查看: 5834|回复: 28
PADS元器件换层
发表于 2010-9-4 12:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
pads中元器件换面后怎么不在原来位置啦?
发表于 2010-9-4 12:47 | 只看该作者
元件的封装问题,自己去琢磨吧!(*^__^*) 嘻嘻……
发表于 2010-9-4 16:34 | 只看该作者
Dear Brother,  N6 P% `/ V4 S/ T
! ]; k) ?' T& d7 d# Y% J
It is not clear to me what the exact problem is.
' a( C; t+ M7 A: ~( _+ E( F6 k7 a6 H' E$ U
Do you want to fix a component in it's position after the placement? If so just follow the procedure;
$ l: e% t/ j2 G! P$ P4 ]% A; U$ [
1 t& ~* i4 v* |9 G% H7 `; u9 }1 Select the component
6 w% s% [& O4 Y' A" x9 c. l2 right click the mouse8 l9 b* f8 F& t, p
3 select properties
' h# G' F/ w8 u# t4 click on glued
% r6 Z1 M  `9 \, w/ S: N' \$ E% s% [  s  _3 ~- U" p
Now the component is fixed at that position unless you remove the glued.
; ?0 Y" U+ a- O2 h9 E8 f) {
1 Y+ w$ _0 e" i4 L8 fHope it helps you." r' u! J5 w* a" \! Y) ]; ]# d
4 h0 H6 F! c1 x1 `$ l: K7 f. N) E& m
Regards( G9 @' `* ?/ {# m" a# }
' ^. L1 ^) F& f
lgos
 楼主| 发表于 2010-9-4 16:58 | 只看该作者
回复 3# lgos12345 , V1 p" p% M/ U( a8 [, Y( K' K
& D7 e6 @$ V5 E& q# _8 d" H. b4 _6 Z$ j9 I- q
    谢谢,你这个是保护元器件不被移动. _1 }2 o# y( ^  c4 W
我说的是,我开始在顶层布好局后,我想把他放到底层去,但一把它放到底层他就不是在原来的位置啦,都乱啦- \1 c/ x) P' a' ]1 \5 R
有没有方法使换层的时候位置不变啊
 楼主| 发表于 2010-9-4 17:04 | 只看该作者
回复 2# bluezenger
+ o3 O& Q3 [" s+ |) R8 ^$ g5 l* c* r  M' s" V
2 y" H1 \$ n7 l
    封装没问题吧,是这样的,我在顶层布好局后我想把一些元器件放到底层去,一换他们的位置就都动啦,乱啦
+ V9 c; s: I7 E有没有解决方法就是一换层后位置还在原处但位置不变
发表于 2010-9-4 17:36 | 只看该作者
Dear Brother,
2 t& r* K8 q8 ]! o4 s8 e8 m0 K7 X4 G( V
I think there is a component on the top layer and you want to take it to the bottom layer without changing the X Y position. Is that so?& {0 O/ B/ ]1 p1 O7 W2 f* ~$ R  U
- E; H; w0 m( I. V
In that case you can try this;) V' g: R1 U- z, M6 [! ]! G
. E% m0 l% M9 M6 l2 k6 {5 R1  Make sure that the selection point of the component is in the center of the component.You have to do this in decal editor.
$ j3 j( m2 k1 W( _
' J7 e2 z4 m2 F5 W; W2 Go to Tools>Option>Design>Move Preference. Select Move by origin.
" p3 ?1 b* }7 Y* o# z! S/ N7 X% I& C
# _- ^1 S* N; @- eNow select the component and flip the side. It will change the side ( from top to bottom ) without changing the X Y co-ordinets.6 B( |+ ?6 R2 I- s4 _9 e6 c- j
! C. h  i' I8 m- G; }
Regards& l; t9 E% S6 `/ q5 j) H
9 i' S9 k4 X' l$ i* X. _& R! H
lgos
 楼主| 发表于 2010-9-4 17:42 | 只看该作者
回复 6# lgos12345
  [; k' O: [& G% E
7 ~2 {( c* ^) N" D' t. i0 t7 l; D
, Q8 f# ^: {8 s5 D. s" E    对啦,现在位置不变啦 是我在设计封装时没有选择好原点6 [8 |1 `: C+ u- z
但现在又有新问题啦,一换层他的方向好像变啦
 楼主| 发表于 2010-9-4 17:46 | 只看该作者
回复 6# lgos12345
# q& h& D2 \7 L: e2 D1 E" D
& f6 O) A2 v: e2 M5 @' V' y% h1 x* @! Z- g7 Z
    直接在TOOL/OPTIONS里选MOVE BY MIDPOINT就行啦
2 t& z* X0 |" c但现在换层后方向反了,难道要选择后一个个旋转回来吗?
发表于 2010-9-4 17:50 | 只看该作者
[size=100%][size=100%]Reply [size=100%][size=100%]8 # [size=100%][size=100%]xiewu5 5 h+ M' P& I& k( Z7 n
* G0 @1 Z( N5 J1 ?7 P% o. R. h4 QCan you send the pcb file so that I can look into it if you want me to do so.
 楼主| 发表于 2010-9-4 17:52 | 只看该作者
回复 9# lgos12345 8 g4 l1 j% d3 r. Z3 Y
8 H# N, R8 n5 q- u( C: B) C
. n% Q! z- F- w    我想在换层后,元器件位置方向不变,我现在位置不变啦,就是换层后都旋转了180度,怎么才能换层后不弯啊,谢谢啊
 楼主| 发表于 2010-9-4 17:55 | 只看该作者
回复 9# lgos12345
sata硬盘.zip
51.86 KB, 下载次数: 16, 下载积分: 威望 -5
 楼主| 发表于 2010-9-4 18:00 | 只看该作者
回复 9# lgos12345
  W" W( i5 k$ d* ^6 X. B, G& H! Y, @. m5 ^3 l0 I
' ~! ?/ {- A3 Z6 \# m- p/ P
    这是换以前的
sata硬盘0.zip
52.11 KB, 下载次数: 19, 下载积分: 威望 -5
13#
发表于 2010-9-4 18:02 | 只看该作者
[size=100%][size=100%]Reply [size=100%][size=100%]11 # [size=100%][size=100%]xiewu5
7 W3 o" V' l5 x: I% m
( @: S+ M* c/ E- w. U
! B" _' P8 p- L' D% z   Got the file. Which component ( for ex. c1,c2 etc)
14#
 楼主| 发表于 2010-9-4 18:07 | 只看该作者
所有贴片元器件换底层
15#
发表于 2010-9-4 18:11 | 只看该作者
OK. " K: c5 Z' {4 q( X! |6 C- G
; h& T0 G/ z5 x
I got the problem.8 l- S. _! t/ H: }
9 v! L3 Q8 K' J8 S  P8 u, L( q' TSelect C5 ( for ex.). Go to decal editor. The origin is on one of the pads. Keep the origin in the center of two pads. Exit the decal editor and then select all to make the change in all similar components. Now try to flip the component. It should work
GMT+8, 2025-10-29 02:16 , Processed in 0.187500 second(s), 28 queries , Gzip On.
