3 r) i% g0 u6 {2 }7 o+ P0 ?
# p2 T3 T, O; M+ R1 EMATLAB Programming for Engineers 4th(含课本源码)
1 [$ C# t) g) E& L# \5 L- G% v2 T3 b7 { S- C! b
MATLAB® (short for MATrix LABoratory) is a special-purpose computer pro[size=9.9988pt]gram optimized to peRForm engineering and scientific calculations. It started life
8 y, _ A8 a: Y) t. Pas a program designed to perform matrix mathematics, but over the years it has [size=9.9988pt]grown into a flexible computing system capable of solving essentially any tech
+ d$ m3 M& l5 m: H Onical problem.$ B" O5 I2 D: _% d; W( p+ J& K6 D; t
The MATLAB program implements the MATLAB language and provides a [size=9.9988pt]very extensive library of predefined functions to make technical programming [size=9.9988pt]tasks easier and more efficient. This extremely wide variety of functions makes it [size=9.9988pt]much easier to solve technical problems in MATLAB than in other languages [size=9.9988pt]such as Fortran or C. This book introduces the MATLAB language and shows [size=9.9988pt]how to use it to solve typical technical problems.
8 y9 o; G) f$ t6 _# U$ I: n5 k% b yThis book teaches MATLAB as a technical programming language, showing [size=9.9988pt]students how to write clean, efficient, and documented programs. It makes no pre[size=9.9988pt]tense at being a complete description of all of MATLAB’s hundreds of functions.
K* P' M4 K* _) ~Instead, it teaches the student how to use MATLAB as a computer language and how [size=9.9988pt]to locate any desired function with MATLAB’s extensive on-line help facilities.$ F8 H4 u# O$ X) ?) R) K4 ^
The first six chapters are designed to serve as the text for an “Introduction to [size=9.9988pt]Programming/Problem Solving” course for freshman engineering students. This
; v2 O( L9 E, c& B0 Jmaterial should fit comfortably into a 9-week, 3-hour course. The remaining [size=9.9988pt]chapters cover advanced topics such as I/O and graphical user interfaces. These$ u7 ]! Z0 i" [% G. ]- z
chapters may be covered in a longer course or employed as a reference by engi[size=9.9988pt]neering students or practicing engineers who use MATLAB as a part of their [size=9.9988pt]coursework or employment.) g) u/ f5 p j* L6 D# |
6 ~" [4 c E( d& o) Z6 S
3 @( f! x7 Y# J( H
5 ~8 f9 v( t7 n
( M, X. [* j* G9 k1 s
; I% p9 y3 g/ E8 m1 I0 ~# ?/ a+ e
( M) ]: [0 o0 x1 F
" K/ a& g' C% j+ p$ T |
