REGRESS Multiple linear regression using least squares.8 a8 V. E6 F. K) n
B = REGRESS (Y,X)
. J% e( L: u6 `( nreturns the vector B of regression coefficients in the
8 ~0 J B& s3 f0 ~9 Y) clinear model Y = X*B.
. R9 t8 i8 T# a& L, m4 b& S* `. |; |$ r/ J
X is an n-by-p design matrix, with rows1 x. {. p+ |6 b7 Y! t
corresponding to observations and columns to predictor variables.
8 r. U4 O, X9 A- v: ?. p% O( L! P6 q( ?
Y is an n-by-1 vector of response observations.
( _6 ? C! G# P& b$ ^5 QREGRESS
5 Z& g3 Z6 A( o/ w' R多元线性回归——用最小二乘估计法
# }2 ]+ i1 x, v, D, j* w- NB = REGRESS (Y,X) ," W G, K3 o& E) E/ f$ n
: V' }3 t7 S A" S: E" d' Q
返回值为线性模型Y = X*B的回归系数向量
) l2 [; j# O& V' D2 Y3 b$ L: U! q( L+ X5 T X ,n-by-p 矩阵,行对应于观测值,列对应于预测变量$ u) _ E6 H R3 V: v
Y ,n-by-1 向量,观测值的响应(即因变量)$ s0 ?& X' g; G! [( Y. x! s- P
8 O3 j" [8 X" @6 d2 U- h) [
[B,BINT] = REGRESS (Y,X)
7 {, U4 c! _' X- Y, \, |% Jreturns a matrix BINT of 95% confidence intervals for B.4 s( y L/ [% m) ]2 C& K
BINT,B的95%的置信区间矩阵: G4 @4 W: u4 U& O
# S6 Q2 ?% ^9 k- ^% ~- r3 F7 {
[B,BINT,R] = REGRESS (Y,X)" M. n3 l# G0 C' c$ B- M+ v% ?# F
returns a vector R of residuals.2 h+ a$ k' ]% w. C" N* O# E
R,残差向量
O: n- m" e. H" T- |6 W" O
' R4 x0 r( U) G[B,BINT,R,RINT] = REGRESS (Y,X) 5 P6 Z% Z p1 S. G! J2 C
returns a matrix RINT of intervals that7 ?2 H8 z$ E% u: F% U4 [
can be used to diagnose outliers.0 A) A# V9 v' R" E; I1 B0 W' v
, z% v' p* `; ]3 Q
If RINT(i,: ) does not contain zero,
; m# f1 x6 Y( f. ^7 I5 {- Q7 {0 S2 ~, ^' r
then the i-th residual is larger than would be expected, at the 5%. |; n& q: N H# a- Z3 S1 l" J; U2 X
significance level., r, C& M$ L% @' V% V$ `5 b w! H
- W1 L0 c) o* h& GThis is evidence that the I-th observation is an outlier.1 _( q' f8 m9 H% ^
2 D, P2 v. W8 j& G" i; x, d
RINT,区间矩阵,该矩阵可以用来诊断异常(即发现奇异观测值,译者注)。0 B; K! i! F& L- p( ^
如果RINT(i,:)所定区间没有包含0,则第i个残差在默认的5%的显著性水平比我们所预期的要大,这可说明第i个观测值是个奇异点(即说明该点可能是错误而无意义的,如记录错误等,译者注)
3 `; g1 q6 H' i0 S+ {% V5 X$ Z8 G
[B,BINT,R,RINT,STATS] = REGRESS (Y,X) : r2 q& K7 A. U9 N
returns a vector STATS containing
9 x! H, E; `& D: e/ n$ N4 cthe R-square statistic, the F statistic and p value for the full model,and an estimate of the error variance.& \( J4 n3 I7 o* d+ y! |9 ]% P
2 Z% f# a1 o& F6 N- X0 F, X# ?
STATS,向量,包括R方统计量,F统计量,总模型的p值(还不清楚)和方差的一个估计(还不清楚)4 b' C3 s, ?8 e+ C4 q
7 `* E- {; Q' f. g9 Z7 {, C
[...] = REGRESS (Y,X,ALPHA)
& h7 d* F2 n. R, ^6 v8 |/ wuses a 100*(1-ALPHA)% confidence level to compute BINT, and a (100*ALPHA)% significance level to compute RINT.
% ]' Z+ e8 u2 E& z* H( S用100*(1-ALPHA)%的置信水平来计算BINT,
+ q( e# Z- e! ]. m用(100*ALPHA)%的显著性水平来计算RINT/ o3 `4 J$ t3 ?" k
4 m% ^, Z! T. Y& z1 `X should include a column of ones so that the model contains a constant
0 M! W; f9 M1 q& Q5 `# Qterm.
9 H/ d \6 T0 H$ OThe F statistic and p value are computed under the assumption
$ E8 q5 t! y7 v) D( F/ W, Rthat the model contains a constant term, and they are not correct for; p) {/ z6 Q5 k+ a+ a* T% ?
models without a constant.3 `( V4 x3 f1 P F- G
The R-square value is one minus the ratio of" t, f. u3 D! m; H% I/ O# |% j, }
the error sum of squares to the total sum of squares.
4 K2 D9 y3 T P, |# Q0 t# h0 yThis value can
1 f. }) _6 T5 ]) p; x9 X8 M& kbe negative for models without a constant, which indicates that the model is not appropriate for the data.$ h/ t# K ^0 f7 g4 |5 {4 Q; e3 U/ M
X应该包含一个全“1”的列,这样则该模型包含常数项。F统计量和p值是在模型有常数项的假设下计算的,如果模型没有常数项,则计算得的F统计量和p值是不正确的。The R-square value is one minus the ratio of the error sum of squares to the total sum of squares.(此句无法把握,请高手帮忙~~!)若模型没有常数项,则这个值可以为负值,这也表明这个模型对数据是不合适的。(即数据不适合用多元线性模型,译者注)" {- G' l3 A6 @7 O! S' M
& H/ R6 n& n, e9 a4 ZIf columns of X are linearly dependent, REGRESS sets the maximum/ z. \, T) \5 i9 x- S5 h
possible number of elements of B to zero to obtain a "basic solution",, F2 ~& V5 ]+ u4 I% L8 o- z
and returns zeros in elements of BINT corresponding to the zero elements of B.
1 W5 M( T0 z; A( I. g如果X的列是线性相关的,则REGRESS将使B的元素中“0”的数量尽量多,以此获得一个“基本解”,并且使B中元素“0”所对应的BINT元素为“0”。
+ j# S) _5 g6 r$ l$ G9 Z/ H% B) p8 c0 g( g
REGRESS treats NaNs in X or Y as missing values, and removes them. REGRESS2 H# v4 s& y+ P7 i+ h+ M9 W3 e4 |
将X或者Y中的NaNs当作缺失值处理,并且移除它们。 |
