RUNNING IBISCHK COMMAND: ibischk4 "D:\moxing\sprm345.ibs"# _( S6 F6 T9 L+ n9 y1 t4 a# g
IBISCHK4 V4.0.1
$ x x. C( j9 u1 G' R4 ^- e% H/ mChecking D:\moxing\sprm345.ibs for IBIS 3.2 Compatibility...& X" J% W O& I+ T3 V; i
WARNING (line 271) - Model BC1850BSHYPDFZ_1P8PD: C_comp min value is not the smallest value listed
4 A" l! a2 v; P: DWARNING (line 271) - Model BC1850BSHYPDFZ_1P8PD: C_comp max value is not the largest value listed9 Z, R5 B" w1 @8 o
WARNING (line 303) - Pulldown Typical data is non-monotonic/ w" d+ d# W. y! W" u, u( w+ |
WARNING (line 303) - Pulldown Minimum data is non-monotonic
/ ? r1 s4 H4 L7 y) nWARNING (line 304) - Pulldown Maximum data is non-monotonic8 U( T+ C% g( D$ \- q' y; z; |
WARNING (line 396) - Pullup Maximum data is non-monotonic0 ]2 g7 ^7 d' W5 M
WARNING (line 397) - Pullup Typical data is non-monotonic' ~* m& ]; F. ~
WARNING (line 398) - Pullup Minimum data is non-monotonic' N$ e/ l, Y# T: y' S
WARNING (line 558) - GND Clamp Minimum data is non-monotonic
) }" u. O, s: j5 K9 q# dWARNING (line 563) - GND Clamp Typical data is non-monotonic
, I# R+ |% u2 [% d/ d% lWARNING (line 564) - GND Clamp Maximum data is non-monotonic
) o3 }& @. v9 ~$ ZWARNING (line 1118) -( N. b( y# q- j6 q
Model BC1850BSHYPDFZ_PDZ: C_comp min value is not the smallest value listed
) H1 [5 G) m% f- @% X0 v' OWARNING (line 1118) -% N) k( k; z5 n# \" t$ O) I( x
Model BC1850BSHYPDFZ_PDZ: C_comp max value is not the largest value listed2 O1 v. d1 S9 z/ Y7 X
WARNING (line 1150) - Pulldown Typical data is non-monotonic
4 `0 i* |9 Q7 F. r1 l: NWARNING (line 1150) - Pulldown Minimum data is non-monotonic
/ T, M# [: ]$ i# }: F k$ l3 b3 B ^ |WARNING (line 1151) - Pulldown Maximum data is non-monotonic
2 @- a2 X+ E0 M0 Z! {. U8 jWARNING (line 1243) - Pullup Maximum data is non-monotonic
7 W8 k& \+ N% xWARNING (line 1244) - Pullup Typical data is non-monotonic
* \9 ^" c# }+ sWARNING (line 1245) - Pullup Minimum data is non-monotonic ^9 t6 ]0 K1 l6 w4 G3 a1 @$ D
WARNING (line 1998) -% Q/ r T+ N0 p9 r! x
Model BC1850BSHYPUFZ_PU: C_comp min value is not the smallest value listed+ f& b# `3 m2 B) G
WARNING (line 1998) -. n5 F7 y$ W2 y& |7 Y! }
Model BC1850BSHYPUFZ_PU: C_comp max value is not the largest value listed
% ~5 ^6 i; W3 o0 c) o7 `- `$ [9 }, IWARNING (line 2020) - Pulldown Maximum data is non-monotonic" w8 v. ^7 F5 S2 N6 t; J$ u
WARNING (line 2025) - Pulldown Typical data is non-monotonic
+ d, r1 y0 x! H J' \. p/ r2 }9 vWARNING (line 2031) - Pulldown Minimum data is non-monotonic
- ~9 E0 C, D4 Y: {! l% m: f, mWARNING (line 2111) - Pullup Typical data is non-monotonic3 O7 ~; X Q+ }3 w- P& K; G& R
WARNING (line 2118) - Pullup Maximum data is non-monotonic8 F7 E2 Q$ |# _! Q3 b. t
WARNING (line 2122) - Pullup Minimum data is non-monotonic
* h/ l0 a& z6 |0 W UWARNING (line 2743) -
/ r0 p3 V. q P) P- O3 H Model BC1850BSHYPUFZ_PUZ: C_comp min value is not the smallest value listed
2 c& B) S% z# r3 ~WARNING (line 2743) -
! S/ t) l5 ]+ J. ^5 B9 r+ q d Model BC1850BSHYPUFZ_PUZ: C_comp max value is not the largest value listed6 Y4 p( i: h! W4 o& S% E
WARNING (line 2764) - Pulldown Maximum data is non-monotonic
5 \1 J: A7 h- y, QWARNING (line 2769) - Pulldown Typical data is non-monotonic, D0 v; A/ u) ~ v8 m# Z0 X% _
WARNING (line 2775) - Pulldown Minimum data is non-monotonic" ^1 T% z& b2 M p2 p
WARNING (line 2855) - Pullup Typical data is non-monotonic
+ t5 z0 L! N. e: z% qWARNING (line 2862) - Pullup Maximum data is non-monotonic
6 m. v& c3 y; T& i% Q- D% ]- |WARNING (line 2866) - Pullup Minimum data is non-monotonic6 O. j4 F+ K1 n2 c, G V# `6 N6 H2 H
WARNING (line 3524) - Model BC1850CSHYPDFZ_1P8PD: C_comp min value is not the smallest value listed. M. m" X) o4 H
WARNING (line 3524) - Model BC1850CSHYPDFZ_1P8PD: C_comp max value is not the largest value listed- O2 p7 n8 u) t9 ]/ S
WARNING (line 3556) - Pulldown Typical data is non-monotonic( v$ m' y2 _3 }8 ~
WARNING (line 3556) - Pulldown Minimum data is non-monotonic
, D' K, L) _" h! r. _: e7 r0 j" UWARNING (line 3557) - Pulldown Maximum data is non-monotonic- Q$ v& @- I! \7 k$ J
WARNING (line 3649) - Pullup Maximum data is non-monotonic
3 ?) R& L4 }( rWARNING (line 3650) - Pullup Typical data is non-monotonic
7 C+ i; p. H% Q% HWARNING (line 3651) - Pullup Minimum data is non-monotonic
# _* |$ L9 C e7 Z+ zWARNING (line 3811) - GND Clamp Minimum data is non-monotonic
" X6 |, k- O! yWARNING (line 3817) - GND Clamp Typical data is non-monotonic8 X' @# e, P* ]1 p
WARNING (line 3817) - GND Clamp Maximum data is non-monotonic
8 H9 ^' Y2 W0 CWARNING (line 4367) -
" S: t1 P+ R/ ]" n% }) U6 W Model BC1850CSHYPDFZ_PDZ: C_comp min value is not the smallest value listed
t: V; U/ B" @+ ~7 J8 tWARNING (line 4367) -
7 \6 @% O+ L- d$ e9 T Model BC1850CSHYPDFZ_PDZ: C_comp max value is not the largest value listed- F9 U4 K! W& C( O0 P
WARNING (line 4399) - Pulldown Typical data is non-monotonic; s5 e2 H% `% B- }% d3 g
WARNING (line 4399) - Pulldown Minimum data is non-monotonic
* [- s8 ?5 H y0 M( o: C7 z( ^WARNING (line 4400) - Pulldown Maximum data is non-monotonic
' J1 p4 j0 W- X. y* v5 E7 r1 oWARNING (line 4492) - Pullup Maximum data is non-monotonic; i- r- D, `; Q
WARNING (line 4493) - Pullup Typical data is non-monotonic! W" Y0 \# V) @( c! d- {
WARNING (line 4494) - Pullup Minimum data is non-monotonic
; `2 q1 h; D+ a2 b ]$ H% uWARNING (line 5245) - Model BT3350BSHYPDFZP18_PD: C_comp min value is not the smallest value listed+ M) i. H/ u$ L. r8 ~. ^
WARNING (line 5245) - Model BT3350BSHYPDFZP18_PD: C_comp max value is not the largest value listed: T8 i( B8 d3 C. K, D' q( H
WARNING (line 5284) - Pulldown Maximum data is non-monotonic8 ? m R$ T% h5 b
WARNING (line 5285) - Pulldown Typical data is non-monotonic
' c9 |0 ^* W2 j: wWARNING (line 5285) - Pulldown Minimum data is non-monotonic
' V+ T. C9 |5 }7 dWARNING (line 5359) - Pullup Typical data is non-monotonic+ K- P. T) R) K$ k! X' r" }2 `
WARNING (line 5365) - Pullup Maximum data is non-monotonic; J5 {' _( P9 V: @: U9 M% q! a
WARNING (line 5380) - Pullup Minimum data is non-monotonic
0 M+ R9 h0 G8 @: E- p( N3 `WARNING (line 5537) - GND Clamp Minimum data is non-monotonic( J1 r- p$ m2 R/ n1 r0 v
WARNING (line 5542) - GND Clamp Typical data is non-monotonic4 }) P+ n- i M# n1 V
WARNING (line 5542) - GND Clamp Maximum data is non-monotonic5 N% b( `' ^6 V! J: S \
WARNING (line 6023) - Model BT3350BSHYPDFZP18_Z: C_comp min value is not the smallest value listed
" j% K" F/ e0 rWARNING (line 6023) -% a6 _2 |/ A, o* `2 d+ x" `5 U
Model BT3350BSHYPDFZP18_Z: C_comp max value is not the largest value listed$ F+ ]& u# N$ ~8 b* U1 b1 c. N% }& ~
WARNING (line 6062) - Pulldown Maximum data is non-monotonic( J) w$ f4 r% r, T$ Q
WARNING (line 6063) - Pulldown Typical data is non-monotonic
' Y8 F" [( ~0 Y% m6 KWARNING (line 6063) - Pulldown Minimum data is non-monotonic
: S3 Q, F4 r. }8 j) {WARNING (line 6138) - Pullup Typical data is non-monotonic1 f' X# s7 C$ O8 Z
WARNING (line 6143) - Pullup Maximum data is non-monotonic
* o' B+ N# ?: N/ K8 }- WWARNING (line 6158) - Pullup Minimum data is non-monotonic
# d/ Q4 D( J' N, ?$ _. PWARNING (line 6825) -
, ~- C6 F6 I- G9 l* c Model IC18SHYPDFZ_1P8PD: C_comp min value is not the smallest value listed
9 U9 y8 l' C8 D+ c1 mWARNING (line 6825) -
; s9 |" }; q8 d4 X7 q# i Model IC18SHYPDFZ_1P8PD: C_comp max value is not the largest value listed
* L+ ?3 A4 V7 c I$ iWARNING (line 6925) - GND Clamp Minimum data is non-monotonic
8 J9 f- Y1 l5 Z: P+ W8 m- EWARNING (line 6930) - GND Clamp Typical data is non-monotonic
$ @$ S- X% J/ Y+ d( i. kWARNING (line 6931) - GND Clamp Maximum data is non-monotonic
5 O8 o1 T9 @. l0 NWARNING (line 7042) -2 Z8 E( k+ u" h3 {% r) G
Model IC18SHYPDFZ_1P8PDZ: C_comp min value is not the smallest value listed
4 L2 B S1 r& j; LWARNING (line 7042) -
5 n; i8 G7 |/ a7 N$ |# _) w# F& ]! E Model IC18SHYPDFZ_1P8PDZ: C_comp max value is not the largest value listed# ^. I* `9 A. E$ m9 F/ X
WARNING (line 7289) -& N0 r4 I" U, s; |
Model IC18SHYPUFZ_1P8PU: C_comp min value is not the smallest value listed
* a9 J) @1 s0 C$ ^/ x' ?; IWARNING (line 7289) -( {* h- f+ f$ u! ?8 Q E
Model IC18SHYPUFZ_1P8PU: C_comp max value is not the largest value listed
' W% K4 p+ h9 i e( y8 sWARNING (line 7502) -
0 f3 E5 y; h7 X" F( U+ X7 I/ q Model IC18SHYPUFZ_1P8PUZ: C_comp min value is not the smallest value listed c2 K) y, E- `" b
9 T- J8 {) D- }. K# F S$ G; K$ q* S- i Model IC18SHYPUFZ_1P8PUZ: C_comp max value is not the largest value listed3 {' y& H# o j- `
WARNING (line 7748) -# B2 q4 |! r7 D$ {+ ]) ]
Model OC1850BSFZ: C_comp min value is not the smallest value listed
: G0 e+ E* B0 ]3 p% U* IWARNING (line 7748) -4 ^: H! L+ ^* F) b5 l+ H
Model OC1850BSFZ: C_comp max value is not the largest value listed
, [8 I% G- q9 \WARNING (line 7765) - Pulldown Maximum data is non-monotonic
. Q i1 j: e& k/ k* EWARNING (line 7770) - Pulldown Typical data is non-monotonic
9 j, a% I: X7 L$ R% E. e/ pWARNING (line 7776) - Pulldown Minimum data is non-monotonic
5 R( S$ |. r2 {) J; Z, vWARNING (line 7856) - Pullup Typical data is non-monotonic
: I+ ^8 q" R) m" x" ^" C8 |WARNING (line 7863) - Pullup Maximum data is non-monotonic
8 e3 `* t( k# g# H8 N+ v; q' @1 t s6 dWARNING (line 7867) - Pullup Minimum data is non-monotonic% F8 V# X; g% j( `5 M* _3 C
WARNING (line 8501) - GND Clamp Typical data is non-monotonic
W0 R( L) d$ D8 K/ \WARNING (line 8501) - GND Clamp Minimum data is non-monotonic
0 K/ a' ~* u3 x% m3 A+ X$ zWARNING (line 8501) - GND Clamp Maximum data is non-monotonic9 J9 |9 C5 x" x( G/ O* D
WARNING (line 8542) - POWER Clamp Minimum data is non-monotonic
" Z8 i. V% e0 sErrors : 0( W* X1 t. {/ \# b
Warnings: 966 S8 y( j X: \ n, c/ U* c
File Passed% B9 V$ t" K2 Y
END OF IBISCHK COMMAND OUTPUT/ s O4 f4 V9 p% @9 V! ]% \
READING IBIS FILE D:\moxing\sprm345.ibs
" i- B9 d# J( K" b; Y: M* kINFO @line 51 --- Completed PackagedDevice DAVINCI_ZWT+ x2 ?1 ~# \8 ~3 g8 O3 d
INFO @line 232 --- Completed PackagedDevice BC1850BSHYPDFZ
( f' f: _9 R- V! P; MINFO @line 261 --- Completed IbisIOCell SPRM345_BC1850BSHYPDFZ_1P8PD' F/ Y. X# ?) ~. {7 x4 z
INFO @line 1108 --- Completed IbisIOCell SPRM345_BC1850BSHYPDFZ_PDZ
& B; V4 Z- ^% @1 s% R _! WINFO @line 1959 --- Completed PackagedDevice BC1850BSHYPUFZ
4 y; g/ a' X% X; DINFO @line 1988 --- Completed IbisIOCell SPRM345_BC1850BSHYPUFZ_PU
7 n. r8 @7 o+ w; w! M! BINFO @line 2733 --- Completed IbisIOCell SPRM345_BC1850BSHYPUFZ_PUZ+ n9 j7 T7 y. ^6 y" U' Q# o
INFO @line 3485 --- Completed PackagedDevice BC1850CSHYPDFZ3 r [# I+ d, `, `5 `% [
INFO @line 3514 --- Completed IbisIOCell SPRM345_BC1850CSHYPDFZ_1P8PD. g5 m% K% { ~0 G- b
INFO @line 4357 --- Completed IbisIOCell SPRM345_BC1850CSHYPDFZ_PDZ
6 B" ~/ m. t" O, l. V" J" }INFO @line 5205 --- Completed PackagedDevice BT3350BSHYPDFZP184 q3 j* i7 M# z
INFO @line 5235 --- Completed IbisIOCell SPRM345_BT3350BSHYPDFZP18_PD- ^7 Q7 s& T& b5 O' \* Y( k% Y1 [8 k
INFO @line 6013 --- Completed IbisIOCell SPRM345_BT3350BSHYPDFZP18_Z
4 w v; H' j L( N Z* DINFO @line 6794 --- Completed PackagedDevice IC18SHYPDFZ
5 m: E7 n I& t3 mINFO @line 6820 --- Completed IbisIOCell SPRM345_IC18SHYPDFZ_1P8PD
5 m: x6 Q2 _9 H! k9 SINFO @line 7037 --- Completed IbisIOCell SPRM345_IC18SHYPDFZ_1P8PDZ
/ E1 o+ C0 m& p5 MINFO @line 7257 --- Completed PackagedDevice IC18SHYPUFZ4 w# ^ ^( f- G" ?) U
INFO @line 7284 --- Completed IbisIOCell SPRM345_IC18SHYPUFZ_1P8PU
, a+ U3 a9 ~9 UINFO @line 7497 --- Completed IbisIOCell SPRM345_IC18SHYPUFZ_1P8PUZ
8 i; a$ C' H1 T! ~2 j" x; GINFO @line 7718 --- Completed PackagedDevice OC1850BSFZ
: E2 `0 J& n- a; xINFO @line 7740 --- Completed IbisIOCell SPRM345_OC1850BSFZ6 K d! c# X8 ~+ p( ~% L4 `
INFO @line 8442 --- Completed PackagedDevice IOSCHF18SHY
# N, R# B0 n4 JINFO @line 8458 --- Completed IbisIOCell SPRM345_IOSCHF18SHY6 y x9 U& h5 @7 C& u9 j
RUNNING DMLCHECK for D:\moxing\sprm345.ibs.dml
3 ]4 k( B8 x: D2 IWARNING @line 567: SPRM345_BC1850BSHYPDFZ_1P8PD PullUp: non-monotonic region(s) in the range of -1.8V to 3.48V 6 u2 q$ s E0 R
WARNING @line 466: SPRM345_BC1850BSHYPDFZ_1P8PD PullDown: non-monotonic region(s) in the range of -1.8V to 3.6V
! C8 z- q, e" ?. F+ d$ f4 t7 `WARNING @line 361: SPRM345_BC1850BSHYPDFZ_1P8PD PowerClamp: Slope at end is not flat - point added
5 f, h- p. h* u: B7 G/ a- D; FWARNING @line 239: SPRM345_BC1850BSHYPDFZ_1P8PD GroundClamp: non-monotonic region(s) in the range of 1.62V to 1.95V - E# p2 j4 U- u* _" @
WARNING @line 239: SPRM345_BC1850BSHYPDFZ_1P8PD GroundClamp: Slope at end is not flat - point added ! |6 i, }( @4 r. Q
WARNING @line 690: SPRM345_BC1850BSHYPDFZ_1P8PD RisingWaveform rise_1 min: Non-monotonic dV = 0.0120151 at time 6.061e-010 exceeds 1% of voltage span
" W' P' g& q7 I% s- I) z ]% XWARNING @line 690: SPRM345_BC1850BSHYPDFZ_1P8PD RisingWaveform rise_1 typ: Non-monotonic dV = 0.0153993 at time 4.04e-010 exceeds 1% of voltage span
9 V9 Z' b$ U& C% y$ `WARNING @line 690: SPRM345_BC1850BSHYPDFZ_1P8PD RisingWaveform rise_1 max: Non-monotonic dV = 0.0148818 at time 3.03e-010 exceeds 1% of voltage span
& z1 V' P$ {, C* b/ FWARNING @line 690: TVCurve should asymptotically approach a final value - point added $ T: X% {+ n/ Z+ q
WARNING @line 1479: SPRM345_BC1850BSHYPDFZ_PDZ PullUp: non-monotonic region(s) in the range of -1.8V to 3.48V 0 N( Y' h9 W2 a
WARNING @line 1378: SPRM345_BC1850BSHYPDFZ_PDZ PullDown: non-monotonic region(s) in the range of -1.8V to 3.6V
2 s, ~5 T0 X+ d5 UWARNING @line 1276: SPRM345_BC1850BSHYPDFZ_PDZ PowerClamp: Slope at end is not flat - point added ( s" i3 ]* S4 Y
WARNING @line 1156: SPRM345_BC1850BSHYPDFZ_PDZ GroundClamp: Slope at end is not flat - point added - C' t) t( z/ ~& |- d$ o
WARNING @line 1602: SPRM345_BC1850BSHYPDFZ_PDZ RisingWaveform rise_1 min: Non-monotonic dV = 0.0120194 at time 6.061e-010 exceeds 1% of voltage span / h4 \% n- A$ `0 y/ a% ^6 T: I, S
WARNING @line 1602: SPRM345_BC1850BSHYPDFZ_PDZ RisingWaveform rise_1 typ: Non-monotonic dV = 0.0154121 at time 4.04e-010 exceeds 1% of voltage span ; T% I5 G- F$ @
WARNING @line 1602: SPRM345_BC1850BSHYPDFZ_PDZ RisingWaveform rise_1 max: Non-monotonic dV = 0.0148861 at time 3.03e-010 exceeds 1% of voltage span
6 u! p2 [1 K7 n6 L. UWARNING @line 1602: TVCurve should asymptotically approach a final value - point added * O3 k& @9 C8 v4 _
WARNING @line 1043: TVCurve should asymptotically approach a final value - point added ' V% r3 l; u& Z
WARNING @line 2326: SPRM345_BC1850BSHYPUFZ_PU PullUp: non-monotonic region(s) in the range of -1.8V to 3.48V ) _( \0 x/ f& J2 @# }
WARNING @line 2225: SPRM345_BC1850BSHYPUFZ_PU PullDown: non-monotonic region(s) in the range of -1.8V to 3.6V
) E9 `% V" `/ y. Z; SWARNING @line 2123: SPRM345_BC1850BSHYPUFZ_PU PowerClamp: Slope at end is not flat - point added 7 s& A% o5 o# I5 C
WARNING @line 2002: SPRM345_BC1850BSHYPUFZ_PU GroundClamp: Slope at end is not flat - point added
- j6 q1 h) G! ], ^WARNING @line 2449: SPRM345_BC1850BSHYPUFZ_PU RisingWaveform rise_1 min: Non-monotonic dV = 0.0082262 at time 6.061e-010 exceeds 1% of voltage span
" c, J7 d" ^+ p, U( m, |: OWARNING @line 2449: SPRM345_BC1850BSHYPUFZ_PU RisingWaveform rise_1 max: Non-monotonic dV = 0.0175137 at time 3.03e-010 exceeds 1% of voltage span ) P3 Q/ e; q1 O4 t! V
WARNING @line 1922: SPRM345_BC1850BSHYPUFZ_PU FallingWaveform fall_2 max: Non-monotonic dV = 0.0182 at time 3.03e-010 exceeds 1% of voltage span 7 [4 \4 t2 E4 l' O% v8 ^6 l0 H, ^, ~+ w
WARNING @line 3139: SPRM345_BC1850BSHYPUFZ_PUZ PullUp: non-monotonic region(s) in the range of -1.8V to 3.48V
! u* M- N; _8 I$ X7 _WARNING @line 3038: SPRM345_BC1850BSHYPUFZ_PUZ PullDown: non-monotonic region(s) in the range of -1.8V to 3.6V
* u7 P# h! \! @* P4 bWARNING @line 2936: SPRM345_BC1850BSHYPUFZ_PUZ PowerClamp: Slope at end is not flat - point added # A# `9 {5 s, }0 O' |, h/ e
WARNING @line 2816: SPRM345_BC1850BSHYPUFZ_PUZ GroundClamp: Slope at end is not flat - point added
% y# y* w- }$ I! bWARNING @line 3262: SPRM345_BC1850BSHYPUFZ_PUZ RisingWaveform rise_1 min: Non-monotonic dV = 0.00894443 at time 6.061e-010 exceeds 1% of voltage span 6 O7 [; u8 c; \2 R( L
WARNING @line 3262: SPRM345_BC1850BSHYPUFZ_PUZ RisingWaveform rise_1 max: Non-monotonic dV = 0.0188834 at time 3.03e-010 exceeds 1% of voltage span
' f3 n# N; q9 v j0 BWARNING @line 2736: SPRM345_BC1850BSHYPUFZ_PUZ FallingWaveform fall_2 max: Non-monotonic dV = 0.0182 at time 3.03e-010 exceeds 1% of voltage span
$ |% r( }6 k4 [+ [/ h. S# c6 @! I7 UWARNING @line 4021: SPRM345_BC1850CSHYPDFZ_1P8PD PullUp: non-monotonic region(s) in the range of -1.8V to 3.48V
" g! s% K8 d) PWARNING @line 3920: SPRM345_BC1850CSHYPDFZ_1P8PD PullDown: non-monotonic region(s) in the range of -1.8V to 3.6V
9 v3 S$ t& X/ R% IWARNING @line 3815: SPRM345_BC1850CSHYPDFZ_1P8PD PowerClamp: Slope at end is not flat - point added - W* A8 F3 v. g' V" n
WARNING @line 3693: SPRM345_BC1850CSHYPDFZ_1P8PD GroundClamp: non-monotonic region(s) in the range of 1.62V to 1.95V 1 ^- F. n4 ~" t( L& N e
WARNING @line 3693: SPRM345_BC1850CSHYPDFZ_1P8PD GroundClamp: Slope at end is not flat - point added
4 R1 ~( g5 J0 {4 oWARNING @line 4144: SPRM345_BC1850CSHYPDFZ_1P8PD RisingWaveform rise_1 min: Non-monotonic dV = 0.0121709 at time 6.061e-010 exceeds 1% of voltage span
( f/ w% A) q8 [ f5 c- nWARNING @line 4144: SPRM345_BC1850CSHYPDFZ_1P8PD RisingWaveform rise_1 typ: Non-monotonic dV = 0.0138916 at time 4.242e-010 exceeds 1% of voltage span
6 C1 T' ?9 {$ B+ @WARNING @line 4144: SPRM345_BC1850CSHYPDFZ_1P8PD RisingWaveform rise_1 max: Non-monotonic dV = 0.0158505 at time 3.636e-010 exceeds 1% of voltage span " K) C- P `% E; m
WARNING @line 4144: TVCurve should asymptotically approach a final value - point added
$ l. {8 ~% l8 L* s# _WARNING @line 4929: SPRM345_BC1850CSHYPDFZ_PDZ PullUp: non-monotonic region(s) in the range of -1.8V to 3.48V * n' Y$ E: i4 K/ B4 m5 L0 j
WARNING @line 4828: SPRM345_BC1850CSHYPDFZ_PDZ PullDown: non-monotonic region(s) in the range of -1.8V to 3.6V
; @9 ]) Q) w( |. `2 P0 \# H' K( f; hWARNING @line 4726: SPRM345_BC1850CSHYPDFZ_PDZ PowerClamp: Slope at end is not flat - point added 3 j9 Q! z) b: S: W" J3 c; d
WARNING @line 4606: SPRM345_BC1850CSHYPDFZ_PDZ GroundClamp: Slope at end is not flat - point added ! O3 a8 ?+ p I
WARNING @line 5052: SPRM345_BC1850CSHYPDFZ_PDZ RisingWaveform rise_1 min: Non-monotonic dV = 0.0121744 at time 6.061e-010 exceeds 1% of voltage span
, G; E$ j# b! DWARNING @line 5052: SPRM345_BC1850CSHYPDFZ_PDZ RisingWaveform rise_1 typ: Non-monotonic dV = 0.0139082 at time 4.242e-010 exceeds 1% of voltage span - T4 W) C* w# y; a7 y, _
WARNING @line 5052: SPRM345_BC1850CSHYPDFZ_PDZ RisingWaveform rise_1 max: Non-monotonic dV = 0.0158861 at time 3.636e-010 exceeds 1% of voltage span 5 C0 F2 m" H$ {& @+ J
WARNING @line 5052: TVCurve should asymptotically approach a final value - point added i+ S* p1 d: X% V7 e; Q
WARNING @line 5824: SPRM345_BT3350BSHYPDFZP18_PD PullUp: non-monotonic region(s) in the range of -3.3V to 6.6V
2 |1 q4 t6 O _# S6 S+ eWARNING @line 5723: SPRM345_BT3350BSHYPDFZP18_PD PullDown: non-monotonic region(s) in the range of -3.3V to 6.6V * l( g7 @6 G0 t9 P$ L7 z+ l N
WARNING @line 5642: SPRM345_BT3350BSHYPDFZP18_PD PowerClamp: Slope at end is not flat - point added 5 Q( d+ z. U* C; x
WARNING @line 5516: SPRM345_BT3350BSHYPDFZP18_PD GroundClamp: non-monotonic region(s) in the range of 3V to 3.6V
@: l3 L7 o @WARNING @line 5516: SPRM345_BT3350BSHYPDFZP18_PD GroundClamp: Slope at end is not flat - point added 7 [$ i- p1 h+ [# K3 h
WARNING @line 5290: SPRM345_BT3350BSHYPDFZP18_PD FallingWaveform fall_1 typ: Non-monotonic dV = 1.7445 at time 1.57576e-008 exceeds 1% of voltage span + l$ d- j1 S8 i) b1 Y
WARNING @line 5403: SPRM345_BT3350BSHYPDFZP18_PD FallingWaveform fall_2 typ: Non-monotonic dV = 1.7437 at time 2e-008 exceeds 1% of voltage span & G7 { w: ], q) |+ @
WARNING @line 5403: SPRM345_BT3350BSHYPDFZP18_PD FallingWaveform fall_2 max: Non-monotonic dV = 2.1393 at time 2e-008 exceeds 1% of voltage span * S* c2 Y1 g# @9 H0 ]
WARNING @line 5403: TVCurve should asymptotically approach a final value - point added
- r) ?" \7 ~6 U9 D& q7 F; l% d% @WARNING @line 6667: SPRM345_BT3350BSHYPDFZP18_Z PullUp: non-monotonic region(s) in the range of -3.3V to 6.6V . d, [# m' |" O5 \! R; O
WARNING @line 6566: SPRM345_BT3350BSHYPDFZP18_Z PullDown: non-monotonic region(s) in the range of -3.3V to 6.6V - {/ o1 b h* b: T" |" L
WARNING @line 6488: SPRM345_BT3350BSHYPDFZP18_Z PowerClamp: Slope at end is not flat - point added
' \- L y& K4 \, _: }6 r {WARNING @line 6364: SPRM345_BT3350BSHYPDFZP18_Z GroundClamp: Slope at end is not flat - point added : N* Y2 \" p: B0 C& U) ^$ O
WARNING @line 6138: SPRM345_BT3350BSHYPDFZP18_Z FallingWaveform fall_1 typ: Non-monotonic dV = 1.7482 at time 1.57576e-008 exceeds 1% of voltage span 8 f& M( f2 B, o: K( D" J
WARNING @line 6251: SPRM345_BT3350BSHYPDFZP18_Z FallingWaveform fall_2 typ: Non-monotonic dV = 1.7432 at time 2e-008 exceeds 1% of voltage span
. Y R, @2 \' G& ~5 p/ oWARNING @line 6251: SPRM345_BT3350BSHYPDFZP18_Z FallingWaveform fall_2 max: Non-monotonic dV = 2.1386 at time 2e-008 exceeds 1% of voltage span
4 I- g: T3 k; tWARNING @line 6251: TVCurve should asymptotically approach a final value - point added
4 `* s/ F; H9 q$ S bWARNING @line 7092: SPRM345_IC18SHYPDFZ_1P8PD PowerClamp: Overall minimum area exceeds overall typical area
) `. k" A' B/ h0 ?( z, X/ D& A, h& AWARNING @line 7092: SPRM345_IC18SHYPDFZ_1P8PD PowerClamp: Slope at end is not flat - point added
* M3 ?% q1 k7 M* P6 kWARNING @line 6972: SPRM345_IC18SHYPDFZ_1P8PD GroundClamp: non-monotonic region(s) in the range of 1.62V to 1.95V
+ J7 g7 I( x9 b( bWARNING @line 6972: SPRM345_IC18SHYPDFZ_1P8PD GroundClamp: Overall typical area exceeds overall maximum area
0 a/ Y- u- P: K \* XWARNING @line 6972: SPRM345_IC18SHYPDFZ_1P8PD GroundClamp: Overall minimum area exceeds overall typical area ! R6 H+ S" @1 T6 T- T; Y5 B4 M; J# a
WARNING @line 6972: SPRM345_IC18SHYPDFZ_1P8PD GroundClamp: Slope at end is not flat - point added 9 c, X- s. z# j8 P, J' D
WARNING @line 7325: SPRM345_IC18SHYPDFZ_1P8PDZ PowerClamp: Overall typical area exceeds overall maximum area
( K; y6 u+ }# H# ?# Z0 tWARNING @line 7325: SPRM345_IC18SHYPDFZ_1P8PDZ PowerClamp: Overall minimum area exceeds overall typical area
' N8 N* |4 x+ X/ j. M# v/ x, t( KWARNING @line 7325: SPRM345_IC18SHYPDFZ_1P8PDZ PowerClamp: Slope at end is not flat - point added / s3 @3 x9 U/ ~7 D
WARNING @line 7207: SPRM345_IC18SHYPDFZ_1P8PDZ GroundClamp: Overall typical area exceeds overall maximum area ( o. n, |3 V1 G
WARNING @line 7207: SPRM345_IC18SHYPDFZ_1P8PDZ GroundClamp: Overall minimum area exceeds overall typical area
9 @" q% T0 o( [; yWARNING @line 7207: SPRM345_IC18SHYPDFZ_1P8PDZ GroundClamp: Slope at end is not flat - point added
) A- K/ F. _/ W- Z: [WARNING @line 7556: SPRM345_IC18SHYPUFZ_1P8PU PowerClamp: Overall minimum area exceeds overall typical area
2 r( {) ^7 U3 z* L' X4 NWARNING @line 7556: SPRM345_IC18SHYPUFZ_1P8PU PowerClamp: Slope at end is not flat - point added
8 T) Z: o( \' wWARNING @line 7437: SPRM345_IC18SHYPUFZ_1P8PU GroundClamp: Overall typical area exceeds overall maximum area
* {* D+ l4 k& R( ?: G% `WARNING @line 7437: SPRM345_IC18SHYPUFZ_1P8PU GroundClamp: Overall minimum area exceeds overall typical area , p- A* r A& U
WARNING @line 7437: SPRM345_IC18SHYPUFZ_1P8PU GroundClamp: Slope at end is not flat - point added % a, A+ W; b; w! A
WARNING @line 7786: SPRM345_IC18SHYPUFZ_1P8PUZ PowerClamp: Overall typical area exceeds overall maximum area
- U' W1 ?6 f) [. a7 C: W: JWARNING @line 7786: SPRM345_IC18SHYPUFZ_1P8PUZ PowerClamp: Overall minimum area exceeds overall typical area
9 h: Q5 @* ^1 Y8 L' u/ zWARNING @line 7786: SPRM345_IC18SHYPUFZ_1P8PUZ PowerClamp: Slope at end is not flat - point added 9 c, E; ^) E( G) |; G
WARNING @line 7668: SPRM345_IC18SHYPUFZ_1P8PUZ GroundClamp: Overall typical area exceeds overall maximum area & \$ G: _9 g, ]
WARNING @line 7668: SPRM345_IC18SHYPUFZ_1P8PUZ GroundClamp: Overall minimum area exceeds overall typical area + M1 [ n" m/ O. d1 u+ k
WARNING @line 7668: SPRM345_IC18SHYPUFZ_1P8PUZ GroundClamp: Slope at end is not flat - point added
. t2 m( z' v( Z# R* B6 l3 `9 r( p/ c) dWARNING @line 7958: SPRM345_IOSCHF18SHY PowerClamp: Slope at end is not flat - point added $ G: |+ k. F; ?" H4 p
WARNING @line 7898: SPRM345_IOSCHF18SHY GroundClamp: non-monotonic region(s) in the range of 0V to 1.8V
7 K0 D2 H7 F2 s+ A. yWARNING @line 7898: SPRM345_IOSCHF18SHY GroundClamp: Slope at end is not flat - point added
2 \2 x# ~; R, } @; B+ TWARNING @line 8460: SPRM345_OC1850BSFZ PullUp: non-monotonic region(s) in the range of -1.8V to 3.48V 1 o, V; e+ S: d! F- ~0 v
WARNING @line 8359: SPRM345_OC1850BSFZ PullDown: non-monotonic region(s) in the range of -1.8V to 3.6V
+ y5 t) x& p/ m: GWARNING @line 8257: SPRM345_OC1850BSFZ PowerClamp: Slope at end is not flat - point added + u1 s2 P/ A) G& L/ g% b; c
WARNING @line 8147: SPRM345_OC1850BSFZ GroundClamp: Slope at end is not flat - point added
' A; Y& A4 h3 k+ l5 j! M9 \WARNING @line 8583: SPRM345_OC1850BSFZ RisingWaveform rise_1 min: Non-monotonic dV = 0.0096412 at time 4.545e-010 exceeds 1% of voltage span ! K. h$ U( B( X) l# ?
WARNING @line 8583: SPRM345_OC1850BSFZ RisingWaveform rise_1 typ: Non-monotonic dV = 0.0155995 at time 3.03e-010 exceeds 1% of voltage span $ \) e; i9 T; B( l; u4 `
WARNING @line 8583: SPRM345_OC1850BSFZ RisingWaveform rise_1 max: Non-monotonic dV = 0.0117303 at time 3.03e-010 exceeds 1% of voltage span / t r. T4 c/ d
Output saved as D:\moxing\sprm345.ibs.dml |
