查看: 741|回复: 1
DSP28335编译下载时发生错误,错误代码233
发表于 2020-8-25 15:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Error connecting to be target:
(Error -233 @ 0x0)
The JTAG IR and DR scan-paths cannot circulate bits, they may be broken.
2 Q* Z' @! H- E+ {/ Z1 h3 ?: wAn attempt to scan the JTAG scan-path has faiLED.
8 F& ?% x# Y3 [4 h6 EThe target's JTAG scan-path appears to be broken: K, Z7 u. z- ?
with a stuck-at-ones or stuck-at-zero fault.  B1 \+ X3 }5 x/ w. J6 p+ J
(Emulation package 5.0.838.0)
% Y* H  O6 K6 L$ ?5 o! y# z重启ccs、重启板子、重启电脑都试过了,但还是无法连接成功。请各位大神帮忙解决一下,谢谢!
8 D9 E4 V" w' o! B+ @% V4 i( k
发表于 2020-8-25 17:42 | 只看该作者
换一根仿真器的线就可以了,很奇怪的错误。
GMT+8, 2025-7-1 19:01 , Processed in 0.062500 second(s), 23 queries , Gzip On.
