TA的每日心情 | 开心 2019-11-20 15:05 |
签到天数: 2 天 [LV.1]初来乍到
MIT6_094IAP10_lec048 `8 Y( g, V4 T8 ^: R8 E
; U0 f! S1 ~( [* ]; O* W: c8 C
• How long did it take?1 g- m4 T# u6 a+ s' J1 H8 `
• Common issues:1 N. f& o/ y W2 h
• The ODE file should be separate from the command that solves it. ie. you should not be calling ode45 from within your ODE file* c% F6 [: n" P' C, {+ P) r2 S
• The structure of the output of an ode solver is to have time running down the columns, so each column of y is a variable, and the last row of y are the last values
# ~6 e5 c0 P6 Q8 k9 A: b+ i• HW 4 was updated today, so download it again if you already started. Show a juliaAnimation
9 \% w: m$ x9 L4 _& Y• Today is the last required class: make sure the sign-in sheet is accurate regarding your credit/listener status
0 d* u2 D# z- I1 ^) i3 v. E# c( p
! a8 L g7 `. i) n8 o J
# u% K% \) ^- K% V: M7 L
