* t/ m% }" O+ h8 S8 S' uGPRS模块使用的说明
; d$ n$ \6 {$ D( v- I4 R使用GPRS首先需要打开串口,设置好串口的各项参数。. a" l7 d! c# V; V, }8 p, h# T! H
) W/ a, U! T! O. o5 n一、AT+CMGL 读取所有短信$ S* w ?7 c5 g5 Z
A、读取所有的信息:/ R# F7 U$ @0 `, p4 O
8 Y9 Q% g+ H; w/ d {# ~4 `
第一步:at+cmgf=1 如果返回ok则继续。
8 c" p& B6 H5 F/ z8 J1 n4 O: G1 A1 y. x9 k, D
说明:AT+CMGF SELECT SMS MESSAGE FORMAT+ J" F$ }) [ S, l
$ N7 I7 \/ O' s6 a/ b7 B* F第二步:at+cmgl=”all”
5 r; v+ q% M/ |- U- [. H# q* W$ B# B; J9 r, @
成功返回OK否则ERROR
: E& \" T5 c9 ~& @& ?. T/ z8 ?
+CMGL: 1,"REC READ","+8613702936376",,"05/12/16,09:04:43+00"
$ S* [5 q1 `5 ^9 x2 ` d5 ^% g% J6 ^' Z9 _. w; B3 R" V3 r
test- p1 f8 c c# B7 i3 b0 F
1 _: c1 Q: N* g6 L
OK" C6 s7 T) k8 u7 { ]
4 U1 S+ Y# q. X T
B、读取未读的信息 [5 V4 B1 L* u2 x
2 I0 ~( f' J' i5 N1 p
第一步:at+cmgf=1
# c, v5 c. c2 X( N8 u: L9 A: m7 F! a
如果返回ok则继续。
/ O" w' Y7 H. T4 a/ X6 e8 l
7 X% r8 E; U' @7 ^4 ]第二步:at+cmgl=” rec unread”/ `; L; ?3 g1 C: i
6 L. A9 b' u) f2 }" R成功返回OK否则ERROR+ [6 l0 ]2 Z9 X4 N/ ]. M& R
; ?8 ~; [6 K0 T2 sC、读取已读的信息6 l* X3 x$ W; _/ |; t% h
) Y! F$ P2 n B' I# D/ j* }第一步:at+cmgf=1
" ^8 _+ Z8 @% U7 o. q! W9 o4 ^- z6 Q
- e/ v' |2 Y. D8 J如果返回ok则继续。; l- |: k: d" o: ?5 |4 K& }
& \" v( w' h7 ?5 R( o7 `% G第二步:at+cmgl=” rec read”
# ]6 `: N' ~1 }3 X. X% z/ w+ H$ \$ c& o
成功返回OK否则ERROR
0 H0 ^- {9 O& T! u- I) @/ v+ j! I0 P8 i+ s- z5 y
AT+CMGL参数: t, u" v8 n" z3 j/ k
+ g0 Z( _- ?. w" S( x
1) If text mode:+ ], F+ r ]6 G
# j% [2 [* c& t# p0 V
"REC UNREAD" Received unread messages (default)0 S& @: L6 [- A5 f; N! \. }. I1 m
; {6 D2 W y0 P0 Z2 n: o
"REC READ" Received read messages
3 x" R- J% z$ a7 ], ~
( Y! `" R5 \" I% F9 `% [ "STO UNSENT" Stored unsent messages
) }8 M3 `) N: T' S$ V* P- g
! t# i5 y# Q2 l# C& k "STO SENT" Stored sent messages
1 a9 D. U4 F4 L! d3 A$ c0 u# x$ N" M) ]$ c( ?2 T
"ALL" All messages
: f* Y7 y7 h( ~7 J- N/ |6 w0 |$ K/ }* H7 J
2) If PDU mode:
5 z9 Z L1 M: t; g2 t- [) T# E* {9 ?+ z
2 \9 k7 A( W7 h& N 0 Received unread messages (default)
5 V7 L2 M$ M+ V( j* a
& J/ w `. L! u$ p3 w# }9 O 1 Received read messages
, b- ^4 m8 H) F
1 w' E& X4 a7 p 2 Stored unsent messages& a: K% ]+ l# R, F1 |
& q9 J" J# i# h/ ?# l! G 3 Stored sent messages
- R: }- q4 d* z+ Q( p3 T- k: v# X; X$ @ @
4 All messages+ B$ d; v$ _* y4 F8 |* {: ^
# ]# f7 y* {2 ]8 s! E二、AT+CMGR Read SMS message" j( t% Q' H! R' q
从X存储区读短消息:2 F! W1 ~/ Y0 `: n( n! J
7 z; |' A. C0 z
! Q' o0 g7 n4 p; L& M. ~
# v, p: J3 V7 R; w9 J 第二步:at+cmgl=x
; W8 p, r0 ~, K5 ?# y$ J
$ u/ f& ?5 r* x9 J三、AT+CMGD Delete SMS message
5 \3 l4 G, E; m+ e6 \: \& R删除信息:8 ^- S, D4 i& U3 t* H1 j7 \
3 ?5 E% q, t& q$ |3 F5 g 第一步:at+cmgf=1
. i& [3 T: P4 e& B; L* E
8 U5 p2 |9 _1 ^ 如果返回ok则继续。1 R- \; a+ Z A2 y- s7 N
- o3 s5 [! Y0 f6 Z3 m# u5 m) K
第二步:at+cmgd= 数字号
% p$ y) p5 s7 t) X& K- U$ \# p2 t2 e3 U' a
成功返回OK否则ERROR
8 i: K) x6 K: [8 t
4 @# N! `# @5 @; P9 G+ `四、AT+CSCA SMS service centre address(设置短信中心号码) w) K3 a' s9 M; L; \
设置短信中心号码:' z% {: f% K- g7 y3 q- [- V
9 ]' |* u: W& H0 k! \ 第一步:at+cmgf=1' ?, Q4 u3 m9 L' a/ q
3 \2 g# X6 w$ r$ F* k 如果返回ok则继续。9 I( Z# I& B1 I; n
0 d8 u6 @5 g4 r$ o% L+ `% G
第二步:at+csca=”短信中心号码” (比如+8613800546500)2 Q8 g2 v) q3 F. ^' B4 K+ U
! v) Q8 L7 C$ k% R* S
成功返回OK否则ERROR, L3 A6 Z% S3 I" D; ?
5 \( f, t ]: c/ N g4 i五、AT+CMGS Send SMS message (发送信息)
' E5 H$ u# H! \! ~发送信息:0 k3 s P* r/ f `& C
/ e& l& O i; A: L2 o$ D 第一步:at+cmgf=10 Z$ o$ O9 k6 a( J
& E5 n/ ?7 N+ c. u9 Y( ]# k0 t 如果返回ok则继续。+ i: P/ u, ]- ~/ @! K( h0 d
4 w* ?5 ?0 z! U" Y* r- ^- B 第二步:AT+CMGS=“+8613xxxxxxxxx”<回车>6 L# r, ]! ^8 ]4 B
7 k0 z4 t6 f: h7 p2 I0 h0 P* E0 k) q
>输入短消息。Crtl+Z结束并发送。6 f& h6 E# U% K3 Z) p
5 x" k6 Z: t2 j3 m注:此只能发送英文与数字 E: g. c7 K2 @0 r- S
. M8 ]* c V" k5 Q$ T六、查询3 `' P6 c3 n* S
查询设备:9 \1 S/ T$ b8 _: J; ^1 z/ q
6 \! _5 f1 q) ~$ |0 V0 b; g2 _命令:AT+CGMI<回车>. O9 _5 _( n+ {. {' w5 |
" z+ q* q# S! \( B5 _; b5 d+ N返回:SIEMENS
3 ]( F$ X- Y- H- q P1 n" `# R( z) A. E2 N
返回:OK4 J& _% O; \3 Y# H+ S
: b, O- q) T- L0 z# q命令:AT+CGMM<回车>
* c* K& e2 E" x
5 N; x3 e4 G& T返回:MC35i0 s# e5 C( B4 b8 |& M
$ h1 w C. P8 t
返回:OK
' T1 P+ U! U' ]0 F/ j+ q! I& O" i+ t& {8 j$ p, m
命令:AT+CMEE=1<回车>
8 B) Q6 X: q6 m+ D; \8 o4 ]! Z. t# y6 Z0 v! `) L
返回:具体的错误代码
5 L& p Q& @) h( W6 x9 h
4 ?$ E8 q5 F* |4 z) }# ?- e/ VATZ;E 回车 Echo OFF
* a2 l s2 M7 y0 c; Z* F
5 _7 Q+ z1 b9 E$ H/ r }# c* XATZ;E1回车 Echo ON
- n4 O, V7 Q7 [, H
! J2 u3 f3 r6 K5 s1 c wAT+CREG?回车 回答x(X=2脱网,X=1注册,X=0状态不明) @2 Y( o% w# k4 M/ [8 @* Q `
6 b4 W* V7 p$ ^! \" R* |6 {
AT+COPS?回车 表示SIM卡是否被网络接受
2 m0 M' n4 o n$ A' h
t. y; d7 K$ R% lAT+COPS=?回车 显示所有可用的网络。
1 x) {, _& P$ {
) C: v8 ^' [) N/ z# G: VAT+CREG?回车(是否网络注册)4 h- T" N4 x C2 |. M
# \7 j+ e* _9 ?2 W' ` a: TAT+CSQ SIGNAL QUALITY REPORT
3 i& d& M4 D8 N# ?1 N* d. l! h1 h+ @
8 A! j+ Y5 o: RAT+IPR=2400 回车(改变RS232口的速率至2400bps)/ f! T! D. P3 A& ]6 |
" O+ z! b0 @% X* r* S X
AT&W 回车 (保存已改参数)
" V- E$ z" E0 w% w' K( q5 `7 b/ v0 V; o* X3 G( }2 ~+ G
输入PIN码:AT+CPIN=“xxxx”
1 k. L( m2 E @' z* ?! ?$ o' _( e8 r9 i9 X Q! ~1 e* A2 Y
七、网络是否注册(AT+CREG?)8 h2 z4 \% `2 _0 P) u
命令:at+cmgf=1
g6 Y) ]) D' m% p- k0 v5 Y7 l6 x; l! P; p& r
返回:at+cmgf=1 返回:OK
1 A w5 [, ^1 _3 R5 H" I7 Q! J6 L8 |3 p# \& j
, N9 l4 q. `# }
8 B. a6 h, ]3 @: b( J9 i命令:AT+CREG?0 h$ h# z3 L- B
3 ~, I" U5 ]- J& c6 G% f& e$ D
返回:AT+CREG? 返回:+CREG: 0,15 o5 ], B: D7 ~/ V1 p2 F
% ?/ A( X' j& ]. D注:( 2脱网, 1注册, 0状态不明)) Q* v* i! S/ J* c$ \" o2 b
- P- {. d# l. s% T, X$ W+ m! R返回:OK
0 p/ H. M. ~/ o3 Q3 f! Z& v/ L* r; y( d2 W# t9 N, `, h5 @. s
5 s& ^4 _! S! u z. l7 _ o; h
j2 @) J6 v: {0 \. k八、SIM卡是否被网络接受(AT+COPS?)! q" V. B- }) f9 r! Z
命令:at+cmgf=1! Q7 L, E7 I2 V& Z$ o% H
; y* I' Z3 G/ k. i+ a1 g5 Q返回:at+cmgf=1
# @' O- m1 H5 B. _) r& @$ w) q/ F2 R h! i7 r
返回:OK
[4 C5 @* [5 C) d% {! B6 o9 V, h0 I2 C& S/ C( Y
4 N8 X. c* Y% e9 v6 _* R# |, F( @! D, F9 F
命令:at+cops?/ N7 x& P) U' j! X% h6 v B- C3 H
$ ]* @) y$ H7 q+ Z! h4 S6 o 0 q/ z' w) p6 y$ U: c$ O
: J4 I/ g0 Q- h! q6 G, u' ^& f
返回:+COPS: 0,0,"China Mobile". n/ g9 E- x' d9 F
, X5 W7 s! m2 c3 N 3 A! k3 z+ z3 k% n6 O
4 X# M9 P# [+ G! R: @返回:OK t7 m5 d6 S! p0 s3 c
( ?" o- Y$ ?/ h8 O - C4 N H! l0 I/ v
/ Q9 u1 B. Q& A% y$ _5 L九、显示所有可用的网络(AT+COPS=?)
( v3 A+ q$ r( T命令:at+cmgf=1
; H+ b' a, C5 m; _& T5 {& G j2 M2 j$ S9 e# L L) Q
返回:at+cmgf=1, v& V2 P; z# {
6 R7 D+ _1 X" B b3 ]9 M9 b, s返回:OK9 n: J* m3 W* t% c1 T1 I# F
3 Y8 h1 H$ g8 Q5 t9 n
命令:at+cops=?
6 V! N3 o$ X% N6 {4 ]5 }# W1 r( g1 u7 O& I8 X
返回:+COPS: (2,"China Mobile",,"46000"),(3,"China Unicom",,"46001"),,(0-4),(0,2)1 Z$ D9 c: J3 i$ L; k( m
* Z, ^. W3 T6 f# ]7 a* o6 P) b返回:OK
* g1 t0 G) R% Q7 ?2 |0 C- p/ k! W. I3 n2 L! U, G1 \! s
十、打电话
: Q% J3 t7 u% Q- aDemonstration Syntax Expect Result! A: V8 ~( u7 J) a" l8 I1 K: ]
$ E; _, V {: f+ X
Make a voice call ATD6241xxxx; OK MS makes a voice call! C! ]' L* i7 p5 d U7 M
" ?2 {+ g8 [- x* h
Hang up a call ATH OK Call dropped
! z4 j/ M+ `. g" Q/ Q E) p/ Z* x5 {' m0 h, _, V( E) \% }* J# B
0 V2 i% b8 U; j' g( ?* Q! A9 B
9 a5 o$ Z& g, q4 c( e0 r; G
8 r; y+ h' H1 l
0 |' [# Z/ [7 B3 w# E' Y& m ' j0 m3 i/ w& R7 R' ]
9 o: X. y2 Q2 f# O! k6 k. I {$ m问题解决, U( `# G" R9 s7 g, x' e, x
采用sim300发送短信时采用下面的格式
/ y- a, x% ^5 v% j7 g
- ?, }& }% @- yAT+CMGF=1 设置文本格式( j8 {0 G6 R' I) O' j2 ~+ j: U* I
& L% [5 a7 i, p+ M9 PAT+CMGS=”13245678912” 注意这块一定要加上双引号。否则返回ERROR8 o1 \; O& s$ p2 {
7 J/ }8 Z$ F& v1 S: @$ J y9 a
另外如果发送不出去,有可能是短信中心号码设置的不正确。9 X* P6 H8 ~2 |$ k) k* b: o
7 B& Z* u4 Q( l6 _, v
完整的程序3 U0 \9 _8 O: q& a+ h
// this is a test about GPRS
3 _% u* p) s* V8 N/ \1 l, T- z, `/ u! _2 B- a
% M1 ?/ a+ m3 [
9 `" G4 S1 T* r9 L4 j6 T#include <stdio.h>9 {4 J) C c, E) u5 v
6 a% c& l, I e/ N#include <string.h>
% e" j' ] U4 b
1 V, H0 ?4 B; z2 A( l( x) U& c. @#include <stdlib.h>, G9 `. i. f; e2 x
1 r- Z' {! |% U+ U0 U, l9 E% M
7 z T- P/ }. E( b/ H2 B" }% ]7 H- H3 E/ s
#include <fcntl.h> // open() close()
& u* i- a/ \( N5 \3 L3 f$ Q9 @" J* V$ \# M4 u) o) F
#include <unistd.h> // read() write()0 K x4 s9 Y3 @
# Z7 b3 c# W W9 y- |7 }) v
+ r, ~/ K9 \ U& r/ a
o& c" a6 w4 e. A. C#include <termios.h> // set baud rate
# C' V3 l% m. l( h& F/ P0 Z j6 E$ T
6 a" J: d% G3 w& Y* m$ s. S4 t5 K
#include <fcntl.h>
9 ]8 Q6 Z/ w8 r& {; b. ?' Z
o" I# }! K7 C#include <sys/select.h>
- b: U5 ^0 W# i/ O6 ~
! z3 h' H. K( l1 d#include <sys/time.h>2 U' e. ?7 Y& D. w4 i2 `
& u9 \% r, s0 [; J# f#include <sys/types.h>
# P ]! o8 W' a% x' _/ X, {0 `. I4 j
! M1 h6 Q8 x: h/ \
" \) w) _. i3 q! y* z/ w" u1 I#define FUNC_RUN 0- v; z/ E+ |# z" R4 L7 j: A" t
3 ^' o$ m% v4 l& t
#define FUNC_NOT_RUN 15 g0 S9 A0 Y1 Q
- G6 o6 Y+ E' K; D3 z 9 \% ^# T$ W5 ?3 B0 z
% G( F* g% h, l" L
#define SIMPLE_TEST 1$ q3 p. M- I, ?6 m3 A+ w
% K/ m3 E7 |! N( q# u* d#define READ_SIM_CARD_ID 2
; z: p9 A I) C' D' P6 f' F
7 Y- o' `3 _9 E. C2 h- S#define GSM_GPRS_SIGNAL 3
7 @6 @7 ^/ I$ c
+ r) I; c5 A3 ]- N' E0 g8 T#define MAKE_A_CALL 44 y& U( F) K9 |" b/ g
( O2 V% j( V H6 s#define WAIT_A_CALL 5/ X1 [7 {9 \+ }& h$ I
. Z: q/ B# X0 i+ q) A' ^
#define SHORT_MESSAGE 6
4 a2 w$ c |/ v6 n) g% n6 }$ N1 P* V: \
#define POWER_MANAGE 7" a* V% c" [. i( `+ R. p
3 d: ?: ]" @ g/ \1 o# s
#define FUNC_QUIT 81 w l' m5 G7 X$ e) Y/ A6 f4 h
9 k6 T$ i; z- U 8 R+ j$ [, R3 ? d4 g) G
; l8 Q3 B& j* [2 g+ O
#define SEND_SHORT_MESSAGE 1& C' t* J8 R" ]. p
/ H, l! U. W- b' A; k# j& j#define READ_SHORT_MESSAGE 26 Q0 C5 f1 u6 D, a6 ^
4 H1 O; P* n. p5 B9 E4 `& v" u
#define CONFIG_SHORT_MESSAGE_ENV 3
# f8 v! b9 i. \* B( K: ?9 W# L& f, F `2 f& `/ o2 l
#define QUIT_SHORT_MESSAGE 4% [( \1 y5 Q% S9 W
0 s0 W3 a1 X- z8 n+ k$ Y
0 T/ l3 Y& @, A4 [2 R
# V$ e9 n8 B% Y3 f% m, C#define DEVICE_TTYS "/dev/ttySAC1"
; [; D# O# m. ^; A$ z7 ?; u5 r5 V9 F0 l7 L, k9 W# R1 n% l% @ z
#define MAX_LEN_OF_SHORT_MESSAGE 1403 ?, U/ R( h4 n$ v3 d/ C
( b6 S& |7 c7 F8 a
* `+ |9 o& ?& M4 X9 c! Q1 d
1 d3 k0 t' N) X8 F d
0 i( k7 O, l6 U* z/ @4 D3 G4 j4 H5 D( b6 ?
#define RECEIVE_BUF_WAIT_1S 13 a2 @7 }) n$ H5 A( O
- h; }6 A6 u1 e/ J2 {! f) E$ L4 o
#define RECEIVE_BUF_WAIT_2S 2
) y2 V! z: E. v( k! w6 r
2 ~$ ?8 r$ ?2 t#define RECEIVE_BUF_WAIT_3S 3
; h2 A3 a' ]9 t( Q* W6 z, q4 x4 j5 {2 P; I+ x' t8 R' b! w
#define RECEIVE_BUF_WAIT_4S 45 ?: U8 t! [+ I5 T+ i
" x. ?9 y- k. k E2 n2 J5 u#define RECEIVE_BUF_WAIT_5S 5
2 Q5 a; b. }- `) z* w5 F2 ^+ R
. o6 S: d8 N$ s4 Z) |0 b4 v
$ T- w x& |% f% c9 { N2 h3 e- h( _" k; }/ {4 D7 u
#define VERSION "YHPDA_GSM_1.0.0"
* R( I: J2 _! O* @4 U+ _- B, h/ T, I5 X! x/ j+ e0 p! [+ v
" i; s( o4 u* {/ U
, P; r% i. F. _" f$ w+ ovoid showversion(void)+ y& N" x- E L8 ]
7 _2 h% g! y1 Z- Q
{$ R0 R! A' \3 N8 `' R& K5 F
. k/ c0 a) c! z" J! M printf("*********************************************\n");
4 P; n" {: K( v
* n1 v" h1 B1 X& x& E printf("\t %s \t\n", VERSION);
2 Z; g9 J2 a. A2 d7 q7 d# { j4 a# c7 u" f. I1 J0 e. K S/ I6 B, U1 X
printf("*********************************************\n\n");
& h9 w$ l: c% _3 H7 o9 n( l
' q2 R# I, G" Y 7 P {$ e" ^9 Y) G9 {1 l7 [ h
! }3 y: H5 i5 B+ u. E}& P1 c# y! r) P1 i
6 J- l8 I/ b; s+ H* A* G5 U/ ?
; y7 P! a4 O. r/ V2 C% m- t) `- \! h- N
//------------------------------------- read datas from GSM/GPRS --------------------------------------------
4 m L- C3 A# G" C& N6 p9 q! Z' h
// succese return 1
8 j3 {+ F' G! t1 w( ?" y
; K0 k% _' e0 N. P. |5 g1 l5 g2 G// error return 02 o2 b" U" n- i
) G7 s/ G, G7 ~
int read_GSM_GPRS_datas(int fd, char *rcv_buf,int rcv_wait)
! A: r! k& S* q% R) q! H* O( e- a! ?6 Z( b
{# [1 y2 P5 b& F# |+ s% H0 m: {
2 ?/ {" W, p" I9 p int retval;
. Y8 ~0 F( x0 p" q7 d' i: B$ `0 g- e/ y
fd_set RFds;
0 _+ o; d* `# y! I$ j: D4 P
# b: F$ [% P3 D; |# N struct timeval tv;
% t. k6 B' G& ?/ i4 i% o
: {- w' K# I: X- Q6 h% v" |& d
, ?9 T: z3 L: a& r8 X7 S8 ?3 Y' `0 z9 w2 O* [8 d$ |' K& d
int ret,pos; F8 x6 a7 c. q
7 F- C6 g1 v% V7 a# E
. Z# Q1 F+ \* D8 o. x/ B8 }# S2 {0 {0 y' Z \' d
tv.tv_sec = rcv_wait; // wait 2.5s
8 h5 b- g# H! k) p
$ C) r4 A( }) B7 b! v4 C+ Y tv.tv_usec = 0;
- {5 ^& \2 e# s- s
+ d$ V" }9 t( p' S) \1 V8 W% s
8 j' e; `1 v, ?7 }* S( J* F v) c. Z/ K% b
pos = 0; // point to rceeive buf
7 @) {3 R( w% d! X! F
5 ^ D i; M/ @! R) Z
2 j7 }/ Z! w0 J8 W" p* G: A! N# m* O0 `1 x
while (1). S. n; k0 m6 f" g% {8 b( a
: d x [7 Z% D, X' O% v0 l
{0 q! g) E$ \9 F6 R; f0 u( l
8 [* @1 `! _* M$ x c
FD_ZERO(&rfds);# C2 G1 p5 Z7 j$ A; C& E
' b2 { z9 y/ ]1 i FD_SET(fd, &rfds);
% g) G6 u M0 d( n* Y- y5 M5 @
3 Y+ l7 q2 `* H B
0 `. l. @3 i5 Z/ y4 m' X
# A' e# p3 P& F H& } retval = select(fd+1 , &rfds, NULL, NULL, &tv);) v8 J/ u, b4 r g% A0 @$ x$ e
% x8 `, ^2 d) R
$ R0 L3 N: ~5 n, T2 z
8 i) D& E, U8 L3 H if (retval == -1)
" q' _# a. \4 r
) f/ T; L u) L5 D' e {
' m! Q2 X' `% k4 N+ P( e
1 g9 k6 ]- ?' c4 z1 O0 s$ G9 ` perror("select()");6 E6 _. g' ]* T# f* B) w+ l
+ J3 s7 ~$ b& R/ Z9 F g
break; `( _4 G+ _3 I$ g. |
/ j) D2 {* w: k& f4 s. h ]# y, i
% J9 N! L* b- U3 r7 X5 Q( s
8 B# N/ A$ z+ C* E0 x else if (retval)
+ E2 S" E5 G8 u, R1 V- V v4 O: N& q4 X: v8 J
{// pan duan shi fou hai you shu ju
9 A6 j1 W" ^2 g% H# g6 c6 b7 ^& N4 L/ d( ^" Z% x" q" v, c
ret = read(fd, rcv_buf+pos, 2048);
" i9 ?2 h) a9 t; |+ b( F7 v
: ^: c: u; t5 |8 k6 d" Z# l pos += ret;
" Q# c u# Y' v4 g
' o% P' T: V- u# j$ e/ J( n$ A9 k if (rcv_buf[pos-2] == '\r' && rcv_buf[pos-1] == '\n')* L c7 J t' j0 y% x2 X
6 g) _9 l/ s9 [3 T
9 |+ B, ]- c1 f0 a8 X0 X- J: H f& @: Y
FD_ZERO(&rfds);
4 G1 \4 X/ }' [" [3 [8 f1 B) T' l1 Q1 U. r/ X" S c; o
FD_SET(fd, &rfds);& ^3 e) a8 ~% a4 l7 C+ w& F
U I& ~# I& q8 Y7 f' h! y & c! \1 M8 R) x6 z0 F! Z1 G, \: r
' m( w! d9 c F* b$ R retval = select(fd+1 , &rfds, NULL, NULL, &tv);/ o% O8 ~, L7 u
! d1 X9 G, a" j
* O0 A+ `" d' m! E
! ?# m9 B! c) W; u2 R5 }1 E+ @ if (!retval) break;// no datas, break
9 Z% n- U3 _3 p7 u# d- |# Q- a2 ?5 L
- U/ P( u( d0 T
1 A* K% I* p; i" `: U } X& H. ]! N" w) Y* a$ d) H1 b" _
! j: t% P. O2 q9 K8 G8 _' T
else/ y# ]) V% u6 T L) A1 H0 R! |
+ T9 @: _$ j) d- x1 R8 f+ w/ Z {- I* k) K3 ~* `& f3 l+ Q( |. x
' J; F/ d; X, w
printf("No data\n");5 R9 p( ?" a6 I# @+ e' s
% G% y# Q3 x/ a% N
break;7 u# E& ~ u# ~" u
3 r \2 F( {9 S9 a; M) V+ d. H
}, Q* t4 y" u0 n9 G" I; U3 v
8 `$ |; u# }$ Y. U3 n' i
}. s2 y8 ?% x3 |& P* o
9 L$ M" [" ?$ l) s" ?/ P9 v
6 E: m: u% Q9 \; ~' O& d- |( V7 S5 b5 q$ ?* u( m
return 1;: @. X( g) O$ K$ ]+ E+ F% d
$ Q! ~& R0 d: k* E4 `5 T3 F
} // end read_GSM_GPRS_datas" B) X! ]( i5 H4 H) o! K* Q
Z! R3 v3 Y0 O, O, u- ?
. r. L7 S' v# W. R! p$ d8 X$ y8 _) y
- P' R ]) Y0 I# I$ g* U: d
% y: @4 J) A, ?8 I. I+ \//------------------------------------- send cmd ------------------------------------------------------------
% [6 T+ [- ?% f7 @" ^& _1 B7 y/ }2 O- `( Q" q& A) a Y
// succese return 1
2 h4 [/ K- j5 a$ G
& F4 o" D3 H/ Z1 }0 Y// error return 0
( e4 [' H$ V" ]. x2 y+ E! q* S' F+ t' u' r" X" S; p2 B
int send_GSM_GPRS_cmd(int fd, char *send_buf)4 Z% d7 b4 m0 a
$ E2 @7 X5 J8 I0 `0 d! e9 i2 ^) q{: ]% A( R2 x$ q$ X9 ^# h2 K0 B
, `0 Y6 K! h7 m! [$ Y ssize_t ret;
! L$ x# X5 N* ?, {8 S5 c, u! J* e' E1 Z( i! Y! N: ^
* j: |0 K2 [. ?, g1 Z! p
" `! n: j1 x7 ~! ?% Z ret = write(fd,send_buf,strlen(send_buf));% _2 [! g9 k- |1 Y) Q0 ?
+ n7 A& N& V; m1 w( X if (ret == -1)( _) `9 P9 D! W. W' ~
9 f7 g% f5 I1 D) @
+ D$ _0 `( g2 ~; Y! \: u9 A; a0 ~4 \( B% `+ K
printf ("write device %s error\n", DEVICE_TTYS);2 Q8 o3 _, q0 j
6 ~. T' W+ q# v' j/ {6 P
return -1;6 y M7 D4 T% m; U' ^: F# q7 e, e
; D/ o- ~( u" C3 Q }
4 z3 H& Q) t& ?( X* q6 g2 y% X! L0 b0 O7 u4 q
% l2 E2 d Y6 ]5 [- Z! Z
: @& {+ {- Y; K) T return 1;
) Z3 _" s5 i( e8 H2 X; [
% U) P0 E q/ e5 A} // end send_GSM_GPRS_cmd
" E( ~" \4 q' a" m! l7 z6 a+ {
1 A! e9 K# T4 R1 Y # w% l# k Y* G) C, X/ A
7 E1 A* y6 g. `$ c//------------------------------------- send cmd and read back result ---------------------------------------
$ `7 ?$ K$ a) L9 \/ n5 a5 x0 ?" r$ i; E+ h9 n9 h" y0 L
void GSM_GPRS_send_cmd_read_result(int fd, char *send_buf, int rcv_wait)( ^0 h! X3 v- o; u A
# @, k; d, I1 [! ~/ B5 p8 @
{; _4 F7 y8 \( Y5 c* w, V
' i5 I" Z7 B3 Y5 R' x& W char rcv_buf[2048];
" f; o2 E3 Z5 E w+ F) h$ P* v7 F" j5 A1 O/ P
) i( S7 l1 u' A0 Y* {' W
) ~6 x V2 N( w5 b/ r if((send_buf==NULL) || (send_GSM_GPRS_cmd(fd,send_buf)))
; z! I7 r& J, b1 ?- [0 Q# p. a' F0 I) y& [
{ // send success , then read
7 Y% R O' y# y7 q$ K! r& T6 z# L' J4 P
bzero(rcv_buf,sizeof(rcv_buf));% C. P: O! C D# W+ b. O% ^/ R
5 }( P7 @; N4 [8 o# D) x if (read_GSM_GPRS_datas(fd,rcv_buf,rcv_wait))5 U1 y g7 Z3 `+ v5 v
6 \8 ?1 ^% A. {2 K1 D
3 g/ \7 m3 o! @" v4 _& r3 _. s7 T' ? g7 j$ {
printf ("%s\n",rcv_buf);
6 v c) U% h! c$ ^+ C, }$ z
$ _3 ~4 [. q0 a* b: N6 f: h }
" O5 P7 W' `1 x1 C7 g
& z3 ~/ j( M* y# v else; G$ H6 H9 j/ N) H5 R
4 m7 F B5 [! ^* z! l" r {
, Y$ E( U. L4 ~* W1 ?
4 V, n4 D& ?4 z printf ("read error\n");
9 Y( n8 u. [2 |& f0 `7 d' \" p2 Q, g* t8 t
}! I4 E4 m- O. L0 y
8 W; ?, `. A/ O. \- g: S. L
3 W0 ]: J1 _; \' |6 e" p2 H z3 b0 Y
2 E& w, W- F5 k+ R
+ z7 ~6 N* Q, c1 o2 c else4 C: i: }; R8 m
2 p& `# L) m- h. Q8 s6 a
{, q' J/ C5 |+ _/ V+ z7 v% A+ R. C
+ ~+ f# ?4 @, { printf("write error\n");
+ l& U; P( ]: c( d: E: l5 F2 T7 o# z! u6 W0 v) x9 x; t/ Z
}9 V6 _" d6 Q" l9 G) L+ S" R
: T+ f0 g' o; t* \0 E* J- b} // end GSM_GPRS_send_cmd_read_result3 e9 p5 F6 Y1 W* ]
8 T! s* P$ W9 p; D8 z8 K9 W
& x5 j2 X2 E2 E" _6 w$ k7 X! G2 U% `3 r
//------------------------------------- send cmd : "at" to GSM/GPRS MODEM -----------------------------------
! b9 w, A, |# I4 I0 Q9 _' b+ D+ A; L; f F
void GSM_simple_test(int fd)1 K& [/ _0 a M" U
. c; c7 `% k: [' n{6 s2 f! o# r3 [( c/ L
8 o: `7 Q& m+ `! c char *send_buf="at\r";
! J' c, q3 G+ D9 \: c* m" u. H! \+ c% V* P& a- @0 `
$ l: V- j- O/ y n% y
; ^; `3 _" I* _4 B' I# n( ^0 \ GSM_GPRS_send_cmd_read_result(fd,send_buf,RECEIVE_BUF_WAIT_1S);$ Y3 ~. v* u% d+ @6 ~
/ p( d: }. x. U/ z5 ?- X5 q
2 t0 W. p, U% X+ P/ C( t. n& S0 A4 j$ {, R: W" K2 \
} // end GSM_simple_test
4 t- q" n; m) L y0 S# _( b9 _# [7 b3 _* S
4 p( Q/ D4 K F1 g. T3 n; _0 K0 R" p! T# \ X- c2 Z# W/ Y% @" v, l
//------------------------------------- send cmd : "at+ccid" to GSM/GPRS MODEM ------------------------------
$ w' @! M, k9 [$ f, z0 P
3 S9 L) a2 I+ n3 n6 K+ mvoid GSM_read_sim_card_id(int fd)
" f0 _5 {+ t. Z' ~' q: A& O+ Z( d1 |$ z' C. C k+ z
{& ~7 \+ b6 \* j% {& t3 Y
) \6 D q" e/ m( f char *send_buf="at+ccid\r";
]* k" r5 y4 d. D# J, x! B: m1 A" T) o6 Y7 j& N& t
' j2 x7 C/ W0 u" ^7 V' f
& d6 N6 a( w# i. s( @2 \
GSM_GPRS_send_cmd_read_result(fd,send_buf,RECEIVE_BUF_WAIT_1S);- T; ^- } o/ }$ I ]
6 b$ N* n. Z2 i8 P1 T* h ( m/ @" z( y" U$ T* V8 j2 X5 ^
: {$ x O/ {, ^! u ^8 {+ ^
} // end GSM_read_sim_card_id1 j! ~' o4 _: }6 x1 F) h, s' }/ x
/ R; b% M9 \1 K, a
6 O9 A$ D2 E9 A+ x% y( Z
0 B B! y* b7 ^% o3 Y//------------------------------------- send cmd : "at+ccid" to GSM/GPRS MODEM ------------------------------
- n* Q% H. b5 k5 Q
- d2 m" J; J8 V4 H6 j$ E r5 Y- ~void GSM_gprs_signal(int fd) I) e X' o3 c, K) q
" {- J, t% G+ J. ^- \- I
{2 P t8 @& F2 a* z* [
$ k% G0 O! d7 C7 V char *send_buf="at+creg?\r";
4 ~# T0 H+ g/ ^' t* ?! I, O1 X) e" T6 i6 e8 @4 L
1 ]/ V& x3 ]7 X" N( S2 X
( o+ u& i5 f u' }5 _ send_buf="at+cgreg?\r";" \+ e- r6 e1 H5 C5 C# |4 g
5 v5 _; P" P% i7 l9 z
GSM_GPRS_send_cmd_read_result(fd,send_buf,RECEIVE_BUF_WAIT_1S);; L" H3 ^3 b; e2 X
4 f4 }3 h2 F6 Y. p1 y6 `5 o
send_buf="at+csq\r";
! P6 f' o3 C8 c1 V' i" } Z, q3 `
2 x0 ]6 J! Q; Q% m3 W GSM_GPRS_send_cmd_read_result(fd,send_buf,RECEIVE_BUF_WAIT_1S);
0 J% v3 S7 `$ a$ }# O2 ?& \
$ R7 t1 m( p. E# W send_buf="at+cops?\r";
& P, Z8 G0 a7 u" `1 h) ~8 {; y# p7 H' H% A
( N- v. W8 Z. {$ c( x& d
7 N# X" @- u3 D' n# |) B8 e} // end GSM_read_sim_card_id
$ f! r5 ~8 y& B: T: i
2 `8 Y% J+ F7 @ f/ ~/ [* ^: T 9 O; j! z7 `: [2 U N# U9 @- G
7 W0 M) Y# H! ]0 z//------------------------------------- send cmd : "atd<tel_num>;" to GSM/GPRS MODEM ------------------------
1 h N' s" q2 O, F0 ~4 z* [9 ^' n: {! z* l- o6 I8 j
//------------------------------------- finish call, send cmd: "ath" to GSM MODEM --------------------------8 }4 V% u# j- K, ?/ ]& ]4 C
0 M( n0 x1 D! I; A/ dvoid GSM_call(int fd)- B6 G) ?3 X( O/ ?2 e+ J: V
+ A6 g/ w* I. c6 ]# w
' ^2 [, H7 l" `% [( \2 N& p' Z% u; t1 [/ v' w7 z
char send_buf[17];
: A& S1 m+ |( h8 Q% K! _. N
# e9 ~' v0 A% E3 g; E: |1 z# o2 G char *send_cmd_ath = "ath\r";
5 l! V+ S* l G1 a
* s) J- { O" u6 d: t+ Z! o5 q( Q int i;; C9 H. U( X; D
& a; r( I$ i' ]/ O/ d* K ( n% ]6 F' U: W4 h0 J7 u
% [" s. l* E' J3 V" e // input telephone number0 S: T$ \6 H2 A, P# Y: a4 u
0 i5 s" X+ g" j! a$ r1 m M# u: R9 w bzero(send_buf,sizeof(send_buf));
+ Q- s* D" C' t' F8 t
4 f8 g7 h2 H1 L5 Q2 Q
! L: U# _1 Q4 f9 M: s& b, w- M
' r) Q6 @ m. z5 V# { Y+ T send_buf[0]='a';! w2 q8 {# `; U' {, w+ Y' _
" l" t$ D: k W R- n# p7 g/ O
send_buf[1]='t';4 D3 d4 I8 V5 z% U* v
& |* J" c3 k+ Z+ g( g( V# d send_buf[2]='d';3 Y' V7 Q; F1 h( y! P* E
. Q5 @) c2 T4 r- C+ h, K+ g
send_buf[16] = '\0';) J5 p& e8 ?# g: a- w: X* G
- v$ G2 p$ ?* ^8 k3 s5 f
5 j" R7 G' }4 g3 A) O$ A( ]. h" q% U7 u1 L& o* ?3 O( l7 M" P
printf("please input telephone number:");1 t, U* f2 L( a a; u, x
" J9 X- c$ O4 k3 Y9 T
. g0 \1 J+ k' Q+ x& \, W; |2 k I/ ?4 O" k: Q7 I$ o# B
i = 3;
6 m& N/ n4 O+ V, h0 I' N& b9 c. ? G, q* E
while (1)6 `+ [& U" B; U- p/ m; v$ G7 w- |
$ d* `/ O8 i) y; b$ J5 L. b2 E. F {
$ T8 v8 t5 [/ i9 Q( b2 h; t- j6 t9 \, t* H8 _
send_buf=getchar();" x& O8 M6 U6 b2 Y
. o$ t. `0 e6 L: }9 V
if (send_buf=='\n') break;% l! [* }8 D& r0 Y( Y) w
. z2 H; {4 M* P1 @) N7 s1 T. j
i++;
" n5 D5 T. `7 L, J. H" G: O5 |2 C/ F4 p \+ ~
}, y* _# q9 Q! x, i* Z- f
1 f( h2 \6 [* _" ^9 N
4 R; D' n; Z2 a0 x/ T/ l4 }2 z( }8 j' w: D
send_buf=';';* M8 ?9 r6 C* j* b8 X! u4 s+ i3 }
h0 M$ y+ t( N' U5 k
send_buf[i+1]='\r';
R: Q4 K2 V, ^0 K, W1 h" u+ k6 R( D
// end input telphone number5 l7 a+ v( K4 |& N
8 m* W6 n* j% M
/ E) @+ S0 Y3 l8 U9 w
9 Q- X! T+ e! @2 K/ e // send cmd
# g) X5 y2 n' |. C
% ~ G' R0 m) N } GSM_GPRS_send_cmd_read_result(fd,send_buf,RECEIVE_BUF_WAIT_1S);% x( m; K6 z5 C7 Z8 N
) Q( a0 W8 F9 g/ o% i1 `" V' j6 @ ; e( z% n) |; G7 P& |7 \. _/ n
# g2 c1 k5 O" d4 \# o, D1 J6 _& ] //quit call& b, p3 o( P' ~, f: U8 S! R
- I; M. }- D; O# N0 i
printf("press ENTER for quit:");
# x4 w" ?5 C4 P, P0 b. ]" W: K/ y. d& J+ J
getchar();. `) x8 q. [) _" ?5 T# g6 |$ R
7 n, {$ n0 k4 E8 A6 Z- I( t0 ?
- C- D1 x0 S- J$ r+ \
9 |. _. i8 [- o# |3 u( H" } // send cmd
& {3 _% e1 A, F. A! t3 @& b1 ^" z0 M- y" K! |
GSM_GPRS_send_cmd_read_result(fd,send_cmd_ath,RECEIVE_BUF_WAIT_1S);
) Z3 V$ N# w4 L; P6 X" B* m8 a$ }# |# p E$ X1 }) E; n
, M. m9 s& z+ Y& n+ W# @8 |4 y7 G0 ?5 b* q
} // end GSM_call
3 U# F: |7 |9 r! Q8 D, A! Q; s* }$ B Z$ f) T$ {8 s, f, p7 b
: j) g* `; l; r7 [5 F4 Q, D, V2 E! _7 b1 ~
//------------------------------------- wait for GSM/GPRS call signal ---------------------------------------
$ L' X- I2 W% R( k% @( c+ Z% }7 q- R! r5 B6 ` e: ?$ C% ~
void GSM_wait_call(int fd) L' ~1 A# k7 J2 R' q7 E" Z
5 F# l2 q& X; p7 Y3 Y+ P
{$ M. n) U8 I( O7 Z
+ @9 g' h( `$ V8 I* V6 U( P% ]. a char rcv_buf[2048];
0 ?: Y' \" L5 V( w1 t: C' X" w7 `2 R5 P3 {. X# Z( l1 d
char *send_cmd_ath = "ath\r";+ K( @; I( p) q# b
* i. A1 e0 S' S. T/ j- [& g int wait_RING;0 ~ V( B7 B. g
4 X4 t2 }5 w- k0 L7 j# n
4 B0 U. {# q3 H. W9 p+ J' _+ E9 Z& Y" }
( t$ U A! a; I wait_RING = 10;
7 H: ]# K& Y. Z2 ^. k: w3 A9 O# m6 M
$ F% y: B$ ` T5 S while (wait_RING!=0)/ ^( d/ V' U' ^
7 g# S! F0 [" p# Z$ Y { / a6 s+ a/ a" P& a2 Y! A/ X
& G) B6 x1 }6 V" }5 @! f2 J1 D bzero(rcv_buf,sizeof(rcv_buf));
# j1 Y: H/ {$ I. c# \! m' S6 B. ^" x# v, G: D
5 M' a. y; _ [9 a
- H( f( m m' ~9 g( Y if (read_GSM_GPRS_datas(fd,rcv_buf,RECEIVE_BUF_WAIT_1S))
6 @, N0 i+ ]6 z$ k/ f# q# \0 t. {: s5 k
) S+ V; f7 u" s( A& I, Y {4 N: N$ `! {0 @/ }6 [6 ~
# j* ~8 j' N' x- u, t
printf ("%s\n",rcv_buf);6 P* J9 N5 e8 ^" q( C+ `
: A; I, y- m: V }' n1 `/ l6 [) B& t+ x+ ^+ C. b
. K, }- o7 s5 K! T
else" ~: U& d( r2 T# A9 }
8 h0 b- A% |' c% M! E
{) h1 z$ W) _; q8 W; ?# P1 y8 x
( O8 S) G' f5 M9 \9 t printf ("read error\n");
. }% e( j% f$ ~; ^7 ]/ @. c0 L" H4 q) T+ p
0 R' Y2 D* ]5 F6 S$ [- S/ j* @1 E0 \2 s" P& g5 q5 c5 N& _5 W+ i B
wait_RING--;
% N1 l! e0 p% {" u
8 P: ^; n/ G6 C }3 E' W8 S4 V+ A" Y" K$ o7 E
3 c9 [8 c7 @9 u& H% K9 Y" ?
j1 |1 g- O0 j7 G5 m+ N
/ e7 D& D; W: g0 C! g: Q( G GSM_GPRS_send_cmd_read_result(fd,send_cmd_ath,RECEIVE_BUF_WAIT_1S);" e2 @1 K& n _& D o
: A# Y8 Z+ ~1 ^2 k# g8 h, C2 D
, g: x0 s% j; ]
, s5 W+ I4 g$ k" K printf("quit wait_call\n");. i# A( i# O; U+ k
! L3 H2 V& L( j/ K- `7 U: z8 G/ V
8 ?& L& u! I+ T6 C' _ f& D5 h6 X
# b' }$ G) u) B9 s. V} // end GSM_wait_call
' p; f* V) C3 P7 G& ~+ z" u2 ?; x" j( ^" @6 N! o( p/ u
: x5 R0 [+ Q0 P c
2 C* p) Z: ~7 U
//------------------------------------- GSM/GPRS Config short message env ------------------------------------ I2 j2 P! F, j: t, t1 z
6 n+ v W! {) O7 x( V6 K. \$ i
void GSM_Power_Manage(int fd)
9 j+ ^) B- T2 m4 j8 S9 H$ ?4 R5 X& q- u. u% E8 ]8 X
# w" C. Q6 i, g* Q3 m% B( `
6 N# _, K; U; R' `) [, f4 ^( k char *send_buf="AT+CPOWD\r";// power off5 E- N4 O& G" v; `( W
* Y! K" i% }/ W" O( k
GSM_GPRS_send_cmd_read_result(fd,send_buf,RECEIVE_BUF_WAIT_1S);/ |' Q3 {& J- V/ T+ O/ c+ [' Q4 u
: X# ]8 j) G; ], |! c5 Y} // end GSM_Conf_Message' Y! i9 D& n- H$ Q+ s+ D6 n u+ ?. P
8 N4 \1 {6 k+ X. B 8 _; c d* T8 D/ y
5 U' |- @0 ^9 ~3 e8 S( K//------------------------------------- GSM/GPRS send short message -----------------------------------------9 v7 s- M6 z% ^# \
2 S( a) H. ~2 w Y S1 u$ b% |
void GSM_Send_Message(int fd)
. P/ p9 o2 u7 `3 s5 j
: |' R1 y; U: R. W) f& b& y+ ]) v{
* s/ c) ~' L2 _! ~( A2 a
' Z7 K: p" v& x2 v$ f- u8 k! y char cmd_buf[23];
3 U, w; f( ?0 j7 Y. S
' }! _# \( t% S0 q0 } char short_message_buf[MAX_LEN_OF_SHORT_MESSAGE];
a# c# s5 V- b, }5 O, S+ m) g3 l+ D6 I% h
int i;
+ t- B8 R( f! m% H4 {; n5 \, o; K* f2 @: [7 u# M0 l* }
char rcv_buf;
5 V/ ~! ^9 U- \; |+ x- \0 j" H0 W& R2 }6 [, j4 m# U+ k' W% _
, B- z* g5 r0 P# j) q* M8 f; N
& @) I3 b) D5 ~4 K- y( L bzero(cmd_buf,sizeof(cmd_buf));
7 V e) M: N, w# ?- d( P
# V6 E6 R' t4 k0 o bzero(short_message_buf,sizeof(short_message_buf));. ] k( L3 p4 s
- ^- m1 J* I/ a- ` ?
2 T3 ~5 b) q% I) \
5 I; l1 v* S8 `5 T- [+ A+ P1 w3 n printf ("send short message:\n");
: k' L' X' f" k& W6 h# E
. W; W- f; a: q: c ! G0 C( H e& B
$ G6 s' U& y5 Z; D cmd_buf[0]='a';$ T, _6 o" k. ]8 W# o" w" ^0 u% H
6 m, w5 C$ M% q, Z8 l/ Y
cmd_buf[1]='t';4 U7 J5 a. t. ?5 A
9 _+ i: g5 i. Y' S9 y
cmd_buf[2]='+';$ |. q) Z, f w! e3 T# c5 I
0 [# [3 H$ d4 s cmd_buf[3]='c';. Y+ B, | O" Y3 }3 T: t
7 X8 j1 m% J% l+ \) o& u% h: @ cmd_buf[4]='m';
+ N9 |9 `$ ]+ A# S: c2 o& v" l/ n% M( |( E0 W3 q+ _" N
cmd_buf[5]='g';# V8 j/ m$ b6 l' k/ |
" ]+ W( c1 {1 u3 F# D7 L
cmd_buf[6]='s';1 o- m9 E) _/ n; H$ j" @0 q
! j4 @) r& L# F: `- d cmd_buf[7]='=';9 H+ r$ r/ q9 V Y& T+ R
4 Q& ?# {5 s4 P' ?2 d cmd_buf[8]='"';5 X' l9 F6 R5 s7 B4 b& x" Q
, R* K x& d3 S& r: O+ z
! o; e7 D" L5 J8 x8 \) J
9 B& `) @) C% O/ V. j2 G/ Z
printf ("please input telephone number:");1 o# u6 R" t6 j( U! }
" m2 `, V& T5 C/ h: n0 J
+ w8 ^$ h0 s/ X& D( P2 [7 v; @; t* A0 T
i = 9; k! r6 z; i: |* E) `" H
; C( i5 H- L: n G7 L& L, w/ h while (1)' S2 d) M1 X4 o9 `1 k5 Z/ }0 Q
7 P0 b+ G7 Z. B8 M
; k1 f0 _9 M4 M# U5 j4 S
! p. N' J7 c/ r" r9 m7 t$ n cmd_buf=getchar();) g$ w1 x% p0 S1 V: ?4 n% |3 c$ B
# D0 ^' U; i# J& ~% q' A9 ~) ^ if (cmd_buf=='\n') break;0 a. t% \: k, f" @" f9 o
7 |. ~$ B4 o: a: w- E i++;
: z6 b$ N5 M# T" e2 F( n6 m) @+ m
}0 ]+ r. ^5 f7 v/ N
# t8 J6 L) H. u4 {9 ] cmd_buf='"';4 \, e; ]2 d, e6 o" r
o+ j7 l4 P8 v" O) e1 V; r+ e cmd_buf[i+1]='\r';% H. {0 \ @3 O: m
x) ]4 E0 v4 Y1 ?6 Z0 J, E1 Y5 i3 f
cmd_buf[i+2]='\0';
6 Z: ?2 A* [) d5 g) u X; t7 z6 X$ s5 T. y3 E# ?
: H8 D" p$ s u3 |6 _4 f
# E- @# [/ p" u9 ^
// send cmd : at+cmgs="(telephone number)": S8 d4 L% M2 {& j$ F1 {
7 X' r1 s% p" m
GSM_GPRS_send_cmd_read_result(fd,cmd_buf,RECEIVE_BUF_WAIT_1S);
9 _$ g. w% ?/ B4 ]% Z7 K/ z4 `% B, a1 {6 z7 j, _" J
4 w x: O* P) H5 }# [
8 u* [. S1 |# c& h3 f
// input short message9 P: i5 o( x0 r& Z' I
5 c4 P% o- U) Y4 L7 x
printf("please input short message:");
$ i8 V- }' z; K9 m* |3 l6 W! ~8 Z) b
. b: x2 q4 [6 C/ J4 u' O9 c/ f' i' C" n4 Q4 B9 h r
i = 0;! x( X; }6 H! H: b+ P3 ~
0 `( f r) b& T. K! `
while(i < MAX_LEN_OF_SHORT_MESSAGE-2)' h* E7 b) c B
# M+ `7 \( y, A7 x1 r0 W; N" [5 P {
- W6 B5 r& m8 |) ?9 s/ c2 d+ f. {5 h
short_message_buf = getchar();3 S; T7 q2 l! P4 h6 n& S- X
" X! C( Y) s5 z0 H if (short_message_buf=='\n') break;
2 _ c4 x% ~* o) {# i$ G; o1 w- h! C$ H. U+ q! f
i++;
/ A) @8 d$ {5 L9 Q+ Z Y0 [6 M; @+ M0 M
}3 c6 w7 A5 o" T9 y
6 A; d i& {, R7 C" ]/ H4 U& u3 ?
short_message_buf = 0x1A;
/ A4 \' x) j0 D7 n0 ]% J# x3 f( `+ n' ^, F) _
short_message_buf[i+1] = '\r';
! V9 s' t$ _# I1 _/ `6 W6 [5 b: d/ n. ^0 ^5 \4 M
short_message_buf[i+2] = '\0';
# E2 l6 a; f+ G/ M; b. `; f3 N; ?0 a( h6 L! e. X6 o7 O8 v
: i8 ]5 _; [: Q6 F% _1 l* W; S
. |; S" \" b: t( q9 I9 |4 y // send short message
/ e* i. \8 O2 W3 B9 R: X# k8 {% |& u7 p5 X( i2 V4 T
GSM_GPRS_send_cmd_read_result(fd, short_message_buf,RECEIVE_BUF_WAIT_4S);8 ?5 Y5 T0 ], O8 q2 f, L0 ]7 e" E
: Z8 o- b# G0 Q; O' a1 }
+ M1 t$ O! f- u& o" z) P: R3 g3 V0 }# O! r
printf("\nend send short message\n");
& q7 M/ q( [; J) Z8 E) S1 {" h F
7 f2 F k9 ^8 \6 J/ u. E} // end GSM_Send_Message) X8 S/ U: D# D H* w) y# C) Y( H
6 c. X6 V+ r6 I, |9 A* V. }! g - ?* ^/ h( H) c+ w
1 o. ?. s; M& w//------------------------------------- GSM/GPRS read all short message -------------------------------------
3 T( Y6 y! V0 k" H+ c5 f* b P* ~% x1 |
void GSM_Read_Message(int fd)7 c# e9 `6 e z1 f! ~
: \ P7 b, ?# n7 ?+ Y{
' C- { `, Q8 B7 [; c8 n0 b& v$ F9 z( Z) c0 p9 _
char *send_buf="at+cmgl=\"ALL\"\r";2 r& B# j& |3 b1 Q& b
3 K% _ R/ B; ^9 T$ U# J
char rcv_buf[2048];
+ |2 [# Y5 g& v, |9 i# {) J1 q9 N; l+ f1 }* n3 Z1 \
; _5 K4 Q4 w3 n- x
+ q# w ~) O2 p, H- x3 m: P
GSM_GPRS_send_cmd_read_result(fd,send_buf,RECEIVE_BUF_WAIT_3S);
! Y7 p0 r. w) D2 ?$ s0 I: H( ^! u" u, G& o1 T7 L
" h5 f5 K( a1 A
5 z1 r1 I1 ~; O- i) S4 q0 d: h* ` printf("end read all short message\n");
* D- Y2 v L2 [2 V" o1 [9 A1 T' S, V- T4 b
1 @% G. L- w7 n$ S" ~8 ], ^) c
/ J4 R7 F2 z, c6 C; l+ q9 S
} // end GSM_Read_Message+ G& w" Z. p1 w V K
5 O, r4 t, l$ A( y0 {1 f
2 B6 h( |0 d1 ?- ]3 o3 p, N
; z- g9 j+ m, m& I1 C4 O6 X//------------------------------------- GSM/GPRS Config short message env -----------------------------------
$ v* \% ]% R3 [* j7 J2 u2 x+ _3 @3 r& s( S
void GSM_Conf_Message(int fd)/ E% k, b! a2 P3 M
. H( W* {1 W& g
{0 \' S7 c/ @: d$ G+ b: U1 z
+ Q' x8 ^' ?+ W5 v+ q- z
char *send_buf="at+cmgf=1\r";/ }4 F5 Y/ @2 W8 _% b
& s1 \% C4 R$ G
char *send_center_buf="at+csca=\"+8613800571500\"\r";$ {& c" `! x) }9 @
8 D2 f0 k9 y4 \2 E - C2 | w. v/ X
2 s" L9 [% q* f) E GSM_GPRS_send_cmd_read_result(fd,send_buf,RECEIVE_BUF_WAIT_1S);
$ L4 P0 X! j. c I( n# w* }$ m' \
* e# K% o8 z9 r2 R F \. Z% C1 ?8 _/ S; ? U6 `1 `
5 V w8 m; ]" z7 N
// set short message center number
+ P6 P/ ]7 i" a6 ~* u0 E3 `6 V s* o" V# s
GSM_GPRS_send_cmd_read_result(fd,send_center_buf,RECEIVE_BUF_WAIT_1S);
M$ v* G* N6 R. P
- b! z- {5 U6 i% ^+ a0 [) n ; D5 {9 @7 H4 h7 g/ I# ^
5 f- K# j% ]) S( }9 v9 O
printf("end config short message env\n");' P; U7 s/ u+ V9 Z
5 i. O0 c& L6 n4 ^0 I} // end GSM_Conf_Message
& \) Y/ `& w& h# u
; O+ t2 _! K K3 d, H% \# E
5 a$ n9 A6 E7 {* @; r" t4 v1 `+ u0 N' o
6 I- L& ]9 \! E3 m- m- c& x) o
/ y9 E# T5 P$ b, l' K//------------------------------------- GSM/GPRS short message ----------------------------------------------$ f3 |; c O7 v, u4 i
. d$ h, P5 R- X$ j1 e
void GSM_short_mesg(int fd)
8 j* F; p2 w3 E4 [' v7 g/ @- g1 v ~
{- |" J+ x; X- t+ N6 V! Y6 s
7 Q- Q9 R) f4 h7 _, d l( k int flag_sm_run, flag_sm_select;4 I! _1 d& z% o# R
5 t; L& ~2 r/ b% j. Q
1 j& p0 x5 C5 P
6 [' Y& W+ t% _! G6 { flag_sm_run = FUNC_RUN;
3 y0 T1 m1 c% w/ D9 P# r# p% f
5 K4 @) l! @* \# b while (flag_sm_run == FUNC_RUN)
% R% b& ~& u8 v8 v: R
* q3 S6 y& c# S# J, Q( m( b% V {9 E$ g/ j3 }* Q5 {
% F, X4 y2 w$ H$ c' G printf ("\n Select:\n");
- f" g# N! c1 a2 \; x* P
5 Q0 Q% ^) ?/ P! N! w' `" Y printf ("1 : Send short message \n");
4 i! I$ u% {; g( H1 d' N( H7 C' ]# A% A6 g# u% s* ]. }6 g
printf ("2 : Read all short message \n");. _6 ]$ ^7 w! Z3 O
* r- D6 I8 \! c; [. X7 n) m( s: [: i printf ("3 : Config short message env\n");% U( o3 z2 B; m
4 I' C/ w; x# L6 T- ` v, O3 F
printf ("4 : quit\n");0 z9 Z i+ R' R1 E; |- Z
, J8 v4 j# P) e& P# A5 q3 X7 P printf (">");
' X6 U n$ p' [ }5 j: ^% ^# e! A; m5 O
scanf("%d",&flag_sm_select);
- _. b8 A& g: w% e2 b j" Q1 R& u
, A: ]& P: Q8 _ e+ d. G0 w getchar();
, i5 a; v; Z, g1 k) a2 E7 N
6 U9 n' G0 b' A' O0 o$ I // temp
* l5 g( h U8 C o% m
3 V3 T' c, M, @' P% W // printf ("input select:%d\n",flag_sm_select);
, a! c+ Y2 j, Q/ p( D- W* Y2 O4 E, M* n) K
// end temp
- z( J5 P5 {! u: \. ]8 A2 c* M) o8 }6 W1 _8 x; [0 g
switch (flag_sm_select); h) l+ e+ ?: c$ F, _7 a
U7 S8 J, K6 T/ Y, Q3 @6 ? {) E f) G6 x3 i
5 E7 r K# d* t0 X0 [$ h9 C
case SEND_SHORT_MESSAGE : { GSM_Send_Message(fd); break; }
3 J- A- Y, T- o2 e1 m$ s* C
# L W% \8 F4 q case READ_SHORT_MESSAGE : { GSM_Read_Message(fd); break; }0 k& |7 d& ^; a& P6 ]1 A3 e
' n. ~$ o- Z# @ J
case CONFIG_SHORT_MESSAGE_ENV : { GSM_Conf_Message(fd); break; }+ `* [# i9 n' J
5 @. i3 s$ Z8 e1 u/ `( K1 g4 a
case QUIT_SHORT_MESSAGE : { flag_sm_run = FUNC_NOT_RUN; break; }
3 m+ u2 L: f/ s! A) m2 m
# ]2 w3 H/ p) W- f, | default :" X G6 Q; P6 u2 b0 ^
! A% X+ ^" I+ n0 p
1 h/ y; H1 @; P8 b$ b! r; t
6 q) H* u3 _7 ~) q+ r printf("please input your select use 1 to 3\n");
" S, W" c) G7 O8 [8 y, ~$ P" E/ [- V6 U ?8 O3 V. X
}/ w3 D7 i( E- u, y8 m
/ ]0 Q5 A2 K! F2 S }% p; d+ i$ t4 x( I+ F) r
. l: z: j% H, O: z P8 ]4 S }. V) y' D- p/ E3 c
: s6 I5 S5 ] L6 h1 O3 l2 u
printf ("\n");
2 _" f+ P( O: x4 U2 A4 y2 M/ v1 R: `( a: Z! ^
+ f; a- d3 A! u8 f* m3 l l: H6 Q6 x+ I9 J7 c
} // end GSM_send_mesg
6 c* F* ~& p7 G5 n" W2 V5 w
, k3 P0 I- {' A9 C/ \
2 M' d, N) e- y& T! L* Q% B3 v- L, o' o2 |* V
//------------------------------------- print ---------------------------------------------------------------
$ r, M& J* X6 n x# A
E7 T) Z3 n t" L$ L$ `void print_prompt(void)
" _# o+ f* X C& c; r5 h
B! M4 | _4 M7 ^6 B! E: w0 ~{
& p( m& I1 p- b. P |* g+ ]6 }1 G' {5 c$ h& A1 f& j+ a0 T
printf ("Select what you want to do:\n");$ s) f! `' D5 k3 T t
/ x5 q$ _$ `- Z& ]# ^
printf ("1 : Simple Test\n");+ ^5 A0 L8 @: U4 c" \; t* K
; g: n: w/ F* W; |* | printf ("2 : Read SIM CARD ID\n");
$ X9 A+ {. r: H3 u2 N) o
& J5 s; i/ r2 u5 e( a' o! L4 h printf ("3 : Test GSM/GPRS signal\n");
0 m# ^; u8 e* E7 H0 r$ Z
. O' L" G' M( N* p- i% p printf ("4 : Make A Call\n");
* q9 @- S, g% W' T- F: X- }1 q! Q5 P0 I7 L) q7 k4 C A5 N
printf ("5 : Wait A Call\n");
7 D* ]6 D% W" P* K2 f" ~) H: }2 o: t3 H2 \+ s
printf ("6 : Short message\n");
9 h& j, F5 L/ ]$ G1 A9 S" J% J& g8 \2 L1 s" I0 Q
printf ("7 : Power manage\n");
" ~) ]" I$ y" T. i& z0 r9 a( M% ~. ?% w+ h+ d6 f' ]
printf ("8 : Quit\n");
s5 O9 F o c: T+ w/ M8 P5 G; w. U: q) L3 U4 d
printf (">");
t" H+ r- A% H o, d
* @; E, c2 [' r: p! i/ d} // end print_prompt
6 T; c1 o6 c! E3 E) Z! P
% v, @: i1 Q" y1 q) B
5 f% L+ W: J1 Y( p6 x& h R
0 Y( H% `# K; v3 Q//------------------------------------- Control GSM/GPRS MODULE ---------------------------------------------
2 d+ z. H7 V9 g) C- U8 g, n
' g+ c2 V' x7 D% p4 Qvoid func_GSM(int fd)
- D, b8 z3 K4 w; q. ?% r# B0 D3 U' C1 [7 b9 Z4 x8 X
5 ~1 }* X8 V. H; V: U: y
" [) [4 g7 z5 \- [' s) T# ] int flag_func_run;. C8 S( y, P4 k) @ y y
8 y0 E) W' Y( V( a+ M2 p! g
int flag_select_func;
- k- I: K, O' R* v
+ H, I, p; ]% O6 j; ^# s. z3 w ssize_t ret;8 x/ w R2 @) P
# h4 V8 [, c, S5 N5 l' U% _
4 U! h9 O- S. c+ d# z8 r3 J1 ^3 ^
flag_func_run = FUNC_RUN;
$ C- W3 I. i% y" n- ]2 v1 }4 F8 Y# \8 f+ T. U" f2 t
; t, I8 J# Z9 [; {7 i4 J+ @
8 t2 U& F2 y0 ~4 A/ w3 P
while (flag_func_run == FUNC_RUN)
8 G2 r' d' r y: ?. `. I+ @" C1 K9 e( `1 n8 y
{" G6 J! |, X2 K, _9 O) j) O( ~
, Q' D$ _4 c8 h! y$ v! K0 u- H print_prompt(); // print select functions' M9 M s+ Z1 N
. c: X# ?) x+ R5 E
scanf("%d",&flag_select_func); // user input select) j! T6 r& k$ {2 h
5 Q: {6 O F- t' L+ \( I: s, f( X getchar();; R* j4 ]! F9 p: i/ G
' B7 _3 p( R0 r: j+ |) g 7 _5 n1 |) J" d) o( W; X& G
1 r1 J* r V5 s$ Y, F
switch(flag_select_func)/ W4 e" f" t, g6 F1 H* U% I
; F( J G9 F, M
0 g" E( a; B0 l# J) u, o4 G/ L, o0 c/ q0 m8 O6 \
case SIMPLE_TEST : {GSM_simple_test(fd); break;}
, K& R' ^3 u4 S, O7 t
; n9 p7 j9 | q3 K/ @0 N6 K: j case READ_SIM_CARD_ID : {GSM_read_sim_card_id(fd); break;}
1 u1 ^8 Q& T% C) q; w3 H) Y! V& i x' ?* L$ d0 K% a0 [3 k
case GSM_GPRS_SIGNAL : {GSM_gprs_signal(fd); break;}# O8 [6 y) Y0 d
/ T8 U, q" A( V9 d5 f; B2 ` case MAKE_A_CALL : {GSM_call(fd); break;}
- k( L' |" E" Z1 U
9 Q' f( m S5 ?9 e) I case WAIT_A_CALL : {GSM_wait_call(fd); break;}/ Y1 b5 T7 r% X! a) t3 i8 |" g
. {* t4 S# K* ]/ n& g case SHORT_MESSAGE : {GSM_short_mesg(fd); break;}
9 n6 f4 G( V/ P% n# _+ g) y$ F8 F ^" x8 @7 z
case POWER_MANAGE : {GSM_Power_Manage(fd); break;}- V4 J4 ^) J3 C/ a' B& M" M% L5 Q
$ K* y! C! P$ Q$ S8 n
case FUNC_QUIT :
9 W, }* } T7 X" _ h" [1 m Q' x6 }/ ?/ e4 a S7 P6 O/ p
{4 S) `9 G& t P0 s) S
( d9 d3 Q V( F% Y0 d' n" [7 n
flag_func_run = FUNC_NOT_RUN;: H) I; a: k3 o' g$ W
8 i$ ~+ b) Z3 I
printf("Quit GSM/GPRS function. byebye\n");$ ?4 n$ X. Q' T, u) f+ z
3 P# t( s. V' c6 r, q* |
break;
6 t% x, Y- n5 o$ D' b3 P4 Q! Q- Y2 M: _6 w4 I2 T
' n" g6 U% X! q+ A( }. U; M6 ?
9 S- B3 f" L- b7 P/ ^/ x default :
4 ~0 g9 Q. N# s, y+ f/ a F+ T M, e) J9 U# p2 J* `
{( E5 @) U3 E# L2 i6 X
) p% A& @" b$ S( @0 V4 l printf("please input your select use 1 to 7\n");; r( |7 a2 M# F8 K3 U8 @& w' Y
" B0 A5 p' A# M1 A' E) b7 s5 k
}0 e0 J5 R6 k; L2 ]* ~
* D2 Q- {; w0 X1 ^, g }: p( I# z) P/ }+ e8 x+ w9 Y
& |1 U4 g& D$ i0 X+ ?" e; X1 B
] T$ F; L0 F. M3 F7 d
3 ?+ e2 D- G3 k" Y0 W% u* s. J
9 \% U: J. o/ V y: |0 D& O! l0 F* c% ^' V# z [' b$ E4 M3 {
}// end func_GPRS
* m4 G7 a2 P$ Y$ Z9 A4 b5 N$ o6 c- q
' |0 j4 H6 v# ?7 Y: H9 k
0 E: ^# a' X- o/ r4 U3 M
//------------------------------------- init seriel port ---------------------------------------------------
* a! o8 V6 b C- z, k
9 ^3 I4 t' T$ `% g" L) ]void init_ttyS(int fd)9 o) W9 k. E' v4 E
! T$ K7 j2 |$ y) D3 {+ E. x
{) [/ S N0 R, W; s' w |: H
5 M# [5 A" {( B* R3 H) `
struct termios options;3 I$ N8 K8 `; r6 k3 C. L
2 G6 Z# u( Y) H( \ bzero(&options, sizeof(options)); // clear options
, d3 n! B1 w* B0 \( p6 R1 l& D* H" H4 g7 x
cfsetispeed(&options,B115200); // setup baud rate
7 g7 m9 k! ^3 S" |1 G8 \2 ?% q7 w r+ F: n; j3 }3 \2 Z( o: t
cfsetospeed(&options,B115200); }6 [* i: l7 X; G5 s
: K1 H5 D7 S: F j' R options.c_cflag |= (CS8 | CREAD);
; E& J( f% u1 C S, v9 L. a4 P/ ?- G7 C
options.c_iflag = IGNPAR;
! R; k. U8 g9 e4 e
6 |! b, C8 J% c6 h7 k tcflush(fd, TCIFLUSH);
2 I% Q5 `! W+ m: E- `; t% Q! U: V n4 b# }+ l. ]" c2 ?0 P
tcsetattr(fd, TCSANOW, &options);; t) {( k3 _* H+ H( M2 w' n J# @
2 j. V5 d7 O& W* B- V}//end init_ttyS
1 J, G2 w/ U3 A0 }# P9 h7 b- r
I, ]/ z# Q2 F m9 R" @7 i% E; j
7 K% }! V" g9 ]+ C6 H/ e S2 \9 M: ?- ^# {$ Y" r- E! Q$ a
! N6 J8 `; C. Q6 N) y$ R0 t
; b: c4 r! c H2 L! J
//------------------------------------- main ----------------------------------------------------------------
: L7 I) w4 h& ?
3 s0 e4 o. u: d3 X3 Z) eint main(void)
5 J& `( n0 B* \
) m# H7 {9 Z+ l1 F7 e7 N+ k1 [7 C{- _2 V7 x% D- k1 J. e2 a' A
& I) `2 y# k' Y8 V J# B/ I+ K
int fd;
( d" r* v3 D1 T, J( Z
& X6 n1 h+ O1 H# R
8 _8 o. [% o, |% k, |1 r
. u( G1 K8 C. k2 ` showversion();7 a3 _) U8 c o! f7 F$ D# X* f
" t7 @( ]9 h3 ?0 w" Q" o
" i+ e9 n5 Y$ m) m1 F
4 P+ R+ Y; r5 b printf("\nGSM/GPRS TESTS\n\n");
5 G4 @* G' m4 I: a. x$ ?! N# N8 g1 d2 x( y
D+ S0 b* H% x+ W* E% T2 K" [- B2 }
// open seriel port0 u& q4 A0 Y; d2 W1 ]* H
' }. S4 j- a7 S- g6 O/ ]2 @7 ~
fd = open(DEVICE_TTYS, O_RDWR);
# ^' i: V, w: P; [4 o
/ w" D v( v5 `2 s( E3 u" D
8 `/ F% s8 b/ r Y
3 A# @3 Q/ j/ Q- o2 _6 B if (fd == -1)
( m) w9 b: q0 i0 y: y3 `" B( D: G
: V9 k+ |. J; f( U9 N7 y. l { m3 ~7 G; M' H$ m o5 ?
- k& a! @& ] R: I1 } printf("open device %s error\n",DEVICE_TTYS);, \4 n4 `5 B2 t% ~! I
! S% o2 b5 b% A
}9 _5 \0 h4 H) n8 D* N
0 e5 H3 z' |' W/ g# P; `9 ~& i else8 g9 g. r. v: v t1 B
. T8 ]3 u( d4 @4 F- K {0 O; J; |5 k! ?6 d4 s3 M
% o9 {- e* D& l" Z* J! X/ k1 j/ g init_ttyS(fd); // init device
0 @! B% Y1 E- W; @
7 z4 y; S6 ] O7 _* b func_GSM(fd); // GSM/GPRS functions
: _3 W( D% X5 p3 c) d+ }
) I$ |2 E" v+ N' J5 [ l# A4 B- f3 k2 } e
# r: [( Y4 @0 \ y2 s! D // close ttyS03 `+ o, R) z+ C5 |
0 j: v6 v/ T5 f4 N3 _! P: E if (close(fd)!=0) printf("close device %s error",DEVICE_TTYS);
) ~6 }+ X) F! N0 m/ |1 k
8 S, a d4 C) j# A }
, A5 O7 R7 v- _6 R" J
4 b4 v/ a9 m; Y0 b 8 y! C$ J: \: o& d. K9 Y6 z
9 A" H$ ~4 l8 ~" I return 0;. F( n; t8 E, C
6 A1 N. r6 i( k5 @}// end main
T; P- y6 R% t3 Y$ @$ _. V# b; {4 R( M* E7 i8 d" q0 k
该程序目前的问题如下,在接受短信的时候无法显示短信的内容,而只是显示一个“~p”,谁有这个问题的解决方法,欢迎与我探讨。
3 Q& Y, d; F' \, W9 m" o* }2 S
6 Q# ~6 v: ^. \3 E7 k2 w
