查看: 1615|回复: 1
我在安装pads进行检查的时候,检查出很多错误,为什么,望指教。谢谢!!
发表于 2010-10-9 08:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    C:\mentorGraphics PASSED Product: Analog Fusion - C:\MentorGraphics\2007pads PASSED Product: DxAnalog - C:\MentorGraphics\2007PADS PASSED Product: DxDataBook - C:\MentorGraphics\2007PADS PASSED Product: DxDataManager - C:\MentorGraphics\2007PADS PASSED Product: DxDesigner - C:\MentorGraphics\2007PADS FAILED Product: DxDesigner Basic Libraries - C:\MentorGraphics\2007PADS
    • ERROR: The expected size of the file:C:\MentorGraphics\2007PADS\SDD_HOME\Libraries\usr.pd07 is 16408, the actual size is 21050
    • ERROR: The expected size of the file:C:\MentorGraphics\2007PADS\SDD_HOME\Libraries\usr.ld07 is 16408, the actual size is 27867
    • ERROR: The expected size of the file:C:\MentorGraphics\2007PADS\SDD_HOME\Libraries\usr.pt07 is 16408, the actual size is 29406
    PASSED Product: DxEnterprise Client for Agile - C:\MentorGraphics\2007PADS PASSED Product: DxEnterprise Client for Matrix - C:\MentorGraphics\2007PADS PASSED Product: DxInteRFace for Agile - C:\MentorGraphics\2007PADS PASSED Product: DxLibraryStudio - C:\MentorGraphics\2007PADS PASSED Product: DxParts - C:\MentorGraphics\2007PADS PASSED Product: DxSim I/F - C:\MentorGraphics\2007PADS PASSED Product: DxVariantManager - C:\MentorGraphics\2007PADS PASSED Product: ePlanner - C:\MentorGraphics\2007PADS PASSED Product: Fusion/SpeedWave - C:\MentorGraphics\2007PADS PASSED Product: Fusion/ViewSim - C:\MentorGraphics\2007PADS PASSED Product: HyperLynx BoardSim / LineSim - C:\MentorGraphics\2007PADS PASSED Product: HyperLynx Extended IBIS Library - C:\MentorGraphics\2007PADS PASSED Product: I/O Designer - C:\MentorGraphics\2007PADS FAILED Product: PADS Layout - C:\MentorGraphics\2007PADS
    FAILED Product: PADS Libraries - C:\MentorGraphics\2007PADS
    • ERROR: The expected checksum of the file:C:\MentorGraphics\2007PADS\SDD_HOME\Libraries\common.pt07 is 1411305733, the actual checksum is 4033845640
    FAILED Product: PADS Logic - C:\MentorGraphics\2007PADS
    FAILED Product: PADS Router - C:\MentorGraphics\2007PADS
    • ERROR: The expected size of the file:C:\MentorGraphics\2007PADS\SDD_HOME\Programs\BlazeRouter.ini is 23, the actual size is 92
    PASSED Product: Pure Libraries - C:\MentorGraphics\2007PADS PASSED Product: Spice Integration - C:\MentorGraphics\2007PADS PASSED Product: Synopsys Libraries - C:\MentorGraphics\2007PADS PASSED Product: ViewRF - C:\MentorGraphics\2007PADS
  • 1 H/ v$ Y8 N, A+ a0 }4 J' M
发表于 2010-10-9 12:35 | 只看该作者
没有库
GMT+8, 2025-10-30 07:26 , Processed in 0.156250 second(s), 24 queries , Gzip On.
