D The license key and data for the feature do not match.
6 }: l7 [& D, D3 \ This usually happens when a license file has been altered.  J  Q5 a+ W3 |) T
Feature:       bsdall_c7 W/ t8 b& P/ N
+ H$ y( M) t% G6 P3 wFLEXnet Licensing error:-8,1308 |" y' K6 d) L% s
) m5 }2 }0 k+ n. yavailable at "www.acresso.com".
; q# W( A5 N4 ~; y. C    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.
7 t' G2 k; I9 U: i4 c4 o' g) b The license key and data for the feature do not match.
9 C: h; ^! X+ K8 K; g This usually happens when a license file has been altered.. l5 M) [; P4 U% k
Feature:       paDSPe_c. v' S" n' C% |
License path:  C:\flexlm\LICENSE.DAT;5 O3 M/ k/ M! Y2 y! o
FLEXnet Licensing error:-8,1309 b2 U4 {/ |! e
7 O) u- B9 R5 d8 y- D2 gavailable at "www.acresso.com"./ O. _: G, |4 O& j7 s: ^' ^7 @
7 D& @, Z) Y( E! Z& q* q. \' T The license key and data for the feature do not match.0 j  n6 H+ U# G5 H0 h
This usually happens when a license file has been altered.+ p6 P/ @8 t& a4 B+ r& K# f( E
Feature:       padsxe_c+ ^* z. ]! |5 d3 A/ b
License path:  C:\flexlm\LICENSE.DAT;( {  b: h' B" f0 z+ t! x6 l
4 _) A, C7 O8 {For further information, refer to the FLEXnet Licensing documentation,5 c+ m4 s4 ^# Y2 ]
available at "www.acresso.com".  Q4 A& i! P( W
1 y" W, F6 K2 W+ V The license key and data for the feature do not match.
  J* m1 ?0 B( I1 y# Y( P1 O1 V% J# s This usually happens when a license file has been altered.
1 \) u; v) ^! m  EFeature:       padsse_c
  ~+ g9 R- a- u, g5 y3 oLicense path:  C:\flexlm\LICENSE.DAT;
# X  h2 r- A4 S; Z7 TFLEXnet Licensing error:-8,130
8 O. A4 i4 M; t  Z+ H5 HFor further information, refer to the FLEXnet Licensing documentation,- L' y7 C1 k8 |/ a* s: ~  N
available at "www.acresso.com".8 ]% Z7 h" L7 m, o' S
7 [( @' q# m' [2 @; v The license key and data for the feature do not match.$ z. n8 m6 ?5 T- F5 _; |
This usually happens when a license file has been altered.9 c7 s8 t& a+ g6 ?6 ?) W9 U, W, H4 c; _& f
Feature:       padsped_c
! i0 q0 ~2 ^- ALicense path:  C:\flexlm\LICENSE.DAT;; i- u5 Y6 q( J" O! ~
FLEXnet Licensing error:-8,130, j0 B. \5 B/ s; B" u) S6 O
) c/ W" x5 y( R2 h8 mavailable at "www.acresso.com".0 T* W: y; t2 X" u9 \4 S7 l; j
    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.6 I4 r7 p1 M, F( f% ~
& z1 |8 B( M& k2 ?8 o1 x This usually happens when a license file has been altered.
$ x6 }* M0 e* k6 ?Feature:       padsxed_c
  K# F0 _5 b( Z7 t5 b- bLicense path:  C:\flexlm\LICENSE.DAT;3 Q' E: L3 b& I& n
FLEXnet Licensing error:-8,130; n  A' g' i1 I  j6 R$ F4 B1 U8 Q
% a3 Y. M  x: ]) wavailable at "www.acresso.com".! ~* V) i9 |* U% x% @' N
    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key., g3 n9 N5 C0 X; j. ^3 t
2 w. z, v0 M9 A: D This usually happens when a license file has been altered.) r0 n# w. v  t8 i7 P& \
Feature:       padssed_c
# `4 K( l0 F2 w1 o3 b, T2 t6 d+ e0 c  DLicense path:  C:\flexlm\LICENSE.DAT;
7 s3 P, Q* F( {" I& f, PFLEXnet Licensing error:-8,130
3 a! q, C% ?; Q' xFor further information, refer to the FLEXnet Licensing documentation,
% X7 ~3 z4 l  k5 Yavailable at "www.acresso.com".
1 y' H) t" \* Y; k# P+ `    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.
* S9 a8 p+ d! v; l The license key and data for the feature do not match.. j) J8 l( X2 N' [! X
This usually happens when a license file has been altered.1 x- ~% n, m, l4 a5 F
Feature:       padsxedars_c
  n0 f  y3 |, s3 e8 ?& DLicense path:  C:\flexlm\LICENSE.DAT;
  i5 J, C! v( ^3 UFLEXnet Licensing error:-8,1300 V3 s* y7 o4 v, E2 M0 L
6 k7 z+ o9 \/ b6 G5 @& o* w( N7 Oavailable at "www.acresso.com".
' ]9 G; B& B$ M2 p! a8 [: ?# h    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.. E( M# }7 S$ ^+ [2 h% O5 ?7 n% t
4 R  N/ T9 h7 r# _( M This usually happens when a license file has been altered.& o6 ~+ N* _& J0 {+ S% ?4 e
Feature:       padspel_c/ ~! E  }  t* Y, y. w
3 u' r- O( l$ u: I1 g7 sFLEXnet Licensing error:-8,130! }) B  K# I/ R
" f& Y+ \6 o% y+ c3 B" p) l. Bavailable at "www.acresso.com".0 K5 l+ ?/ \' P, U
8 J  ?7 }$ a7 K/ o6 j The license key and data for the feature do not match.
0 D  u4 w6 ]5 c" _ This usually happens when a license file has been altered.
3 S, L9 O9 E  S$ l" ?% DFeature:       padsxelars_c: |6 [) J3 r6 J& V, f+ _
License path:  C:\flexlm\LICENSE.DAT;, n2 q( N# v5 e/ @
FLEXnet Licensing error:-8,130* X/ ~  z; j: i8 f  X% u
For further information, refer to the FLEXnet Licensing documentation,& z: h* i  `$ E/ d+ o- |6 ~( N
* Q9 b: Y# K3 x  S! R    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.
! n, N$ ~: J$ Z+ r# D The license key and data for the feature do not match.
% z0 ]* h: X: |3 e8 A! _ This usually happens when a license file has been altered.
5 g5 a1 o9 o, [7 d5 }Feature:       padssel_c
) `. W8 Z: b2 S/ d$ g1 E1 sLicense path:  C:\flexlm\LICENSE.DAT;
: N& u8 |& F" K" [% Q4 E- G. KFLEXnet Licensing error:-8,130
0 y  r2 z) b6 T/ HFor further information, refer to the FLEXnet Licensing documentation,, C. @* u  M: p
* X' H& u- a3 h5 G    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.  ?8 ^6 w9 Q0 M- S' G
The license key and data for the feature do not match.9 a9 H* I) g5 o2 g
% _1 k. ]  L# E: }: y$ G' eFeature:       padscrl_c7 h+ l6 I1 @8 ]; ?  X' X* Y
; \' }" X5 k' |! E- ]; eFLEXnet Licensing error:-8,130/ l& _3 I! G- I2 n% {: S
For further information, refer to the FLEXnet Licensing documentation,' z9 F3 s; Q, a0 L4 v6 N7 y
" N& A  a/ S$ `; t, f& ]/ t    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.& ~: F% w2 p3 |6 W  B8 ^3 I( {
9 [  B9 n% S& S This usually happens when a license file has been altered.$ T- I6 C% q  @! E2 p
Feature:       padscrd_c7 \+ t0 K; I; T' r0 _8 l
License path:  C:\flexlm\LICENSE.DAT;1 w) X, j! g7 G: }! g
FLEXnet Licensing error:-8,130  @  v$ a1 X; j9 }7 Y# m( K
( L# [7 C% B/ A) x: L3 g) C: o* c8 ~available at "www.acresso.com".
+ z5 V9 B4 v5 C    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.3 ^$ \( Q. R$ U8 e$ o
The license key and data for the feature do not match.% k' L- b  l; Y4 B$ J$ ^* F
4 R" p1 |0 `! M: VFeature:       padsxedxs_c
. j: W0 C0 S( q6 h# zLicense path:  C:\flexlm\LICENSE.DAT;
* d9 Q  n: W$ x$ o7 hFLEXnet Licensing error:-8,130, H8 ~# b, o/ M; {/ a
For further information, refer to the FLEXnet Licensing documentation,- H/ y2 U: c1 h1 _: j. n
available at "www.acresso.com".7 ~; E7 v0 c# L2 m
    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.) U: h) h" s" G& ]% d( F4 ~5 L
The license key and data for the feature do not match.0 |; m1 G5 U3 V4 L, ^
" }  M( w, f/ j7 e6 r( d) D% f  gFeature:       padssedxs_c
, S( h7 |9 d+ j+ s1 R' E2 HLicense path:  C:\flexlm\LICENSE.DAT;
6 x  b) [" x4 e4 N: W/ I' j4 Y$ AFLEXnet Licensing error:-8,1307 \9 \! k; ?$ w! T
) M0 ]) V3 x; I; J2 Bavailable at "www.acresso.com".
6 j( d( i( }  x- \6 P    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.
' U& B+ e4 x1 I% S4 _  k0 G" } The license key and data for the feature do not match.( M% Q  }7 g% e( v. [2 p" I& w9 \
% S; m0 B4 g% U' ?' U: u" YFeature:       padssedxsar_c
. k9 Q9 h$ q( f# x; s; w2 \2 FLicense path:  C:\flexlm\LICENSE.DAT;8 X3 D, ~0 S% u) |8 @
FLEXnet Licensing error:-8,1300 B5 E/ t! O3 \; e1 a/ I
For further information, refer to the FLEXnet Licensing documentation,* T( u: z( e3 r- |4 L" T
6 F# P9 H) z- I6 T1 q' t    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.7 I+ y5 I+ ^. a
The license key and data for the feature do not match.) h' ^6 [  P! N; d$ |" @
: _9 r4 j% T6 o* Q/ C7 ?6 fFeature:       padsselar_c* s  C8 k8 a4 _6 F) P$ n/ b
& r- z! ^+ O1 N- V# h' k- t* TFLEXnet Licensing error:-8,130* n* s9 R2 f; t8 @! C7 R
For further information, refer to the FLEXnet Licensing documentation,9 k& t/ Z, v0 f% s  g2 k4 J! h
available at "www.acresso.com".( ~0 |2 Z: h" B) P7 Q
8 W) ?0 V( s$ y4 R; n# c The license key and data for the feature do not match.9 T4 K; J, B) n5 @
This usually happens when a license file has been altered.- _  {: X& [8 K- d+ J
Feature:       padses_c
& Q8 y* j) Q$ C; z: U2 ^License path:  C:\flexlm\LICENSE.DAT;
0 ]2 J/ U+ j5 p. Y" OFLEXnet Licensing error:-8,130
( g" s# Z$ x, G2 w" U6 Q, Z5 AFor further information, refer to the FLEXnet Licensing documentation,$ W5 d, A+ I% \) y. Y
available at "www.acresso.com".  A! `4 N  F' `) ^. \; r
    Server C:\flexlm\LICENSE.DAT: Invalid (inconsistent) license key.+ M! S1 g9 Z( Q
6 C: z9 w, N' n( } This usually happens when a license file has been altered.
: w/ {. ~% e- O. c( TFeature:       padsls_c% X7 \1 y! R0 c4 K# T3 ?" I' L2 o" X* y% `
# e* s9 s' M9 n; r* y3 UFLEXnet Licensing error:-8,130+ u' k& }. \9 c+ X
For further information, refer to the FLEXnet Licensing documentation,+ p. j0 P" J. y1 a& |" i5 v
# q9 L) a; O' W5 q( [    Server C:\flexlm\LICENSE.DAT: No such feature exists.
) j: F/ O% ^1 m, x3 q! AFeature:       pwrshell+ m9 m) U: n# T' I  J9 @% g, Z9 N
' a& h: i: T% K( Y, u  kFLEXnet Licensing error:-5,357) o- Q, d3 E$ n- K2 `1 [! o* [) f; f
0 A' ]5 g$ S% _/ T; C! bavailable at "www.acresso.com".
) ~. T: A" S4 |6 E    Server C:\cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.3 [1 ~  W" R% b9 o  r1 K
# y: }6 |! O0 | This usually happens when a license file has been altered.
2 @$ L+ a' C* ~, L- xFeature:       mgc_s
- {) d0 r! z* K+ kLicense path:  C:\flexlm\license.dat;" C# P2 L- a9 U4 k+ f/ E% M
  ^  h$ x& y+ N1 X0 @& fFor further information, refer to the FLEXnet Licensing documentation,9 E' m  v* T) @  _( i0 [$ H
2 Q& l$ Q; _0 {) c6 v9 p* b! Z    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.! D7 z5 |1 M" V2 C* c( w$ s
5 I. l, Z/ ?1 ]7 M9 k This usually happens when a license file has been altered.
7 T. F: J+ }. Y6 BFeature:       mentorall_s
3 p3 O; @2 @# }9 }# p' E3 iLicense path:  C:\flexlm\license.dat;2 q' S" F2 u; ?: U) Y
FLEXnet Licensing error:-8,130% q7 ~1 n' @* L3 Y% g9 f6 k, i
For further information, refer to the FLEXnet Licensing documentation,! q$ y; Y! S2 ^# b2 Y
available at "www.acresso.com".9 s8 y3 U0 ~- a' D
    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.' k! |# g2 R' y. B6 P
The license key and data for the feature do not match.' e1 w7 Q( B9 x8 s! E$ ~* l
This usually happens when a license file has been altered.7 T" i; L/ d5 c
Feature:       bsdall_c$ t2 `5 _; o: P" |3 R. s
+ A* G% F+ y0 c4 f) V* p; ]FLEXnet Licensing error:-8,130
" C) D  m5 V! F7 h, a' lFor further information, refer to the FLEXnet Licensing documentation,
8 ]) ~3 b2 J& Z3 ?6 lavailable at "www.acresso.com".5 W. v6 e( Z2 W: p/ x6 a+ u% l9 t
    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key./ b1 O6 F' X: @& \
/ C, N  @7 F* r This usually happens when a license file has been altered.4 m9 G' p6 f7 w3 l5 J. v: q/ E
Feature:       padspe_c
) T4 `9 G" U  N' n! x1 \License path:  C:\flexlm\license.dat;
1 ]& x( b* G, _/ EFLEXnet Licensing error:-8,130
# W9 R6 ?1 r+ i( X% z$ E; wFor further information, refer to the FLEXnet Licensing documentation,
% S1 x) S7 _$ }# Favailable at "www.acresso.com".* X1 w5 n! q* z5 e9 y# o" l
    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.1 E" L7 [0 v! v/ w
2 \" I) [3 l1 A  E+ F* U" }5 l This usually happens when a license file has been altered.
2 v5 _* P, `1 M( a. F' C7 XFeature:       padsxe_c% H2 A6 d: Q4 X4 i
License path:  C:\flexlm\license.dat;) i9 U1 C# H9 C7 Q
FLEXnet Licensing error:-8,130; t5 t* y; C% n$ Q% x, S& O
; w4 [2 j4 u: h/ F' B; j8 [available at "www.acresso.com".- d8 w2 B' \# z. `. p
    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.$ Z, V9 s7 A; H2 e1 x
The license key and data for the feature do not match.' {# p0 E2 }) G- {' {+ D5 z
2 Z1 e2 \2 o+ S+ l! W2 g$ TFeature:       padsse_c7 x4 ~+ t8 B0 N; {
License path:  C:\flexlm\license.dat;( d+ T$ W( }9 r# g. T( r
FLEXnet Licensing error:-8,1303 m1 e4 I4 h7 _3 t2 g
For further information, refer to the FLEXnet Licensing documentation,. S; r2 I3 k+ U9 G7 w
available at "www.acresso.com".$ J0 L) l4 E( o5 x' d
    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.8 k0 s& e  L; l3 C  Y. M$ u
The license key and data for the feature do not match.# D: G  [. S4 E, O. y- J
This usually happens when a license file has been altered.5 N9 S) M7 O! m- e, B8 S9 i4 |- T3 P
Feature:       padsped_c
/ J8 d6 w; w& L$ oLicense path:  C:\flexlm\license.dat;
/ A- o4 a1 W& b4 l( ^FLEXnet Licensing error:-8,130: v; m) V/ B. ?2 |' ^$ G
For further information, refer to the FLEXnet Licensing documentation,: S# K, L9 C5 X3 F
7 z7 C. v1 W( T    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.0 \% l4 `: x# ?0 G& b0 O3 T
- P1 Z0 u2 Y% y4 N6 B This usually happens when a license file has been altered.* g" c7 L: Z) C3 C6 ^2 L
Feature:       padsxed_c
' H' l5 e$ ^& s( X& |License path:  C:\flexlm\license.dat;, p0 q& a4 o! S5 `/ Y
9 W: b$ |2 i5 W5 KFor further information, refer to the FLEXnet Licensing documentation,
3 Q9 \. \! O3 r$ p( N( Favailable at "www.acresso.com".
( {! h9 }/ r! O    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.  e" A, {& p- v1 f! M& a/ e
The license key and data for the feature do not match.: S0 K2 a! i4 w: P3 O& v0 ]
This usually happens when a license file has been altered.' \" u+ d& W/ r3 @/ C) N
Feature:       padssed_c* ?4 q  y# ]# J, R& f2 {, Q
, y- G7 A; I, W7 ]/ M0 dFLEXnet Licensing error:-8,130/ v, g( \- L$ H0 V+ g% D* P
& B( `% Y- C* C4 B+ _available at "www.acresso.com".
" C2 X: u( S" o9 h( M( c    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.+ P+ [# |" l& F% i
The license key and data for the feature do not match.1 ]9 N1 ~7 E* e8 u) z; I" P. O7 k
This usually happens when a license file has been altered." ^( Z0 Q7 _6 _7 u
Feature:       padsxedars_c4 h+ T2 n7 o9 |+ L$ K6 i
License path:  C:\flexlm\license.dat;- c  @; h8 M( n* y% w
FLEXnet Licensing error:-8,130- k) M3 [" [3 G+ ^8 s
4 L3 V) ]/ H. R2 D/ e$ _" }$ Wavailable at "www.acresso.com".1 a9 Z1 l. A2 d& ^
    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.; k' \8 l2 M& ]1 g' N) c3 x' f
0 k5 x3 d  C" `* L2 I This usually happens when a license file has been altered.4 m6 S, b( F5 O5 W' e
Feature:       padspel_c
6 v3 L  g- f1 MLicense path:  C:\flexlm\license.dat;
( c% k: I+ Q8 K( `" k4 c7 ]& yFLEXnet Licensing error:-8,130
+ E5 F# }4 j! iFor further information, refer to the FLEXnet Licensing documentation,# P' h* g( `7 o8 E0 U0 u9 [* Q
5 `! }( ^7 z. G" s0 l5 B& ~    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.* K& T1 [; E9 l6 g  e
The license key and data for the feature do not match." Y# T, d: b) ^+ Y5 ]+ M
  u: N' X6 ~# W9 p6 @! FFeature:       padsxelars_c& O) X# X. v2 `4 ~
" G/ u; L# O" _" N, y/ CFLEXnet Licensing error:-8,130
! E' Z. U# p& a2 C' M4 A! NFor further information, refer to the FLEXnet Licensing documentation,
" t/ \3 a3 f0 _; Favailable at "www.acresso.com".
( V8 z9 V4 I- ~' q/ d    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key., G" h, w! W3 F
The license key and data for the feature do not match.9 W- ]" _1 I2 k
( m5 G5 ?. y1 V# s, |/ M7 A5 }2 t6 p  UFeature:       padssel_c
! @6 A$ _+ }7 R9 r/ c$ wLicense path:  C:\flexlm\license.dat;
' O9 `6 T  o) X- x4 f6 XFLEXnet Licensing error:-8,130/ `& x6 u* E  ~( B! N
For further information, refer to the FLEXnet Licensing documentation,1 i7 g( W7 }: p
available at "www.acresso.com"./ o! z1 C; y" h6 ?/ a; B" H5 k
    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.1 T3 O# q, R- \3 t. _# \
: O7 l0 K3 F7 l4 Z  \; @ This usually happens when a license file has been altered." _) E6 l+ |; j5 t! J
Feature:       padscrl_c7 t1 c% c- U& E" G8 D8 T
0 z7 ~8 Z: N1 uFLEXnet Licensing error:-8,130
* Z6 Z! z: H& ]For further information, refer to the FLEXnet Licensing documentation,
% g; [& O, z1 ]# k9 d! q; P& Y. Lavailable at "www.acresso.com".3 _( i4 k. ^, }/ e, t+ q" A
1 W7 Q# @" P/ k. V: m' Y. ] The license key and data for the feature do not match.
4 r( ?  ?  H% k6 |4 L% d' p& N This usually happens when a license file has been altered.
5 J  |9 ]* l  u. Z' cFeature:       padscrd_c: R5 K8 M3 u, \' A" V3 L/ H& N
0 J0 T1 K  ~( h* Y5 X- Q% y0 N0 _) vFLEXnet Licensing error:-8,130* Z9 u* q* @  Z& d: ?7 {; R% s9 p5 F! P
For further information, refer to the FLEXnet Licensing documentation,- u2 N* t% `' ]/ o6 v0 M$ d
available at "www.acresso.com".! V" A  l3 ^6 b0 ~3 }% o5 P
    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.6 _# W% W( ~% f0 r, ?1 _0 ?1 s
/ Z7 r2 e9 C9 m& c; S1 B This usually happens when a license file has been altered.* T" n: m2 b( i
Feature:       padsxedxs_c5 k+ @4 r! w; c0 t+ k+ S/ x
License path:  C:\flexlm\license.dat;# w6 z0 T0 k: i5 g3 W: A
FLEXnet Licensing error:-8,130& I/ L$ X0 w: N
) A! E4 ]7 P- z+ [available at "www.acresso.com".- j: L- R. C/ `' |
3 l  d, k, }, W5 ? The license key and data for the feature do not match.
/ R1 T* O, x" W: e' L! M! G) P% ?/ f This usually happens when a license file has been altered.6 J8 a% K+ Q9 O8 K; N- \' _0 U
; B" A1 e/ j# `1 u# DLicense path:  C:\flexlm\license.dat;
6 i/ Q, l! P4 n2 x$ Q, |! qFLEXnet Licensing error:-8,130
9 ~( l8 t+ l  CFor further information, refer to the FLEXnet Licensing documentation,3 A$ {* b+ D: K/ f* c9 k0 O, o' p# ~" e, v
available at "www.acresso.com".- g+ e9 }& G9 d- d, g% T$ Y! j  ]* L9 y
9 S: P5 {4 X& y The license key and data for the feature do not match.! V; Q* D; X* {; v9 ]
) N9 r% E; H' w9 Z6 a3 @) TFeature:       padssedxsar_c$ X4 Y' a& H, V. R
8 p9 V; M8 ^5 d" m$ gFLEXnet Licensing error:-8,1305 G& y# y# U4 r, D1 Q3 N% H
6 W( J, R. K: {7 ^8 v0 d# L3 Zavailable at "www.acresso.com".& B6 H2 D7 Q! `9 d
    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.3 U# ^5 Z+ }7 F. }' E
- b% A) b; I+ t5 B% ^' c* } This usually happens when a license file has been altered.
# r) a/ Y( `' }; C  Z3 G$ q- s% l! aFeature:       padsselar_c- h1 f0 `# d$ j! q6 N/ Z
1 }; [, F8 K, V8 d8 }) ]FLEXnet Licensing error:-8,130
4 [; e6 H0 t* `; w: h' UFor further information, refer to the FLEXnet Licensing documentation,
1 {+ ?  y1 k2 |) a) yavailable at "www.acresso.com".
, {2 S6 z5 e8 o* v% r! w9 O3 ]    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.& v" b# S9 E" o( j' h/ J- x9 T
The license key and data for the feature do not match.4 U/ ^; i: ~' J5 T; K
This usually happens when a license file has been altered.: ~. ]$ F! y/ P7 n. E
Feature:       padses_c! J0 T8 x5 t2 E
' i+ Y3 x) X# G1 a9 j! uFLEXnet Licensing error:-8,130
5 N% F/ e: F) a$ L( F: G! S4 C+ {For further information, refer to the FLEXnet Licensing documentation,
- K5 y9 i0 B  j$ |  V- Q* h- navailable at "www.acresso.com".
( C% w4 z% U/ e2 r    Server C:\Cadence\LicenseManager\licencse.lic: Invalid (inconsistent) license key.% g8 \( V9 S6 B! Z
6 v0 Q% _& g# L! ^ This usually happens when a license file has been altered.6 t, E' P* Q  j4 \" y2 [  o
Feature:       padsls_c5 G* j5 x/ z; |$ W1 g6 s
License path:  C:\flexlm\license.dat;- R  n& C! l" q6 u( d
4 l) U& j3 U0 |4 F5 H) U. n+ PFor further information, refer to the FLEXnet Licensing documentation,
0 O& h" a9 {5 M, _3 Vavailable at "www.acresso.com".2 E2 r, m# w. x& S
    Server C:\Cadence\LicenseManager\licencse.lic: No such feature exists.. O  r0 F) F9 |3 ^
Feature:       pwrshell% C3 a9 v; K, N0 l
License path:  C:\flexlm\license.dat;+ R" F. B1 i; c6 m5 i' K
" W' m3 Q+ B  P- iFor further information, refer to the FLEXnet Licensing documentation,
2 I, R5 u) w9 X( cavailable at "www.acresso.com".: j' t. `" S1 T% |- k# Y7 T
    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.
* n  ~# ]' a5 y4 N# D, p The license key and data for the feature do not match.
  Z' v/ X: x9 O! ` This usually happens when a license file has been altered.
$ B, C4 k5 s& W0 v6 Z# TFeature:       mgc_s
* g& Z+ T% E  o9 GLicense path:  C:\flexlm\license.dat;/ y! X" C' u( A7 S
FLEXnet Licensing error:-8,130# a) _, I  y* a0 G# ^) d
For further information, refer to the FLEXnet Licensing documentation,2 e4 E1 F6 h+ q- Z' h
available at "www.acresso.com".6 A$ _5 [; \; w) m1 H/ J
    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.6 R8 R) U% v1 T& [4 h
; j4 Q; W) q7 S) h! H This usually happens when a license file has been altered.' o# T: c. ?; O
( p  Z" C- P8 g5 ]4 z+ h4 MLicense path:  C:\flexlm\license.dat;# X$ l% C3 z" W1 {) q. c
5 I7 K+ G9 Q$ `- M* a9 [4 B1 r/ U2 vFor further information, refer to the FLEXnet Licensing documentation,. l1 p* J: K5 ~" Y3 j
available at "www.acresso.com".1 u% h, R; K: C* P; m
    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.6 I6 _* v& Y& S7 K( O
1 d# Q+ G. ]& z This usually happens when a license file has been altered.
6 j( V3 Z( f8 m1 \  [( D* kFeature:       bsdall_c% T" u0 k  ~! j) x4 E# y
! C+ R2 r: \/ K4 {: sFLEXnet Licensing error:-8,130
. @' @  \2 {4 ZFor further information, refer to the FLEXnet Licensing documentation,
3 |# F) g' w; I: c& k5 m/ oavailable at "www.acresso.com".
5 s& U3 y$ K- d' s0 V7 \& V7 y: U" {    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.4 o0 ~) A6 u$ d9 e& z0 k) z2 @
+ m* g* U2 J' Z' S# ]2 E' T" g This usually happens when a license file has been altered.  [0 J. Z+ q( A' r1 c
Feature:       padspe_c
3 v# l' g1 |3 |5 @3 D: f  }- RLicense path:  C:\flexlm\license.dat;
# a" @1 W5 L1 _5 `/ qFLEXnet Licensing error:-8,130
& `& z6 q  Y4 o3 ]# U2 `5 w" w  E5 UFor further information, refer to the FLEXnet Licensing documentation,7 T9 S$ b8 v! i& D7 Z: Q5 R5 O9 M" A
available at "www.acresso.com".6 H" m9 ~( b( I- l% S! I9 C
    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.$ }( Y3 Z2 N! ~5 F. P
The license key and data for the feature do not match.0 a, {/ w& |. O+ Z9 a$ D/ {4 }5 e8 K
This usually happens when a license file has been altered." E1 c9 r( k5 h) p7 T" S
Feature:       padsxe_c; a! f  `% K$ k0 t
License path:  C:\flexlm\license.dat;8 x2 F9 |% T5 B' |, |( X
; U$ A& }" |- E3 ]( C" o- LFor further information, refer to the FLEXnet Licensing documentation,
& U( x, e6 K, I0 X. j! P/ B; `available at "www.acresso.com".  f9 h, X: H+ X; W
; d* I" w) m4 a4 D% j+ j0 ?4 k The license key and data for the feature do not match." @2 x/ t7 V0 X$ Z9 S
6 ^; I( u3 a( H$ T0 M, ~Feature:       padsse_c8 {/ m/ i2 P3 T$ s0 y6 o
! K% R! w, t8 ^5 _FLEXnet Licensing error:-8,1309 ]6 U1 K0 j* O8 C/ `
For further information, refer to the FLEXnet Licensing documentation,% M' F  N( W5 E  F: F# F8 x
available at "www.acresso.com".* z6 @8 h5 Y# b+ Z' p5 ]7 t
: c( m; w8 o, G; i/ t1 `& V8 K8 f The license key and data for the feature do not match.6 u* I6 f' z( V3 N$ Z3 R7 |
This usually happens when a license file has been altered.0 i+ ^: Y8 P9 Y+ v6 X
Feature:       padsped_c
$ i! g9 t$ _+ k) s2 kLicense path:  C:\flexlm\license.dat;  P" O% `+ E7 b6 o: @6 w& f
FLEXnet Licensing error:-8,130* a" k- P5 c' T! A
For further information, refer to the FLEXnet Licensing documentation,$ ^. I( n6 z& ~8 C% u
available at "www.acresso.com".9 [) b4 i" O: M0 R6 @
    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.& l( V1 A. w6 u/ W3 m4 t6 T
The license key and data for the feature do not match.# ?+ k; z/ `; @% U
This usually happens when a license file has been altered., ?6 C! \& \/ x) {+ i$ Y
Feature:       padsxed_c) o: v6 M4 c0 ~8 e) W) K
2 P7 |6 W+ f4 f+ m8 Y5 f% yFLEXnet Licensing error:-8,1300 {- [7 L) H* Y" w1 \  {. ?8 \: m! G
2 b$ ]; F! m# X" r8 aavailable at "www.acresso.com".# I: i% g. ^* E- k0 G+ }( q
! d9 p9 X  ~/ \8 e# J3 u( p The license key and data for the feature do not match.
. B! F& L8 p7 g& Y- Y* y. o This usually happens when a license file has been altered.
" A4 n+ G* g  E/ {5 Y: SFeature:       padssed_c' R, x1 d! E7 O1 k, I
License path:  C:\flexlm\license.dat;1 J4 d# l% J* D4 I8 A7 F
FLEXnet Licensing error:-8,130' _8 q4 D. D  X
# v* t8 V& k- l+ [; y5 E& g- wavailable at "www.acresso.com"., s% E4 h, y7 h8 I/ h9 c# H
: f  |0 j# t  Q) ^5 J The license key and data for the feature do not match.! M4 G3 B7 f# f9 a
, l7 m& }( U6 t% `1 |Feature:       padsxedars_c
; r- d8 e- w0 k/ p2 ILicense path:  C:\flexlm\license.dat;
) g, }! N9 a1 k  G1 n! KFLEXnet Licensing error:-8,130
* y0 @- Z2 k# A4 f9 ~; TFor further information, refer to the FLEXnet Licensing documentation,4 q) _; ^/ f. A4 Y0 D& v& A5 t2 Q
/ ^' ~8 A+ `* d    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.
( J/ u1 P$ y) |0 m  u  e The license key and data for the feature do not match.6 G# e% L$ f" D# H
This usually happens when a license file has been altered.3 b6 o: u# ?( T7 l4 I9 o' _
Feature:       padspel_c
2 J4 \# Y$ Z5 H( |( l) C2 eLicense path:  C:\flexlm\license.dat;
. M6 _5 d1 H& P1 i% c8 xFLEXnet Licensing error:-8,130
) f. \9 h% V- X; N( ]For further information, refer to the FLEXnet Licensing documentation,3 t; L5 _. k! C3 N' B
& x* |9 }; b1 p    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.
; ]) Q/ h7 X4 K7 o: {- M The license key and data for the feature do not match.% f0 f1 a8 _* e( l2 c% u
2 B: V: q/ w  x/ f. EFeature:       padsxelars_c/ X5 _8 U; X$ V6 e/ O. U* K
License path:  C:\flexlm\license.dat;7 c% h$ i/ x) M4 u- R6 n+ A. `7 C$ V
FLEXnet Licensing error:-8,130; t. ^9 Z, ?# O* k" g! e
0 j# s: B; [: @7 J8 ^+ |/ u  @available at "www.acresso.com".
3 }0 a% A0 y% m1 ~' i' }, [    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.
) I0 ?7 L- I2 X- V- }2 k The license key and data for the feature do not match.& J/ k$ g' Y6 H* \) p$ q
  l* v& v% \/ u" T- o2 X1 U& kFeature:       padssel_c  r; ^/ \7 I# ?- p6 i" B* n4 ]. n: m3 K
8 M% M8 x( N9 H7 a/ ^FLEXnet Licensing error:-8,130  Z4 d! K3 v* z3 g5 b" G# O
For further information, refer to the FLEXnet Licensing documentation,: H2 n' Z6 h& J' O
available at "www.acresso.com".4 y. E, w+ `6 X& l: K! a
    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.0 y- {5 C: @5 s, y8 a
, R* R; [( A5 M- ~  b( Y8 v This usually happens when a license file has been altered.
! b: l5 Q8 z- }5 Y, i: n3 a, Q0 q3 GFeature:       padscrl_c
3 ^/ {9 S8 ]1 |" V# mLicense path:  C:\flexlm\license.dat;
2 H: z- C# N- s1 k! n3 CFLEXnet Licensing error:-8,130; g. d# T6 ]; b: ?, D
6 h/ A* w/ H: Oavailable at "www.acresso.com".1 `; O7 B& N: k+ p# m' u
7 ]$ C7 B& x; N1 G! p The license key and data for the feature do not match.: u3 A/ J/ ~5 K9 q. R4 ~* J
4 _; B: _  m. y7 |9 O: ZFeature:       padscrd_c
0 m- _, d9 R. M+ tLicense path:  C:\flexlm\license.dat;
; p3 s3 h. |3 V7 h. F/ R' BFLEXnet Licensing error:-8,130
4 D- _, @, @6 |For further information, refer to the FLEXnet Licensing documentation,
  I2 Q! R& P, d9 V5 e% l$ Z. u9 Savailable at "www.acresso.com".4 D1 Q$ R6 g& S" \  z; d$ k
) l) |" H8 t9 s The license key and data for the feature do not match.8 k+ K* C6 ^$ b: n, z
* k" R$ L7 |+ T6 I+ EFeature:       padsxedxs_c+ L) ^9 W; N& R0 y
+ k' i; V9 k. P1 X8 xFLEXnet Licensing error:-8,130
& T! q0 Q4 L: {! m. HFor further information, refer to the FLEXnet Licensing documentation,
& |. @* t9 e: uavailable at "www.acresso.com".0 v$ c9 ]' `0 o4 D1 ]
6 \/ ?4 o8 N0 v5 A2 a3 T The license key and data for the feature do not match.
" J% K; H1 d2 i2 l! n1 F% z This usually happens when a license file has been altered.* S( L; d& v- a; m
0 t9 v8 K7 l0 U6 ELicense path:  C:\flexlm\license.dat;
# u6 k$ D$ Z* RFLEXnet Licensing error:-8,130
. f1 @$ ~9 r1 i. L8 z8 e) dFor further information, refer to the FLEXnet Licensing documentation,; K/ m0 y5 g5 G, g% {+ s4 o
" `3 e& z* O. P. P    Server C:\flexlm\license.dat: Invalid (inconsistent) license key.; d8 E2 Y& C) r/ B% q! I
The license key and data for the feature do not match.4 ?* E; U) c0 }( e
This usually happens when a license file has been altered./ ]( l/ j* }! R! [5 E# ]
Feature:       padssedxsar_c6 s# [4 e: q* t( S9 n; ^6 I
License path:  C:\flexlm\license.dat;7 f( L' B, {: c' N  a
FLEXnet Licensing error:-8,130! {# Q4 g" N, `; `# Y, G3 X/ q
9 T" Y2 U, K/ {) p! navailable at "www.acresso.com".8 T0 P- ]# }: i8 ?. B
8 {* z5 w9 F/ s8 e The license key and data for the feature do not match.' d: G& ]' i. R2 c/ T, C- E0 J
This usually happens when a license file has been altered.) ^; s+ u4 a8 v& e5 c8 q
5 s7 I  C9 `3 ^& Q( WLicense path:  C:\flexlm\license.dat;9 f% o7 ?7 c$ s6 q1 W/ H0 p
2 {/ e6 M9 L" S4 W) cFor further information, refer to the FLEXnet Licensing documentation,& ^2 X2 X2 p4 }& I# I6 K1 B; M
available at "www.acresso.com".- y4 y% r- D& C7 k, }% E
3 m$ D3 S9 F5 U The license key and data for the feature do not match.
9 u* \) ^% C2 N) V' s+ b) c, T% J5 Y This usually happens when a license file has been altered.
; L! F3 V4 n2 Y5 |; MFeature:       padses_c; }0 z+ N% H) X7 P
License path:  C:\flexlm\license.dat;# P/ k+ Q" |; x
7 T. P! K) d3 ]) K% l) X6 o2 tFor further information, refer to the FLEXnet Licensing documentation,
! e" X" |# T7 ^$ T8 m) L) Oavailable at "www.acresso.com".1 T! a% J. Y# T1 J8 _/ B6 G
3 R3 S; H7 a, I- ^& e  ]1 _, s The license key and data for the feature do not match.  b/ K' i' w0 \# ?/ B$ B" m
! R/ o+ i2 }# oFeature:       padsls_c
/ `3 |3 Y) T6 W" YLicense path:  C:\flexlm\license.dat;
- N2 t+ O) O4 k+ JFLEXnet Licensing error:-8,130$ |1 t3 l9 ~; U$ y+ r; n
& V' _7 F$ ^0 F: {. bavailable at "www.acresso.com".) p- m0 [5 O; J4 O4 J7 E* r4 \" z( r
    Server C:\flexlm\license.dat: No such feature exists.$ D8 D/ t* l$ g: ~2 w
Feature:       pwrshell
- J% v* c8 B3 P7 i+ L8 eLicense path:  C:\flexlm\license.dat;2 u/ v& O+ ~+ \( i
  z2 S8 w" B2 {- U; gFor further information, refer to the FLEXnet Licensing documentation,, ?4 ^$ i1 x" K* a
available at "www.acresso.com".% K" P* u; H1 W# k2 ?; c
  Q' e; X; A! y" n6 [" K
发表于 2010-11-4 14:48 | 只看该作者
# N% y. |3 x+ S/ h$ E' v6 y# @4 E: v4 l6 s; w$ G; ?7 J  P
破解版xp 下也有这个问题,注意安装次序!先安装PADS,安装成功后在 在安装ORCAD!
 楼主| 发表于 2010-11-4 16:44 | 只看该作者
不会吧  没有解决的方法吗?
    2019-11-18 15:03
    发表于 2010-11-4 16:57 | 只看该作者
    我以前碰到的冲突问题是安装PADS9.2后再安装candence16.3就有冲突,candence16.3运行不了(提示丢失某文件),PADS9.2可以,解决办法是在环境变量里把PATH中有关candence的值放在最前面就行了。
     楼主| 发表于 2010-11-13 00:17 | 只看该作者
    回复 isrca01 的帖子- K! k' y. x5 A- w4 q  X
    % \$ o' G( g, \8 c; a8 z; b我看见 有说先装ORCAD然后装PADS
    8 J9 c& `* A# g" \但是这个有原因吗
    ) b8 i6 ^/ D2 O2 H( m' L2 b能解决吗?) U/ W* p9 a: |$ {/ g
     楼主| 发表于 2010-11-13 00:19 | 只看该作者
    有没有先装ORCAD  然后装PADS  在WIN7下  成功的????
     楼主| 发表于 2010-11-15 09:48 | 只看该作者
    继续等帮主
    GMT+8, 2025-10-30 16:27 , Processed in 0.203125 second(s), 27 queries , Gzip On.
