TA的每日心情 | 怒 2019-11-20 15:22 |
签到天数: 2 天 [LV.1]初来乍到
; \4 Q A9 {( S* H[root@qljt globalmem]# make -C /linux_kernel/linux-2.6.30/ M=/linux_drivers/06/globalmem/ modules0 [ o O# D# n2 u6 U( B
0 r" W& M. a( X ~/ H4 m, H* m8 f
make: Entering directory `/linux_kernel/linux-2.6.30'
# U" y/ E3 L* W7 Y% u- {9 D2 d& J2 V- d
CC [M] /linux_drivers/06/globalmem/globalmem.o' c! O; Y; k3 Q
C& ]6 O+ u- M% @
In file included from include/linux/gfp.h:4,
) i" q8 v' v& l8 {7 U3 l7 X5 Q# f4 c0 y) |$ U8 F
from include/linux/kmod.h:22, w5 w- J; c3 t& \, J+ F7 f% U
& q" e; Q4 W% j# X0 _
from include/linux/module.h:13,
+ ?: T n% ?: Z# y/ K7 B. W" I7 K c: A. @, W: T+ ^
from /linux_drivers/06/globalmem/globalmem.c:7:6 [+ \1 i" E/ |& c2 \
( R7 W7 a& S8 y* _# f. Winclude/linux/mmzone.h:18:26: error: linux/bounds.h: No such file or directory. F4 ~6 y' M6 n
' f, y- ?. \; D* u% G3 oinclude/linux/mmzone.h:256:5: warning: "MAX_NR_ZONES" is not defined) ^% n1 W' g& H: r! Y
& I$ M9 x+ J* O. H* m9 j
* j+ D, a! Q1 {
9 S; F6 u) |6 D2 ^" C5 ufrom include/linux/kmod.h:22,
/ U& Q+ O& B) P. y% g: C# v+ ?! E) k: c0 L$ W
7 z! o% n8 n! d* s" `1 |+ X8 J2 p( k0 ]3 b' e; ]5 D& ~( [& _: H
from /linux_drivers/06/globalmem/globalmem.c:7:% o; V& @4 q7 R; Y3 f
2 e& x% ?$ T* u+ N( G, l
include/linux/mmzone.h:290: error: 'MAX_NR_ZONES' undeclared here (not in a function)
( r$ Z6 T c1 |3 ^9 d/ x7 b7 W
, r" S! {6 F1 |8 W( L- p. sIn file included from /linux_drivers/06/globalmem/globalmem.c:11:' F. r# Z- Z) X' a! _5 ]
" ?# C5 a4 G. ?include/linux/mm.h:446:63: warning: "NR_PAGEFLAGS" is not defined8 a7 j# e7 S- f- }% {+ }: h! w
m4 |% m' [7 [ S2 s1 A9 V
include/linux/mm.h:494:62: warning: "NR_PAGEFLAGS" is not defined. W* i- m" c; c9 S8 x
: K- d5 u# K, i
/linux_drivers/06/globalmem/globalmem.c: In function 'globalmem_read':
0 y4 k# ?' l3 E N0 x& G! {* W- E! h2 B: n8 X: E
/linux_drivers/06/globalmem/globalmem.c:89: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int'
; O4 O2 U9 v/ j" w3 k1 T/ v @- @3 e
/linux_drivers/06/globalmem/globalmem.c: In function 'globalmem_write':
2 k% k: Q1 @; r$ f0 G2 K8 d
# `3 Y8 b' n/ N6 @% d/linux_drivers/06/globalmem/globalmem.c:118: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int'
0 [+ ]6 y: [& E1 ^* U& E1 J4 c* e* v7 w; N0 t
make[1]: *** [/linux_drivers/06/globalmem/globalmem.o] Error 1$ j$ K# E" f5 E6 S0 r
- ~ s+ W* J2 l& R s
make: *** [_module_/linux_drivers/06/globalmem] Error 21 @3 R# A0 P! }6 x e p$ }4 P
' e: ]2 J* p6 A/ W& Q
make: Leaving directory `/linux_kernel/linux-2.6.30
V% {: q F- N! J! i& E% A$ U4 Z5 H
解决的办法:+ e& x0 `4 T1 a/ U% b5 V
7 w4 i5 q: g9 ^! _到你内核的根目录下执行1 l; W' V( D% f. \
5 \! V) K ~& p1 s9 `! F2 o) B8 w
#make zImage 或
, R/ [ U8 w! Y0 G" e' N* E, S7 g
#make prepare |
