查看: 271|回复: 1
求助!!!mcbsp spi模式发送多字节问题
发表于 2020-7-15 15:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用例程试了下,发单个字节是没有问题的:
7 c5 V: R5 C0 G8 R1 q6 v下面是我的配置:* R( k  R( {) P/ |8 n# q' Q
//*************** RESET MCBSP
, {! w9 N' f% I; M0 W$ s" V        McbspaRegs.SPCR2.all=0x0000;                 // Reset FS generator, sample rate generator & transmitter1 t, M( Y$ E: z4 x- f
        McbspaRegs.SPCR1.all=0x0000;                 // Reset Receiver, Right justify word, Digital loopback dis.  p; w: o, c' g" ?( ^5 e
" Z, G9 E: Y" w! p2 }
        McbspaRegs.PCR.all=0x0F08;           //(CLKXM=CLKRM=FSXM=FSRM= 1, FSXP = 1)% q1 y6 Y9 {; k5 m% D
) ?' ^5 B/ t( B" _+ E( E4 E7 L: k% m" L: `
        //McbspaRegs.SPCR1.bit.DLB = 1;3 q5 H( ~4 I4 w8 z: T
* i! v" d& o  Q% _5 X( F/ G( x) R" |        McbspaRegs.SPCR1.bit.CLKSTP = 2;     // Low inactive state without delay:& D" F) X6 G& ?. u* ~
        McbspaRegs.PCR.bit.CLKXP = 0;                 // transmits data on the rising edge5 Q: r$ v! M+ @- V
        McbspaRegs.PCR.bit.CLKRP = 0;        //receives data on the falling edge of MCLKR.
. Y4 V: F( W/ h, s( H1 d- m# a# @' }5 e
        McbspaRegs.RCR2.bit.RDATDLY = 1;      // FSX setup time 1 in master mode. 0 for slave mode (Receive)( M, N% e9 Z% b3 _: h% W
        McbspaRegs.XCR2.bit.XDATDLY = 1;      // FSX setup time 1 in master mode. 0 for slave mode (Transmit)
( c# r1 m# A) @) P$ D3 P0 R6 @4 Q6 W+ N' H1 e: b% `  y
        McbspaRegs.XCR2.bit.XPHASE = 0;  //发送使用单相位帧7 ?+ ?6 k+ @5 v
        McbspaRegs.RCR2.bit.RPHASE = 0;  //接收使用单相位帧
& h5 m/ I- B; |: e5 X0 b* Q+ h4 Y1 C  s$ p, Y8 w' L7 h+ G
        McbspaRegs.RCR1.bit.RWDLEN1 = 2;     // 16-bit word
$ |, ?) z0 E6 s+ x9 h% a        McbspaRegs.RCR1.bit.RFRLEN1 = 15;  F- S9 [' a: G
        McbspaRegs.XCR1.bit.XWDLEN1 = 2;     // 16-bit word& n9 a/ W1 y. ]) q. g
        McbspaRegs.XCR1.bit.XFRLEN1 = 15;* e( S2 `( {/ |2 w* V6 w* g
. v0 X4 I0 f" K. S3 p% J. Y, E        McbspaRegs.SRGR2.bit.CLKSM = 1;                // CLKSM=1 (If SCLKME=0, i/p clock to SRG is LSPCLK)& J& Y4 e7 q: h
        McbspaRegs.SRGR1.bit.CLKGDV = 8;        //10 CLKG frequency = LSPCLK/(CLKGDV+1)
. X2 Q& I- ~, T& G& C
/ v4 G6 }9 ^0 S8 r7 \* F  ^        McbspaRegs.SPCR2.bit.GRST = 1;         // Enable the sample rate generator
, o! B- q* }7 ]. V( L# Y1 z2 j        //delay_loop();                        // Wait at least 2 SRG clock cycles6 J0 k# F& j1 Z7 {& O
        McbspaRegs.SPCR2.bit.XRST = 1;         // Release TX from Reset( J4 v, K; ~( ?3 T! w: }& A- T
        McbspaRegs.SPCR1.bit.RRST = 1;         // Release RX from Reset
1 m" |" j6 a0 X) {* w9 ]1 c$ J        delay_loop();
7 ?# T: K8 D& L        McbspaRegs.SPCR2.bit.FRST = 1;         // Frame Sync Generator reset# h9 d7 s; O5 \7 y( ]
) {$ y( w) }+ s* ~# M& t
我定时发数据16个字节数据
$ F& L) M8 I4 zfor(i=0;i<16;i++)
- O1 J2 w4 V) I( o# B4 c{0 D# w( N  D( |# _7 s
        McbspaRegs.DXR1.all = Send_Dat[i];6 w6 e  v" F/ H' q( L
- U5 w4 J0 |# n数据就全部错位了,但如果只发一个字节,则没有问题。
( e* I% n; P% g9 Z7 q4 t- ]请教各位,是否有遇到这个问题,谢谢!5 o7 R( `6 I7 X
    慵懒
    2022-12-26 15:28
    发表于 2020-7-15 15:51 | 只看该作者
    你检查检查你的设置,看有没有问题
    GMT+8, 2025-10-25 14:17 , Processed in 0.156250 second(s), 23 queries , Gzip On.
