查看: 239|回复: 1
RK3399 4G模块移远EC20移植调试
发表于 2020-8-11 14:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CPU:RK3399
系统:Android 7.1
1 K; W0 I8 w6 b: ^3 Q
1、通过串口打印或者adb获取模块的 pid 和 vid,顺便可以看到生成 4 个虚拟串口 /dev/ttyUSB*
[   11.734379] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
[   11.828247] usb 1-1.1: New USB devicefound, idVendor=2c7c, idProduct=0125
[   11.828386] usb 1-1.1: New USB devicestrings: Mfr=1, Product=2, SerialNumber=0
[   11.828413] usb 1-1.1: Product: Android
[   11.828436] usb 1-1.1: Manufacturer:Android
[   11.835480] option 1-1.1:1.0: GSM modem (1-port) converter detected
[   11.841217] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
[   11.844988] option 1-1.1:1.1: GSM modem (1-port) converter detected
[   11.851892] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
[   11.853964] option 1-1.1:1.2: GSM modem (1-port) converter detected
[   11.864677] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB2
[   11.865658] option 1-1.1:1.3: GSM modem (1-port) converter detected
[   11.871387] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB3
' O; C0 c6 v7 @, X# s5 D( F2 O; ^# R: p
2、在代码中添加模块的 pid 和 vid,原始代码中已经包含移远的几个模块,仿照现有的添加 EC20
diff --gita/kernel/drivers/usb/serial/option.c b/kernel/drivers/usb/serial/option.c
index1799aa0..f6c9e5d 100644
--- a/kernel/drivers/usb/serial/option.c
+++b/kernel/drivers/usb/serial/option.c
@@ -241,6 +241,7 @@ static voidoption_instat_callback(struct urb *urb);
" f( C* x! B+ ]3 r
#defineQUECTEL_VENDOR_ID                     0x2c7c
/* These Quectel products use Quectel's vendor ID */
+#define QUECTEL_PRODUCT_EC20                   0x0125
#defineQUECTEL_PRODUCT_EC21                  0x0121
#defineQUECTEL_PRODUCT_EC25                  0x0125
#defineQUECTEL_PRODUCT_BG96                  0x0296
@@ -1200,6 +1201,8 @@ static const struct usb_device_id option_ids[] = {
        { USB_DEVICE(QUALCOMM_VENDOR_ID,YUGA_PRODUCT_CLM920_NC5),
          .driver_info =(kernel_ulong_t)&yuga_clm920_nc5_blacklist },
        /* Quectel products using Quectel vendor ID*/
+       { USB_DEVICE(QUECTEL_VENDOR_ID,QUECTEL_PRODUCT_EC20),
+         .driver_info =(kernel_ulong_t)&net_intf4_blacklist },
        { USB_DEVICE(QUECTEL_VENDOR_ID,QUECTEL_PRODUCT_EC21),
        { USB_DEVICE(QUECTEL_VENDOR_ID,QUECTEL_PRODUCT_EC25)
% r9 K8 g' ^, L
3、添加模块的 so 库,此库需要移远提供,so 支持的系统要匹配,将 so 库拷贝到下面的路径
vendor/rockchip/common/phone/lib/libreference-ril.so
" y& X, N$ ^+ }1 `
4、打开device/rockchip/common/device.mk 文件,修改 rild.libpath 路径为rild.libpath=/system/lib64/libreference-ril.so
diff --gita/device/rockchip/common/device.mk b/device/rockchip/common/device.mk
indexbe2cb2c..69034a7 100755
---a/device/rockchip/common/device.mk
+++b/device/rockchip/common/device.mk
@@ -699,7 +699,7 @@ endif
ifeq ($(strip $(BOARD_HAVE_DONGLE)),true)
ifeq ($(strip $(TARGET_ARCH)), ARM64)
PRODUCT_PROPERTY_OVERRIDES += \
-   rild.libpath=/system/lib64/libril-rk29-dataonly.so
+   rild.libpath=/system/lib64/libreference-ril.so
else
     rild.libpath=/system/lib/libril-rk29-dataonly.so
因为 rk3399 是64位 CPU,所以 ifeq ($(strip $(TARGET_ARCH)), arm64)条件成立。
但是前提都是 BOARD_HAVE_DONGLE变量值为 true
注:本人测试,修改下面两个文件中的 rild.libpath 不起作用
device/rockchip/rk3399/system.prop
device/rockchip/rk3399/rk3399_all/system.prop
* ]5 E! ^- k0 k5 _
5、编译时将 so 库拷贝到上面指定目录/system/lib64/libreference-ril.so
diff --gita/vendor/rockchip/common/phone/phone.mk b/vendor/rockchip/common/phone/phone.mk
index946aacd..f8fc6e7 100755
---a/vendor/rockchip/common/phone/phone.mk
+++b/vendor/rockchip/common/phone/phone.mk
@@ -8,7 +8,8 @@PRODUCT_COPY_FILES += \
    $(CUR_PATH)/phone/etc/ppp/ip-down:system/etc/ppp/ip-down \
    $(CUR_PATH)/phone/etc/ppp/ip-up:system/etc/ppp/ip-up \
    $(CUR_PATH)/phone/etc/ppp/call-pppd:system/etc/ppp/call-pppd \
-    $(CUR_PATH)/phone/etc/operator_table:system/etc/operator_table
+   $(CUR_PATH)/phone/etc/operator_table:system/etc/operator_table \
+   $(CUR_PATH)/phone/lib/libreference-ril.so:system/lib64/libreference-ril.so
# E; ^: X* [: d* f* A
ifeq ($(strip $(PRODUCT_MODEM)), DTS4108C)
2 w1 M# a- L4 p1 K- Z3 A$ h
6、设置 BOARD_HAVE_DONGLE变量
diff --gita/device/rockchip/rk3399/rk3399_all.mk b/device/rockchip/rk3399/rk3399_all.mk
index7a2d870..ce5060c 100755
---a/device/rockchip/rk3399/rk3399_all.mk
+++b/device/rockchip/rk3399/rk3399_all.mk
@@ -63,7 +63,7 @@BOARD_NFC_SUPPORT := false
BOARD_HAS_GPS := false
) c+ I8 A7 \8 B/ h1 h3 x3 x( e
#for 3G/4G modemdongle support
-BOARD_HAVE_DONGLE:= false
+BOARD_HAVE_DONGLE:= true
8 A1 M5 a# H8 k# D- Y$ y
8 i! @& J) h5 ]# z$ o
BOARD_GRAVITY_SENSOR_SUPPORT := true
" N. }/ O1 H, j7 G. t6 B7 _
此时移植完成,只要 so 库没问题,就可以正常上网。
  m9 v- J9 g4 H  [
如果 radio log 中打印如下信息:
RIL_SAP_Init notdefined or exported in /system/lib64/libril-rk29-dataonly.so
检查 rild.libpath 的路径和名称是否正确。
2 ?+ Y. F0 O. p6 @
No /proc/cmdlineexception=java.io.FileNotFoundException: /proc/cmdline (Permission denied)
此报错不影响联网,可以忽略
2 ^0 N; r7 P+ ~2 Y; d1 j2 T( E
    2022-12-5 15:27
    发表于 2020-8-11 15:22 | 只看该作者
    学习了,谢谢分享
    GMT+8, 2025-6-27 22:38 , Processed in 0.078125 second(s), 23 queries , Gzip On.
