查看: 958|回复: 5
[allegro16.6][4层] arduino开发板(SD驱动芯片+SD+USB)原理图和pcb文件
发表于 2020-5-15 20:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
( X, H7 s+ h+ J0 J0 c
, a4 |" I: ^2 Y" p8 d
# U: R, \- x6 `6 V" ?# D文件描述:
& B, _* j! w+ t
+ {" Z, f/ T) M; U) R+ B4 g$ I1. 作品用途:arduino开发板
9 E7 A4 B8 v; U) D# o, k2. 软件版本:allegro16.68 a; k6 s# h9 x/ Y- _
3. 层数:4层
" ]! F! b2 N$ D( U. ?4 I! f0 `4. 用到的主要芯片:SD驱动芯片+SD+USB
1 ]7 x7 a, _9 P0 ?) ~" j5. pcb尺寸:122.2248*71.9836 MIL$ D9 W- f4 }0 ]& w; J% ?
5 \' u6 {3 j' ?* W作品截图如下:
% {" v9 ~3 ~* ~  Z" c
" Y; y9 R: R/ u7 [/ }8 F* S顶层截图:' J/ w- U" @! B5 g1 @" k
5 v7 E! s5 M- G8 c9 X# B) V
底层截图:' h5 ?  O4 w& A/ g8 q
1 P' K& J, B/ L6 W9 c) @* i
: N" r9 t( Q$ [' ~
全层截图:
: @- {: f" F3 N6 N- _3 H$ \6 z/ I' T4 K' ]. t' x9 y6 f0 V, H
* q5 [: W( {/ s% G/ j# j
叠层阻抗信息如下:
2 J/ _- i; o1 r5 D" `: ^
( Y9 B8 x8 W* W4 C1 iBOM:
" ^% ^& ~5 }0 |
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1X6RCPT_2P54_VT_THH46111-0016Pin_HDRIC1J1A1
1X8RCPT_2P54_VT_THH46118-001CON8_HDRIC2J1B1; J2A1
1X10RCPT_2P54_VT_THCON10,1X10,0.1,0.093,E74918-0011x10IC1J2B1
2X35_P4MM_BTB_AXT_SKT_MBH42241-00170Pin BTB Socket HIROSE DF40IC1J7
102276-001E81838-001CON2_HDRIC4J2; J10; J14; J15
102276-003A91829-001CON3_HDRIC3J8; J9; J13
102276-005C88650-0011X5_HDRIC2J11; J12
BGA6_5MM_37X57G42189-00174LVC1T45 CSPIC20U4; U6; U8; U10; U12; U14; U18; U19; U20; U21; U23; U24; U26; U27; U28; U29; U30; U31; U32; U33
BGA8P_5MG2X4LVC2G5374LVC2G53 CSPIC12U5; U7; U9; U11; U13; U15; U22; U25; U40; U41; U42; U43
BGA20_P4MM_1P96X1P56TXS0206TXS206-29IC1U35
C0201CAP_C0201_0.1UF_C83410-0270.1uFIC3C3; C56; C57
C0201CAP_C0201_0.1UF_C83410-0140.1uFIC29C6; C9; C10; C12; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C48; C49; C50; C51; C52
CONN4_D23040001D23040-001D23040-001IC1J6
CONN6_H18587001H18587-0012X3HDRIC1J4
CONN_SDCARD_8P_PPREQ3437SD CONN G46739-001IC1J5
DFN6P_65M_2X2MIC,MIC2039,USBPWRSWTCH_0_DFN6P_MIC2039IC1U36
JK_3P_RAG60557-001DC_JACKIC1J1
LCC6_P35MM_SQ1P0_NONC_P5HH22984-00174AUP1G125IC1U44
LCC10_P5MM_EP65X94G67765-001TS3USB221IC1EU1
LCC12_P5MM_3X4MMG38734-001LTC4067IC1U38
LCC16_3X3MM_67DIE_39HTPS62133_0_LCC16_3X3MM_67DIE_39TPS62133IC1U1
LCC16_3X3MM_67DIE_39HTPS62133_0_LCC16_3X3MM_67DIE__1TPS62130IC1U45
LCC25_S41_5DF89X89MAH31921-001PCAL9555IC2U16; U34
LCC25_S41_5DF89X89MAH47895-001PCAL9535AIC2U17; U39
LCC32_P5MM_3P2SQ_NONCFT232R_0_LCC32_P5MM_3P2SQ_NONC_FT232RIC1U2
NPIN787MOUNTING HOLE 787_NPIN787_NPIN7NPIN787IC2MTG1; MTG2
QFN24P_5M_4X4MADS7959_0_QFN24P_5M_4X4M_ADS795ADS7951IC1U3
R0201R_0_R0201_0R_C80792-0090RIC10R1; R2; R6; R7; R8; R9; R10; R11; R123; R124
R0201R0603_R0201_1K_C48657-0101KIC1R5
RCPT_USB_5P_DIP_SMG58911-001G58911-001IC2J3; J16
SCR_27X17MAH33384-001D2BW319000IC3CR2; CR6; CR7
SMC0201C83410-01733000pFIC2C4; C53
SMC0201D70542-001100pFIC7C34; C40; C41; C42; C43; C44; C45
SMC0402G21049-00110uFIC5C5; C8; C11; C13; C46
SMC0603_HI_VALUE602433-08122UFIC2C1; C54
SMC0603_HI_VALUE602433-0912.2uFIC1C36
SMC0805G27061-00210uFIC2C47; C55
SMF0402A51464-017120 Ohm@100MHzIC1FB1
SML0805G95926-0011uHIC2L1; L2
SMLED0402E54986-003GREENIC3DS1; DS2; DS3
SMR0201C80792-00210KIC46R3; R4; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R45; R46; R48; R80; R81; R85; R87; R95; R96; R97; R98; R100; R102; R104; R105; R106; R107; R109; R110
SMR0201C80792-011100KIC1R37
SMR0201C80792-0144.7KIC11R39; R40; R41; R42; R43; R44; R50; R51; R108; R122; R125
SMR0201C80792-046220IC2R47; R49
SMR0201C48657-11847KIC33R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R89; R90; R91; R92; R93; R94; R111; R116; R117; R118; R119; R120; R121
SMR0201C48657-0132KIC2R72; R73
SMR0201C48657-04333.2IC6R74; R75; R76; R77; R78; R79
SMR0201C48657-08810.5KIC1R112
SMR0402RESD,0201,1%,1/20W,562_SMR0402_576IC4R38; R86; R88; R114
SMR0402C65288-008100mOhmIC5R82; R83; R84; R113; R115
SOD123_67X106E58800-001RB160M-40IC3CR1; CR8; CR9
SOT23C81974-001BSS138IC8Q2; Q3; Q4; Q5; Q6; Q8; Q9; Q11
SOT23_6_SUPER_NOEP_1P22HFDC6331FDC6331LIC5Q7; Q10; Q12; Q13; Q14
SSW2RPBD90553-001LIGHT TOUCH SWITCH EVQP7J01PIC5SW1UI1; SW1UI2; SW1UI3; SW1UI4; SW1UI5
SW_SSAJ110100_3PG99612-001Slide switch,SSAJ110100IC1SW1
SYMBOL_NPTH125SYMBOL_NPTH125_0_SYMBOL_NPTH125NPTH125IC6MGT5; MTG3; MTG4; MTG6; MTG7; MTG8
TP30STESTPAD_3030 MIL TESTPADIC88TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP57; TP58; TP59; TP60; TP61; TP62; TP63; TP64; TP65; TP66; TP67; TP68; TP69; TP70; TP71; TP72; TP73; TP74; TP75; TP76; TP77; TP78; TP79; TP80; TP81; TP82; TP83; TP84; TP85; TP86; TP87; TP88
附件:& I$ y/ ]7 ?  ^8 r1 d
原理图和PCB文件如下:
0 |% B& Q% H) H- c
游客,如果您要查看本帖隐藏内容请回复
/ |- g% _7 g8 T+ M# d: q9 P& n8 E+ E  _6 X# T7 H) H! z- F
发表于 2020-5-15 21:07 | 只看该作者
我拿来练练手,谢谢楼主分享。
发表于 2021-2-23 22:44 | 只看该作者
我只想下在這些資料看看是唪有可以用的  @' a3 p$ ]7 d' D
    2022-9-30 15:56
    发表于 2023-11-21 16:05 | 只看该作者
    多谢了,能练习一下!
    ! D2 J$ Q2 ^4 @9 r1 T7 t
    2025-10-10 15:06
  • 签到天数: 593 天
    [LV.9]以坛为家II
    发表于 2023-11-23 10:31 | 只看该作者
    研究一下,学习。
    GMT+8, 2025-10-12 18:24 , Processed in 0.156250 second(s), 27 queries , Gzip On.
