TA的每日心情 | 怒 2019-11-20 15:22 |
签到天数: 2 天 [LV.1]初来乍到
将结构的四边形网格转换为三角形网格。
# P1 }6 T& r* G/ s8 eDemo:
2 ^. Q0 v. v+ l( L% Yclear all; close all; clc;7 S/ w) U' B3 }
5 {, S. K# m! c5 L" b8 O
% 1. Create mesh grid# y) F, m* v# C. R- D( G# a3 J {
[X,Y] = meshgrid(linspace(-10,10,25));
. X& |* S5 n" r( M' r& jZ = sinc(sqrt((X/pi).^2+(Y/pi).^2));4 w K0 V6 S6 E( q8 T ~, t% | q
figure('units','normalized','Position',[0 0 1 1],'Color','w'); colordef('white');
) [" M5 w/ @! t4 n$ P+ z. b& N% L+ Q7 `9 y
% 2. Plot the original rectangular mesh4 l$ M' x) p: d' H; B/ d+ I8 W. R! e
subplot(2,2,1);
( ]9 i! a& ~/ x9 O3 WsuRF(X,Y,Z); hold on;
) |3 Y, D1 h& D0 `/ x- Daxis tight; axis square; grid on; axis off; view(3); view(-30,70);! L' W( T) F9 Q0 e0 {3 D
title('Meshgrid','FontSize',20);
6 v6 _ t0 r( o. p/ ^/ T: @+ U# x5 B% f
%3.1 forward slash division of quadrilateral! O+ f; `: o% F s
1 D3 ^ k, E2 Y' d
[F,V]=mesh2tri(X,Y,Z,'f');5 `/ F4 @3 h3 d5 | q
C=V(:,3); C=mean(C(F),2);5 ]# ^+ G ^# [6 v
subplot(2,2,2);) j8 Z( b3 Z% M
patch('Faces',F,'Vertices',V,'FaceColor','flat','CData',C); hold on;. `; _5 H/ F/ e" W* P
% ]1 ~7 ?1 O; Y" `9 ntitle('Forward slash','FontSize',20);3 n5 G/ L, d. r, w* f4 U- O. h! O
# T1 {* P7 M' X& p- y$ t& Z% m%%3.2 back slash division of quadrilateral
/ u, }1 |, w7 ]! v- ]# i% T2 g[F,V]=mesh2tri(X,Y,Z,'b');; G: z/ E. q* V5 F' ]
C=V(:,3); C=mean(C(F),2);6 B X% V( S3 E- ^& u5 B6 N
subplot(2,2,3);
2 C4 `+ B" Q5 Q+ H5 H' K%Example of using original meshgrid coordinates instead. x4 m" H+ z4 b: ?- ]# h3 V& y
trisurf(F,X,Y,Z);
. q0 z# |0 v+ w% C' n3 B$ G) U' ^axis tight; axis square; grid on; axis off; axis off; view(3); view(-30,70);6 u& g$ v. N% o2 V
title('Back slash','FontSize',20);
% p/ }4 O4 _) I! p( P& h
6 a7 s% O4 |6 [& H/ V. }9 \! c# ]- F%%3.3 Cross division of quadrilateral0 ?( I' k- | q3 p9 J5 h, A
[F,V]=mesh2tri(X,Y,Z,'x');& l4 p) Z. V7 T: ?; \
% Replace Z-coordinates of added points by interpolated values if desired
# c6 S9 U" q7 T7 t( {$ xIND=(numel(X)+1):size(V,1);
2 y: \, Q& g1 S( zZI = interp2(X,Y,Z,V(IND,1),V(IND,2),'cubic');
3 v9 F; M; d G& w) cV(IND,3)=ZI;, _7 a2 X2 Y- N1 A' ? W
C=V(:,3); C=mean(C(F),2);! g2 n9 w6 g) S O4 I6 B" L
subplot(2,2,4);
* G! j M }0 `4 jpatch('Faces',F,'Vertices',V,'FaceColor','flat','CData',C); hold on;
+ s( N. V7 T4 W5 {: [axis tight; axis square; grid on; axis off; view(3); view(-30,70);
, U! _0 W/ i! x3 Vtitle('Crossed','FontSize',20);2 V7 t6 Q! Z4 E" ~* z
, T" v/ W' @1 v. h7 ]/ r# t/ j
结果如下:
, i/ }5 {" D8 F1 f! K/ l3 x
% }5 a6 a! g/ v, T$ m& _4 N: y
0 M8 W6 H3 y, g- [, Q: ]3 k, P
# V4 @0 X* Y) r4 p7 Q$ j6 T% r7 `; z9 B5 f' `0 i, U% p8 E$ a, k1 j/ W; I4 L
% ~7 G3 {2 f: `0 Z! Q& W) y1 L$ n9 ^) J |
