EDA365欢迎您登录!您需要 登录 才可以下载或查看,没有帐号?注册  & m8 y6 M6 e! Z2 L; \" q" C. [, A' d
 DESCRIPTION
 ( R" m* h1 Y3 @  KThe MP1584 is a high frequency step-down 4 v" S: n0 g6 w( l6 o" W+ Z6 L
 switching regulator with an integrated internal
 7 V( P; A# o- h! }high-side high voltage power MOSFET. It , f; L* k$ E3 E, h, [
 provides 3A output with current mode control for
 ( M4 _" A6 Z+ g* Zfast loop response and easy compensation. . K) F. S# n7 A
 The wide 4.5V to 28V input range accommodates
 : n7 r7 e5 Z7 g9 l3 \4 o  D4 ga variety of step-down applications, including : B/ E) i- G" P1 |( o& {
 those in an automotive input environment. A ( X: U, {+ f) F- a3 p6 r
 100μA operational quiescent current allows use in $ a/ V+ x6 B' J! l
 battery-powered applications.
 2 U9 H6 [+ t+ ]High power conversion ef
 # k. U, m& P. I, f: y4 l) fficiency over a wide
 . q6 g, J" a6 K/ V- ?load range is achieved by scaling down the
 # H  r  J9 K% {; A( \switching frequency at light load condition to
 . }7 ^- I; W: y* ~( f5 dreduce the switching and gate driving losses.
 ) v6 v% |3 n- mThe frequency foldback helps prevent inductor ( _$ c! H- A! Q8 ~6 o9 G4 ?- b
 current runaway during startup and thermal
 , Q3 o/ `- d, o7 j% R! ~) yshutdown provides reliable, fault tolerant 1 J3 K3 V6 v8 x& g! ]7 A3 A
 operation.
 9 _- @# `8 c+ ^; IBy switching at 1.5MHz, the MP1584 is able to / ^" k$ `# X* e" r
 prevent EMI (Electromagnetic InteRFerence) noise . G; V5 L) Q  ?, r- B! S  e5 n
 problems, such as those found in AM radio and ) Q4 Q) W$ a- W" w( m9 j
 ADSL applications.
 # J% |. V4 ^1 Q: g* vThe MP1584 is available in a thermally enhanced # H- {! @1 d9 f2 P- T$ R9 j7 B- K) Y
 SOIC8E package.
 0 W  ?8 f; t! s6 p8 N2 E$ {3 }0 C  w6 Q$ l
 ( \- P. B' B( U" KFEATURES8 N1 N2 }7 j4 v% {
 5 T1 G7 y' ?4 O0 l( }, `4 n. X
 Wide 4.5V to 28V Operating Input Range
 ( m, e7 x+ p7 O" k  q
 ! a) K& R8 H' t) G7 |) L0 R! w Programmable Switching Frequency from & j" c4 k9 V7 ?4 {% k! N1 C
 100kHz to 1.5MHz & Y  [, I: F* ]4 s" R0 U' M9 L# l
 0 ~" A; g+ R' k High-Efficiency Pulse Skipping Mode for
 0 F9 b$ S9 B0 }6 O5 }Light Load
 # f0 x: ?* S! A# d, x
 / p) y" z+ Q5 o/ \  t$ C6 x& i5 n1 R Ceramic Capacitor Stable
 5 X; D' t7 S; A  A% r/ o* z1 h% u0 U) S* B5 a
 Internal Soft-Start 6 d( H$ \" n: e/ S- l2 [
 5 D3 T0 ?7 Z' A, v. f) t
 Internally Set Current Limit without a % W% e1 D" G) C  r: e; l
 Current Sensing Resistor
 , s; F( G% B" q3 a$ _9 P" Y
 1 U8 e4 M, N' z Available in SOIC8E Package.
 ! h8 T1 @8 V) t8 EAPPLICATIONS * t% R# Q5 V' @
 8 X" i; A4 k6 I
 High Voltage Power Conversion 8 u1 S8 Z  V' c% Z1 L" ^- a0 o: n
 $ Q# n1 O4 }- v" _% C5 ] Automotive Systems
 ( s3 q$ Z! \3 m9 J, i9 J. O/ r  f1 ]; v+ l( z, b9 U& W
 Industrial Power Systems ; c$ \8 Z4 |% Y$ H& c& V  P
 / O! y& A- u; v" g, z
 Distributed Power Systems
 ' n7 w  v; v- T/ _
 . z% S* J9 y) l5 W: k2 ^' L9 _4 o5 eBattery Powered Systems ( Y; W0 V6 i, Q) K: i
 Tel:15820760660 熊R& [" V. E) y  n* Z& M. B
 . T5 ?* t, T; E7 I5 {% i
 * i5 T% B2 U1 k6 e
