WARNING - Model CLKIN_800 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 30)
1 V' D2 w1 X+ q' J) D$ nWARNING - Model CLKIN_800 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 30)9 U9 s1 h; e: w4 V+ }
WARNING - Model CLKIN_800 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 30)- \( H/ B% n- R0 R5 _+ r# x3 X
WARNING - Model CLKIN_800 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 30)
( j' \) A9 q l GWARNING - Model CLKIN_800 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 30)
% D# c1 n+ l; ~' h. N: R& X8 b- vWARNING - Model DQ_HALF_ODT150_800 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)
; Q, r1 W, g) D$ wWARNING - Model DQ_HALF_ODT150_800 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)8 O* |' j' p0 Q" N4 d0 b
WARNING - Model DQ_HALF_ODT150_800 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)
8 g* a1 k' X: B Q/ l5 bWARNING - Model DQ_HALF_ODT150_800 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)5 Q% N' L9 c: ~" i3 K. w. ~
WARNING - Model DQ_HALF_ODT150_800 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)8 X! C3 T- r$ X2 H$ ?3 X
WARNING - Model DQ_HALF_ODT75_800 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)$ V/ a) f! B7 l+ |& f1 h
WARNING - Model DQ_HALF_ODT75_800 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)
! B: C& [; G% I9 Y; b/ ?* aWARNING - Model DQ_HALF_ODT75_800 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)
: h( n2 K, J1 {& N& F7 }$ r' QWARNING - Model DQ_HALF_ODT75_800 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)- M* |% N/ y4 Q i# q$ ?6 Y
WARNING - Model DQ_HALF_ODT75_800 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)5 @8 p) l1 W4 i( D" M) f
WARNING - Model DQ_HALF_ODT50_800 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)1 H2 U: d% H! T' L p7 `3 R) i% b) |
WARNING - Model DQ_HALF_ODT50_800 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)
3 V+ r t& {8 b) T- [$ ~WARNING - Model DQ_HALF_ODT50_800 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)
9 o2 h1 l, t& e" r. CWARNING - Model DQ_HALF_ODT50_800 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)
2 Y x! p. H5 i* kWARNING - Model DQ_HALF_ODT50_800 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)
. K: H# P. F( {# B+ }WARNING - Model DQ_HALF_800 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)
) j1 @$ ?4 b, x: w7 z, @WARNING - Model DQ_HALF_800 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)5 P1 _0 f* a3 J: z
WARNING - Model DQ_HALF_800 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)
( l8 k' P. l* E" `) eWARNING - Model DQ_HALF_800 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)2 Q0 V$ b& q5 c5 F( V* y& b5 y* s
WARNING - Model DQ_HALF_800 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)2 `1 g& ~6 b5 [) j
WARNING - Model DQ_FULL_ODT150_800 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)- a4 q/ b) w/ k, \
WARNING - Model DQ_FULL_ODT150_800 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53). B' {9 o$ \. m3 _% S
WARNING - Model DQ_FULL_ODT150_800 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53), D) ^; N. C8 U9 v: N& c, s
WARNING - Model DQ_FULL_ODT150_800 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)! z! N' n( `0 b$ z9 W
WARNING - Model DQ_FULL_ODT150_800 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)
8 n0 r' N! H% A7 ^. U+ dWARNING - Model DQ_FULL_ODT75_800 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)* [' ^( N9 ?7 z Z' [) j
WARNING - Model DQ_FULL_ODT75_800 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)/ C2 R& k! b' h0 V
WARNING - Model DQ_FULL_ODT75_800 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)5 `; K% s9 Q: C6 z& c1 `% x* J
WARNING - Model DQ_FULL_ODT75_800 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)! [% Q; b3 j9 R! G
WARNING - Model DQ_FULL_ODT75_800 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)
7 X' ^/ Z; V+ I& y) w b0 _2 GWARNING - Model DQ_FULL_ODT50_800 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)
4 O$ \( V/ |) B4 X9 \, S" S" HWARNING - Model DQ_FULL_ODT50_800 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53) V4 M' ^4 ~3 E
WARNING - Model DQ_FULL_ODT50_800 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53) ?# j; W8 j7 z7 O
WARNING - Model DQ_FULL_ODT50_800 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)
9 c4 \3 w9 T, Q; Y9 y# C$ `/ X$ T4 qWARNING - Model DQ_FULL_ODT50_800 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53): W! [% A3 ]4 z9 M( a+ d X4 e. F _
WARNING - Model DQ_FULL_800 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)5 \# Q' s8 ?' a( w' [
WARNING - Model DQ_FULL_800 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)
' ]- x) i- U+ F; J. O$ Y/ jWARNING - Model DQ_FULL_800 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)- H# n( y3 [" e4 a) [# [- l% ~
WARNING - Model DQ_FULL_800 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)" t3 j0 x2 J% w1 R% @
WARNING - Model DQ_FULL_800 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)
4 f( U2 d) I; s* }- V: ]WARNING - Model CLKIN_533 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 30)
! M; P, r$ L5 Q( a2 S. y: NWARNING - Model CLKIN_533 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 30)! H$ s' X9 D9 Z( y9 H
WARNING - Model CLKIN_533 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 30)5 Q% {" Q) {! W. I) A; W" @ T
WARNING - Model CLKIN_533 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 30)
5 ~6 |3 d, g @# ~WARNING - Model CLKIN_533 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 30)
! S/ r4 O+ @% ]% f U5 s0 U% EWARNING - Model DQ_HALF_ODT150_533 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)2 d; L9 x6 [, x, N
WARNING - Model DQ_HALF_ODT150_533 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)
. C& L& N) s9 O# V1 X1 p8 x9 ^WARNING - Model DQ_HALF_ODT150_533 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)
$ ?( l3 }& K( g) sWARNING - Model DQ_HALF_ODT150_533 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)
6 t, ^* y1 M T# gWARNING - Model DQ_HALF_ODT150_533 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)4 m, B0 e6 q% w
WARNING - Model DQ_HALF_ODT75_533 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)+ {# u- x2 d; f5 f/ X
WARNING - Model DQ_HALF_ODT75_533 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)
4 v3 a; v% \9 X' W9 u+ l8 E6 CWARNING - Model DQ_HALF_ODT75_533 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)
! ]( W, g- J( U1 kWARNING - Model DQ_HALF_ODT75_533 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)+ T5 G* k! i& e& u" W' E9 L* C
WARNING - Model DQ_HALF_ODT75_533 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)
. f. N/ A( a8 @: e R3 V, w1 HWARNING - Model DQ_HALF_ODT50_533 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53) ^1 g: X6 J+ c9 G; \' I e
WARNING - Model DQ_HALF_ODT50_533 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)! L& z0 r3 e1 P
WARNING - Model DQ_HALF_ODT50_533 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53) x; T3 q/ Q1 x- |- w; o6 a
WARNING - Model DQ_HALF_ODT50_533 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)! y+ `' o( N) U( _
WARNING - Model DQ_HALF_ODT50_533 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)
) o7 [, D1 O9 D6 q# B* nWARNING - Model DQ_HALF_533 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)
7 Y; d& l5 q+ a9 l2 ^8 mWARNING - Model DQ_HALF_533 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)9 J" k, Z0 ?( \; N8 Y# m: {% b# C
WARNING - Model DQ_HALF_533 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)1 M& W4 x: J. e+ P4 ^) N% r
WARNING - Model DQ_HALF_533 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)
2 w4 p* E! X6 Z9 gWARNING - Model DQ_HALF_533 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)# L& N) {! H% z3 j- _
WARNING - Model DQ_FULL_ODT150_533 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)
7 C! `% X# f, l8 n1 m ~WARNING - Model DQ_FULL_ODT150_533 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)
; w/ c& f1 k. u: ^# ]" X. _8 lWARNING - Model DQ_FULL_ODT150_533 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)
) \# p( c( R9 l/ x5 BWARNING - Model DQ_FULL_ODT150_533 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)) j' q$ @2 ?' u7 }
WARNING - Model DQ_FULL_ODT150_533 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)5 b" _& H% t$ m
WARNING - Model DQ_FULL_ODT75_533 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)
# ^: W$ p( f2 [+ z! GWARNING - Model DQ_FULL_ODT75_533 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)
. G( [* L/ T6 h1 R1 HWARNING - Model DQ_FULL_ODT75_533 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)5 c. ]! R# [. d' I
WARNING - Model DQ_FULL_ODT75_533 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)' Y# }- l0 j+ [& d4 U; I
WARNING - Model DQ_FULL_ODT75_533 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53) {, F" ^ F/ W" X0 d9 i j7 V
WARNING - Model DQ_FULL_ODT50_533 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)4 x3 P/ u8 ~5 k& \
WARNING - Model DQ_FULL_ODT50_533 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)0 w2 ^( ~# n% a* X' }, z! n
WARNING - Model DQ_FULL_ODT50_533 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)
5 m" h$ ?3 B9 {4 _4 E4 y& WWARNING - Model DQ_FULL_ODT50_533 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)+ |4 u8 `& w2 m: k, ]
WARNING - Model DQ_FULL_ODT50_533 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53)
" f/ H- l4 @2 W/ x2 pWARNING - Model DQ_FULL_533 Receiver Thresholds: Vcross_low must be specified for differential receivers (Pin 53)) X! S! ` Q7 A2 U& Z
WARNING - Model DQ_FULL_533 Receiver Thresholds: Vcross_high must be specified for differential receivers (Pin 53)
_% N/ ~- A" {1 W# vWARNING - Model DQ_FULL_533 Receiver Thresholds: Vdiff_ac must be specified for differential receivers (Pin 53)- |% M' W0 s9 j- U
WARNING - Model DQ_FULL_533 Receiver Thresholds: Vdiff_dc must be specified for differential receivers (Pin 53)
7 u* H. V& m" ~/ L: B9 m) wWARNING - Model DQ_FULL_533 Receiver Thresholds: Tdiffslew_ac must be specified for differential receivers (Pin 53) |
