可以查查Help->contents->Automation 裡的shortcut keys
# d9 d% U! C/ _, G
' p: \/ y0 u1 N1 j8 E+ p
4 U, L& B& B) t. `- f. B+ {% B- NAssign shortcut keys to a command7 W! r' k7 B& q! Z' x# s
You can assign shortcut keys to the PCB application commands. All these functionalities are provided by the key binding server. The sample script KeyBindings.vbs shows how to use the key binding server to assign shortcut keys.2 M' w5 ~- _5 ?6 K. D7 ~
7 Q3 O" a! i3 J" s2 f
$ z5 |+ e) I, }' D4 S P( O: b* F# ?8 T6 p, e9 I9 H
o4 n" t, s m. {$ t$ g3 R, j6 C
1 d; _# ~" p7 [1 ]0 ]Shortcut keys modifiers# `1 J* Z8 A% S* o5 p8 M, h7 }9 X$ @
To assign shortcut keys, the following modifiers exist for key combinations such as:: W# e' l& @1 A* u. t+ w
; w' [7 o+ v* W
<key>
3 Z* I* q0 \2 [0 r C" T9 T/ f# I0 W; L5 ]+ {
Alt+<key>. ]. C8 X" z: ]1 m$ G5 b
% p- d6 L" Z. n( f5 C
Ctrl+<key>" p. D1 ^) P8 G; X# J& M* I
0 {% L5 M+ u* X+ V5 J
Alt+Shift+<key>
% D1 s2 t) d- H% u Z4 z6 l/ V: Z- K$ T H. p, x
Ctrl+Shift+<key>3 @- e; {1 o4 @7 ^% q$ q# Q4 v
4 A& K: D3 ^7 n& m# n- T
Ctrl+Alt+Shift+<key>. q u, ~6 H; e# t
9 b$ _) M( b! F- v/ Bwhere <key> is the keyname such as: Enter, Space, A-Z, 0-9, F1-F12. Note that do not override any of the existing function keys (F1-F12) without using a modifier or that functionality will be disabled in the product.
0 ^, |! }) c% ? U T9 a9 ?$ m$ p/ Q( z6 h F6 S: B' [1 F
; h: l+ p0 K0 C+ J: ?3 N
) k5 Q6 W J, s) Z' N! X8 Q( _+ s $ ^( O4 k+ q0 z0 m
, ]% E8 [0 X! ?6 hConnecting to the key binding server
, X9 v# T+ d$ ~3 q2 tThe Bindings property of the Gui object returns a reference to the BindingTables collection object and from which you can start assigning shortcut keys. The following example returns the BindingTables used when design is loaded : p( e+ j- ]& z
+ z8 ]$ l" L* Y$ x K# P
6 {8 ^1 e" w5 |/ D% m" V% h. u" p3 J, |. R0 i; W
Set keyBindTables = Gui.Bindings("Document")
/ ^9 |( H; x5 ~7 O7 G4 Z& ]8 z; O& }* l5 o) R
# ?2 c- M7 \9 w
g; v/ c- N1 H* j5 C9 k
7 ^" D* t3 m/ u+ x/ d2 p
2 Z8 u3 W) m0 _% O# yAssigning shortcut keys to menu command8 g" B3 S5 X% ?& F" ]3 Z6 k
The AddKeyBinding method of the BindingTables collection object allows you to assign shortcut keys to any menu command. The following example shows the use of the AddKeyBinding method to assign shortcut keys to some menu commands : ' \6 Z: I' Q2 r# l6 I: \2 t2 z
5 Z- j. \8 j2 s) i- a* x( k
5 K) Q# v R! m" v
) ]) I" J" m( z8 l( g keyBindTables.AddKeyBinding "Ctrl+1", "Edit->Review->DesignStatus", BindMenu, BindAccelerator) q5 ?3 ^; t5 i9 h" v. Q
e" _5 M6 C7 y+ B5 V
keyBindTables.AddKeyBinding "Alt+D", "View->DisplayControl", BindMenu, BindAccelerator
3 S! Y! V- D+ t: p4 H* ]5 ?' |9 P5 W( J
keyBindTables.AddKeyBinding "Alt+F1", "Help->Contents->Automation", BindMenu, BindAccelerator
, k4 n0 R: i: F. M# d7 h2 A
# p9 v( q, f. f8 \ T6 ^% n
0 b8 `5 M" h) b! Q& E
5 [0 b7 k9 k8 L: ?
/ \! q2 Y' C- i/ k0 @" u! d: I6 v& [1 H/ d& b. d
Assigning shortcut keys to user-defined scripts
" _; F8 f3 O1 @1 W# ?1 p1 q+ HYou can also assign shortcut keys to your own scripts. In the Command parameter of the AddKeyBinding method, type in your script filename as if it is ran as a key-in command :
" g/ B9 R/ p( y! h8 [) T4 z2 J, z/ p6 W/ Y
J9 {2 x4 ~% u: d9 _1 Z
0 Q I# _$ h' k3 Q# k) y keyBindTables.AddKeyBinding "Ctrl+3", "run c:/temp/ctrl_3.vbs", BindCommand, BindAccelerator' i0 q8 h( `, |5 R( P r
8 l' Q- j9 V, w# s
keyBindTables.AddKeyBinding "Alt+X", "run c:/temp/alt_x.vbs", BindCommand, BindAccelerator
" `' [$ {! n1 h! C2 i6 N! G* c# a& A7 t) e
, W" u) b8 b& R" ~' C+ C keyBindTables.AddKeyBinding "Ctrl+Alt+Shift+5", "run c:/temp/ctrl_alt_shift_5.vbs", BindCommand, BindAccelerator |
