顺便发个新的启动脚本,可以在64位linux下启动cadence- #!/bin/bash
: {5 e; {" J1 g( S0 ~/ [% O - #/*
& _7 D: X: N: ~' [; N* y - # * zenger @ ( zengeronline@126.com )9 s! z, {3 Z! S3 P- j
- # * Mon, 16 Aug 2010 22:51:08 +0800
7 u3 k% X* i; B$ {& b2 o8 x$ \ - # */, H3 E, b' j9 t9 k# O8 G+ d" O h
- 5 ?$ l% l* s# S, {5 t4 W
- # defined this for 64 bit linux operation system+ ^& _0 ^4 O9 X: p& x
- LD_LIBRARY_PATH=/usr/lib32
1 x) C* c! E3 u! O4 A& ~& W - 2 N, b& W# B0 b w) ~0 S% q$ R+ ]
- # Cadence SPB 16.3 environment variable
+ Y8 w; ^. J o, B8 }$ Z - export CDS_INST_DIR=/opt/Cadence/spb163
0 U6 q q2 \& A - export CDS_LIC_FILE=$CDS_INST_DIR/share/license/license.dat$ e. ~$ r& Q# q/ x ` N
- export CDS_DIR=$CDS_INST_DIR
* }% o, T4 P* n2 G% e Y - export CONCEPT_INST_DIR=$CDS_DIR; Z0 K- ?# }' J4 C' D9 z
- export CDS_SITE=$CDS_DIR/share/local/
8 ~$ l/ N* _ C2 i - export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$CONCEPT_INST_DIR/tools/lib
+ N' R9 P7 Y6 \1 i+ C - export CDSDOC_PROJECT=/CDS_INST_DIR/doc
" P6 i( Z3 q0 y. p - export PATH=$PATH:$CDS_INST_DIR/tools/jre/bin:$CONCEPT_INST_DIR/tools/bin:$CONCEPT_INST_DIR/tools/libutil/bin:$CONCEPT_INST_DIR/tools/pcb/bin:\( ~0 J: u5 P' U9 f
- $CONCEPT_INST_DIR/tools/fet/bin:$CONCEPT_INST_DIR/tools/PSpice:$CONCEPT_INST_DIR/tools/PSpice/Library:$CONCEPT_INST_DIR/tools/specctra/bin:\+ W4 I& V8 C3 i& u8 d1 H
- $CONCEPT_INST_DIR/bin:$CONCEPT_INST_DIR/tools/Capture:$CONCEPT_INST_DIR/tools/specctra/bin; B, Y: V( Q9 |5 g* f
% l6 ]0 B6 p, C3 r- #exec allegro8 t9 B8 V+ {7 o8 ]
- #exec concept
* X9 o5 t/ X6 Y4 x4 o. p7 w - #exec allegro_package_designer
0 k2 i c( E- b1 {+ Z - #exec allegro_design_entry_HDL
$ D; |: P" e$ P! l - #exec pad_designer0 g; @/ j/ g0 O7 `) V0 X
- #exec dbdoctor_ui7 Y4 ?& X3 R0 T) b" g K
- #exec copyprojectui5 p! J+ O: a8 V3 |0 Z1 ?5 w! D y/ B' I- Z
- ##exec designmanager) c; s# T' R% m1 ]/ A% O8 v0 C
- #exec downrev_library
& Z, [+ Y: @* C, R3 J" f; g+ u1 L) I) \ - 3 H1 E" w7 P' E2 h6 z( @5 B
- #echo $0 $1' |+ i1 }* A# Z
- #exec $1, i% M* a# k9 m2 F* m! \: R. y: T: n
- - Q% c, d4 d% k, |6 j" [+ v
- USAGE() {1 a+ {6 y) \ [4 m* ?1 e9 V
- echo "Usage : $0 { allegro | concept | dbdocter | package_designer | pad_designer | projmgr | help }"
, f# ~& K1 O0 T: ^; ]$ h - }
. u& S( k$ r R8 J+ E
& `* B7 ]1 U' ~; R- case $1 in
0 b+ z6 R& Z1 N$ ~& S$ M4 N' r - allegro)9 n. ]+ Y/ _) w0 j J$ h6 y' r
- exec allegro
1 s0 H. D& q% G0 @9 ] - ;;
' z8 Z8 |4 l* n, U - concept)
/ l2 J- v- h2 }& `7 F3 e - exec allegro_design_entry_HDL
" x6 V' A* j2 G1 ]: N* ` P% O0 V U - ;;
7 c3 L* B+ Q$ L0 l1 B/ b- _ P - dbdoctor)5 `# r7 Y4 Z6 e1 N, d* w+ W
- exec dbdoctor_ui
% C9 V: \) }; ^2 X X2 P - ;;
/ E- Q# F, F9 o g' s - package_designer)4 g% F4 F( i0 p9 T
- exec allegro_package_designer
+ W* f7 ]8 I1 ] - ;;
6 o# u5 r! Q" e - pad_designer)8 P. [4 J6 W5 d# H/ @- h& n C
- exec pad_designer
& t1 w9 u& ?1 f7 z" X, s - ;;
& r( u6 B, B: p6 C1 ~6 ^9 g& i - projmgr)8 h. X- w* b2 ]0 m5 E8 }
- exec projmgr
, d( Y+ ]: ?( s! u1 i - ;;
% o+ d) M3 E8 w0 k p( h w - help)* `+ \) l( w1 m3 @
- USAGE
4 h3 T1 g6 D. u) T2 E - ;;
9 W, C8 { j# V4 }4 l k - *)
# m# u0 ^# s' J2 [2 _ - echo "Argument Error..."
0 I! ~- F [6 O, @ l2 ^9 v8 A5 v - USAGE
' Y6 K8 E- ^0 [ n# M r* g - ;;8 }; z1 T8 g7 j1 q. q
- esac8 ?( o& i C& X. q8 p3 \+ @
复制代码 |
