Reading file -- E:\pads Projects\padsnet.asc
% {* ~9 w: Q ]6 i3 u*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal GND B8 ?7 x0 T! V* r1 c
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal +5V
6 c1 ~) K' M5 G1 \! j( iWarning: deleting signal GND7 ^3 Y+ m, c7 ]) C( {% [# i
Warning: deleting signal +5V
w" H! D3 \, J% X6 O0 L**INPUT WARNINGS FOUND**/ N4 u; L+ B U" U- D1 p
( t- b( _, R% d- `5 [我的原理图就是
% P9 T2 r! _0 ^6 v, }3 X+5V电源,接一个电阻,再接一个二极管,接地。我刚刚接触pads,画了个简单的试试,没想到就出了问题。
" R8 \& M' \# G/ N: n# _; c麻烦哪位大侠给回答一下,谢谢! |
