查看: 2068|回复: 0
求助:关于逻辑图生成pcb的问题
发表于 2010-7-22 10:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
逻辑图第一次进行ECO TO PCB 没有任何错误和警号,但是我什么都不改再点一次ECO TO PCB就会出现很多警告:
. f3 E: f& ~# K2 g: l- ~: @9 J, y0 E6 P( W4 y8 N' p8 D
Line 15 , Section *DEL_ATTRIBUTE** @& A- {# n& N7 V: g5 q
"Comment"
) Z5 C/ V; H3 Z/ Y/ Z* WARNING: Processing command to delete attribute "Comment" from Component J2.
& ~) h6 l3 j" O/ j*          The attribute is also inherited from Decal AUD_JACK_6PIN." {1 R/ ^3 c3 x; A% N8 }
*          The change is not fully reconciled for cases where the schematic
& D0 N# Z) X, I- V2 F8 ~. A*          does not support hierarchical attributes.
$ ?  f8 z/ P% k: U( W* LLine 17 , Section *DEL_ATTRIBUTE*
) `  m' m* m/ |$ ^"Comment"" l- n! I3 e6 D  U6 @3 r
* WARNING: Processing command to delete attribute "Comment" from Component BT1.' I, h. f, M; S( @/ ~/ x0 |; x; u
*          The attribute is also inherited from Decal HB414--II06E(RTC).
% W- d% Q9 t0 ^+ Y*          The change is not fully reconciled for cases where the schematic& z9 e" H% X5 e* r
5 o8 O5 M3 D& z( n2 J4 C# V$ u( ?Line 19 , Section *DEL_ATTRIBUTE*2 e1 ?: S; a9 d  F# R* V
"Comment"# u/ `) z! E# |, m; U6 l) ^
* WARNING: Processing command to delete attribute "Comment" from Component J5.
* ?4 u, N" [; c: B& D+ ?' {*          The attribute is also inherited from Decal BAT_HEADER1.! c+ T: P" m' G: Q  \8 L
*          The change is not fully reconciled for cases where the schematic2 T. ~. V2 @" W7 F
9 X8 C: o: y" r  y' v7 i2 y
" H# k$ H7 n% _6 U9 T警告有700多个,但都是像上面一样的,想请教是什么原因
$ k/ o  R9 m" g5 m! o& G ! J1 j/ C, v: m4 M! S
GMT+8, 2025-10-25 14:24 , Processed in 0.140625 second(s), 24 queries , Gzip On.
