环境是vBox里的centOS8,是可以访问https的,docker里容器不行。
$ E, ]5 `+ q4 ?2 B! G# e/ c
7 y1 G3 ~% B% X/ \curl http://www.baidu.com 可以6 V; t& X# o. C
curl https://www.baidu.com 不可以# E' E. F* X6 P' {1 J6 [% O* A
4 U5 m4 ?/ h4 a3 `; B8 B
报错:curl: (60) SSL certificate problem: unable to get local issuer certificate4 {2 n$ i1 s1 b. N. }
More details here: https://curl.haxx.se/docs/sslcerts.html1 W5 _. ?% `' a( {
2 }5 D. @: `1 E% z: U) L
curl failed to verify the legitimacy of the server and therefore could not
# U2 v% j+ b+ U# t5 X3 ?9 ]0 v- _establish a secure connection to it. To learn more about this situation and' m! ?; C8 a8 K! s) g4 G, m, Q' P
how to fix it, please visit the web page mentioned above.6 ^: n, e. [7 U$ b
, a7 e8 p. j3 o6 |: ]7 _
( B! L5 F6 l9 ?+ e& |
