FPGA为xc6vlx130t, flash为xcf128x, 软件为ISE12.1 design suit% E6 f6 ?# T$ r- ^% c' D6 ~$ k
! `$ H0 V2 ?2 }( M( q; T下面是出错信息:
, T* d* k2 l4 U2 y2 t----------------------------------------------------------------------
& Q0 E) A9 f2 F/ ^2 |- C, ~! z----------------------------------------------------------------------
4 P1 g8 z" I0 w$ A" n" [Selected part: XCF128X4 j0 F# Q+ M5 x- s7 L" y
// *** BATCH CMD : attachflash -position 1 -bpi "XCF128X"+ c* e- z" F5 Q( V
// *** BATCH CMD : assignfiletoattachedflash -position 1 -file "D:/My Documents/Work/Pcie_logic/ddr_pcie_test/test.mcs"
4 p: K% u1 j/ o# h' B) s// *** BATCH CMD : attachflash -position 1 -bpi "XCF128X"& h% d. v. o) P" f9 d5 Y7 V8 J
INFO:iMPACT - Current time: 星期一 九月 6 16:00:19 2010
8 q) E- B2 E! N5 ]' Z' I// *** BATCH CMD : Program -p 1 -dataWidth 16 -rs1 NONE -rs0 NONE -bpionly -e -v -loadfpga - P- D. Q3 K( N6 D3 V$ @ K
PROGRESS_START - Starting Operation.
' t0 }9 f d: ^7 O! K$ ?Maximum TCK operating frequency for this device chain: 33000000. p0 T" H! m; h! s8 \2 z" m
Validating chain...
E* n; a( m6 b) T5 z, WBoundary-scan chain validated successfully.
4 t D- h( g, \3 d1 D1: Device Temperature: Current Reading: 37.58 C, Min. Reading: 23.80 C, Max. Reading: 38.56 C
3 K. K. O1 R4 \" B. M) P9 M1: VCCINT Supply: Current Reading: 0.955 V, Min. Reading: 0.940 V, Max. Reading: 0.964 V! G& [7 G A9 N2 n% x; z# P
1: VCCAUX Supply: Current Reading: 2.569 V, Min. Reading: 2.552 V, Max. Reading: 2.631 V+ p8 J4 i+ K; Z, o3 D: x( Y
'1': BPI access core not detected. BPI access core will be downloaded to the device to enable operations.7 d9 s2 a0 S3 F" I4 W1 ]
INFO:iMPACT - Downloading core file C:/Xilinx/12.1/ISE_DS/ISE/virtex6/data/xc6vlx130t_jbpi.cor.
9 [+ [' U0 h% x9 K0 g3 ?'1': Downloading core...
2 ~. P7 Y& U. H7 _" q% e* Q: j Match_cycle = NoWait.1 h7 P$ ^% e/ Z) R1 w
Match cycle: NoWait2 g* y- x3 Y9 x* }1 P5 w3 T
LCK_cycle = NoWait.0 z' w! O9 p* {4 g( k; ~
LCK cycle: NoWait0 q2 Z' e% ?) E9 G. [
done.6 U# W. @8 a. ~; E0 F% v' i
INFO:iMPACT:2219 - Status register values:" Y- W3 X4 V2 o
INFO:iMPACT - 0011 1111 0111 1110 0000 1000 0100 0000
1 Q" e \' }3 Q+ f( ]INFO:iMPACT:2492 - '1': Completed downloading core to device.
2 T% p5 O8 t6 |, F' gCurrent cable speed is set to 6Mhz.
8 ?' c: G' L- }# ~& yCable speed is default to 3Mhz or lower for BPI operations.
# W, h r/ {1 e" ^Current cable speed is set to 3Mhz.6 _: M) p4 L# A) t
Setting Flash Control Pins ...
6 S. i4 n6 D5 j- R! v. _' _. DSetting Configuration Register ...
1 c0 O" C! K' H2 H, LPopulating BPI common flash inteRFace ...
2 n' }( E2 O2 F( ?' w3 oCommon Flash Interface Information Query completed successfully.2 f* W+ t8 S* z2 N7 u: b/ h
INFO:iMPACT - Common Flash Interface Information from Device:
. L7 R% p+ a, Q7 W4 F* y0 y* eINFO:iMPACT - Verification string: 51 52 598 A4 s1 q' f s" o; R
INFO:iMPACT - Manufacturer ID: 49 2 L. W1 b# X" n" j
INFO:iMPACT - Vendor ID: 01 ; l1 B- B! V; q3 Y2 p, @% x
INFO:iMPACT - Device Code: 18 8 }1 G: H' M) _0 K3 Q4 K
Setting Flash Control Pins ...: ?) ]1 q+ n9 ~
Using x16 mode ...
( { x8 X1 `/ e+ kSetting Flash Control Pins ...
5 |+ q! B' r3 {7 Q) ESetting Configuration Register ..., y& B2 @9 S# ]) Y( Q8 h$ Z ^
'1': Erasing device...4 c: W- }/ h" e" S+ i8 B. f- V8 C
'1': Start address = 0x00000000, End address = 0x0053638B.
2 F3 `) A0 P9 }* m( \( t6 b. Wdone.0 [" h' h4 I {; f- c& |" c
'1': Erasure completed successfully." z4 V& ^3 n9 t8 c
Setting Flash Control Pins ...! X: _) `2 w0 { L2 s4 W
Using x16 mode ..., L$ L! u( l/ Q2 H
, B3 z- x5 Q) A1 l1 N2 XSetting Configuration Register ... K- e8 ^! u3 ^6 z1 A8 D5 W* k
INFO:iMPACT - Using Word Programming.
. A8 i9 |) f) l$ T$ i( B; S'1': Programming Flash.1 z2 }' N2 \0 z+ U
done.
3 @' B7 U% y6 ]* `Setting Flash Control Pins ...& g1 h: o0 [) U% s- O5 Z
'1': Flash Programming completed successfully.- |2 u" x0 f# ]" g+ Z1 D
Cable speed is default to 3Mhz or lower for BPI operations.% z% f1 j! D* s
3 D) ]9 y! A- m3 _Setting Flash Control Pins ...0 v) l2 w- a+ q5 |# I) s* O
Setting Configuration Register ...8 s' s2 _( ] T" c: d5 Q4 `
Populating BPI common flash interface ...
: `% W) R y3 @: C2 cCommon Flash Interface Information Query completed successfully.( M: F4 E" O- ]' W& y
INFO:iMPACT - Common Flash Interface Information from Device:- d/ F7 v( y) |. l
INFO:iMPACT - Verification string: 51 52 598 i0 y8 k0 u& s' I1 u# Q6 m$ ^
# b, |; s* Z) u0 l% T7 n+ f- | PINFO:iMPACT - Vendor ID: 01
% x; ^: A1 Z# Y4 y" V, T/ s5 }INFO:iMPACT - Device Code: 18 0 z" V+ A+ k" F! o% u( v6 C
! W& O' K' @& y+ xUsing x16 mode ...# J$ J2 [3 `! H$ R5 l4 ?0 Q, ~
2 _8 O3 ^" D: h$ D7 YSetting Configuration Register ...
4 G5 J0 _, k" e7 I'1': Reading device contents...
/ s. U& z. u* Y v! a/ d8 `' K% YFailed at address, 0./ C) o8 e* N/ D% e8 y2 n: c1 Q
'1': Verification Terminated.
7 [7 ]0 q8 a% R5 q2 |1 QSetting Flash Control Pins ..., j' u% X9 d8 r6 A. w; M
Current cable speed is resumed to 6Mhz.
9 ^. @4 A6 v4 g3 _INFO:iMPACT - '1': Flash was not programed successfully.
0 I/ a/ x* t2 ~. m% ]& s9 x+ x; ^PROGRESS_END - End Operation.
9 Y, K9 a' m8 n# P( N4 YElapsed time = 323 sec.. \; v t6 X5 _& G5 D
$ u6 O" _* p% X, d) {5 e7 i! F p: G
/ R1 I, }5 H$ b1 [关于紫色字体部分我有几处不明白的:% g5 n0 _; g( S0 B. y) O
1. 为什么绿色字体部分已经完成Common Flash Interface Information Query ,紫色字体部分还要再做一次?) ~) U: ~& P% j/ z# U) o1 b2 Q
2。 紫色字体部分为什么会显示programming flash Done? |
