8 w3 y8 X- {; c7 i这算是学习MATLAB中的函数filter需要提前知道的理论基础知识,如果学过数字信号处理一定不会陌生,甚至能信手拈来。
0 o) s4 ~, @ J% ?/ z# r) w1 b
1 \5 L* q% _/ |; h3 o" b. E y其实英文版已经能看了,如果觉得不方便,那么最后也给出中文版。( w; ?7 u+ _1 i3 ` U9 e Y0 C: `
$ \1 e2 j m# g' e i: t- N英文版:
6 N: o2 ?# d: ERational Transfer Function
[' g6 w% q/ ^6 {. O3 KThe input-output description of the filter operation on a vector in the Z-transform domain is a rational transfer function. A rational transfer function is of the form,2 Q, e' S% }# Y/ k( M
, Z4 r7 I+ U a% Q2 B6 v5 ?
3 b9 q/ X2 s7 v1 J
" w( H, y* v" [1 \which handles both FIR and IIR filters [1]. na is the feedback filter order, and nb is the feedforward filter order.& u7 I! X! d) B+ t* K% o
1 R& [6 f$ y0 q) W0 S7 zYou also can express the rational transfer function as the following difference equation,: u( h& L: Z( t) f/ I! H0 k
d% r `4 H7 F" B# B
' s: ^/ l; f4 ~2 C- {
- `0 t2 W2 u4 U9 zFurthermore, you can represent the rational transfer function using its direct form II transposed implementation, as in the following diagram. Due to normalization, assume a(1) = 1.
6 i! E! }% S2 f1 r9 E! z2 C9 L' {6 c* m
# x, K. F! o+ k7 Z% @, i1 g( D
; B4 r3 l" F( U& m% A. ~有理传递函数% J+ j+ e6 Q8 {; `
( X8 w: B: X: v# V% x; {+ [* }
对Z变换域中的矢量的滤波操作的输入 - 输出描述是有理传递函数。 有理传递函数是这样的形式,
( h( H+ T- A: k
# M- \/ \" I* ]; m- |8 Y
: s3 o2 c/ P- D( N0 P7 c2 F1 H5 G+ V' q7 L, S9 J
它处理FIR和IIR滤波器[1]。 NA是反馈滤波器的阶数,和nb是前馈滤波器的阶数。
/ G: U0 ~7 D: @' Z" o3 A$ S
8 c* G1 H1 }; E# t您还可以将有理传递函数表示为以下差分方程,: X7 \7 i4 W$ S" g& I r- }4 U
" r7 p) ]1 F. ]1 I
5 R* j; f. Z' K# |) P+ A0 C i0 j! ~8 C. q# L" p
此外,您可以使用其直接形式II转置实现来表示有理传递函数,如下图所示。 由于归一化,假设a(1)= 1。4 ^' n0 H- y b* W
7 N: r/ E( v( k4 Y6 Z2 N% U5 L
* L$ H, N, U1 U+ T7 @0 }+ Q! j; V& s2 Y5 G! u4 p, E
0 Y# a1 c# r6 Y* a( _+ P* L
& A6 ?2 E e3 H) T, g% d! I! [1 c 1 F5 d3 z2 Z1 }! k2 Q- S
# ]* v0 v+ H# b. q3 ?
* h$ X5 n0 g/ o. D/ I _8 y. v# k, G" M: b8 o
) S2 e2 c* p' l+ V/ ]4 T" _) J
5 C. w4 q0 ^. ]
6 y$ n9 i' o+ v# w& l1 L
; m2 v% `9 O. B+ @0 \: a P
6 x M! Y- A4 T2 ~ u5 j
! T" O0 W+ H5 g% |' m$ ~: V+ d4 _* V, g: Z: y& j# [8 Z
" N2 Q* ]1 R6 s7 _& z; r' w5 U- o |
