查看: 3146|回复: 6
[Ansys仿真] SIWAVE设置Simulation\Computer Resonant Modes后出问题
发表于 2010-4-20 10:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
设置后出错误!那位高人帮忙看看
发表于 2010-5-5 11:11 | 只看该作者
帮你顶下,这个问题我还没遇到过,不知道怎么解决
发表于 2010-5-5 23:02 | 只看该作者
是不是你的路径是中文路径 或者你使用的破解文件已经正在使用 你可以将这个文件在copy一份仿真试试
发表于 2010-7-30 22:37 | 只看该作者
Dear Brother,1 e' [& F) r2 m5 E
I faced the same problem. This is how I solved.
6 K& q% K# b$ P6 G; ?1 o/ W6 x1 N: N( Y5 c
1  Import the .ANF file# E3 k- [& Z2 \5 `
2  Save it as  abc.siw ( abc means name of your choice)
7 a% n) _" q& x 3  Open abc.siw file.
( ]  B. r7 X8 d! ?; o& e( I# a0 G4 [3 I2 a* k5 U0 ~5 m
The problem gets solved. I hope this will help you.% ?6 U' k+ I: G2 L9 P
  U: |( i  i: q+ bBy the way I have a problem.9 w" H' K% S$ m, W
% T9 H3 v+ D' b# C* CIn the simulation menu, only Compute Resonance Mode is working. Other functions are not working. Can you please tell me what to do?- V' a7 T; m: h# K7 j% _
, X1 z) S: j0 g5 P: ?$ z- v
Also do you have a good training manual and tutorial .siw files? Please give me. ( lgos121345@yahoo.com)
; _; H' `% A* h/ ?& ?+ Q9 l0 v# ?- u3 [0 d
Regards6 \4 z- A  P) L) Y) }7 c* e7 x
* J( w- s' b4 w. {
lgos
发表于 2010-7-30 22:38 | 只看该作者
[size=100%][size=100%]Reply [size=100%][size=100%]1 # [size=100%][size=100%]xyy_zhong 5 E5 J4 A9 u, h
  B* X# n- p  F0 ?- X8 O
Dear Brother,
9 }, p0 T" J  Q/ SI faced the same problem. This is how I solved.0 |: X' y9 I9 @+ M9 `) F
. q- d/ k& A- \- `0 C7 @# b5 u2 K) Y1 Import the. ANF file7 ~/ h1 o% G3 J: o
2 Save it as abc.siw (abc means name of your choice)
0 T* J, Y  ?$ k. n/ q& O4 v( J/ y3 Open abc.siw file.
4 R; a2 F+ T4 X  q) Y. W9 h0 X) w, y2 j$ P, z
( {; e% U5 U' A2 b; y) @& E' Q. E- g+ F$ K* B
By the way I have a problem.( B/ }) m7 c2 _; Y" g
3 f+ L6 Z+ z$ `; H
5 O9 c4 Q. ]" H: ]8 x1 |
  G: b" b; s+ Q# d1 pAlso do you have a good training Manual and tutorial. SIW Files? Please give me. (lgos121345@yahoo.com)
& s/ V. e4 ?4 e6 l; @6 \: p8 `- r( j- o& t6 f8 g, D# o
Regards
. @& H" X6 i5 l4 B# S
) J$ J$ M9 P& Q5 h5 _( vlgos
 楼主| 发表于 2010-7-31 08:54 | 只看该作者
Compute Resonance Mode,英语不行会翻译不会写。3 ~# A1 ~7 w( g- \
不知道你是不是这个问题:其他功能需要你设置PORT,电压PORT或电流port才能仿真,来提取S参数Z参数和相应模型。你去看看教程就知道了。
发表于 2011-6-11 17:43 | 只看该作者
看似叠层设置错误或无地平面
GMT+8, 2025-10-25 19:42 , Processed in 0.125000 second(s), 27 queries , Gzip On.
