查看: 509|回复: 1
这是书上的一段代码,但是用18的matlab运行不了,想请教一下大神如何修改才能运行...
    2019-11-29 15:38
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2020-6-18 13:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    % f) z. U4 s2 \. z" b& z. L# A
    $ ~3 g$ b  k/ }这是书上的一段代码,但是用18的matlab运行不了,想请教一下大神如何修改才能运行呢?感谢!1 q' [- G+ W: w& L
    syms a b x;
    # r1 g% [' H! n" r4 R! Y- G. Wf1=a*sin(x)+b
    ; L5 ~: C% _- I; g4 Df2=subs(f1,sin(x),'log(y)')
    ! c4 w: u5 O6 H; w6 I% L) Dclass(f2)3 @# S5 p8 V; {2 u! X! X% H
    f3=subs(f1,a,sym(3.11))$ E6 g1 I+ e8 n& P% J$ ]! X7 l% N
    class(f3)6 L' |, a0 l2 M4 }& W4 s
    f4=subs(f1,x,[0,pi/2,pi])9 ]8 P% i9 A- }
    class(f4)8 p1 R& g7 I9 R- k5 V' G1 f; g
    format
    1 ?; C* k9 a& a8 sformat compact$ `* \+ l# Y5 }2 H. x% u+ }
    t=0:pi/10:2*pi;! f  S# M1 I! b& L: j8 P( Z4 R
    f5=subs(f1,{a,b,x},{2.3,t});
    6 N8 T5 o% Z( R* o2 fclass(f5)
    / G6 {1 y" [6 X  y+ v  nplot(t,f5,'r:','LineWidth',5)
    # [4 m2 W" b9 ck=[0.6;0.8;1];
    1 I+ ?9 m9 x& L2 r+ @' U" Zf6=subs(subs(f1,{a,b},{k,2}),x,t);
    7 S/ j- N  E1 c  ]# eclass(f6)
    . j: P, v6 j$ v, v* J# z0 Y- h7 M$ aplot(t,f6)
    6 ~, }- T. J4 A" t( K3 `  r9 r) ^8 q# H- r) ^9 i1 d
    3 I& y9 o5 G  E9 o" S
    提示错误信息( n8 B  j6 _7 ?$ u+ Z
    错误使用 sym>convertChar (line 1448)
    : z- |! |' L$ u$ QCharacter vectors and strings in the first argument can only specify a variable or number. To evaluate character vectors and strings
    6 U  ~( H# E  j9 g* Wrepresenting symbolic expressions, use 'str2sym'.
    ) M1 V( G- b0 V7 R5 ^* }6 D" w9 V. o" o) Y
    9 t$ s5 ]. |3 g: P5 t. Y$ o
    出错 sym>tomupad (line 1214)6 U$ ?& Y3 y1 [1 l9 h1 E- R
            S = convertChar(x);! P3 }, o5 d! m* i
    : {0 V) f/ ?' d' u" v& ^0 r. P9 w5 w
    出错 sym (line 211)' N' @8 N# K) y- N; o
                    S.s = tomupad(x);# N( B2 |, f1 S
    ! g+ w- h* g$ u- F$ O* b" R- A
    2 u; s0 X( m7 P- z0 s4 b出错 sym/subs>normalize (line 211)
    / O4 F0 o+ M& y7 R8 Q/ E    Y = {sym(Y)};
    " t7 ]- j! L5 s5 Z: E+ D' M
    4 C' _' H, z( ~6 Y4 g4 v, A3 R/ G) S" n! x
    出错 sym/subs>mupadsubs (line 157)
    # v5 e" X' g4 g9 s+ ?, b[X2,Y2,symX,symY] = normalize(X,Y); %#ok
    8 R) z5 o% R  W6 z* V& U2 K" Z3 {% Z" o+ @
    " K% j! b2 F6 c; L2 R+ p+ G
    出错 sym/subs (line 145)
    6 I! s. ~- B" |) T# M& s: g& z. L0 r7 e. n' S3 |# g7 }
        G = mupadsubs(F,X,Y);
    发表于 2020-6-18 14:37 | 只看该作者
    & }4 Y2 x: U8 i
    sym 不能用 char 替换的。& Y/ R) j; G+ W
    提示也给出来了。
    ; D9 I8 E( k& ~4 |8 G! X" v) V6 ff2=subs(f1,sin(x), str2sym('log(y)'))
    GMT+8, 2025-11-5 14:36 , Processed in 0.156250 second(s), 24 queries , Gzip On.
