粒子群算法 - O. V7 D+ D0 ^
! r S% i/ n. @4 u
function [x, fval, exitflag, output] = pso(objfunc, nvars, options) % PSO Particle Sw ARM Optimization Algorithm % % PSO attempts to solve continuous optimization problem of the form % % min OBJFUNC(X) % X % % No constraints on the values of entries of X can be imposed, not ewen box contraints in form of % the lower and upper bound. Any desired constraints should be dealth with by modification of the % objective function: by introduction of penalty functions, by reformulation of the problem, or some % other way. % % In the present implementation, only classical 'star topology' PSO is considered, where each % particle is interconnected with each other particle, and there are no subswarms. Also, no % additional, GA like, operators are applied to the particles during the search. % % PSO(OBJFUNC, NVARS) Optimizes objective OBJFUNC defined as a real-valued function of a single, % real-valued vector argument. Dimensionality of the search space, that is the number of entries % in the argument of OBJFUNC, is defined in NVARS. PSO expects at least these two arguments. % Failure to provide any of them will result in error. % % PSO(OBJFUNC, NVARS, OPTIONS) Enables the user to specify a number of settings in order to % customize or fine-tune the pe RFormance of the algorithm. OPTIONS is a structure containing % desired values of these settings. Detailed description of available parameters is given in the % sequel. % % X = PSO(...) Returns vector at which objective attains its minimal value. Due to the nature of % PSO algorithm, this is not guaranteed to be neither exact global nor local optimum, yet PSO is % robust optimizer, well suited for complex, multimodal problems. Well tuned, it can give VERY % GOOD and quite commonly EXCELENT solution to the problem at hand. In most cases, this is all % that is needed. % % [X, FVAL] = PSO(...) In addition to the optimal X, it returns the value of the objective at X, % FVAL = OBJFUNC(X). % % [X, FVAL, EXITFLAG] = PSO(...) Returns indication concerning a reason why the algorithm stopped. % In the current implementation the only supported return values are 0 and 1. EXITFLAG 0 denotes % that maximum number of iterations has been achieved, while EXITFLAG 1 is used in testing mode, % if the value of global minimum has been found prior to achieving the maximal number of % iteration. % % [X, FVAL, EXITFLAG, OUTPUT] = PSO(...) Returns OUTPUT structure containing valuable information % concerning performance of the algorithm in the present run. The exact members of this structure % are variable, and depend on the settings specified in the OPTIONS structure. In general, there % are four levels of detail that can be specified. The 'LOW' detail level means that the algorithm % keeps track of objective value for the best, the mean and the worst particle in the swarm in % each generation. If the 'MEDIUM' level is specified, exact position and index of the global best % particle are tracked for during each iteration. If the 'HIGH' level is specified, exact position % of each particle in the swarm is logged during the entire search process. If the swarm is large % and the number of generations is great, high level output logging can result in considerable % memmory consumption. Finally, the output log level can be set to 'NONE', meaning that no data is % wanted within the OUTPUT structure. The exact way for specifying output logging level is given % below. % % OPTIONS = PSO('options') Returns default options structure. Usefull when one desires to change % values of only a handfull of options. % % The OPTIONS structure contains the following entries % % options.npart The number of particles in the swarm. % options.niter The maximal number of iterations. % options.cbi Initial value of the individual-best acceleration factor. % options.cbf Final value of the individual-best acceleration factor. % options.cgi Initial value of the global-best acceleration factor. % options.cgf Final value of the global-best acceleration factor. % options.wi Initial value of the inertia factor. % options.wf Final value of the inertia factor. % options.vmax Absolute speed limit. If specified, the speed is clamped to the range % [-options.vmax, options.vmax]. It is the primary speed limit, if set % to NaN, the VMAXSCALE options is used. % options.vmaxscale Relative speed limit. Used only if absolute limit is unspecified, i.e. % set to NaN. If used, must be a scalar quantity, and denotes the amount % of initial population span (the INITSPAN option) used as the speed % limit. % options.vspaninit The initial velocity span. Initial velocities are initialized % uniformly in [-VSPANINIT, VSPANINIT]. This option must be specified. % options.initoffset Offset of the initial population. Can be scalar or column-vector of % dimension NVARS. % options.initspan Span of the initial population. Can be scalar or column-vector of % dimension NVARS. % options.trustoffset If set to 1 (true) and offset is vector, than the offset is % believed to be a good solution candidate, so it is included in % the initial swarm. % options.initpopulation The user-suplied initial population. If this is set to something % meaningfull, then INITSPAN, INITOFFSET and TRUSTOFFSET are % ignored. If set to NaN then the above mentioned offset is used. % options.verbose_period The verbose period, i.e. the number of iterations after which the % results are prompted to the user. If set to 0, then verbosing is % skipped. % options.plot If set to 1, evolution of the global best is ploted to the user after % the optimization process. The objective value of the best, mean % and worse particle troughout the optimization process are plotted % in the single graph. % options.output_level The output log level. Possible values are: 'none', 'low', % 'medium', 'high'. Each log level denotes a specific amount of % information to be returned to the end user. If less than 4 output % arguments are specified log level is ignored, since it would only % occupate (possibly) large amount of useless memory. % options.globalmin Global minimum, used for testing only. If specified, the algorithm % will stop as soon as the difference between GLOBALMIN option and % current global best becomes less than TOL option. % options.tol Precision tolerance, used for testing only. It is maximal difference % between current global best and GLOBALMIN option at which the % algorithm stops. If GLOBALMIN options is set to NaN this option is % ignored, and the algorithm stops after the maximal number of iteration % has been achieved. % % The OUTPUT structure is the fallowing % % output.itersno The actual number of iterations. Usualy the same as NITER options, but % can be less if in testing mode (if GLOBALMIN option is specified). % % If at least LOW level output logging is specified: % % output.gbest_array % output.gmean_array % output.gworst_array Arrays containing the objective value of the best, mean and worst % particle in each iteration. In fact, gmean_array does not contain % objective value for any concrete particle, but instead it contains the % mean objective value for the entire swarm in each iteration. % % If at least MEDIUM level output logging is specified: % % output.gbes**x_array The array ontaining indices of the best particle in each iteration. % output.Xbest Matrix of dimension NITERxNVARS, containing, as rows, global best % particles in each iteration. % % Only if HIGH level output logging is specified: % % output.X 3D matrix of dimension NPARTxNVARSxNITER containing the entire % population in each iteration. % % % The following examples ilustrate the use of PSO function in several common cases. % % Suppose we are attempting to optimize 5-dimensional objective f(x) = x*x'. Since, it is assumed % that objective receives a row-vector, the objective is in fact a 5D paraboliod. The easiest way % to optimize would be to write % % obj = @(x) x*x'; % [xopt, fopt] = pso(obj, 5); % % The preseding code lines would yield XOPT as the found near-optimal solution and FOPT as the % objective value in such point. Of course, other outputs can be obtained as described earlier. % % If one should choose to change the default options (say to specify different number of particles % and iterations), the code would look something like this % % obj = @(x) x*x'; % options = pso('options'); % options.niter = 500; % options.npart = 60; % [xopt, fopt] = pso(obj, 5); % % Other options can be specified as well on the exactly the same way. The best way to explore the % option structure is to experiment. % % PSO is compatible with MATLAB 7 and higher. Some modifications are needed for it to work under % lower versions of MATLAB. %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % Checking the number of input and output arguments. % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% msg = nargchk(1, 3, nargin); if ~isempty(msg) error('mrr:myoptim:pso:pso:narginerr', 'Inadequate number of input arguments.'); end msg = nargchk(0, 4, nargout); if ~isempty(msg) error('mrr:myoptim:pso:pso:nargouterr', 'Inadequate number of output arguments.'); end %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % The body of the algorithm. % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% if nargin==1 && ischar(objfunc) && strcmp(objfunc, 'options') % User desired only to access the default OPTIONS structure. if nargout<=1 x = getDefaultOptions(); else % The user required multiple outputs, yet only default options can be returned. error('mrr:myoptim:pso:pso:nargouterr', ... 'Cannot expext more than one output when only OPTIONS are required.'); end else %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % User requested optimization to be conducted on a given objective. % % The following code deals with initializations and validations of options structure. % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % If no options are specified, use the default ones. if nargin<3, options=getDefaultOptions(); end % Determination of output level, that is of amount of data to be collected in OUTPUT structure. if nargout == 4 % User supplied four output arguments, therefore output level is determined from the OPTIONS % structure. The output_level variable is used to code the desired log level: 0 ('none'), 1 % ('low'), 2 ('medium') and 3 ('high). if strcmp(options.output_level, 'none') if options.plot == 0 output_level = 0; else output_level = 1; end elseif strcmp(options.output_level, 'low') output_level = 1; elseif strcmp(options.output_level, 'medium') output_level = 2; elseif strcmp(options.output_level, 'high') output_level = 3; else error('mrr:myoptim:pso:pso  ptionserr  utput_level', ... 'Invalid value of the OUTPUT_LEVEL options specified.'); end else % User has not supplied forth output argument. The only reason to log information during the % run is to be able to plot to to the user after the optimization process. Therefore, if % ploting is requested low level logging is used. if options.plot == 1 output_level = 1; else output_level = 0; end end % Maximum velocity can be specified in absolute amount, or relative to the initial span. % If both values are specified, the absolute velocity limit is taken into account, while the % relative is ignored. Whatever the initial specification of the maximal velocity, the curent % code block will generate a column vector, vmax, containing maximal velocity along each % dimension of search space. if ~all(isnan(options.vmax)) % It is not allowed to let some of the entries of the VMAX option to be NaN and others to % have numerical or Inf values. if any(isnan(options.vmax)) error('mrr:myoptim:pso:pso  ptionserr:vmax', ... 'VMAX option cannot have some Inf and some numerical (or Inf) values.'); end % Warning of the confusing entries within the OPTIONS structure. if ~isnan(options.vmaxscale) warning('mrr:myoptim:pso:pso:optionserr:vmaxconflict', ... 'Both relative and absolute velocity limit are specified. The relative limit is ignored.'); end if length(options.vmax) == 1 vmax = options.vmax*ones(nvars, 1); elseif length(options.vmax) == nvars % Maximal velocity should be a column-vector or a scalar. if size(options.vmax, 1) ~= length(options.vmax) error('mrr:myopim:pso:pso:optionserr:vmax', ... 'VMAX option should be specified as column-vector, or as a scalar value.'); end vmax = options.vmax; else error('mrr:myoptim:pso:pso:optionserr:vmax', ... 'Inadequate dimension of VMAX option. Should be a scalar, or a column vector with NVARS elements.'); end else % It is not valid to specify both VMAX and VMAXSCALE option as NaN. if isnan(options.vmaxscale) error('mrr:myoptim:pso:pso:optionserr:vmaxscale', ... 'Either VMAX or VMAXSCALE options should be different than NaN.'); end % Contrary to the VMAX options, VMAXSCALE option must allways be a scalar. The initial span % should take into account the different scaling among the cooedinates of the search space. if length(options.vmaxscale) == 1 if length(options.initspan) == 1 vmax = options.vmaxscale*options.initspan*ones(nvars, 1); else % If the dimension of INITSPAN option is not correct, the function will break later, % therefore, no need to check validity now. vmax = options.vmaxscale*options.initspan; end else error('mrr:myoptim:pso:pso:optionserr:vmax', ... 'Inadequate dimension of VMAXSCALE option. Must be a scalar.'); end end vmax = repmat(vmax', options.npart, 1); % Initial population. % If the initial population is not supplied by the user, each particle of the initial population % is spred in [INITOFFSET-INITSPAN, INITOFFSET+INITSPAN] where both INITOFFSET and INITSPAN % are specified within the OPTIONS structure. Both of these options are either scalars or % column-vectors of appropriate size. If INITPOPULATION option is specified, both INITOFFSET and % INITSPAN options are ignored. if ~isnan(options.initpopulation) % The user supplied complete initial population within the OPTIONS structure. % The size of the supplied population must be consistent with population size and number of % variables. If no, an error is reported. [pno, pdim] = size(options.initpopulation); if (pno ~= options.npart) || (pdim ~= nvars) error('mrr:myoptim:pso:pso:optionserr:initpopulation', ... ['The format of initial population is inconsistent with desired population', ... 'size or dimension of search space - INITPOPULATION options is invalid']); end X = options.initpopulation; elseif (length(options.initoffset) == 1) && (length(options.initspan) == 1) % The same offset and span is specified for each dimension of the search space X = (rand(options.npart, nvars)-0.5)*2*options.initspan + options.initoffset; elseif (length(options.initoffset) ~= size(options.initoffset, 1)) || ... (length(options.initspan) ~= size(options.initspan, 1)) error('mrr:myoptim:pso:pso:optionserr:initoffset_initspan', ... 'Both INITOFFSET and INITSPAN options must be either scalars or column-vectors.'); elseif (length(options.initoffset) ~= nvars) || (length(options.initspan) ~= nvars) error('mrr:myoptim:pso:pso:optionserr:init', ... 'Both INITOFFSET and INITSPAN options must be scalars or column-vectors of length NVARS.'); else initoffset = repmat(options.initoffset', options.npart, 1); initspan = repmat(options.initspan', options.npart, 1); X = (rand(options.npart, nvars)-0.5)*2.*initspan + initoffset; % TRUSTOFFSET option is used when OFFSET option is, in fact, previously known good (or very % good) solution to the problem at hand. When set to logical true (1), offset is inserted in % the initial population. Thus, it is guaranteed that objective value at solution is not % greater than objective value at that, previously known, good point. if (options.trustoffset) X(1,  = options.initoffset'; end end % Initial velocities. % Velocities are initialized uniformly in [-VSPANINIT, VSPANINIT]. if any(isnan(options.vspaninit)) error('mrr:myoptim:pso:pso:optionserr:vspaninit', ... 'VSPANINIT option must not contain NaN entries.'); elseif isscalar(options.vspaninit) V = (rand(options.npart, nvars)-0.5)*2*options.vspaninit; else if (length(options.vspaninit) ~= size(options.vspaninit, 1)) || ... (length(options.vspaninit) ~= nvars) error('mrr:myoptim:pso:pso:optionserr:vspaninit', ... 'VSPANINIT option must be either scalar or column-vector of length NVARS'); end V = (rand(options.npart, nvars)-0.5)*2.*repmat(options.vspaninit', options.npart, 1); end % Initial scores (objective values). % Initialization of the best personal score and position, as well as global best score and % position. Y = calcobjfunc(objfunc, X); Ybest = Y; % The best individual score for each particle - initialization. Xbest = X; % The best individual position for each particle - % initialization. [GYbest, gbest] = min(Ybest); % GYbest is the best score within the entire swarm. % gbest is the index of particle that achived YGbest. gbest = gbest(1); % In case when more than one particle achieved the best % score, we choose the one with the lowest index as the % best one. % These variables are used in testing mode only. tolbreak = ~isnan(options.globalmin); foundglobal = 0; if tolbreak && ~isscalar(options.globalmin) error('mrr:myoptim:pso:pso:optionserr:globalmin', ... 'globalmin option, if specified, option must be a scalar value equal to the global minimum of the objective function'); end % Initialization of the OUTPUT structure. % The output structure is filled and initialized differently depending on the OUTPUT_LEVEL % options, or equivalently depending on the output_level variable. if output_level >= 0 % NONE log level output.itersno = options.niter; if output_level >= 1 % LOW log level output.gbest_array = NaN*ones(options.niter+1, 1); output.gmean_array = NaN*ones(options.niter+1, 1); output.gworst_array = NaN*ones(options.niter+1, 1); output.gbest_array(1) = GYbest; output.gmean_array(1) = mean(Ybest); output.gworst_array(1) = max(Ybest); if output_level >= 2 % MEDIUM log level output.gbes**x_array = NaN*ones(options.niter+1, 1); output.Xbest = NaN*ones(options.niter+1, nvars); output.gbes**x_array(1) = gbest; output.Xbest(1,  = X(gbest,  ; if output_level == 3 % HIGH log level output.X = NaN*zeros(options.npart, nvars, options.niter+1); output.X(:,:,1) = X; end end end end if options.verbose_period ~= 0 disp 'PSO algorithm: Initiating the optimization process.' end % Denotes normal algorithm termination. exitflag = 0; %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % The main loop. % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% for iter = 1:options.niter % Verbosing, if neccessary. if options.verbose_period ~= 0 if rem(iter, options.verbose_period) == 0 disp(['iteration ', int2str(iter), '. best criteria = ', num2str(GYbest)]); end end % Calculating PSO parameters w = linrate(options.wf, options.wi, options.niter, 0, iter); cp = linrate(options.cbf, options.cbi, options.niter, 0, iter); cg = linrate(options.cgf, options.cgi, options.niter, 0, iter); % For later calculations only GXbest = repmat(Xbest(gbest, :), options.npart, 1); % Calculating speeds V = w*V + cp*rand(size(V)).*(Xbest-X) + cg*rand(size(V)).*(GXbest-X); V = min(vmax, abs(V)).*sign(V); % Population is moving X = X + V; Y = calcobjfunc(objfunc, X); % Calculating new individually best values mask = Y<Ybest; mask = repmat(mask, 1, nvars); Xbest = mask.*X +(~mask).*Xbest; Ybest = min(Y,Ybest); % Calculating new globally best value [GYbest, gbest] = min(Ybest); gbest = gbest(1); % Filling in the OUTPUT structure. if output_level >= 0 % NONE log level if output_level >= 1 % LOW log level output.gbest_array(iter+1) = GYbest; output.gmean_array(iter+1) = mean(Ybest); output.gworst_array(iter+1) = max(Ybest); if output_level >= 2 % MEDIUM log level output.gbes**x_array(iter+1) = gbest; output.Xbest(iter+1, :) = X(gbest, :); if output_level == 3 % HIGH log level output.X(:,:,iter+1) = X; end end end end % The code used in testing mode only. if tolbreak && abs(GYbest - options.globalmin)<options.tol output.itersno = iter; foundglobal = 1; break end end if options.verbose_period ~= 0 disp 'Optimization process finished.' end % Setting up the output variables. % X is set to be the final global best position, since that is the best position ever achieved % by any of the particles in the swarm. FVAL is set to be the value of the objective in X. x = Xbest(gbest, :); x = x(:); fval = GYbest; % The global moptimum has been found prior to achieving the maximal number of iteration. if foundglobal, exitflag = 1; end; % Plotting the algorithm behavior at each iteration. if options.plot r = 0:options.niter; figure plot(r, output.gbest_array, 'k.', r, output.gmean_array, 'r.', r, output.gworst_array, 'b.'); str = sprintf('Best objective value : %g', fval); title(str); legend({'best objective', 'mean objective', 'worst objective'}) end end function Y = calcobjfunc(func, X) % CALCOBJFUNC A helper function used to calculate objective function value for a series of points. np = size(X,1); Y = zeros(np,1); for i = 1:np Y(i) = func(X(i,:)); end function opts = getDefaultOptions % GETDEFAULTOPTIONS Returns a structure containing the default options. % % This function, in fact, defines default values of the options within the options structure. opts.npart = 30; % The number of particles. opts.niter = 100; % The number of iterations. opts.cbi = 2.5; % Initial value of the individual-best acceleration factor. opts.cbf = 0.5; % Final value of the individual-best acceleration factor. opts.cgi = 0.5; % Initial value of the global-best acceleration factor. opts.cgf = 2.5; % Final value of the global-best acceleration factor. opts.wi = 0.9; % Initial value of the inertia factor. opts.wf = 0.4; % Final value of the inertia factor. opts.vmax = Inf; % Absolute speed limit. It is the primary speed limit. opts.vmaxscale = NaN; % Relative speed limit. Used only if absolute limit is unspecified. opts.vspaninit = 1; % The initial velocity span. Initial velocities are initialized % uniformly in [-VSPANINIT, VSPANINIT]. opts.initoffset = 0; % Offset of the initial population. opts.initspan = 1; % Span of the initial population. opts.trustoffset = 0; % If set to 1 (true) and offset is vector, than the offset is % believed to be a good solution candidate, so it is included in % the initial swarm. opts.initpopulation = NaN; % The user-suplied initial population. If this is set to something % meaningfull, then INITSPAN, INITOFFSET and TRUSTOFFSET are % ignored. opts.verbose_period = 10; % The verbose period, i.e. the number of iterations after which the % results are prompted to the user. If set to 0, then verbosing is % skipped. opts.plot = 0; % If set to 1, evolution of the gbest is ploted to the user after % the optimization process. The objective value of the best, mean % and worse particle troughout the optimization process are plotted % in the single graph. opts.output_level = 'low'; % The output log level. Possible values are: 'none', 'low', % 'medium', 'high'. opts.globalmin = NaN; % Global minimum, used for testing only opts.tol = 1e-6; % Precision tolerance, used for testing only function x = linrate(xmax, xmin, tmax, tmin, t) % LINRATE Linear interpolation of value X in instant T, defined by previously known points % (tmin, xmin), (tmax, xmax) x = xmin + ((xmax-xmin)/(tmax-tmin))*(tmax-t);
% V; P4 m' M4 k0 [9 y8 X |
