查看: 6967|回复: 4
[Ansys仿真] 原创:allegro与siwave 连接后 原FPM菜单不见的问题解决方法!!!
发表于 2010-4-2 14:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
安装ansoftlink4.1后 , 原先allegro中的 FPM skill程序菜单不见了:: |) _2 m- q$ d' N6 N8 c
原因:allegro的menupath 变量值被修改为:d:\Ansoft\integrate4/cdsmenus1633 E7 p" s: g  x
在此目录下 编辑allegro.men文件 添加代码如下:8 k1 T7 O, U* [
// FPM_BEGIN) }% ?- {3 e& H7 V) H; j
POPUP "F&PM"% U  {/ ]0 o9 |6 \4 b
BEGIN+ M  B8 U4 H( x/ |
MENUITEM "Quick &Grid","grids"
" I0 Q5 v" c) o# Q6 QMENUITEM "Quick &View","qview") L& @) J/ \$ {' ]7 t
MENUITEM "check_dir","check_dir"' E! l  v* N' x5 H" w( Z
MENUITEM "check_no_refdes","check_no_refdes"
- r# P1 b: A+ j( BMENUITEM "ch_nc_via","ch_nc_via"
; O! U) K1 b# c' r2 hMENUITEM "ch_text_overlap","ch_text_overlap"
/ ?% K7 s+ x. W& _MENUITEM "colorset","colorset"
' I9 |9 g, ~6 s! PMENUITEM "cot","cot"9 `8 N6 F0 t0 T' ~
MENUITEM "DeleteDanglingLines","DeleteDanglingLines"
% L  I, w" Q& x' B7 k: u- B' O8 K# UMENUITEM "drc walk","drc walk"8 [. N5 o# U- x; t: y
MENUITEM "hl_null_pin","hl_null_pin"! N% B$ d: B* L# G& F& {$ Z
MENUITEM "MoveRefDestoBodyCenter","r2c"
" ^2 Q7 O2 ^4 M( fMENUITEM "OrphanNet","OrphanNet"1 p4 _  s- D4 p( f; K
MENUITEM "ref_rot","ref_rot"9 C( T5 |! }# [0 i; Q  k4 f6 E' C
MENUITEM "StackVias","StackVias"+ D- M; U4 w; O& O
MENUITEM "uc shape","uc shape"1 u; q! M5 k- P' d' |+ m
MENUITEM "auto balance","auto balance"; I) u$ R' w9 v7 X. s/ b2 ^
MENUITEM "align_sym","align_sym"4 n' d# s! |0 X1 s' t
MENUITEM "boundaryview","boundaryview"
9 D0 P% `- F" n9 G! dMENUITEM "conv","conv". n# j) D) D2 ~! b
MENUITEM "hlvia","hlvia"- h( c  D* O, A" q. b' a: M
MENUITEM "scalpel","scalpel"/ U: \: M5 x: |3 w- k- p- ?
END5 p% f( a! {8 ^# {1 C( h. V
// FPM_END- l5 Y, C0 P4 G1 c* z
此段代码为FPM添加allegro菜单时 自动生成的 & O9 y- u- z/ z8 `1 {
保存文件 重启 问题解决!!!
参与人数 1贡献 +10 收起 理由
袁荣盛 + 10 Not Bad
 楼主| 发表于 2010-4-12 17:40 | 只看该作者
本人用的是16.3版本,使用中发现原16.3有些功能不能用,例如:setup->constraints->Modes 点击后没反应命令提示行 命令无法找到,错误原因ansoft下的allegro.men菜单文件 把Modes的调用命令改掉了,还有一些快捷键不能用,修改方法:打开16.3默认.men文件 复制到ansoft下的allegro.men文件中,并保留POPUP "F&PM",POPUP "ansoft"部分内容,保存文件 重启allegro 问题解决!
发表于 2010-12-21 17:10 | 只看该作者
高人啊!!!!!!!!!
发表于 2011-5-15 21:38 | 只看该作者
happybai ,你用的SIWAVE是哪个版本?
发表于 2011-9-1 15:13 | 只看该作者
15.5乍搞或
GMT+8, 2025-10-25 08:41 , Processed in 0.140625 second(s), 29 queries , Gzip On.
