导网表出现不明错误,请高手帮忙看一下,这问题该怎么解决,谢谢!5 D/ ~0 F$ r2 m$ I0 d6 W
#1 ERROR(102) Run stopped because errors were detected8 l8 j- e# j! z2 ~4 S2 c" Y( E: q
netrev run on Aug 23 10:28:27 20102 A: X9 m( v" _) S2 C9 i; P
DESIGN NAME : 'MINI6446CODEC-100811AF2'7 [, S0 A% F3 ?+ f
PACKAGING ON Apr 6 2004 19:58:38% `% X Y% P& e+ ?: Y
COMPILE 'logic'" H! Z# S3 |2 |
CHECK_PIN_NAMES OFF& J* ~' k- C" _: K/ c4 Y# \8 d
CROSS_REFERENCE OFF
+ m+ E# ]) }0 b m/ |4 ?( J5 u FEEDBACK OFF0 _5 c( |$ F3 r5 X, t& H% m @
INCREMENTAL OFF0 Y; N8 ]% }& Q0 j" I+ q6 M* w
INTERFACE_TYPE PHYSICAL
* ?' M# C! `2 b7 [ MAX_ERRORS 500' s) M" z5 o; t% Q
MERGE_MINIMUM 5
% h. q- n9 j4 W4 X NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'% R. g: e- m4 \4 F- K
NET_NAME_LENGTH 249 N8 n+ c( K8 `8 P* l5 `
OVERSIGHTS ON
9 V+ ?0 ]$ N O% M) p REPLACE_CHECK OFF
. z2 U+ j2 z! g8 f4 }" V SINGLE_NODE_NETS ON
! G# Q/ j3 [$ i5 g SPLIT_MINIMUM 0, C, d5 M) d- _! y0 s
SUPPRESS 20
2 [1 u- \6 z3 U4 X! Y" t8 o WARNINGS ON" c8 [: @2 W; S9 d8 d
1 errors detected& L+ Y2 Y; ]2 z" g( f
No oversight detected f) L$ A( w( S
No warning detected
6 ~" X) t }2 H" R- P, Z7 E+ tcpu time 0:01:43
. ~3 T' w& E# p) _/ X# X/ x, telapsed time 0:00:00 |
