利用MATLAB绘制双 X 轴曲线
6 {) L0 j0 G1 s
# ~8 O1 m- N- z) t该函数调用格式为:" p5 O" s8 n6 B0 R- ~
+ _1 i, N" L; c6 Y, {[ax,hl1,hl2] = plotxx(x1,y1,x2,y2,xlabels,ylabels);
% ^- b9 c# ?, \) c* e: c- b! |* y( _, B7 u+ M0 W: Q2 J- F( T
参数说明:
3 M3 F- M3 V; i: n) q- X' y# p% x% m; X, [
ax是坐标轴的句柄。h1 和 h2 是两条曲线的句柄。x1,y1,x2,y2 是绘图数据。Xlabels,Ylabels是X轴和Y州标注内容对应的细胞结构。4 C1 d8 E' H W% K$ y
) t8 S5 L) A! @. X6 N1 F例:2 `5 h# G, n* e' U
% ?: G6 H7 d& d5 e! e5 K1 M+ k
D = linspace(-100,0,50);%Y轴数据0 H* N- n8 P2 A: Y
S = linspace(34,32,50);%上侧X轴数据2 E, F0 D1 B% F! i( r2 S7 A8 A6 b+ M
T = 10*exp(D/40);%下侧X轴数据
& b' ]6 G7 x: ]/ l. {6 |xlabels{1} = 'Temperature (C)';%下侧X轴内容标注7 }2 v: h4 g8 u) I% F; ^, [
xlabels{2} = 'Salinity';%上侧X轴内容标注
+ v2 j+ A5 A* P% `ylabels{1} = 'Depth(m)';%左侧Y轴内容标注
9 s( ?& t6 W$ {ylabels{2} = 'Depth(m)';%右侧Y轴内容标注
* R, }% Q# }4 w2 n# `) m" m) G* {[ax,hlT,hlS] = plotxx(T,D,S,D,xlabels,ylabels);%绘制双X轴曲线( M% b) R# L2 N* o
0 v/ O; r1 R( X+ O, \5 {2 N: V' U/ i: s
4 Q' C/ h4 m6 _5 B; v/ E+ X, H' w+ D# C& O
. Y9 a! G. q+ S6 l0 o2 x附件:plotxx.m2 T" c$ ]! a' N+ }0 h
- }$ Q* i) n' F( K! z
function [ax,hl1,hl2] = plotxx(x1,y1,x2,y2,xlabels,ylabels);
. [& C" A1 }5 g3 u, ?( ^0 n9 H%PLOTXX - Create graphs with x axes on both top and bottom , U- o3 D* x' L) V, P/ [* H: R
%/ L% g" z: M" _ W8 L
%Similar to PLOTYY, but ...$ s# i# r' u# E9 X Q. s
%the independent variable is on the y-axis, & R3 ]" m9 k6 Y) E3 [% O
%and both dependent variables are on the x-axis.& F. f, M0 ?2 P2 H% t
" J! a% s. B$ V) r%Syntax: [ax,hl1,hl2] = plotxx(x1,y1,x2,y2,xlabels,ylabels);0 T4 b- P( i+ l* s* U+ t0 }7 d6 I
( H c8 u! R' g% j% _%Inputs: X1,Y1 are the data for the first line (black)$ T2 E0 B7 e+ A4 W. d! ?
% X2,Y2 are the data for the second line (red)
3 w* n# u) ]0 `; o* J! N% XLABELS is a cell array containing the two x-labels
! u, X( @3 ?7 r3 [8 m+ i* f- C% YLABELS is a cell array containing the two y-labels0 j& V4 x- G; n- Q5 `
%' q/ G% ]- @* W- W) r+ i7 r; m
%The optional output handle graphics objects AX,HL1,HL25 |* F. j! x( V- G9 e! N# ?
%allow the user to easily change the properties of the plot.
: A, u6 c! |: G+ E/ P, p4 w5 M%2 k$ B6 w. Z/ l. H2 m1 `. t
%Example: Plot temperature T and salinity S
* i: z' ^3 G3 J. ?! O% as a function of depth D in the ocean$ u5 D' `% i- K6 ~
/ I3 n$ w- l( Z- U$ H7 Y%D = linspace(-100,0,50);
, F7 S. q$ g2 t" O* Q+ D5 N%S = linspace(34,32,50);. K0 q+ ~6 V: B8 {
%T = 10*exp(D/40);
) U: w1 z/ d Y7 Z% X" K%xlabels{1} = 'Temperature (C)';
5 O( O# J% ~" D%xlabels{2} = 'Salinity';& M d( T% h f3 a+ i) Y: q/ B B
%ylabels{1} = 'Depth(m)';
5 c/ ?, l9 R+ y R! X%ylabels{2} = 'Depth(m)';
9 z. ], }2 G9 H: U1 t. [%[ax,hlT,hlS] = plotxx(T,D,S,D,xlabels,ylabels);- y; q) n( m0 h5 G6 A- M
8 l6 d) }8 h2 C0 c/ J3 B( P
$ V9 a6 y3 j. t) f R, E( ~% b%The code is inspired from page 10-26 (Multiaxis axes)& |- P2 a$ L8 V5 ?. r. _8 f
%of the manual USING MATLAB GRAPHICS, version 5.6 Q. G6 M/ k' s/ f* G9 o
% X: J5 p5 G# L g1 D9 u% X%Tested with Matlab 5.3.1 and above on PCWIN
8 m$ e+ L' E* Z& c6 y
$ N- Q2 s% c9 w# d%Author: Denis Gilbert, Ph.D., physical oceanography
) N; f8 Q' s& G0 c' {5 k%Maurice Lamontagne Institute, Dept. of Fisheries and Oceans Canada$ p# V* T0 X( H% x" y* Q+ L w9 V
%email: Web: http://www.qc.dfo-mpo.gc.ca/iml/
- `. h5 A: a; o%November 1997; Last revision: 01-Nov-2001
# R0 K3 G z3 K$ [
2 ]' S+ D. G5 q. c6 I0 I1 fif nargin < 4! f6 o# q( L! T# O% K
error('Not enough input arguments')% X0 B4 A8 t& N; _1 Q
elseif nargin==4
. a* D' v' ^& {: G* n7 _ %Use empty strings for the xlabels1 k9 u. Y. y# k0 V k: @0 r
xlabels{1}=' '; xlabels{2}=' '; ylabels{1}=' '; ylabels{2}=' ';# u9 q$ @) l& Q. K9 M/ @( n, P
elseif nargin==5; Z& q2 y. A) q$ z
%Use empty strings for the ylabel
- W* l' N/ V7 t) s ylabels{1}=' '; ylabels{2}=' ';
5 Q5 \8 [& T( i- n# xelseif nargin > 6
, q7 M* G5 L# R% Q* B( q0 `2 H error('Too many input arguments'), Y2 `' n+ X( u, g$ u' \" y
end. r- }1 G, C, X- M( n! b+ y- t/ d
0 D! |6 d: }% _4 b5 x5 Sif length(ylabels) == 16 r- B$ I% K6 g+ J7 I
ylabels{2} = ' ';
# A, g/ z5 o) t( j) {# Mend
; F1 `* C' [! g2 E2 i
! Z* _# S; ?6 X" y- mif ~iscellstr(xlabels)
; k. y, @- T# e# |0 N. { error('Input xlabels must be a cell array'); N% p7 G$ h& D s: Z
elseif ~iscellstr(ylabels)
6 t3 P( D2 k5 @6 q! o error('Input ylabels must be a cell array')3 A3 i) N6 q2 ], q
end0 I) i7 t4 P% l
7 W2 u9 P/ R5 d4 l! C
hl1=line(x1,y1,'Color','k');
! u) O3 [- I2 z! v* i9 uax(1)=gca;8 X- N: a% d- M( m
set(ax(1),'Position',[0.12 0.12 0.75 0.70])
$ h0 y+ C2 _; _! uset(ax(1),'XColor','k','YColor','k');( `0 ^- y9 H) ?! \
/ Q0 D* ~$ }+ @
ax(2)=axes('Position',get(ax(1),'Position'),...
) R: A/ `* O5 P$ O% o% f. o 'XAxisLocation','top',...
1 C5 n/ @& @; f) f3 h 'YAxisLocation','right',...
, ]! q5 h8 A1 F- } 'Color','none',...
, k6 F/ e' b1 P 'XColor','r','YColor','k');; ^. ]! y8 { u& P; r
1 f# n) @1 p; k- i+ n3 {2 s8 S
set(ax,'box','off')
) j6 n4 a# [' o: H1 v$ N, T! v7 K- W7 j
hl2=line(x2,y2,'Color','r','Parent',ax(2));
* u3 _' J# c9 e( j$ ^+ s$ ?5 ~4 u$ `/ s3 e
%label the two x-axes
. C" F; O( ?7 G1 J' oset(get(ax(1),'xlabel'),'string',xlabels{1})
# W4 ^# z/ j: ^9 z! i( mset(get(ax(2),'xlabel'),'string',xlabels{2})' | e1 v; O1 G! ?, o
set(get(ax(1),'ylabel'),'string',ylabels{1})
0 `% u* b% n7 V3 \& j: xset(get(ax(2),'ylabel'),'string',ylabels{2})3 S' E" | A$ c% M2 ~( W9 x
$ u$ k4 H& n9 Z
4 P, X2 J' Q, [2 P& ^) F: z
, B: y9 g- Z% o%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%2 R- r3 O7 I+ q
) I& R. O$ h7 n% |7 P( v
另一种要求:只画一条曲线,但要求标注上下两个x轴的坐标% L+ g5 V; W$ `
3 W+ Y7 b& W, B# `http://www.ilovematlab.cn/forum.php?mod=viewthread&tid=104483
, c" c% r. a- n) m3 W$ n/ h6 a; e" }% P, A
或者: ^6 ~, R2 I3 a+ W' n4 h
, s. ^* }- A4 Y9 Xx1 = [0:.1:40];
n% p. d3 d N* X5 ?$ Uy1 = 4.*cos(x1)./(x1+2);
9 B: m$ F: S% |. z8 d% ]x2 = [1:.2:20];
8 c/ m+ T! Q$ e5 X! M6 D$ T! Ky2 = x2.^2./x2.^3;4 b! |$ _" j& M! \6 ?# Y
3 ~6 g1 g" o' Q0 xhl1 = plot(x1,y1,'Color','r');
+ y/ d6 z1 e/ N, ?0 r! Q" X2 E. pax1 = gca;& r# R6 R( S6 f. [& P; X! |( q- A
set(ax1,'XColor','r','YColor','r')
, i, c5 C7 b3 P# p
+ q3 N$ s) P8 _% d7 m Cax2 = axes('Position',get(ax1,'Position'),...0 l- f% I, h4 f/ t. d. J2 h
+ j/ Y8 F% s" ~ 'YAxisLocation','right',...* t' E( ~# a9 `: t
'Color','none',...
2 T+ z! e; Z! r! M; i: X& L# g 'XColor','k','YColor','k');
7 r8 p7 A; O4 M e9 m0 @! _+ E3 j$ J# ~8 g3 t- q1 g& `8 f( k
. ? W5 c% d/ r0 d0 t8 Q
hl2 = line(x2,y2,'Color','k','Parent',ax2);& S/ ?1 ?1 T% q9 z9 L4 U: g
