程序是给的示例程序,是不是还要设置什么啊,
/ `$ s2 l1 _, S% Y [& R7 w
% L8 t4 F4 H0 g. {4 b
/ u& _' E& c5 a( u6 B& o* s#include <Lpc213x.H>
' @, e( s1 \6 g. P- m9 c! R5 Z$ d% n3 z- x) b" M5 s. \# H+ e# ]
#define UART_BPS 96007 s, B+ {* M {0 i# b' x
#define FPCLK 12000000
0 b. f6 {+ C! K9 H" l2 Z2 u1 }2 V9 g- t( r' q1 O
3 b: H, N9 e' _- B& n9 ?5 a
typedef unsigned int uint32;9 W; h( |+ l. `2 ~7 U5 {- s" y
typedef unsigned short uint16;
$ N9 O' g" G& Y+ {typedef unsigned char uint8; V$ W7 @/ P) \' a9 w
T( B A" [4 A2 R8 P
, D6 w, A$ }/ M, Y0 D9 i: {( H
void DelayNS(uint32 dly)
4 A; i. n6 L- b& [0 Q; _{
% T7 Y v K i, @' k; R5 W( R uint32 i;: o& m# E$ h1 J2 `" `$ H4 x
for(;dly>0;dly--) ) f' q S5 N4 I# x" _" F# n
for(i=0;i<50000;i++);! @& \! ?5 L# i0 {) K
* E; U4 n8 k- D3 o0 b: ]% I
6 K5 B8 X' Z X8 ]3 h+ V$ ^6 L4 e; |% x, d( U, a2 y9 O
void UART1_init(void)
% H4 A6 z8 x1 n{1 f0 h1 ^ V) O1 _! B8 V# `9 q4 r
uint16 Fdiv;
/ z2 t& ^; }6 u# O U1LCR=0x83;
" x* v: o: u6 c5 [ Fdiv=(FPCLK/16)/UART_BPS;
0 I3 R! D2 N8 U% J& \; N U1DLM=Fdiv/256;" @, ~, h" b2 m
U1DLL=Fdiv%256;
6 e% u5 b0 b) C0 E- } U1LCR=0x03;
: m* I, m/ _5 ~}
. V, n% j0 c: y% E _2 Z
5 c# H+ V6 f2 r/ E' ~7 C) evoid UART1_SendByte(uint8 data)
. S4 L! @% T1 ~1 S{
4 H+ I8 o7 J' C: I U1THR=data;' F7 b" K V4 Y! s9 J3 S7 |
while((U1LSR&0x40)==0);
2 N: X/ L" K5 ^; y/ N}
Z2 r" k5 \' f9 M1 N* N" a+ N+ p4 u$ z8 K, S, A
void UART1_SendStr(uint8 const *str)& ^& l# F2 L J. h
. y2 f/ D$ Y$ k2 @& n& s while(1)6 n% H2 I# J8 {$ d
7 o! D6 i$ D7 ]$ k* Z UART1_SendByte(*str++);
( e0 j" S# ~0 q; U5 @3 Y3 [ if(*str=='\0'); Q8 d$ o& l/ u3 o
break;
& E k0 P) w; V6 [+ U. f9 b3 Y8 D$ z1 z5 c }
/ U# {7 S1 c/ E0 b! b! m6 ^}
+ \7 K: t4 u& k d, l- }; e* @
: Z; s- g* b6 V1 _8 Mint main(void)8 o5 `+ T& t8 N
{" o1 o1 A; i$ r8 Y) \/ I
PINSEL0=0x50000;, d Q1 I4 X# ? W# l
UART1_init();( @2 t7 {4 z$ m/ f% B
while(1). {1 B% C$ Z' Y( N) t
. k2 Y+ l6 m% a+ G5 v UART1_SendStr("welcome!\n");1 F- o; ^2 i6 c8 V
DelayNS(100);
# I# H) r' [3 J6 _! }: y2 O7 P1 E. \9 ^, j/ R* a% r+ A. s
( V8 K# G5 h5 Q9 z% A+ t1 Q
} 3 ^2 j, |9 L& _3 y
return(0);
" \ I& H, ^! u}
# Z6 i) [( x: T3 k8 {. y |
