查看: 2090|回复: 6
[Cadence Sigrity] 请教 ibs 文件报错 如何解决 !急!!!
发表于 2010-5-21 10:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
allegro model integrity 打开ibs文件 出现以下错误:
+ y. w! u1 j3 m7 g: }ERROR - Model 'pvhsoscbrt_s_00_PADY' in Model Selector 'pvhsoscbrt_s_PADY_md' is not defined in the file. R: L+ l& P+ Q8 d! ]9 Y/ L2 [
ERROR - Model 'pvhsoscbrt_s_01_PADY' in Model Selector 'pvhsoscbrt_s_PADY_md' is not defined in the file
# F# c% V' q, z: F3 Q& PERROR - Model 'pvhsoscbrt_s_10_PADY' in Model Selector 'pvhsoscbrt_s_PADY_md' is not defined in the file
. F7 h# E2 `% Q8 e; @0 S% eERROR - Model 'pvhsoscbrt_s_11_PADY' in Model Selector 'pvhsoscbrt_s_PADY_md' is not defined in the file
7 r8 \- Y5 t; e- zERROR - Model 'pvhtbsudtafs_t_00' in Model Selector 'pvhtbsudtafs_t_model' is not defined in the file
& h8 Z0 A4 h4 ^. u/ d8 z8 cERROR - Model 'pvhtbsudtafs_t_01' in Model Selector 'pvhtbsudtafs_t_model' is not defined in the file, m1 R- j3 f  j  S/ t
ERROR - Model 'pvhtbsudtafs_t_10' in Model Selector 'pvhtbsudtafs_t_model' is not defined in the file( q, `/ h; y7 b
ERROR - Model 'pvhtbsudtafs_t_11' in Model Selector 'pvhtbsudtafs_t_model' is not defined in the file
( m* s, M0 r* W1 I' [; L2 yERROR - Model 'dqs_t_100_PADN' in Model Selector 'dqs_t_PADN_md' is not defined in the file
0 O: y$ O+ x# l- l& W  RERROR - Model 'dqs_t_101_PADN' in Model Selector 'dqs_t_PADN_md' is not defined in the file
; ]7 \$ z/ P9 O# {2 x1 r9 bERROR - Model 'dqs_t_110_PADN' in Model Selector 'dqs_t_PADN_md' is not defined in the file
1 u2 q6 v) a7 m; p$ j5 T' zERROR - Model 'dqs_t_111_PADN' in Model Selector 'dqs_t_PADN_md' is not defined in the file
# x" i7 F/ M- @, w3 A8 OERROR - Model 'pvhtbcudtafs_00' in Model Selector 'pvhtbcudtafs_model' is not defined in the file: B' i' w8 t) ]0 q
ERROR - Model 'pvhtbcudtafs_01' in Model Selector 'pvhtbcudtafs_model' is not defined in the file
8 `7 d7 N# ]5 g. R: f3 bERROR - Model 'pvhtbcudtafs_10' in Model Selector 'pvhtbcudtafs_model' is not defined in the file1 H# A, Y/ ~2 O+ ~4 ~1 [
ERROR - Model 'pvhtbcudtafs_11' in Model Selector 'pvhtbcudtafs_model' is not defined in the file
7 l8 v, ~, B- i  [  G2 h' G  Y: CERROR - Model 'pvhsosca_s_00_PADY' in Model Selector 'pvhsosca_s_PADY_md' is not defined in the file% e8 U: q4 c9 c' h
ERROR - Model 'pvhsosca_s_01_PADY' in Model Selector 'pvhsosca_s_PADY_md' is not defined in the file9 l* N, Z* ^: I3 F2 x% N
ERROR - Model 'pvhbsudtart_00' in Model Selector 'pvhbsudtart_model' is not defined in the file
! r6 l& r+ _; w& E3 E8 FERROR - Model 'pvhbsudtart_01' in Model Selector 'pvhbsudtart_model' is not defined in the file
) v4 W  D9 v' IERROR - Model 'pvhbsudtart_10' in Model Selector 'pvhbsudtart_model' is not defined in the file
7 e( U7 d& z# Z1 X, X& [0 I5 A$ kERROR - Model 'pvhbsudtart_11' in Model Selector 'pvhbsudtart_model' is not defined in the file
0 N/ S' p7 u% O  g" eERROR - Model 'dqs_t_100_PADP' in Model Selector 'dqs_t_PADP_md' is not defined in the file
% `# e* P+ t4 d- M8 hERROR - Model 'dqs_t_101_PADP' in Model Selector 'dqs_t_PADP_md' is not defined in the file/ u  n* M2 t' D# u1 n; m9 E
ERROR - Model 'dqs_t_110_PADP' in Model Selector 'dqs_t_PADP_md' is not defined in the file
# Z, y( |. D  ]5 }8 }0 E( xERROR - Model 'dqs_t_111_PADP' in Model Selector 'dqs_t_PADP_md' is not defined in the file  i3 g' e& Y- Y8 Y# H
ERROR - Model 'pvhbcudtcrt_t_00' in Model Selector 'pvhbcudtcrt_t_model' is not defined in the file  w2 q% U) q: z& W# k! @6 |
ERROR - Model 'pvhbcudtcrt_t_01' in Model Selector 'pvhbcudtcrt_t_model' is not defined in the file
4 e, A( H% m& j4 }/ a0 qERROR - Model 'pvhbcudtcrt_t_10' in Model Selector 'pvhbcudtcrt_t_model' is not defined in the file
* l+ y( d% H# T9 f8 IERROR - Model 'pvhbcudtcrt_t_11' in Model Selector 'pvhbcudtcrt_t_model' is not defined in the file
  u4 r+ f; `5 W2 H$ h& [ERROR - Model 'pvhbsudtcrt_t_00' in Model Selector 'pvhbsudtcrt_t_model' is not defined in the file/ A, F" D. z3 T' y% I
ERROR - Model 'pvhbsudtcrt_t_01' in Model Selector 'pvhbsudtcrt_t_model' is not defined in the file
& c6 X) W  q' G5 s, O/ u# ^ERROR - Model 'pvhbsudtcrt_t_10' in Model Selector 'pvhbsudtcrt_t_model' is not defined in the file
6 ]3 b6 A( J& [% W5 k8 h# \ERROR - Model 'pvhbsudtcrt_t_11' in Model Selector 'pvhbsudtcrt_t_model' is not defined in the file
; }" |1 h5 C0 |* Z% l; o. NERROR - Model 'pvhbcudtcrt_00' in Model Selector 'pvhbcudtcrt_model' is not defined in the file5 E, f5 e& E% k( h
ERROR - Model 'pvhbcudtcrt_01' in Model Selector 'pvhbcudtcrt_model' is not defined in the file
* N3 n' X- Q& W* QERROR - Model 'pvhbcudtcrt_10' in Model Selector 'pvhbcudtcrt_model' is not defined in the file: q/ |9 o& O! H" S
ERROR - Model 'pvhbcudtcrt_11' in Model Selector 'pvhbcudtcrt_model' is not defined in the file
9 u. m* Y3 y5 S8 G' G4 PERROR - Model 'pvhbsudtcrt_00' in Model Selector 'pvhbsudtcrt_model' is not defined in the file
( z2 t( J& Z, E: pERROR - Model 'pvhbsudtcrt_01' in Model Selector 'pvhbsudtcrt_model' is not defined in the file+ h; h/ P& k/ J
ERROR - Model 'pvhbsudtcrt_10' in Model Selector 'pvhbsudtcrt_model' is not defined in the file4 R" P1 |& K9 ^* P
ERROR - Model 'pvhbsudtcrt_11' in Model Selector 'pvhbsudtcrt_model' is not defined in the file
# b* F! K4 Q. U; q* W+ |% uERROR - Model 'pvhsoscbrt_00_PADY' in Model Selector 'pvhsoscbrt_PADY_md' is not defined in the file8 G+ X- V& e6 q! l, ^
ERROR - Model 'pvhsoscbrt_01_PADY' in Model Selector 'pvhsoscbrt_PADY_md' is not defined in the file
6 Y* R3 }& ]1 R: V- [ERROR - Model 'pvhsoscbrt_10_PADY' in Model Selector 'pvhsoscbrt_PADY_md' is not defined in the file
; V+ N; y9 I+ _( ]# ?  yERROR - Model 'pvhsoscbrt_11_PADY' in Model Selector 'pvhsoscbrt_PADY_md' is not defined in the file
1 M( A2 j& T7 d2 K# u* `ERROR - Model 'pvhbcudtcrt_s_00' in Model Selector 'pvhbcudtcrt_s_model' is not defined in the file
, A; P  [% P0 k9 r( HERROR - Model 'pvhbcudtcrt_s_01' in Model Selector 'pvhbcudtcrt_s_model' is not defined in the file
5 W' g1 Q" X9 z, h' sERROR - Model 'pvhbcudtcrt_s_10' in Model Selector 'pvhbcudtcrt_s_model' is not defined in the file# R1 B7 S8 m% K0 r0 J
ERROR - Model 'pvhbcudtcrt_s_11' in Model Selector 'pvhbcudtcrt_s_model' is not defined in the file2 `7 C" T/ r3 p4 |) V7 b
ERROR - Model 'pvhbsudtcrt_s_00' in Model Selector 'pvhbsudtcrt_s_model' is not defined in the file
1 I+ i+ D) x8 N* x+ |: e8 KERROR - Model 'pvhbsudtcrt_s_01' in Model Selector 'pvhbsudtcrt_s_model' is not defined in the file3 u# @% S- U& m2 E+ L
ERROR - Model 'pvhbsudtcrt_s_10' in Model Selector 'pvhbsudtcrt_s_model' is not defined in the file# S/ G  Q/ D8 ?+ H" N0 K
ERROR - Model 'pvhbsudtcrt_s_11' in Model Selector 'pvhbsudtcrt_s_model' is not defined in the file
8 I3 v+ [+ F1 X/ q$ ~) X6 nERROR - Model 'pvhbsudtbrt_t_00' in Model Selector 'pvhbsudtbrt_t_model' is not defined in the file5 |6 k( ?; v$ t$ `# z+ G7 w1 o: y  M
ERROR - Model 'pvhbsudtbrt_t_01' in Model Selector 'pvhbsudtbrt_t_model' is not defined in the file
+ f; B5 }  T3 C& ?& p) X% c' vERROR - Model 'pvhbsudtbrt_t_10' in Model Selector 'pvhbsudtbrt_t_model' is not defined in the file0 r2 t! T: V6 ?& o4 Q! `
ERROR - Model 'pvhbsudtbrt_t_11' in Model Selector 'pvhbsudtbrt_t_model' is not defined in the file
+ V! x! W- s0 N: j; t$ I% EERROR - Model 'pvhbsudtbrt_s_00' in Model Selector 'pvhbsudtbrt_s_model' is not defined in the file
5 M* I8 p: c& _7 G# Z7 O  B' W9 PERROR - Model 'pvhbsudtbrt_s_01' in Model Selector 'pvhbsudtbrt_s_model' is not defined in the file
9 B, e! b; |, N/ x% }; Y5 o1 FERROR - Model 'pvhbsudtbrt_s_10' in Model Selector 'pvhbsudtbrt_s_model' is not defined in the file$ E4 H/ r' `% g9 r  S$ c: N$ E3 e' B
ERROR - Model 'pvhbsudtbrt_s_11' in Model Selector 'pvhbsudtbrt_s_model' is not defined in the file
+ i5 k+ W% ^- K  ^ERROR - Model 'pvhsoscbrt_t_00_PADY' in Model Selector 'pvhsoscbrt_t_PADY_md' is not defined in the file
2 A: _2 W2 R6 I6 sERROR - Model 'pvhsoscbrt_t_01_PADY' in Model Selector 'pvhsoscbrt_t_PADY_md' is not defined in the file- u) o  k2 z2 j
ERROR - Model 'pvhsoscbrt_t_10_PADY' in Model Selector 'pvhsoscbrt_t_PADY_md' is not defined in the file0 b+ A# i% |$ c( |# Y
ERROR - Model 'pvhsoscbrt_t_11_PADY' in Model Selector 'pvhsoscbrt_t_PADY_md' is not defined in the file( L3 J7 w" y7 `
ERROR - Model 'dqs_s_100_PADP' in Model Selector 'dqs_s_md' is not defined in the file
% ?- @% k, ^: g3 lERROR - Model 'dqs_s_101_PADP' in Model Selector 'dqs_s_md' is not defined in the file
6 u; u. e/ v$ [ERROR - Model 'dqs_s_110_PADP' in Model Selector 'dqs_s_md' is not defined in the file
- v9 \) E8 W7 J  V& X' M& hERROR - Model 'dqs_s_111_PADP' in Model Selector 'dqs_s_md' is not defined in the file" E; ^  v, N* @/ k" `
ERROR - Model 'pvhbcudtbrt_s_00' in Model Selector 'pvhbcudtbrt_s_model' is not defined in the file/ H2 T; M; W1 P& p) H
ERROR - Model 'pvhbcudtbrt_s_01' in Model Selector 'pvhbcudtbrt_s_model' is not defined in the file
4 s( ^0 _  U' Q7 D& o7 pERROR - Model 'pvhbcudtbrt_s_10' in Model Selector 'pvhbcudtbrt_s_model' is not defined in the file! N% P/ U+ T; M# z9 O, r
ERROR - Model 'pvhbcudtbrt_s_11' in Model Selector 'pvhbcudtbrt_s_model' is not defined in the file
% h0 n* w0 a6 I4 @' T' @$ PERROR - Model 'pvhbcudtbrt_t_00' in Model Selector 'pvhbcudtbrt_t_model' is not defined in the file
; P; W0 \* @2 c! b- V. ]ERROR - Model 'pvhbcudtbrt_t_01' in Model Selector 'pvhbcudtbrt_t_model' is not defined in the file( A) u9 u( `7 s! t; v; V# f
ERROR - Model 'pvhbcudtbrt_t_10' in Model Selector 'pvhbcudtbrt_t_model' is not defined in the file) x( J0 g. t- ^: e/ m" P
ERROR - Model 'pvhbcudtbrt_t_11' in Model Selector 'pvhbcudtbrt_t_model' is not defined in the file( @7 O8 Q8 O/ I8 W
ERROR - Model 'pvhbcudtbrt_00' in Model Selector 'pvhbcudtbrt_model' is not defined in the file, I1 f1 S6 ~+ p# F5 J5 }
ERROR - Model 'pvhbcudtbrt_01' in Model Selector 'pvhbcudtbrt_model' is not defined in the file4 _, q' p  N. l, x) P$ _' [1 M6 l
ERROR - Model 'pvhbcudtbrt_10' in Model Selector 'pvhbcudtbrt_model' is not defined in the file
8 O; @- B0 I# }' |% l" _+ @ERROR - Model 'pvhbcudtbrt_11' in Model Selector 'pvhbcudtbrt_model' is not defined in the file
5 V6 a7 J$ N% QERROR - Model 'pvhbsudtbrt_00' in Model Selector 'pvhbsudtbrt_model' is not defined in the file
& c. P5 A6 \( U6 ]' EERROR - Model 'pvhbsudtbrt_01' in Model Selector 'pvhbsudtbrt_model' is not defined in the file+ c; B9 s. c' o; C5 m" I- D
ERROR - Model 'pvhbsudtbrt_10' in Model Selector 'pvhbsudtbrt_model' is not defined in the file
5 N1 R8 F/ @' u5 E1 bERROR - Model 'pvhbsudtbrt_11' in Model Selector 'pvhbsudtbrt_model' is not defined in the file
. d6 A4 \; W3 i: gERROR - Model 'dqs_s_100_PADN' in Model Selector 'dqs_s_PADN_md' is not defined in the file5 D7 c) h2 j- l9 U
ERROR - Model 'dqs_s_101_PADN' in Model Selector 'dqs_s_PADN_md' is not defined in the file! f. ?) c! r) W- H) ]
ERROR - Model 'dqs_s_110_PADN' in Model Selector 'dqs_s_PADN_md' is not defined in the file
1 z; h9 h* D( }, H& `ERROR - Model 'dqs_s_111_PADN' in Model Selector 'dqs_s_PADN_md' is not defined in the file4 h5 f; r7 K0 ~7 t4 j
ERROR - Model 'pvhsosca_t_00_PADY' in Model Selector 'pvhsosca_t_PADY_md' is not defined in the file- O7 D4 }! ~  e' `+ C
ERROR - Model 'pvhsosca_t_01_PADY' in Model Selector 'pvhsosca_t_PADY_md' is not defined in the file3 M8 L4 l! Y9 x3 L9 q  q
ERROR - Model 'pvhtbsudtafs_00' in Model Selector 'pvhtbsudtafs_model' is not defined in the file! L: _2 F& I) g' J8 n
ERROR - Model 'pvhtbsudtafs_01' in Model Selector 'pvhtbsudtafs_model' is not defined in the file
: i- p# Q7 v/ ]! t5 C& f3 w$ c2 cERROR - Model 'pvhtbsudtafs_10' in Model Selector 'pvhtbsudtafs_model' is not defined in the file# ~, K0 l* v, s1 n7 h
ERROR - Model 'pvhtbsudtafs_11' in Model Selector 'pvhtbsudtafs_model' is not defined in the file& Q, i( K  t/ c+ j
ERROR - Model 'dqs_s_100_PADP' in Model Selector 'dqs_s_PADP_md' is not defined in the file
6 x4 g1 U0 g8 e3 e( `/ d/ i3 mERROR - Model 'dqs_s_101_PADP' in Model Selector 'dqs_s_PADP_md' is not defined in the file5 l# h3 G5 K, `
ERROR - Model 'dqs_s_110_PADP' in Model Selector 'dqs_s_PADP_md' is not defined in the file
" ?! K' ^: l0 G. b2 |ERROR - Model 'dqs_s_111_PADP' in Model Selector 'dqs_s_PADP_md' is not defined in the file1 [0 }5 i" x2 Y( F
ERROR - Model 'pvhtbcudtafs_t_00' in Model Selector 'pvhtbcudtafs_t_model' is not defined in the file7 `6 |* r: l0 q; ]: |& y
ERROR - Model 'pvhtbcudtafs_t_01' in Model Selector 'pvhtbcudtafs_t_model' is not defined in the file
4 c! }! i9 x& XERROR - Model 'pvhtbcudtafs_t_10' in Model Selector 'pvhtbcudtafs_t_model' is not defined in the file+ e/ G& ]5 B/ V8 p7 h7 `2 w' q
ERROR - Model 'pvhtbcudtafs_t_11' in Model Selector 'pvhtbcudtafs_t_model' is not defined in the file5 [& v4 M( \# S# K: l; q# ]
ERROR - Model 'pvhsosca_00_PADY' in Model Selector 'pvhsosca_PADY_md' is not defined in the file" N$ P5 I4 ~! V; S
ERROR - Model 'pvhsosca_01_PADY' in Model Selector 'pvhsosca_PADY_md' is not defined in the file4 I8 I9 k) F0 @0 H4 c. R
ERROR - Model 'pvhtbcudtafs_s_00' in Model Selector 'pvhtbcudtafs_s_model' is not defined in the file& @  b- n- K8 I, k# @" F
ERROR - Model 'pvhtbcudtafs_s_01' in Model Selector 'pvhtbcudtafs_s_model' is not defined in the file: W$ N  [/ w( s8 ]# }4 e8 H# v: l
ERROR - Model 'pvhtbcudtafs_s_10' in Model Selector 'pvhtbcudtafs_s_model' is not defined in the file
; \2 _5 [2 P# O6 C$ `/ Y; W' UERROR - Model 'pvhtbcudtafs_s_11' in Model Selector 'pvhtbcudtafs_s_model' is not defined in the file# |) h* o0 P+ a- l+ s
ERROR - Model 'pvhtbsudtafs_s_00' in Model Selector 'pvhtbsudtafs_s_model' is not defined in the file5 x$ R& ?: e/ z. O4 m0 O/ F
ERROR - Model 'pvhtbsudtafs_s_01' in Model Selector 'pvhtbsudtafs_s_model' is not defined in the file
, `) b. U* \6 p" N) W8 X& BERROR - Model 'pvhtbsudtafs_s_10' in Model Selector 'pvhtbsudtafs_s_model' is not defined in the file% z' O- n: Z7 l+ l7 ]
ERROR - Model 'pvhtbsudtafs_s_11' in Model Selector 'pvhtbsudtafs_s_model' is not defined in the file
, @1 c; B( l4 N8 @3 e0 f9 g% xErrors  : 114- D- Y, x/ s& s3 m) E" h
Warnings: 5
' O, x' _; _* N! A+ qFile Failed
# `5 k3 `: i+ q- F' V# Z该如何解决,多谢,期待高手回帖!
 楼主| 发表于 2010-5-21 13:26 | 只看该作者
没人帮忙吗 版主帮看下啊 ! 多谢
发表于 2010-5-21 13:49 | 只看该作者
你修改过模型么?'pvhtbsudtafs_s_model' 没有定义
 楼主| 发表于 2010-5-21 14:02 | 只看该作者
没修改过
 楼主| 发表于 2010-5-21 14:03 | 只看该作者
给我的时候就是这样子,厂家的技术支持说用HyperLynx打开没问题,我的版本16.3,ibs文件3.20 会是版本的问题吗
发表于 2010-5-21 19:25 | 只看该作者
传上来看看
 楼主| 发表于 2010-5-21 22:48 | 只看该作者
已解决,继续前行,多谢各位帮助,等做完了整理个文档出来
GMT+8, 2025-10-25 19:58 , Processed in 0.156250 second(s), 24 queries , Gzip On.
