查看: 333|回复: 2
1-4节锂电池充电同步降压 内置mos IC
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2020-4-8 14:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    General Description
    " U. @2 |2 j1 A6 Z1 S$ i: CThe ZCC6688 is a 3A Li-Ion battery charger. It utilizes
    % g) Q) V! O9 Ia 500KHz synchronous buck converter topology to
    ! C- @0 a2 C) zreduce power dissipation during charging. Low power
    ' _8 \  O& }) Ydissipation, an internal MOSFET allow a physically / Z" ^' X$ ^' J  c" V- Z3 [
    small charger that can be embedded in a wide range 9 n* C/ L" j8 c/ f8 w
    of handheld applications. The ZCC6688 includes , }6 \* H8 C3 o: C6 P
    complete charge termination circuitry, automatic
    ' h4 r# N- s! n9 P. Y4 v. Trecharge and a ±1% 4.2V /8.4V /12.6V /16.8V float + l+ t; w% K- v6 h5 D( f, x7 ]2 w
    voltage. ! s) J. c9 v9 K! Q  |+ C4 o3 |
    Battery charge current, charge timeout and end-of-
    - H2 a+ x+ U3 W9 S. G/ H$ t" n8 z! Vcharge indication parameters are set with external
    ( l$ w5 C8 {2 Z9 N2 K' L. I$ Jcomponents. Additional features include shorted cell + X/ d. ~- j& F  Q( O% T
    detection; temperature qualified 0 T" ~" ?! x) F' J3 S3 D
    charging and . {$ k$ {# i' W! w
    overvoltage protection. The ZCC6688 is available in a
    8 V* o5 U8 L9 M& Flow profile ESSOP10 package.
    ( G# T4 l& Q2 }" zFeatures
    0 R4 @! D9 N# P' p" c Input voltage range 4V~22V
    ) Y* C0 N$ w- r7 H/ V) D  J Dynamic input current allocation for maximum
    # O$ e# N3 A8 ^: acharging rate
    + o1 L& W1 D0 g0 z! ^* q8 x, c' B 3.0A Maximum Charge Current # ?0 L6 C$ L5 ]( m
     No External MOSFETs and Blocking Diode
    6 k, J7 f$ C: G- rRequired 7 d% R1 J- S* J4 U+ C; g
     Efficiency up to 90% + P: a+ s; N5 L4 x1 C
     Constant-Current/Constant-Voltage Operation
    7 t2 D2 P8 g! Q0 t2 ?  Gwith Thermal Regulation to Maximize Charge
    * z; c& O6 d: N5 ^' IRate Without Risk of Overheating ' i- f  k2 C3 Z
     Optional Battery Temperature Monitoring Before
    : r& k% y* ]. R9 Aand During Charge Automatic Sleep Mode for 3 a$ ?& v0 W% z+ C
    Low-Power
    8 }' d: y3 P4 g$ m: Y Over Current Protection ) U9 E7 q! z# o6 K
     Consumption Available in ESSOP10
    * d/ ~2 }* ?1 v9 ~% O, W RoHS Compliant and 100% Lead (Pb)-Free
    / W) T7 o$ {3 Z. y7 Q6 U3 k ZCC6688 V2.3.pdf (1020.45 KB, 下载次数: 0)
    5 a- Q' n) ]: @2 p6 C
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
     楼主| 发表于 2020-4-8 18:09 | 只看该作者
    helendcany 发表于 2020-4-8 18:06
      E0 Y, V$ }; [& G5 h$ U- u, Y看看。
    ; N% n0 R9 g* h) ~* Y5 T7 w3 m
    2 a7 }: q* Z& ]4 z* A+ k! q
    GMT+8, 2025-10-27 12:34 , Processed in 0.156250 second(s), 26 queries , Gzip On.
