PCB专业英译术语
# c1 p [- n! ]& h5 W4 A
5 {; J' ^# _ `7 e一、 综合词汇% j% c6 X. ~9 k6 i9 G3 U
1、 印制电路:printed circuit6 k' a) k1 I/ F
2、 印制线路:printed wiring
7 L/ _! C8 F0 `) \" z3、 印制板:printed board: N/ p, V) ~7 P7 s& I
8 b9 @( o1 o$ x8 i: o4、 印制板电路:printed circuit board (PCB)( ?! I' y9 o' U3 }
% W0 x7 n+ a2 x# |, e! v5、 印制线路板:printed wiring board(PWB)
; o5 V/ I% B. z6、 印制组件:printed component7 X! J/ s1 y; w s+ I
7、 印制接点:printed contact0 o) B) G# {! e6 a1 U+ h* `5 H7 I6 ?
8、 印制板装配:printed board assembly1 Z9 V- F& ]& f/ V' Y
+ a8 x$ e y+ i5 _" f, b- r: ]9、 板:board
, X% P, k, Q' I, f( D10、 单面印制板:single-sided printed board(SSB)
! g, r9 R% [: }. @* J5 M$ E11、 双面印制板:double-sided printed board(DSB)) `/ N/ o! a0 G4 i; N
12、 多层印制板:mulitlayer printed board(MLB)# n. t2 V) e, g: H- U8 g
' K$ B+ w- u" c1 Q2 d- Q4 v13、 多层印制电路板:mulitlayer printed circuit board$ w1 |# r7 A5 J# ~( g
14、 多层印制线路板:mulitlayer prited wiring board% s" p/ t; B3 r* H0 q; A
3 V! { f; e% L! ]15、 刚性印制板:rigid printed board4 |- F+ g ^/ m, M8 C
: S1 T0 Q8 q4 J% }7 E9 n; ^4 Y* `" z16、 刚性单面印制板:rigid single-sided printed borad9 D5 ?9 ]$ b% S- _, d8 _
17、 刚性双面印制板:rigid double-sided printed borad" R/ D) P( ?6 p' _
18、 刚性多层印制板:rigid multilayer printed board
5 t: v( N0 ^9 F7 C _, o. [6 O+ ?( {19、 挠性多层印制板:flexible multilayer printed board& M2 r8 X" p" w
20、 挠性印制板:flexible printed board0 D9 R$ D1 Z! w4 h! n
21、 挠性单面印制板:flexible single-sided printed board3 X8 O2 y! Q* J( W! g$ h
22、 挠性双面印制板:flexible double-sided printed board% F* N! r ]& T5 M
( `8 b' G5 m \8 o23、 挠性印制电路:flexible printed circuit (FPC)" i' F; B# k( L( o0 M. c
24、 挠性印制线路:flexible printed wiring. f; d. i7 \: e: K2 U6 G
25、 刚性印制板:flex-rigid printed board, rigid-flex printed board7 S' V3 w1 |% @9 z% \" \; O$ y
26、 刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed
|' E, Y1 q' D9 w+ ]27、 刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board
G9 @+ v* z+ ~' T* X" r! x% b( W28、 齐平印制板:flush printed board, i7 r5 `& Z7 V1 f n9 h8 ^% O
# o* D4 I; Q: o9 o29、 金属芯印制板:metal core printed board) [9 ^1 E4 Q7 d
# y7 k9 h5 m5 [9 K+ E* t30、 金属基印制板:metal base printed board" h* n9 K t1 |+ m5 e- @& W
31、 多重布线印制板:mulit-wiring printed board0 c: Q- V1 F, J: c6 C9 a% ~6 \& J" g8 a s
32、 陶瓷印制板:ceramic substrate printed board7 A1 T7 g+ M1 `1 p7 o Y v
33、 导电胶印制板:electroconductive paste printed board4 |# D: N: g/ V1 s2 ~9 W8 i" Z' A( b8 f
34、 模塑电路板:molded circuit board% `) B0 a& g* _8 n/ n9 J& x
- B- g& k$ }* C! X! ?3 D3 A0 j* u35、 模压印制板:stamped printed wiring board1 D8 U y/ f& `
36、 顺序层压多层印制板:sequentially-laminated mulitlayer9 t# p# O" A! u2 }
37、 散线印制板:discrete wiring board& \/ R# D/ K) E6 w. H1 s
9 V% r7 q% O1 [38、 微线印制板:micro wire board
. j% y- E8 }* ?) j39、 积层印制板:buile-up printed board `- |, S$ V, b5 v* o8 Z3 u
3 K; _+ O9 r6 S8 f40、 积层多层印制板:build-up mulitlayer printed board (BUM)9 {4 B, Q8 j* a; _& k4 e: D M, F
) h/ _5 r" F F; L: {! o# ]. j41、 积层挠印制板:build-up flexible printed board, j d" R$ H0 R i, W; r% K
: @' s% R/ _/ w) F( I# L/ c42、 表面层合电路板:suRFace laminar circuit (SLC)" x- S8 |" S1 ]! }$ P) N! v1 o0 ~: y4 G
43、 埋入凸块连印制板:B2it printed board& d& ^# G" ]- |8 y, s# K
44、 多层膜基板:multi-layered film substrate(MFS)
) Y+ h# j. V; Q% L0 g45、 层间全内导通多层印制板:ALIVH multilayer printed board
$ S: [* @- y8 ]1 L8 L46、 载芯片板:chip on board (COB)
- |4 X2 W. M' M) I; {1 _3 q; L6 D9 f7 T47、 埋电阻板:buried resistance board; y" T& _. d9 Y y" n
9 o w$ u/ |3 W' M& E- s48、 母板:mother board
+ |. f1 H, O$ o& b49、 子板:daughter board8 m2 I* U3 z6 V* i- n! V5 Q. ~# ]2 I7 n& w4 [: B% w
50、 背板:backplane- N# s6 T4 W2 W# b0 \# ]5 ?" f' {- N; V/ z* a
51、 裸板:bare board% t l- K/ E1 Y" O9 b; B# v% b
52、 键盘板夹心板:copper-invar-copper board2 X W: T/ q) J9 c2 y- i4 h* @2 d5 i4 H% g
53、 动态挠性板:dynamic flex board, C+ X$ h+ j7 {! ]3 i4 S2 |5 b+ h( u- k2 _
54、 静态挠性板:static flex board) u9 Y8 F" a% s( a: h; L) }3 ~5 c
55、 可断拼板:break-away planel# d0 ]% e5 v1 l+ k- Z- R- m3 t8 @ @8 _8 |- v- f" ]( x3 \. W3 L! g0 e
56、 电缆:cable+ r* B+ U( ^ U# g4 J
+ p; S+ ?2 M5 j57、 挠性扁平电缆:flexible flat cable (FFC)9 G; D0 l6 t/ o/ T5 q9 c, ~3 i# u* d! d. h$ }! m; c7 N
58、 薄膜开关:membrane switch
9 f2 Z& b4 j+ [( ]& }59、 混合电路:hybrid circuit
$ S# y# D5 j- |8 i9 a4 K; T2 `60、 厚膜:thick film
& m: S5 g5 l- f9 o4 ^7 T61、 厚膜电路:thick film circuit
B: v# h' x Y- n, R2 l62、 薄膜:thin film" V f* x+ p; P' [# c. q% _9 E' _
, _) W8 p' b* ~) V" o/ f63、 薄膜混合电路:thin film hybrid circuit0 M8 a% d+ P# q+ q4 C( ~4 R. T4 U9 g2 [" L1 @8 Q
64、 互连:interconnection, @$ ^" G. W" p( u( h# ?. r4 ~2 F I; Q# p3 H
65、 导线:conductor trace line) Z6 C: G7 S: C7 N
5 |# B/ J- O- R, Z6 b0 I/ a- |8 j66、 齐平导线:flush conductor
2 k' I( J: r: `" G67、 传输线:transmission line8 F/ |5 M& g* ^1 U4 ]% M! J
; K/ I! ~' [! j0 L: b: P/ r# k68、 跨交:crossover {% b6 J; h2 V c& ~8 S, T; b
+ k* n0 F. ^4 Q. b$ J69、 板边插头:edge-board contact4 Q1 p) ~# i6 p9 D& [: @ ?+ y$ Y
4 I" e3 o, J% q: u. A+ s3 F70、 增强板:stiffener
# l6 e Y) N0 l, c71、 基底:substrate
' w3 |; k7 w0 ~% N! L) S$ z72、 基板面:real estate) O( t5 g& b# I, ]( m$ i
# ~8 E& y. ^% J6 }( W% d/ L73、 导线面:conductor side
2 J+ q; ?1 K) m/ _$ g74、 组件面:component side
! k2 @1 s$ m" I0 u75、 焊接面:solder side
6 C& Y* L6 x& ?5 L76、 印制:printing
6 K1 j! E' z( ]& c# k% k- v# A77、 网格:grid! N. w# b, W' Y1 O# Z" @. o, ]+ m1 V; t) }
78、 图形:pattern
. P z' A2 e3 Z79、 导电图形:conductive pattern$ z- L5 x3 n% I( k# ~/ S
1 H! P0 p" O: J4 J4 k0 V80、 非导电图形:non-conductive pattern O' y: Y7 g# C: t* ~; o
81、 字符:legend3 E. O9 N9 v4 C2 r& ~
82、 标志:mark* l" @8 p5 T1 B% q( @* c: g4 f$ K9 F3 [3 k1 r
6 D8 D* h$ |: }+ Q3 b
4 ^ w3 A6 O: j/ V4 \3 b二、 基材: t, ^8 V( u; H" F
1、 基材:base material
7 }% V; f5 j& G- x2 k/ ?2、 层压板:laminate
0 q$ f! w; o6 t5 D% K3、 覆金属箔基材:metal-clad bade material( D, Q: B/ r9 ^8 X0 H! {
% V+ }- q: P) Z, u+ |4、 覆铜箔层压板:copper-clad laminate (CCL)
, J& z% J4 E! o0 Q5、 单面覆铜箔层压板:single-sided copper-clad laminate
$ t6 G2 C+ T4 X# M e' G$ l6、 双面覆铜箔层压板:double-sided copper-clad laminate, _% x( E" `( t; k$ F6 J6 Y# Y7 L$ L/ v. k
7、 复合层压板:composite laminate( K! v' A/ j1 Q5 ]6 P7 o5 u7 A* v& r8 d" G Z8 b: _
8、 薄层压板:thin laminate8 ]( d- F9 W1 R& C; G5 s7 I/ M* q8 @/ v5 U
9、 金属芯覆铜箔层压板:metal core copper-clad laminate7 l1 J& g) x, Q+ q$ Z
9 O8 ` P2 D- P10、 金属基覆铜层压板:metal base copper-clad laminate
$ o! a# A+ c/ F8 @. o0 o11、 挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film
/ X( g1 P- m7 k; u9 T& l12、 基体材料:basis material" E5 |& q' H. x; ^3 N% G9 o
13、 预浸材料:prepreg
) Y5 [- h" \& u1 c; l14、 粘结片:bonding sheet& z) S, f, U/ T2 P* R7 j5 J2 R
15、 预浸粘结片:preimpregnated bonding sheer8 D- n8 P+ n* o! }( ]8 Z! t
' a/ `' Y" F9 ^3 h' J16、 环氧玻璃基板:epoxy glass substrate( C" K, P5 F7 O! K% U7 \
17、 加成法用层压板:laminate for additive process$ U% B7 a- K2 F' L" Z% W
18、 预制内层覆箔板:mass lamination panel- y9 \& B$ S1 D: R
/ r: y& F# v. _# b. B19、 内层芯板:core material/ q# x' L6 E, N
8 L' W) Z$ @3 p) n20、 催化板材:catalyzed board ,coated catalyzed laminate+ w' R& G: N8 G) V4 ~
21、 涂胶催化层压板:adhesive-coated catalyzed laminate
$ ] t8 g8 P( ~3 z22、 涂胶无催层压板:adhesive-coated uncatalyzed laminate7 w; v4 h/ l0 d7 m) d: D7 r! u
( Y6 X+ u7 B+ r, l6 c* L23、 粘结层:bonding layer3 I2 P" B. f8 b7 N" P
' {! I4 M) w0 f8 j' E& Z24、 粘结膜:film adhesive1 t: s3 A) z7 z6 }( c% u
25、 涂胶粘剂绝缘薄膜:adhesive coated dielectric film1 R4 T! x% z3 ^: X$ C' w* h9 Q! g6 h6 ?: \5 Z0 q
26、 无支撑胶粘剂膜:unsupported adhesive film& C, V$ K- y% P8 H* {! z
27、 覆盖层:cover layer (cover lay)
" \* T$ i1 z6 i6 ]& K- X9 f28、 增强板材:stiffener material% u }2 _( e+ W- Z* a$ S5 U0 s, ~7 Y P. P* E
29、 铜箔面:copper-clad surface
& v5 w' Y! x; g30、 去铜箔面:foil removal surface5 i/ I, |. }. @: Z( m) A9 [( r+ K5 H0 A. D7 [
31、 层压板面:unclad laminate surface1 t; w; d% y' i' Z2 U5 T% \* q0 `
. v3 j: L2 [3 c0 d, Z9 ?( X32、 基膜面:base film surface9 ]: Q! |$ C. w9 l: \. A! [
33、 胶粘剂面:adhesive faec
: \) D# v W; H: B' s& ~: Q9 U4 D34、 原始光洁面:plate finish/ c8 t$ y0 e! @# M. n/ w
35、 粗面:matt finish% Z$ [& e. c, H$ J3 Q8 D) `* M" @% Q9 }) X, \
36、 纵向:length wise direction7 s; J9 T# T" L( w, }* g2 L- N, \+ h( _6 q D8 l, F/ E4 T/ g8 h: j
37、 模向:cross wise direction P2 g$ G8 `$ R- k2 W. l
38、 剪切板:cut to size panel; u1 G7 ~' ~# M0 V* F
39、酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL)5 a5 h: w4 X/ w( |6 ^7 \, `5 J" {
40、 环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL)/ H5 c8 y ?- M$ C" N
41、 环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates5 i! ~; `& h# C3 ^- _. M, P; m& Z* M8 u3 B
42、 环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass cloth surfaces copper-clad laminates( b) i& D8 ~, ^# k! O2 r1 G+ B
43、 环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates
9 B b3 {# e5 b3 C* m6 Q) N5 S44、 聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates9 U0 o0 b" i% _
45、 聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates
/ w O. b) | E$ Q) ^6 a46、 双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates
" [+ r) j3 t' U! ^ j47、 环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates! V% d7 b j( Y
48、 聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates
/ B# S+ s! B5 e9 c3 q6 U0 X49、 超薄型层压板:ultra thin laminate
1 R2 v: [2 J( y" i. K; o50、 陶瓷基覆铜箔板:ceramics base copper-clad laminates( L' O% m6 ~6 B2 }! q
51、 紫外线阻挡型覆铜箔板:UV blocking copper-clad laminates
$ u7 ?/ |; d' E) Q. R5 {% A ]& b7 @) |8 ?) ?( R' b2 ~* T/ k. F
, V, j* M. o/ b5 U$ s: z: \! M% k$ s7 ~ t
三、 基材的材料$ t9 P) {' I) v% k4 f
1、 A阶树脂:A-stage resin, N( {; r% B+ ~. I
2、 B阶树脂:B-stage resin _1 k' f# R4 H: {- i7 S- x) U" `! z( ?
3、 C阶树脂:C-stage resin, ^5 i5 k0 _! F. T/ |' H$ j' G4 n8 P* S6 Y6 X" |: H9 x
4、 环氧树脂:epoxy resin1 d% T, x0 ~6 y' S
6 B% D, U& H% s) b, S5、 酚醛树脂:phenolic resin; ]9 A8 A: ~+ j9 y8 G) e* q
& H( E2 X/ {: w% L; a6、 聚酯树脂:polyester resin
* G0 U1 j* W* p1 N' s% o+ j' }7、 聚酰亚胺树脂:polyimide resin
9 r- `: X# a1 e# W( H, k/ ~3 J3 H8、 双马来酰亚胺三嗪树脂:bismaleimide-triazine resin/ F" X4 \. r# o9 d `1 _# E6 x3 a. D
9、 丙烯酸树脂:acrylic resin9 I4 g; E, u7 u2 p% Q9 t% N9 ?1 z* F( d
10、 三聚氰胺甲醛树脂:melamine formaldehyde resin3 e' [9 g3 X; W8 y, G! _9 z( A( f D! M& Y2 [; _; Y; G3 n
11、 多官能环氧树脂:polyfunctional epoxy resin
2 ^- I, Z; V! A2 H2 s/ B' a12、 溴化环氧树脂:brominated epoxy resin! _8 j( W& S1 a2 o% X! K: @6 [: h
13、 环氧酚醛:epoxy novolac% h4 J9 u2 W; `/ V, S7 C1 s. ~0 e H1 K- s/ o
14、 氟树脂:fluroresin: [4 N5 ~ ~9 m" i3 `3 p1 q6 L) g5 _6 X7 |/ b* S. O! I
15、 硅树脂:silicone resin# }( D- m# |9 X e3 U* @1 w
+ f, \ u8 R* {2 \+ ?* q1 }6 |16、 硅烷:silane4 j/ g: P: a3 ~9 I5 \% w
* q, x8 Y1 ?6 h3 r) K: I% S17、 聚合物:polymer
- z) E$ z$ d; W. [% ?2 I0 I18、 无定形聚合物:amorphous polymer: L9 b: m! [0 d* b- P6 h
19、 结晶现象:crystalline polamer5 s4 e% k+ J9 M, @, {
p4 a- P7 F1 k' m' W20、 双晶现象:dimorphism3 d7 M; D) }$ i& }) h. z' E1 B
: _) v) R. {3 `8 U5 y1 ~; x9 u21、 共聚物:copolymer! F% d6 k9 F- p: y$ o! G5 o
0 y9 z; i! `4 ^3 J22、 合成树脂:synthetic4 v. e7 B ^5 D7 C. S t$ M8 P6 [
23、 热固性树脂:thermosetting resin7 W( _/ l' C, q. S9 k# @
24、 热塑性树脂:thermoplastic resin9 L# I5 F( u4 \$ u* D# n- V- z, m7 b: Z. o
25、 感旋光性树脂:photosensitive resin3 Q- e' o1 G" @2 ~6 @
3 l( w- Q* [6 {, F9 M+ |26、 环氧当量:weight per epoxy equivalent (WPE) g {- m& S$ S1 T2 x1 @3 }1 \0 t* q ?! I9 w. K8 g1 M
27、 环氧值:epoxy value
; Y: ~: w9 I9 K+ g28、 双氰胺:dicyandiamide: c: z3 i0 M, ?1 V* F
# s- n" P& b3 g29、 粘结剂:binder% A& W5 b) i- j9 @5 _5 t7 ?4 S
30、 胶粘剂:adesive- k& Y# g7 W% {' F* B
0 i; x6 ]3 d* F: C7 {/ l31、 固化剂:curing agent/ R7 u+ {5 N5 {& X
32、 阻燃剂:flame retardant6 n, e8 U {) Q" B% }7 u# H
! v- u1 X& g5 K: g* d N1 _33、 遮光剂:opaquer& |9 F$ _ T p4 z) t+ r, T8 X* c- K( ^, A0 c: @
34、 增塑剂:plasticizers5 t) S" G& i) A" K
! v6 {7 x6 I) a8 }! a* G35、 不饱和聚酯:unsatuiated polyester" o) w$ D( W% g7 F6 C
" f3 |' L8 N5 q) `. z" K2 r36、 聚酯薄膜:polyester/ u- i1 ^5 }0 P, b |: I9 _0 p
1 I' r5 j) u4 g4 M! w37、 聚酰亚胺薄膜:polyimide film (PI)6 |! H( H2 V" k5 t) k7 A( E/ M, ^
38、 聚四氟乙烯:polytetrafluoetylene (PTFE)3 Q1 T- U# e6 V1 C7 m; q
39、 聚全氟乙烯丙烯薄膜:perfluorinated ethylene-propylene copolymer film (FEP)# Y$ V5 [# w8 K5 i
& x( e" x" W5 ]5 K# b40、 增强材料:reinforcing material2 Z% R6 P$ ~, o+ j
41、 玻璃纤维:glass fiber$ N: G5 d8 p1 ~, N0 y( z m
& c7 B; j6 W+ t1 x42、 E玻璃纤维:E-glass fibre
; I/ t0 [1 D8 Z2 Z3 D7 @43、 D玻璃纤维:D-glass fibre* Y0 k$ @0 ~: N; T* Z9 o- [) K. @6 |2 G( M8 w
44、 S玻璃纤维:S-glass fibre# g% E2 d6 Q" G8 u e. D
8 [, }; G$ n: s5 [45、 玻璃布:glass fabric
: i8 w3 T' E0 }9 G/ C46、 非织布:non-woven fabric8 }: J/ i3 V: B6 r' O
2 a: p3 z, R) t3 M$ y4 c, b+ e47、 玻璃纤维垫:glass mats/ U3 g J8 K. [* K
48、 纱线:yarn7 {6 J" E! Q( B/ f/ g
1 e) [* D! o6 }- r: V, k9 R49、 单丝:filament% p7 o& l/ M ]9 h: Y$ K# I
; q( ]5 i- x8 u+ [0 _2 y) Q; |3 q50、 绞股:strand4 a, U0 [( N$ l' B& G
2 i2 Q7 L# R) I2 V51、 纬纱:weft yarn) f# F2 J; X2 H+ g+ n( k
% B& M/ s/ F# X% [1 X- x52、 经纱:warp yarn) ] j$ @" l( h2 r! b
53、 但尼尔:denier
& D j% Q2 Q( Z* P/ y+ B7 ]/ Z54、 经向:warp-wise$ z; R. }, L: m# O* q% q2 l8 x- i' S0 @6 c0 r8 R1 } G/ M; X
55、 纬向:weft-wise, filling-wise. q6 b4 o( V" E$ j2 C% Z
56、 织物经纬密度:thread count% T* K% A1 B7 @4 X2 L3 Z3 o
' O" n" u0 v7 l1 }1 {$ P; Y& G57、 织物组织:weave structure
' m8 W) p" s! M z58、 平纹组织:plain structure7 U: T0 ~- F2 K
0 j* C# u" i; N, {2 [; T" K, F! D59、 坏布:grey fabric0 j6 M, y6 G8 ]$ E9 Y2 `( e0 c' l9 ]
60、 稀松织物:woven scrim3 Z6 R) g! y' X* b0 `0 v& W1 { i& `
d' M& U( P9 l( ]# n% J# _61、 弓纬:bow of weave' ]$ ]' ?+ e' }5 i) I4 A; B3 E2 q! T! G1 @
62、 断经:end missing! I$ e% V6 s9 G8 X! q' n/ B
63、 缺纬:mis-picks
* O4 u! A4 k9 M! H \64、 纬斜:bias
# J- f5 m a1 V4 x65、 折痕:crease
( Z* [' R" O1 f. D; _4 N66、 云织:waviness2 ~8 t7 b3 M0 x
67、 鱼眼:fish eye' @/ N8 X ?' w3 H: u: C h: a
) x: \9 s" v9 H Q: |. s; {68、 毛圈长:feather length3 ?5 \ m0 ?) ^2 t* f! q; c
69、 厚薄段:mark
" C6 D6 v' l* L* V. e' H& P$ T- B70、 裂缝:split2 z1 J' p p3 M/ R4 d; P6 H; H; ^5 T
71、 捻度:twist of yarn( P5 B" D. f1 V7 _8 o# `3 ]; ]- b" j
72、 浸润剂含量:size content* u4 o" A% w. s) s# [- l: a, J' f) }, z. w) k
73、 浸润剂残留量:size residue+ B6 p: Y6 u' C) I0 r9 H9 |& |9 N# a" Y7 y8 b! G" }- H* u R; e
74、 处理剂含量:finish level
# R" ]+ j) _" `; a75、 浸润剂:size( j8 k- S/ y6 A- A/ ~# s
76、 偶联剂:couplint agent3 i7 e0 Q; V* K+ B6 p: d
4 S! j, ~) N- s% @+ w77、 处理织物:finished fabric
& ^9 m5 i0 k5 k- d78、 聚酰胺纤维:polyARMide fiber- F6 {! J3 ]4 q$ Y8 v! m# T
79、 聚酯纤维非织布:non-woven polyester fabric6 t3 |" w$ S" z, M* n6 y5 [5 `' p0 g7 s$ M5 t; u
80、 浸渍绝缘纵纸:impregnating insulation paper; b; C, n2 N7 `2 J& f; K4 A8 p& T4 O8 x6 H0 \9 U& g
81、 聚芳酰胺纤维纸:aromatic polyamide paper- y r, w3 F6 s+ R
82、 断裂长:breaking length' w0 T" Y9 L( ^! i) j% M4 A
4 x! o: C0 q7 `! F83、 吸水高度:height of capillary rise$ H: Z; ~4 }4 A: Z5 @( V4 \+ Y+ h! N- [5 i- l1 ^4 K& s3 O+ G
84、 湿强度保留率:wet strength retention4 F/ H9 r6 U7 m
j( f1 V; e7 E; J' y' u5 G" j85、 白度:whitenness
( g& z7 g5 x4 q) t4 ^86、 陶瓷:ceramics. C) F3 i1 k2 c6 @% G- q
87、 导电箔:conductive foil
3 V# ]2 i/ \9 S3 Z; y% I; t& z7 ^0 \88、 铜箔:copper foil2 T# O; U' b; O2 E6 `
89、 电解铜箔:electrodeposited copper foil (ED copper foil)3 b4 i- L6 ^: a, u
, d z6 U2 G2 E& k90、 压延铜箔:rolled copper foil3 V) }1 t- W, u# W2 A& S) z
: x6 P7 O" y- Z$ w. P91、 退火铜箔:annealed copper foil8 v# F; V o: j) H0 _5 C; H- K1 ~1 t" l# E) g" A
92、 压延退火铜箔:rolled annealed copper foil (RA copper foil)7 _7 j7 C/ c/ w! `2 @, o" M0 H# D, P! ]5 W7 G8 v
93、 薄铜箔:thin copper foil+ _4 ? c# r1 i$ l
94、 涂胶铜箔:adhesive coated foil5 t5 U N2 \) a5 @+ I1 J- B! l
95、 涂胶脂铜箔:resin coated copper foil (RCC)! h; x# }/ x- V5 e8 }! ^" J" X
& C& F. x/ {) m' Z96、 复合金属箔:composite metallic material
% h. U- u5 _8 L2 o# J; I+ e; X" x97、 载体箔:carrier foil H% j- Z" M- q& L& H( R
. O3 e1 J/ H* u( d7 j+ k98、 殷瓦:invar; ^9 `- N1 h$ U# c" O. p2 P' _9 C
99、 箔(剖面)轮廓:foil profile4 f" F9 x6 k7 z. |. R
: t' e) C3 y2 b( g8 S; A; t/ a- o100、 光面:shiny side7 N9 ^' k& L, \9 X. [; j! U% z6 x$ u; ]
101、 粗糙面:matte side
7 R) z! S, X& n2 J6 Q. E102、 处理面:treated side
$ k+ P& Q+ L' r7 `( j0 d103、 防锈处理:stain proofing' P# d! a1 W( R+ Y( a% p1 M
104、 双面处理铜箔:double treated foil
: P X N/ K7 D
2 z1 h t3 I5 s" o& p$ h% f- r# G% H四、 设计3 E( j& o+ s2 I6 e
1、 原理图:shematic diagram; s0 O& t; }' W# y* O4 N" h
2、 逻辑图:logic diagram) I4 h2 P0 y; p
3、 印制线路布设:printed wire layout
' F/ y2 ?" ~6 O+ c5 i0 ]4、 布设总图:master drawing5 w: r4 A' Y) i
w8 J2 U- D1 C1 {5、 可制造性设计:design-for-manufacturability& r, _% ~8 V9 @6 e
6、 计算机辅助设计:computer-aided design.(CAD)
+ E# j |1 |- t2 r4 Z7、 计算机辅助制造:computer-aided manufacturing.(CAM)3 X# V T, H% o' T# Q% |
8、 计算机集成制造:computer integrat manufacturing.(CIM)
7 W) K& u$ O, O s: T9、 计算机辅助工程:computer-aided engineering.(CAE)5 N/ {4 Q( b/ v) |, S+ v7 O' N% d: F6 o
10、 计算机辅助测试:computer-aided test.(CAT)
$ A w: t$ E* \8 ]6 a. ]" G11、 电子设计自动化:electric design automation .(EDA)% O n8 g1 D: j; h3 a* N& G
# i, q9 ^' j6 G- u12、 工程设计自动化:engineering design automaton .(EDA2)
; h6 N$ A# j4 N$ K" h- e; T13、 组装设计自动化:assembly aided architectural design. (AAAD)
/ a9 N# p* ^+ J+ J0 @- A14、 计算机辅助制图:computer aided drawing: q' m! N, e8 c1 ^) ?
15、 计算机控制显示:computer controlled display .(CCD)
# _9 @! m% B1 h0 E$ N d+ }16、 布局:placement& f9 n- C# [& X+ e4 s- A2 L
& x* {( P& l% @17、 布线:routing2 K4 M3 s" t* H# _$ b: L( q: \. A- y* a' s
18、 布图设计:layout
( r( I/ I6 ~( K' D' y/ U4 Q9 T19、 重布:rerouting [. A0 {2 ?/ L1 x
20、 模拟:simulation$ \% d% q: |' d
: Q. S! U5 D& _9 \4 r8 {21、 逻辑模拟:logic simulation* a2 H4 @( @$ H
22、 电路模拟:circit simulation% R& r4 M3 f" C/ X6 r, [
& ]. K1 `9 q B% i v0 s1 e8 R23、 时序模拟:timing simulation0 d. L. q) G% m* M% Q
24、 模块化:modularization6 N7 h1 A" v! a3 b7 d' q3 l7 q" ^4 W: D! r
25、 布线完成率:layout effeciency
0 [" l" w* E7 D9 A: s26、 机器描述格式:machine descriptionm format .(MDF)
( F( v+ y9 V9 j; v; x27、 机器描述格式数据库:MDF databse# q0 B3 d* R$ ?
9 e/ k9 ~! O3 c28、 设计数据库:design database
M* |* ~+ H" m, Q( Y# B29、 设计原点:design origin" N$ o$ W5 b2 \ V* w5 P( k
30、 优化(设计):optimization (design)$ w% U( z! _9 m0 k) v; s
/ e2 u( G& G# I& }3 n) l& c3 Q* H31、 供设计优化坐标轴:predominant axis$ G5 j$ n5 T' J3 f5 F% G1 _+ ~! R# ]# j/ \% F6 I* d- {# n7 Y
32、 表格原点:table origin. x. v% Y3 s& g
33、 镜像:mirroring4 J; L% C H3 U' p& o
- P, L; [# H& Q) y/ p! I. l' f34、 驱动文件:drive file+ `# L+ T1 i% v5 P6 o' O
35、 中间文件:intermediate file
5 o. d; N9 c; N3 z3 |36、 制造文件:manufacturing documentation( C4 C# ^& i& |6 X1 u0 Q' M' O6 l; ?# \4 F4 k
37、 队列支撑数据库:queue support database7 D+ s# u- F* j# z( K) H: K, h: R5 l6 I' K8 g
38、 组件安置:component positioning& s7 H+ N3 _$ N$ G. X8 w3 w, v' T" k
39、 图形显示:graphics dispaly: Y8 [" M) e: |6 w2 r5 \: K
40、 比例因子:scaling factor& F& J# E& r |9 [. R% R* J+ P1 @
41、 扫描填充:scan filling4 x2 e3 P# v. N% U6 J; B$ Y/ y
42、 矩形填充:rectangle filling, @0 u' n1 b) q% f$ r+ T1 X w6 \+ ] W. \4 L- ~) L& K
43、 填充域:region filling! D0 t6 p* B) [) \- \
8 |. [8 B6 X/ q; B8 v4 r4 i8 r44、 实体设计:physical design! K* F5 K' c* C% M
2 c2 P: x# m) o _45、 逻辑设计:logic design h6 N( r3 w& W* W9 J( S r. s2 g/ M, t y/ p. l/ ?
46、 逻辑电路:logic circuit6 c$ |/ }# g1 O6 ^4 d1 w1 _
47、 层次设计:hierarchical design s! l2 E* g6 l! S3 {4 M+ d
48、 自顶向下设计:top-down design' C0 G* B/ i: E4 _; S: _. {3 P+ N" d6 X W2 S
49、 自底向上设计:bottom-up design% a/ R: c6 A" s$ S
50、 线网:net' \3 c6 U. \. m5 r2 N( B9 S
) ]" U/ C. U+ i5 `( g X51、 数字化:digitzing1 s. \! ~7 {' d9 A
52、 设计规则检查:design rule checking5 W8 M: `. k: }7 L
53、 走(布)线器:router (CAD)( B2 T3 Q4 ]% c! V O( y8 c1 K' H0 t# y5 m
54、 网络表:net list9 s# a% ]7 x, Z8 H, s
& ]% U* g2 m" k6 @1 J, s55、 计算机辅助电路分析:computer-aided circuit analysis1 A! a7 l4 m4 Y5 h/ G6 N. _+ q. N& ^, g# a! i* G5 r4 n& C# Z
56、 子线网:subnet$ n+ `( T0 |8 j: W) a4 ?. h7 e& o, E! P' A
57、 目标函数:objective function+ e0 _ h" n& I0 h7 L9 }# X/ |9 n* t3 U8 o7 c3 s7 @
58、 设计后处理:post design processing (PDP)
6 X+ ~6 ^5 S9 v6 p1 p1 |* e3 D59、 交互式制图设计:interactive drawing design$ @' |( b- ^) u% ?1 \$ j6 B% k8 k
60、 费用矩阵:cost metrix5 {6 m: o- b# o: i, T& g( h1 g# r9 H, q9 `
61、 工程图:engineering drawing
( _+ A c7 y: p% B! [+ o62、 方块框图:block diagram- W1 H# k; G. k6 Q% N6 R
63、 迷宫:moze
2 Z% O6 H4 |( S1 V# H# _64、 组件密度:component density
5 {% g4 O/ ]- e: H) ^3 ]" X65、 巡回售货员问题:traveling salesman problem$ D/ [- W$ x; u& R9 C
66、 自由度:degrees freedom1 ^) S3 C: c0 c. E
67、 入度:out going degree
' \7 V/ T6 ?2 D# Q, {68、 出度:incoming degree) E' L" o- d) V. b
. A0 L/ z% N, c6 c69、 曼哈顿距离:manhatton distance8 {1 P6 }$ x/ B y
70、 欧几里德距离:euclidean distance
4 W$ [0 n" w/ M2 q0 v K8 u" I71、 网络:network4 j. L# a+ ?- b
72、 阵列:array
6 _9 s2 @; ^: U4 D* o73、 段:segment& \) A: u( @3 g k
, i) n1 ~1 x9 i v% q74、 逻辑:logic
1 ^7 @8 m6 Z8 ~$ o: C. w: {75、 逻辑设计自动化:logic design automation5 j9 q0 C3 i) \6 S' o8 K: u1 g9 s4 x. g; ?( A }
76、 分线:separated time, _4 T }3 S2 I9 p! V2 k! D$ w' J/ L& c% S7 H) n8 f1 C% k
77、 分层:separated layer
* M! B" h: h' \" ~78、 定顺序:definite sequenc$ @8 f! J- _9 q; B9 G6 N# U* c+ I3 h+ h
' g% E. Q. A0 K' ]4 ?
% x: D( p$ {- `% J( G五、 形状与尺寸:
) { L& L$ I( z; I9 d& \1、 导线(信道):conduction (track); F/ `" u/ w" q3 v+ Y ]
' c9 l$ r# m0 T" ]1 i: g- I7 ~. t/ P2、 导线(体)宽度:conductor width7 }( {5 `1 r6 [' L
4 e) b: F) E9 v% `) M+ I5 j3、 导线距离:conductor spacing" b' F( `5 q& r! e
4、 导线层:conductor layer; ]' U7 M; y* l7 E' r" p3 i/ |6 [% a
5、 导线宽度/间距:conductor line/space+ m; |1 g" F& _7 e! s; B/ Q( T2 M: S5 {# L1 a
6、 第一导线层:conductor layer No.17 B. L0 Z8 [: Z8 k, d6 N' _; o" H& {- C7 D% n
7、 圆形盘:round pad
5 _0 M& I: U4 q; |& \7 {+ U7 Y8、 方形盘:square pad! q0 p- Z5 s) b7 x/ M2 e6 |- k
a1 w/ ]9 E S% u+ a' Y9、 菱形盘:diamond pad# w6 }) r/ F! e& Z% v
2 x, z- O) f, ]8 W10、 长方形焊盘:oblong pad
' U7 s9 P5 i, h8 ^! w11、 子弹形盘:bullet pad2 y E4 T# W' z% B0 J) M! d
12、 泪滴盘:teardrop pad3 x F. w' q8 T2 p. ^; U
+ Z6 K0 C/ ^% F$ a13、 雪人盘:snowman pad
, |) ?- X7 `- N9 @* f2 l# f14、 V形盘:V-shaped pad) n3 g( q( t4 e- M2 F2 m5 H
# C8 @7 M* e1 x+ ?: ] z15、 环形盘:annular pad+ S4 k4 f8 Q. e+ X& |; F' \% Q" F. G& ?$ M
16、 非圆形盘:non-circular pad& N( B3 r' P9 }9 Y: B) f) b U. P, O8 R. H6 ~
17、 隔离盘:isolation pad
" \: l" }3 y$ V( Z" ]18、 非功能连接盘:monfunctional pad0 Y/ _, h' z; _! O* `& d0 n, Q6 N
9 t' b, {' J0 {4 G; c7 }; {5 M19、 偏置连接盘:offset land
* ~ \# \6 h! a( _/ b- z20、 腹(背)裸盘:back-bard land
8 q5 v. T! a( k, T( U21、 盘址:anchoring spaur
. X, |1 O$ y4 w3 P5 z22、 连接盘图形:land pattern# H! T/ G3 a5 c: P% {* A$ o6 g
; i# W$ X. Z7 w D3 B3 }23、 连接盘网格阵列:land grid array$ b8 }+ @; A0 C& {8 O2 w6 g' a/ `6 f1 ?; C; y7 Q$ u
24、 孔环:annular ring; A6 ?; }: f5 E ? v& D; e. [" |! U( O
25、 组件孔:component hole% _# u+ t' W$ X9 [3 }3 ]' q- K8 f3 M& m9 M. n, K" l
26、 安装孔:mounting hole$ M3 l2 }$ ?4 q
% t9 Z( r3 f* a$ h27、 支撑孔:supported hole; O0 `' p2 f/ e
28、 非支撑孔:unsupported hole* p L: p" E) }2 Q& a' Q! g2 e
6 X; N# L+ _* V) g1 ^* z29、 导通孔:via
1 O s) `; r/ `& X }+ y30、 镀通孔:plated through hole (PTH)
+ A9 u. U/ a/ s* f$ }2 x3 m- ^7 l, _* a31、 余隙孔:access hole9 a8 ~/ A3 V$ O3 n8 V: O
0 P" R2 L! C. f& _4 u32、 盲孔:blind via (hole)" S- W" ?4 T2 J4 Z
) z- R+ ?/ f0 Z6 a" a33、 埋孔:buried via hole5 x0 [5 p# b6 x: a8 m# c0 p% o% A! L# E
34、 埋/盲孔:buried /blind via" L ^ r j! f- x4 Q. Q7 E) n9 B( P3 M+ P/ n0 b2 l1 j1 M
35、 任意层内部导通孔:any layer inner via hole (ALIVH)
0 V' d8 r* n+ }; r: i) N, P, T: F36、 全部钻孔:all drilled hole8 J @3 T) y5 q% U
37、 定位孔:toaling hole3 {+ j0 C) H8 _0 t6 h/ N! @6 S& Z
38、 无连接盘孔:landless hole2 ?4 v$ e: B0 c" ^% ]- w X: i, l- |3 W5 z( t, m
39、 中间孔:interstitial hole
3 z8 m4 l/ _" G1 U; j; D' Y40、 无连接盘导通孔:landless via hole0 C5 h: T' G5 P6 z i O
5 D7 {* \3 T( t41、 引导孔:pilot hole) t2 G# G, U# x& m( O& k5 s
! U6 H0 f* l) N) i8 \% E& B8 f42、 端接全隙孔:terminal clearomee hole8 S$ K2 ?/ O& j2 m! Y8 Q7 T, `: _0 P7 v
43、 准表面间镀覆孔:quasi-interfacing plated-through hole: k; V6 r3 n% g- p. o% u# [ y
5 f8 Q; I( F: m+ g( e0 p$ P! H44、 准尺寸孔:dimensioned hole! B' O( I2 L8 l+ p- X" }% C
45、 在连接盘中导通孔:via-in-pad! {8 d* B3 ]- y: e8 c
46、 孔位:hole location/ Q$ R; Z, n0 E% N& o! b% c" L+ M* r) \9 I
47、 孔密度:hole density
7 n: K. T8 ]$ B48、 孔图:hole pattern/ [2 t N2 |8 N- {. v
49、 钻孔图:drill drawing
8 m" O& y8 m7 Q( v1 o50、 装配图:assembly drawing8 g$ |) s+ ]+ T! g" r; F$ D! `+ A! m2 f
51、 印制板组装图:printed board assembly drawing
8 Y8 M0 d! c8 }9 X) n1 H52、 参考基准:datum referan
5 ?9 f. O- b0 t0 S% ?3 x( X8 n* ~% k0 P8 x ~/ f0 z. m1 d3 f, {3 L0 m* v& x- J0 s
1 K% W3 G3 c, w- C. D, B$ @
六、流程. ]' O, r% z; }# x
( j/ n- U" h8 m( c5 j9 N2 K1 P' K: `+ v9 B( y
: b+ {; T4 [, I" D ~+ J9 D% B* Z+ x
1.开料:CutLamination/Material cutting i1 s' N" A/ a6 K _
2.钻孔:Drilling# r+ H2 R8 x0 E/ T
3.内钻:Inner LayerDrilling
* g, C( @$ s7 ~ _) G' Q- h4一次孔:Outer Layer Drilling
$ i* j" k( h- A S; m" H8 ~5.二次孔:2nd Drilling / y- P2 `& P! }2 H
9 o1 a# q2 z7 w) a: ^6.雷射钻孔 aser Drilling /Laser Ablation * O, f0 h5 K7 k; ~9 j k6 G! t% b9 h2 O
7 X/ Y4 m/ Y% C3 j7 R7.盲(埋)孔钻孔:Blind & Buried Hole Drilling / L/ w" I: {. b2 J
8.干膜制程:PhotoProcess(D/F)/Dry Film& H& C3 v/ K6 I" A& }1 J
- c2 \( u. a/ W) H; M& n9.前处理 (Pretreatment)7 m( g, Q; I" ~6 Y9 v9 x o& ^& ^1 N6 | S8 {. a
10.压膜 ry Film Lamination
! h3 O. y! q. e; z11.曝光:Exposure
1 b0 h' j4 }9 ~6 a/ Y! k+ v12.显影 eveloping ( H4 S9 Q4 C1 a9 D! \
* x4 \% w7 h4 J* R13.去膜:Stripping 0 y$ |) a5 W! L- U
. v' g0 ]6 Q" ?- t2 L5 G! m( a S14.压合:Lamination
% T7 C# U, P, b. ]# H- x0 U- c4 U15:黑化:Black OxideTreatment + }; W6 j$ p3 H- p& K' q7 o: b) T# B M* R0 H. }$ y
16.微蚀:Microetching ! g5 e- r6 M. B) ~6 _5 T
17.铆钉组合:eyelet ( q+ z8 D+ A4 `* n& E5 q. m4 y) i/ R/ F# b% S9 H% u5 @. j
18.迭板 ay up 9 H( T2 D5 X7 N( W: i
9 O$ Q( }: c* |# D O19.压合 amination + G) u3 t. x8 B+ ]( B9 Z
20.后处理 ost Treatment / q! V) Q* N1 c9 B5 y0 L7 d4 w) y- o4 X d& f/ `* a4 k6 o/ p
21.黑氧化:Black Oxide Removal ' J3 m0 \' D% e
22.铣靶:spot face
0 k7 v5 N+ L6 |/ q" ]. H9 e23.去溢胶:resin flush removal$ p5 a M& @" l( ]) m: U) M# _' d, O; R |5 H
24.减铜:Copper Reduction/ I: h; a2 X' O: u4 T* H( v9 {4 d4 ^) D0 Y$ A) D6 F
25.水平电镀:HorizontalElectrolytic Plating* k( Z9 w1 Q3 x% h5 {
26.电镀:Panel plating
2 }- g% n/ M1 [27.锡铅电镀:Tin-Lead Plating /Pattern Plating ( a% A) z6 V2 u N4 o
2 V1 _" g* P/ t1 g& W" ]! a' D28.低于 1 mil: Less than 1 mil Thickness
7 @% u7 n; A/ g0 {9 `9 [29.高于 1 mil:More than 1 mil Thickness 6 \; {% e1 u) d* y% g2 \
30.砂带研磨:Belt Sanding ; P% n" ?7 ]) e& z
9 F1 k9 d/ h5 m6 a- @31:剥锡铅:Tin-Lead Stripping
+ |8 t; [8 y0 T9 W2 C32.微切片: Microsection
. ^& C$ u) h, @6 R" X' e8 l33.蚀铜:Etching % X) |0 I% K9 a( I
34.初检:Touch-up. L* l( c `. N @4 \
" }4 Q) D: Q: o, Q) _* V35.塞孔:Plug Hole6 h5 r& J6 v% R- }6 ]/ B
. [, v1 E8 m. O/ N36.防焊(绿漆/绿油):SolderMask- c) t4 }3 u5 H/ B5 }% Q5 F# q% H) i9 i9 u0 X7 t8 \
37.C面印刷 rinting Top Side / r! W e( F, h% U
38.S面印刷 rinting Bottom Side ' A |1 Q& A: x! ^- c# c v& C- | G, V/ \/ e J- V
39.静电喷涂:Spray Coating 8 @# o" w2 I2 D) D) m
40.前处理:Pretreatment # U3 Q$ ]$ l3 A( h4 U7 y8 B6 f2 e+ N
; A, T. D) b- Z, M$ n' v41.预烤:Precure; c# h9 h" ^+ o3 M) x' u
* [/ q, u- ^4 P( ?* a42.后烘烤:Postcure
8 S' X. E2 E6 B3 h43.印刷:Ink Print) P6 ] V% S# M" t1 h2 c
8 x/ s; A% x6 w- X2 W44.表面刷磨:Scrub
( b7 u J v# v- ~ Y0 i' o0 v45.后烘烤:Postcure
/ S9 ^2 J: T2 k' n46.UV烘烤:UV Cure 8 L; d, U. a% C" C- D' n$ Z' u' q
47.文字印刷:Printing of Legend
" {$ z- ]( b% b& E8 l1 n48.喷砂:Pumice/Wet Blasting 0 e. @2 z$ \* J4 j5 ^) m7 N" B3 U
49.印可剥离防焊/蓝胶:Peelable Solder Mask)7 x! w: R! Y* H2 @( |& r+ w) d1 X* e; B
50.化学前处理,化学研磨:Chemical Milling 2 j0 i0 }9 I' S. d# L
' L" `( `3 r% T/ M5 U: O8 O51.选择性浸金压膜:Selective Gold Dry Film Lamination( M6 V$ ^# X) y" q( G5 i; H
( T4 X; @& B; \( v _! ~52.镀金:Gold plating8 N I# I4 n, Y) {$ m; R
" W) j1 e/ `9 o53.喷锡:Hot Air SolderLeveling) l- F. V* g3 D3 i9 c
/ V& `7 H2 N' _54.成型:Profile/Form% I1 `" \6 e; Z7 ?* t
55.开短路测试:Electrical Testing' l/ F; C# Q0 Q- h
56.终检:Final VisualInspection( \2 W+ y5 l u
5 s N# t/ _+ a57.金手指镀镍金:Gold Finger . @. b4 W; r4 m Y" J. d7 q2 k( ?
. ?$ `% d+ E& a, C' R58.电镀软金:Soft Ni/Au Plating8 r+ g' B# S' P( ?6 Y
5 l0 _. B9 ^8 Y9 e+ z59.浸镍金:Immersion Ni/Au / Electroless Ni/Au. o) P$ w' }8 v# l% F" D, R+ }6 ?8 P. z
60.喷锡:Hot Air Solder Leveling 4 E- b+ r& x$ a' g. M
61.水平喷锡:HorizontalHot Air Solder Leveling ( P$ U( ^& ^+ z9 z; q1 k; o+ e8 ^! `
62.垂直喷锡: Vertical Hot Air Solder Leveling
0 A0 ~* d- U; k/ u1 h9 V63.超级焊锡:Super Solder. b6 O( Z: _1 l J7 Y J6 K4 F! d9 Y O n6 N
64.印焊锡突点:Solder Bump, ^0 ?, a9 ~ Q( a0 m! q5 K! g; j# C% G# y* D4 K9 K
65.数控铣/锣板:N/C Routing/Milling; Q0 L* h" a, `9 N; \; F0 {9 r" b `4 E& K$ `
66.模具冲/啤板:Punch
) q+ a% q8 Y3 S8 t, ?0 A) C' d67.板面清洗烘烤:Cleaning & Backing0 S" f; M& ~4 g. E4 ?0 s1 e9 z
68.V型槽/V-CUT: V-Cut/V-Scoring
; T0 a5 V9 h4 m69.金手指斜边:Beveling of G/F1 `" y6 S& ?$ `' n# K$ e4 p
70.短断路测试Electrical Testing/Continuity & Insulation Testing 6 r" x( D q9 t" f2 m7 x1 V
71.AOI 光学检查:AOI Inspection/ K2 m+ z- U! W* n4 E7 ]8 @5 s4 g4 F# y6 `6 v9 l
72:VRS 目检:Verified & Repaired* m* I! K) j7 Z9 }8 t
73.泛用型治具测试:Universal Tester
- }6 }4 }' H. l3 n# l! J( y. N74.专用治具测试:Dedicated Tester3 d' {7 g( |' a) G }/ W" t8 [+ i( P t! W O; Q" N" }+ r
75.飞针测试:Flying Probe; w! ]2 ^. K) l) F3 o7 r0 d7 n3 X) @; T7 L2 W
76.终检:Final Visual Inspection ' O( c' B2 ?5 M6 b1 J5 R6 r
6 R' n. r" R! a. A, j+ T77.压板翘:Warpage Remove/ V. O$ r, {; {7 O
78.X-OUT 印刷:X-Out Marking
% B2 F4 Z5 T* S" |4 _& q9 M79.包装及出货:Packing& shipping) c; ~+ l* `' S1 q. N& y4 ~7 G9 v3 j. X3 h; I
80.清洗及烘烤: Final Clean & Baking 1 B# r# V2 ]" R/ o, m. c9 I5 z! z% J
' w2 I! e0 b3 |: r81.铜面保护剂:ENTEK Cu-106A/OSP) \& v1 m; h- Y' K1 r! N% f+ a/ q N6 ]
82.离子残余量测试:Ionic Contamination Test/ Cleanliness Test , Y# {' x( G s! }. o% @( }
83.冷热冲击试验:Thermal cycling Testing
# A& ]: B# V) g! Z/ h84.焊锡性试验:Solderability Testing 8 z, Q' q6 y" M# I) u
- p/ x& G) D. K3 t85.雷射钻孔:Laser Ablation 5 M* z. a1 {: `6 t0 j3 c3 g
" R G* T0 ?1 h/ k* L4 e3 a86.雷射钻Tooling孔:Laser ablationTooling Hole3 y/ L2 X) A8 I c' h
' Y6 l/ o, H* M& z0 l87.雷射曝光对位孔:Laser Ablation Registration Hole8 y) @% u9 h4 `. m2 L
88.雷射Mask制作:Laser Mask
1 L- ^0 Z/ A2 r7 A$ I89.雷射钻孔:Laser Ablation) U& ^3 c. r n4 Q0 L2 o/ a- I3 J2 Q( r
90.AOI检查及VRS:AOI Inspection & Verified & Repaired 4 h& r# \1 \* d; C4 y6 t6 a% b& b! S. T, U, Q% f, G
91.除胶渣 esmear y% D- }* V5 ~$ u" A F l8 H
92.专用治具测试:Dedicated Tester" A3 U7 s6 M9 E; a# s0 D, j/ }2 u4 Z% n6 p
93.飞针测试:Flying Probe2 ~ z0 r% Y5 v+ o; F! q' M& P3 {& u" \
94.压板翘: Warpage Remove 7 x, \# t% l* X; q0 _1 \' p! [( ^) K4 z+ X5 J7 s
95.底片:Ablation
) v9 K* A/ p3 [6 H+ B' q96.烧溶:laser)
1 f6 h7 t9 M+ l9 K5 r. L. E! ?7 L4 m9 U97.切/磨:abrade : M9 s* z- D- r1 _/ l8 O# _2 F3 p. P/ r. z
98.粗化:abrasion ' ^4 O. G; R8 x* e( Y# F! N8 S: v& _6 \' i
99.耐磨性:absorption resistance * ^# ?' B* v* D+ n
100.允收:ACC /accept ' A8 X! w# S' _ g* D2 w. b
m" x- S' z$ j8 W9 A3 V101.加速腐蚀:accelerated corrosion test
+ Q5 B! E; _" W102加速试验:accelerated test$ A6 j8 |/ L% u! l4 O$ [
103.速化反应:acceleration 4 @1 P7 P" R# B
/ t! ]3 p' n! y" ~+ T) O; E104.加速剂:accelerator $ |0 O' Q6 ^. a/ Q" L/ w) M
7 b, \( n d, w/ A* u, T0 R$ n105.允许:acceptable
; C6 o: x' Q1 m. [. h106.活化液:activator
. G2 U7 V& T# C w+ A107.实际在制品:active work in process
, t7 [2 E7 T! Z# R2 u9 C' l108.附着力:adhesion
- n- {7 u- j# H' Z' ^. F/ O. V109.黏着法:adhesive method ( P6 W( p2 Z0 g6 m/ A' y" l4 L9 t! F9 t2 L: u) W
110.气泡:air inclusion : c" n" K" h- B; @; s
111.风刀:air knife
+ k9 E9 F! h" T/ g8 i1 b112.不定形的改变:amorphous change
/ i3 v( O* H. ?) T* G% b. O2 q113.总量:amount / R: U! @) x6 l, C& r* R; Z
114.硝基戊烷:amylnitrite
2 f6 Z% ]; P& y115.分析仪:analyzer ( T5 p0 R4 v8 M \/ G% ^& f }( s7 F9 R- I K2 V- n1 `; a& e& [
116环状垫圈;孔环annular ring " q& r n0 L+ @; M& R) V" u
117.阳极泥:anodeslime (sludge) 8 o. x+ F: h" I! l, Y: @7 v, D/ N
118.阳极清洗:anodizing & x: b. P* D; B: j) g4 X4 y" \! ~+ g+ l
119.自动光学检测:AOI/automatic optical inspection
( F% i3 A0 _: `9 F! W120.引用之文件:applicable documents , M9 d* B; m# n ]) ^! A! L
121.允收水平抽样:AQL sampling
( _8 y3 e3 v2 p: L. y5 i t122.液态光阻:aqueous photoresist
7 L/ a! @( O3 W' E. q6 T$ y123.纵横比(厚宽比):aspect ratioAs received
7 M% F4 I# y* V1 V, [* Z124.背光:back lighting / D+ b; m* |3 P% C5 s2 h+ @
$ G z3 P2 k2 }6 W, |125.垫板:back-up
. C6 V5 p/ T0 {$ i8 F6 M126.预留在制品:banked work in process 2 o/ b, e1 k" @. N$ H$ I F+ A* t1 R- c! o' v
127.基材:base material 8 f7 K$ ~. x9 y) i0 U$ ?# N: ~
128.基准绩效:baseline performance
# ?. Q6 z4 g/ h/ y( U129.批:batch
# @. s; J) ?6 a( h# |6 d+ p130.贝他射线照射法:beta backscattering 1 y1 \" T' A( l: ]7 P2 ]" O' C- m# L& A7 Q
131.切斜边;斜边:beveling c. k, M- |- d5 P/ l. d9 e
132.二方向之变形:biaxial deformation 7 D; S" ~1 F) \3 C8 t7 B5 G
133.黑化:black-oxide ' S% G! I% t$ S# Z" B1 O. t2 s
# I$ H+ Z1 @3 D N! W0 z, b$ T9 \134.空板:blank panel 4 S/ `! t' Y! Z9 s* g3 v' I+ O1 d& T9 z, N5 {3 f% q, x
135.挖空:blanking
4 l/ Z$ ]$ P: s( c, U8 L136.弹开:blip 2 `" V4 E% a$ ?& x- E! V( E8 q0 q6 ~6 k9 ~; y0 {: G. h! m
137.气泡:blister blistering ! W& [$ V* S# Y9 F
7 d9 T" e/ P0 \1 P138.吹孔:blow hole u. I- l7 ^ V2 r9 B& k
1 M5 o9 s( d* n9 E6 a4 y139.板厚错误:board-thickness error 1 l9 e- J% C0 I; |, s2 x% t/ f; c/ d! r% r* l5 e
140.黏结层:bonding plies ; ]1 ?$ l- k$ Y# s/ J) |/ ]* m$ a7 |7 H/ ^9 X% _# T
141.板弯:bow ; bowing
) w7 U2 d7 X& C: m u142.破空:break out
, z9 _, e, Z/ w0 x* q8 d143.搭桥;桥接:bridging / N T$ W( ]2 @- d g$ a# ?9 V) u7 m( K3 E( q' a: r2 s9 g
144.接单生产:BTO (Build To Order) " k: ?, P' W! _7 v" w9 E0 L
145,.烧焦:burning : H" d; L! J- D2 l7 N+ u0 r) j8 z7 [$ I
146.毛边(毛头):burr ( Y# x# {% Z$ a
147.碳化物:carbide
" ]5 M6 x! E ^. n3 E148.定位梢:carlson pin - ^/ T$ H, X* M$ x; C. |- E3 P0 [. Y
149.载运剂:carrier ! g' g8 \5 p7 Z. |6 _- {. X
150.催化:catalyzing ) X# ~# ?1 t- @1 G! f8 B
151.阴极溅射法:catholicsputtering ; t/ A# U% q, i! W1 C- y
+ ~5 t O& p3 H% F4 _7 _+ }* P152.隔板;钢板:caul plate " B# E: }" y' _8 [# v" o
153.校验系统之各种要求:calibration system requirements * b7 B2 U$ m4 Z: h) p% r8 k, t0 z1 h) X6 C
154.中心光束法:center beam method ( g8 M4 @, H$ r) A) ]: G3 a a6 O1 m
155.集中式投射线:central projection 2 P/ N2 K' n2 E; V' i J
156.认证:certification % F; L* J, I ]* }6 H9 E+ c
157.倒角 (金手指):chamfer chamfer ! u0 A. J S/ h& B+ p& ], u/ h) j
158.切斜边;倒角:chamfering
3 Q/ S: K9 z) d$ [+ R159.特性阻抗:characteristic impedance
, w- i: S. c3 B; K160.电量传递过电压:charge transfer overpotential ) C' R) z: x/ V& g3 O
. x0 Z( g1 U5 x% i2 w8 \, f161.网框:chase ( R+ C$ g/ i( ]5 Z
162.棋盘:checkboard * T9 r+ D) Z, j- I% i. y7 t# \' ?; x$ B/ Y4 e8 C
163.蟹和剂:chelator ( J+ }( W2 I7 i' X% ] L2 o2 v
164.化学键:chemical bond 4 C% i9 c1 F N! v$ z W4 c3 {
- z, j8 V7 o4 s! _165.化学蒸着镀:chemical vapor deposition ; {. f9 C8 y& O2 T+ \5 N2 o" Z" \4 d% ?: x
0 A& N0 J8 e. C1 j166.圆周性之孔破:circumferential void $ A& D! J& r8 k* A7 R- X
5 V8 F( G: [' A4 E& t& k' ?167.包夹金属:clad metal 8 l: s$ L) M. x9 }# X, T
168.无尘室:clean room : d' I& L+ Q1 F" i: b1 c o1 A! [% {
169.间隙:clearance
# y+ R2 z' S0 \1 L }170.表面处理:Coating/Surface Finish6 ^$ ?( r& I% ^ g+ O& v
