查看: 542|回复: 2
安装aptitude报错:Unable to correct problems, you have held broken packages
    2019-11-19 15:34
    发表于 2020-7-6 15:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    树莓派更换清华源,安装aptitude报错:Unable to correct problems, you have held broken packages.
    , f) V& |" ]0 _) `9 T0 P/ c
    - a$ }8 P; T9 X2 q. F" W安装aptitude ,各种问题,具体错误信息如下:# |: a( g& v% h/ h5 Z1 V  B; w
    , u$ }3 F) W# }! V5 W( j: G& t
    pi@raspberrypi:~ $ sudo apt-get install aptitude: e' m. t) e4 `% Q& i9 ~2 T  E
    Reading package lists... Done
    0 D/ [" g$ I2 }% L: p2 s5 b/ d3 EBuilding dependency tree
    3 P' z/ e, x: l+ B/ z) t' |; TReading state information... Done0 x7 u6 @2 F: v7 W( X7 S: C
    Some packages could not be installed. This may mean that you have
    1 R" t8 @! i% h* m4 c1 }. crequested an impossible situation or if you are using the unstable! ?1 z6 S  Q7 O( g) N- P+ O
    distribution that some required packages have not yet been created' c2 p0 v! s! v% T3 e& V
    or been moved out of Incoming.
    9 Z# }) r5 @* c9 qThe following information may help to resolve the situation:
    . i4 x9 y" B7 H  w4 a6 K5 Q7 C: ]
    4 l1 G( a% B$ b# u# G$ ]; ]) Y* NThe following packages have unmet dependencies:* l4 Z% X: m  V8 k! J
    aptitude : Depends: libapt-pkg5.0 (>= 1.1) but it is not going to be installed
    4 T2 Z4 W! w7 E0 `7 O            Recommends: libparse-debianchangelog-perl but it is not going to be installed
    7 B) v2 q+ y5 Q% |E: Unable to correct problems, you have held broken packages.# Y7 b, y. `6 O% R/ ]+ l
    9 a! Y. }$ x, u& ~
    发表于 2020-7-6 16:26 | 只看该作者
    想知道答案,感觉这个好难的
    2019-11-19 15:34
     楼主| 发表于 2020-7-6 17:26 | 只看该作者
    1、经过查找,发现原因为树莓派 Linux 系统版本为 buster ,但是使用的镜像源版本却为 stretch ,后来将树莓派使用的镜像源修改为与系统版本一致的源即可。
    + h) y* B  E: P2、修改完镜像源后,不要忘了使用命令:sudo apt-get update,sudo apt-get upgrade。% L' A& Q3 [" W$ e
    3、更新完毕后,即可再次安装想要的软件;这里推荐使用:aptitude 安装所需软件,此工具可以有效地解决软件依赖包等问题。
    GMT+8, 2025-10-26 18:40 , Processed in 0.140625 second(s), 24 queries , Gzip On.
