查看: 523|回复: 4
代码问题
发表于 2020-7-13 11:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
代码如下:2 P# h; W5 {( H$ m* B+ h; l
clear all;
* C7 s# r# \2 H. Sclc;
7 o( N% J5 O* T+ |; Srandn('state',0);- M- u6 G4 e! }
rand('state',0);) |% |: |3 {( _, a) W
dt = 0.005;
' }7 {3 z2 c3 a$ B! Z# i' ~J = 1000000;3 Y1 R( |/ V) V7 L8 S2 \1 ~
for h = 1:100% o" r& v( M0 v! D% c6 S" S- `; j. ]
    x = normrnd(43.68,39.85,[1,J]);%设定分布:正态分布,Avoided fertilizers application) z0 a- H6 L) b4 w9 }/ @9 _
    x1 = find(x>0);9 B: |8 Y( @! P0 n$ [" q# D$ A. N
    x2 = x(x1);$ P- F# N) d2 r3 z1 u3 `- j
    X(h, = x2;
! F8 {+ G3 c: |8 R    A(h, = mean(X(h,);
! X: R, K) z- H# k7 w! P    B(h,:) = std(X(h,:));
+ r7 i% g3 {5 \6 W    y1 = X(:);9 I) V# V' O& w: F8 y/ V$ N
    Y1 = sort(y1);
3 W: S: n; N. C5 t        W = length(x1);6 a6 u3 ?( Q& |6 Y/ x  i
    if rem(W,2)==0
7 J6 n2 W, h! o# g+ x# H- }, ~        W1 = W;! S5 x6 b8 y) [' D( D5 n9 x& d% A9 @
    else
8 B. ]' H$ E0 `6 X        W1 = W+1;& z5 F8 r7 d: H5 V) t" w) U$ K
    end; w3 ^& T5 J/ m- s/ E: A# x) C9 q! H
    for r = 1:W1 * 5/100% ^  V2 S+ ?  @" r8 E3 _8 n
        W2(:,r) = X(W1 * 95/100 + r) - X(r);
% D, v9 I+ q/ [2 ^9 [* z    end
! f5 y$ O1 y8 |" p" z' T' z    n1 = find(W2 == min(W2));& @! R9 |6 \2 ?) F
    C(h,:) = Y1(n1);- E7 `) i! G5 S7 |; Z
    D(h,:) = Y1(J * 95/100 + n1);
" T) p# g/ [- h& ?    if h > 1
) F: T8 s0 k4 N" B- L& _        A1 = 2 * std(A)/sqrt(h);
9 X3 o7 H; {- ^6 t7 b- Y        B1 = 2 * std(B)/sqrt(h);
8 D" {; e  o9 ~, \; @) b        C1 = 2 * std(C)/sqrt(h);
; e) b0 z7 I& z3 ]- |3 u        D1 = 2 * std(D)/sqrt(h);" t# B6 V! a0 e
        if (A1<=dt&B1<=dt&C1<=dt&D1<=dt) == 1
( _  M! l/ i* [) |! L            break
7 \3 u/ C& M: d3 ]- l        end. q3 i2 P* A! Y& M$ S  N0 }/ O
    end! u+ U$ _, O2 t5 O3 {2 L
end6 X; I+ [" b. S0 Q
" f  l' Z9 v2 n' S9 f7 q
8 x& J( f- y" U0 U- Y: ?. @9 H$ @' O) S" D6 A5 f  g9 w
" u# v- _% K! {! ?- S
& ~4 g! |- p3 U1 w5 L$ ?" a5 |
上述代码运行后出现“下标索引必须为正整数类型或逻辑类型。”  为什么
2 ^( Y8 K: N6 w5 C4 u9 o. @: G
发表于 2020-7-13 13:07 | 只看该作者
帮你顶一下
发表于 2020-7-15 14:06 | 只看该作者
W2(:,r) = X(W1 * 95/100 + r) - X(r);; q3 H! k# d4 N. C% V! A" z! b" y
这句的问题,你的代码前面算出来的W1,并不能够被100整除,导致 W1 * 95/100 就不是一个整数,打个比方,点名时候可以有3个人可以有30个人,但不可能有0.3个人,你这个索引值 W1 * 95/100 + r 不是整数,就相当于点名发现全班有0.3个人一样。
谢谢,我去试一下  详情 回复 发表于 2020-7-16 15:05
 楼主| 发表于 2020-7-16 15:05 | 只看该作者
kekek 发表于 2020-7-15 14:066 Q1 X/ Z6 c& O  i
W2(:,r) = X(W1 * 95/100 + r) - X(r);/ a. |0 G) \. W
这句的问题,你的代码前面算出来的W1,并不能够被100整除,导致 W1 ...
9 O  w4 y" x- Y7 {3 c2 o+ T谢谢,我去试一下
3 _# A+ e+ g' y
GMT+8, 2025-11-5 06:34 , Processed in 0.156250 second(s), 27 queries , Gzip On.
