查看: 559|回复: 1
Writing fast Matlab codes
发表于 2020-8-4 14:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1. 使用profile. m/ Y. f' R6 O& z4 O$ c- i
8 R) ^3 d) ^* y) ^profile on, profile clear3 n. R% C! q3 P; z3 X/ Y6 H* N( r, @
example(5000);  %此处可为任何你要运行的代码
" ^' _3 G# C8 z" {  u" c$ j: Qprofile report# b- H% g# |3 O* b4 W% N' t# A" x: j
' @$ F/ q( l: h4 w/ G2. Array Preallocation
$ {2 D; }! ?2 x# u1 i% `
+ y8 W3 K  N8 `( F代码1: 2 J3 q. h) {( C  j6 `. D
tic;6 D% k+ j' \+ V& s' d
a(1) =1;
% j+ w( ]) ~  x$ \1 R& i% ~b(1) = 0;
' q; z9 d+ d, y4 Y4 K' pfor k=2:10000! s+ I$ y5 E0 @9 z7 y
  a(k) = 0.99803 * a(k-1) - 0.06279*b(k-1);
7 z: s% K3 w1 H! w5 H/ Y5 Y* e  b(k) = 0.06279 * a(k-1) + 0.99803*b(k-1);9 p# `' k7 J5 Q% D' c9 b- x! J% ]
end) C" S9 z- Q1 d+ r
toc;4 n$ n- Y5 }! E" `1 m4 P
! ]# g: ^! J: N
结果为: 1 \9 m. D. _1 ^; g  _* i, d: M, m- a
Elapsed time is 0.475989 seconds.- A: B5 ]8 U) W( p' X1 f" V6 U4 e5 B
而且代码中a,b下面会有红色的波浪线提示,+ {- ~% _4 x  p3 k! L" A! c' ~9 P
( K% n8 B9 z5 Q* d# C
; P: T" \* r* S7 K
# P: X! \+ P. D2 Z3 w* o7 s6 F0 P' H+ {1 j$ i$ J9 ]
修改后的代码2:
6 |, c# w9 T7 i8 d- btic;: N) @5 H+ l2 k2 p5 u
a= zeros(1,10000);* p( W- o& w# l4 s0 F: w/ s2 L
b = zeros(1,10000);% p& s+ l2 o: w' Y# W$ J0 G
a(1) =1;
$ D  |  H8 z- B2 A! K1 |: f( Ab(1) = 0;& E8 G& j$ H, x' ^9 l7 P0 N/ ]6 P/ V
for k=2:10000/ u! p  o7 w1 V1 k6 E$ E4 L6 {
  a(k) = 0.99803 * a(k-1) - 0.06279*b(k-1);7 M2 F$ D7 P/ D* {! |. X
  G5 P& [9 U8 v! R7 a8 t4 t! gend
' u: g# r8 B5 i4 Ytoc;
" ~9 w/ S; |- F! P* M1 H1 A! o  ]# O
) S& D) @2 \7 a. {/ Z4 m
结果为:; E8 v9 `, `6 {( q. a
Elapsed time is 0.000581 seconds.. X$ K# }% W* E" r7 u) N# p! P
" z1 M* B* q& j/ f
4 O* i. X7 Q% l( ~3. JIT Acceleration" q7 _  c6 w& Z( A& f$ J
" Z, C* {0 N8 e5 ?- P: P2 B4. Vectorization( X2 }% x1 D  `) D
Consider following function:
( Y9 x% A' J. @; A7 g! H" wfunction d= minDistance(x,y,z)5 a8 |  O2 [! b
nPoints = length(x);
  X: F3 p+ Q4 Z$ Y5 [( o' L  ^d=zeros(nPoints,1);$ j; n9 k7 @, L6 {& R; n) G
for k=1:nPoints% h' M3 k; `" t; O& {3 }
   d(k) = sqrt(x(k)^2+ y(k)^2+z(k)^2);4 g5 ^2 V/ z4 u) ^+ v" V
end
( U, \4 }0 x. c+ v  ld=min(d);$ H& p3 m* l9 i2 |9 n6 o7 q2 `
end1 l! F4 e. h" F9 ]
% s" ?9 w# d+ D7 q% O; D( W" Y( ]( Y6 Z
% Q5 w4 {; s+ p, g$ d6 N
function d= minDistance2(x,y,z)2 _" t' ~- O& E; H2 _( B* n
d= sqrt(min(x.^2+y.^2+z.^2));
$ i! O0 n0 m" m  l5 ^# o# uend% ~- r2 B4 g2 x! _
( _- I; k' Y$ c3 ^8 y$ V: C6 \
" ?$ ]; G* w, A0 g8 ~/ R, M- s测试:$ c- |+ X( s; d3 E! [* R2 z& S
clear all;
0 o1 t1 E) q* K6 y9 Q9 K7 Y. uclc;% M: {  E+ h( B4 r/ _8 b
nPoints = 100000;
# N% ]  E( k6 |% @( D6 w8 Dx = rand(nPoints,1);8 M" J, i( ~  @, Z; y2 ^
y = rand(nPoints,1);5 L9 `) r+ ^# A
z = rand(nPoints,1);/ B* C. B: R' A
, [- D. i3 Q, A; N# C0 F; X3 a
tic;% L% j& g! ^) l3 _- W
d=minDistance(x,y,z);" W3 c* W! A  }: c
toc;& W$ W, c5 u7 q/ I# V3 ^
! D+ k1 H! u$ \( @& ^% M5 I
tic;
9 r  p7 o, q5 o5 t! K* gd=minDistance2(x,y,z);9 }) n! ]" x5 z3 Y( D! j# g3 t
toc;
6 N" f0 Q2 T0 H: ~. @, ]
0 A# S% N( N! x6 M" {; S3 m$ S5 y( W7 B- I. M+ ^
结果如下:
; {* S1 j5 h0 L4 sElapsed time is 0.010904 seconds.: _7 J8 R& @& F, K+ g6 ^5 [
Elapsed time is 0.003773 seconds.5 z5 v7 b+ K( Q( m. ^; Q4 H& }/ ]
- i  H* n7 Z' x! I( y% b2 Z5 ?+ e6 ?6 S# Q" S
& T. B$ X' i0 w. \, {' ]# ~# D3 `. [+ ]* ~( i' m$ m+ i
% }% E8 G# [# a3 T$ ?+ J' w
0 P  W+ i9 ^& j% a
发表于 2020-8-4 14:37 | 只看该作者
GMT+8, 2025-11-5 13:35 , Processed in 0.171875 second(s), 26 queries , Gzip On.
