查看: 513|回复: 1
ROS仿真
    2019-11-19 16:54
    发表于 2020-3-25 08:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    一、Stage simulator
    二、Rviz
    一、Stage simulator
    Actuator model
    Blinkenlight model
    Blobfinder model
    Camera model
    Fiducial detector model
    Gripper model
    Position model
    Ranger model
    Wifi model
    Ranger model
    ranger
       sensor (
       pose [ x y z a ]
       size [  x y z ]
       fov a
       range [min max]
       watts 2.0
       color_rgba [ 0 1 00.15 ]
    Position model
    position
        drive "diff"
        velocity [ 0.0 0.0 0.0 0.0 ]
        localization "gps"
        localization_origin [ <defaults tomodel's start pose> ]
        odom_error [0.03 0.03 0.00 0.05]
        wheelbase 1.0
        velocity_bounds [-1 1 -1 1 -1 1 -90 90 ]
        acceleration_bounds [-1 1 -1 1 -1 1 -90 90]
    Blobfindermodel
    blobfinder
         colors_count 0
         colors [ ]
         image[ 80 60 ]
         range 12.0
         fov 3.14159/3.0
         pan 0.0
         size [ 0.0 0.0 0.0 ]
    •订阅的主题
    /cmd_vel (geometry_msgs/Twist)
    •发布的主题
    /odom(nav_msgs/Odometry)
    /base_scan(sensor_msgs/LaserScan)
    /base_pose_ground_truth(nav_msgs/Odometry)
    /image(sensor_msgs/Image)
    /depth(sensor_msgs/Image)
    /camera_info(sensor_msgs/CameraInfo)
    提供的tf
    base_link → base_laser
    base_footprint → base_link
    odom → base_footprint
    base_link → camera
    控制机器人运动
    sudo apt-get install ros-indigo-teleop-twist-keyboard
    rosrun teleop_twist_keyboard teleop_twist_keyboard.py
    简单的gmapping&保存map
    rosrun gmapping slam_gmapping scan:=base_scan
    rosrun map_server map_saver
      激光雷达应用:障碍物检测
      sensor_msgs/LaserScan.msg
      std_msgs/Headerheader
      float32angle_min
      float32angle_max
      float32angle_increment
      float32time_increment
      float32scan_time
      float32range_min
      float32range_max
      float32[] ranges
      float32[] intensities
      Rviz属性
      turtlebot_stage in Rviz
      安装:sudo apt-getinstall ros-indigo-turtlebot-simulator
      运行:roslaunchturtlebot_stage turtlebot_in_stage.launch
      troubleshooting
      Invalid <arg> tag: environment variable'TURTLEBOT_STAGE_MAP_FILE' is not set.
      Argxml is <argdefault=" $(env TURTLEBOT_STAGE_MAP_FILE)" name="map_file"/>
      The traceback for the exception waswritten to the log file
      export TURTLEBOT_STAGE_WORLD_FILE="/opt/ros/indigo/share/turtlebot_stage/maps/stage/maze.world"
      export TURTLEBOT_STAGE_MAP_FILE="/opt/ros/indigo/share/turtlebot_stage/maps/maze.yaml"
      运行指定的Rviz文件
      rosrun rviz rviz -d `rospack find stage_ros`/rviz/stage.rviz
      stage_ros gmapping
      <launch>
      <nodename="stage" pkg="stage_ros" type="stageros" args="$(find
      stage_ros)/world/willow-erratic.world"/>
      <nodename="gmapping" pkg="gmapping" type="slam_gmapping">
      <paramname="scan" value="base_scan"/>
      </node>
      <nodename="rviz" pkg="rviz" type="rviz" args="$(find
      stage_ros)/rviz/stage.rviz"/>
      </launch>
      Rviz中载入地图
      <launch>
      <arg name="map_file"default="$(find my_package)/maps/willow-full-
      0.05.pgm"/>
      <!-- Run the map server -->
      <node name="map_server"pkg="map_server" type="map_server" args="$(arg
      map_file) 0.05" />
      </launch>
    发表于 2020-3-25 18:08 | 只看该作者
    有没有更多注释一点
    GMT+8, 2025-11-6 19:17 , Processed in 0.187500 second(s), 27 queries , Gzip On.
