; s3 m7 K& D$ e( R! U% V采用内核4.19.59编译完内核、模块、设备树后,将新编译产生的文件替换SD启动卡中rootfs分区对应文件,并安装模块到rootfs分区,系统启动卡在mmcblk1: p1 p2。请问各位大神这是什么原因?- x# x. L) P( f2 z. \
启动信息如下:
. T3 X: g' G. ?- aU-Boot 2014.07-00115-g6c69db3 (Jan 30 2016 - 17:32:22)0 c: q+ g0 p) Y, M( J6 N1 ~" g
4 `* E0 D. ]- x- P
1 M* f- L( {( n0 aI2C: ready
. K& ~" r1 q5 I/ g! cDRAM: 1 GiB
% V8 a; ^; r. q( b n9 i* S; SNAND: 512 MiB0 C$ z o+ b/ o7 E/ V
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
. |9 N9 c6 R4 L0 B2 M3 \/ Y* K4 }+ y9 Ireading uboot.env
8 F3 m' r: G* ?0 j7 K. `3 t8 TCould not probe the EEPROM at 0x50( E0 E1 {5 j+ B7 j6 _% p, Q
Could not get board ID." r+ Y1 ^- u. K) q5 F* ?
Net: cpsw, usb_ether& o/ B* ~" f8 L& ?1 b* n+ N! |7 d4 \
Hit any key to stop autoboot: 0 0 _( A4 D7 t9 O/ a3 r+ M
switch to partitions #0, OK) G5 u; r: A( a5 m6 V: w6 R1 O4 l. [
mmc0 is current device% C9 z! \0 o6 R" {
SD/MMC found on device 0" g9 k, d# w. Q' Q; t8 y
reading uEnv.txt
& }2 |# R, B# a; O6 K9 {** Unable to read file uEnv.txt **
) J5 e- f# ?. u4 T$ f- T4133376 bytes read in 195 ms (20.2 MiB/s)6 R$ c8 W% z4 t* f. |* y8 t
47121 bytes read in 9 ms (5 MiB/s)
( d8 J. o4 w, B7 ~% Z! ?7 QBooting from mmc0 .... k- n6 Y; l o0 @' i9 g
Kernel image @ 0x82000000 [ 0x000000 - 0x3f1200 ]
9 F4 J' {% ?) Q$ u7 ], @## Flattened Device Tree blob at 88000000
6 r+ O/ Y/ [) {5 ?- Y1 ?! { Booting using the fdt blob at 0x88000000
7 v% B, b3 A @! ^ Loading Device Tree to 8fff1000, end 8ffff810 ... OK# U4 V) k6 s/ O% Y" N( t) |* K
- N* i6 b. S1 s8 y8 ], `
' p* C* j+ A5 x: ~; J0 S& ?Starting kernel ...
5 s' T3 c9 l( _4 n% w, ?0 p$ }! Q1 p5 J1 ?" L x/ r
$ d' m* S3 ?5 X; J5 j- ?, g[ 0.000000] Booting Linux on physical CPU 0x0. Y' y% U F' d# E% M6 g$ G4 o; H
[ 0.000000] Linux version 4.19.59 (nan@nan-virtual-machine) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (ARM-rel-8.36))) #1 PREEMPT Fri Jan 10 10:12:38 HKT 2020
- v% D& p% v7 g* P6 t/ S[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d. g0 J& J: U* Z+ L3 i$ _
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
, X% ^, A, p$ I, ]. F T" r[ 0.000000] OF: fdt: Machine model: TI AM437x GP EVM
. j# p& W3 c/ Z' O[ 0.000000] Memory policy: Data cache writeback
! t! G- N. |: N0 N" R[ 0.000000] efi: Getting EFI parameters from FDT:
6 t p$ ?6 c# Q1 Y6 d[ 0.000000] efi: UEFI not found.
7 G' o2 C. X3 H) A[ 0.000000] cma: Reserved 48 MiB at 0xbd000000
9 k+ ]' y; X N' M$ y: p2 U[ 0.000000] CPU: All CPU(s) started in SVC mode.
# I: N* F5 C7 r# ^8 Q[ 0.000000] AM437x ES1.2 (sgx neon)4 Y y4 K8 f. n e& y
[ 0.000000] random: get_random_bytes calLED from start_kernel+0xa4/0x434 with crng_init=0' R" N6 |. g+ I5 l4 o
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260416
* E j6 G" C5 R7 b* W, U/ E* J9 c[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait% h* ~, A- S5 @- Y- |
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
+ b" ^0 T5 U% m2 O0 n* l) y/ g[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
# }2 E; h4 u+ }9 ?+ \% S# {9 V[ 0.000000] Memory: 976328K/1048576K available (8192K kernel code, 310K rwdata, 2612K rodata, 1024K init, 254K bss, 23096K reserved, 49152K cma-reserved, 212992K highmem)
. [6 f9 l$ `' m5 j6 O[ 0.000000] Virtual kernel memory layout:
$ k7 j s: t( u" D1 P[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB); m; K: m x5 m- ^( D$ N' _
[ 0.000000] fixmap : 0xFFC00000 - 0xfff00000 (3072 kB)0 C; o5 F+ x+ P- q
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)4 n) n5 p% t! @
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB). e. ~- e2 }7 X
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)/ h! x5 R W0 U8 V
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)& ?* c0 @3 y+ ]" T8 Y
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (9184 kB)
* A( w) |, Y( y; G+ Y; o$ y8 y[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
$ |7 t5 p& J, \ E8 ^% G[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 311 kB)
1 D- X3 T0 N1 a( |0 C& G[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 255 kB)% {# _; A0 ~9 X* `. `
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
! ~+ ~$ h+ E4 _ @9 E1 h# F[ 0.000000] rcu: Preemptible hierarchical RCU implementation.. T m$ s5 o7 g C
[ 0.000000] Tasks RCU enabled.
! R% a, R m1 m4 o[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16- H3 @, a0 p4 C( g# K7 }
[ 0.000000] L2C: platform modIFies aux control register: 0x0e030000 -> 0x3e430000 ] D1 f0 i* V
[ 0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
! H# j e2 j$ a9 M8 u" I6 {[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
+ x- N; Z+ n5 z% L[ 0.000000] OMAP L2C310: ROM does not support power control setting
0 q. k+ a' f& Z/ ][ 0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
1 U0 b# P% U D2 h/ d6 k[ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB s- H1 ^6 V6 w* l2 R$ J4 e, I
[ 0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000! m) E1 t/ O$ U3 i
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
5 ~. W& p, k3 Q+ X2 ?[ 0.000013] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns- \/ K$ Q7 y% y7 V9 @. y
[ 0.000030] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
* G; r" H+ w" E+ S5 {2 y[ 0.000039] OMAP clocksource: timer1 at 24000000 Hz% |, m7 _! ^ U
[ 0.000408] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
& K6 h; v3 {* l- N( ~& A4 o[ 0.000419] OMAP clocksource: 32k_counter at 32768 Hz
- [" f3 a1 Q9 e/ X. V[ 0.000783] Console: colour dummy device 80x30
- S4 _5 x* z( e! Y- y9 a1 H% C[ 0.000810] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'* c: k) X M! K* ]+ u
[ 0.000815] This ensures that you still see kernel messages. Please8 ^1 t" A/ c9 f# u6 p4 o5 p
[ 0.000820] update your kernel commandline.
- q& y H+ j: \0 \% ?1 K! f[ 0.000864] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)+ ^; I; I4 W: _( I
[ 0.060185] pid_max: default: 32768 minimum: 3013 u" S6 s& b5 c- P5 c* e, ^1 c: d- ?
[ 0.060372] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)6 v7 N- U/ f1 ~) ~# b; U
[ 0.060396] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
6 C' w" B* x* B9 ^$ C% w[ 0.061139] CPU: Testing write buffer coherency: ok; T2 O7 z% B3 M- k1 L- s
[ 0.061205] CPU0: Spectre v2: using BPIALL workaround
' u8 Y' l6 U& m. m( x3 U, k[ 0.062055] Setting up static identity map for 0x80100000 - 0x80100060 J# O/ i+ v2 N
[ 0.062198] rcu: Hierarchical SRCU implementation.
6 Q P; Q; B' m* | [$ O; l[ 0.062533] EFI services will not be available.
- ?8 y+ G4 V( \- I: j8 y[ 0.063443] devtmpfs: initialized' W9 R: B9 k: e# s( I; a* i8 E( B
[ 0.071741] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 44 n7 ^' s* f: P" ]$ _
[ 0.072128] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns! @* j; J5 i" n# z( u# h9 y
[ 0.072151] futex hash table entries: 256 (order: -1, 3072 bytes), i( J3 p5 Z3 { }! s8 M
[ 0.075293] pinctrl core: initialized pinctrl subsystem7 O+ Q7 r8 V c3 w4 u. i
[ 0.075984] DMI not present or invalid.! _- g0 F9 g4 {& c
[ 0.076400] NET: Registered protocol family 16# U" ^# K5 n1 {- |7 Z
[ 0.078066] DMA: preallocated 256 KiB pool for atomic coherent allocations
; c- w7 Y; U; J" @7 i! `3 W[ 0.156038] l4_per_cm:clk:0240:0: failed to disable
. f* p( U2 I% B- c9 F[ 0.157707] cpuidle: using governor ladder
! e( H* F" I% m2 [[ 0.157741] cpuidle: using governor menu
8 t, f: Z! I: S7 q4 m[ 0.159410] omap_l3_noc 44000000.ocp: L3 debug error: target 8 mod:0 (unclearable)3 u. B6 p7 B. O. o; r8 o
[ 0.159482] omap_l3_noc 44000000.ocp: L3 application error: target 8 mod:0 (unclearable)
; z& |* {8 I( ~2 W[ 0.164906] OMAP GPIO hardware version 0.1, ]( i9 P6 k) M
[ 0.173772] No ATAGs?1 G# R7 W+ K2 D8 {7 L
[ 0.173796] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
. O* [+ N. `4 T7 f+ m* Z[ 0.173812] hw-breakpoint: maximum watchpoint size is 4 bytes., y6 Z6 n% D% [
[ 0.186941] edma 49000000.edma: TI EDMA DMA engine driver
' f) {) r6 a' V: a# ^6 a& K" q% B[ 0.190805] SCSI subsystem initialized3 [6 {5 [8 i ^7 c1 r
[ 0.191324] media: Linux media inteRFace: v0.10/ ]& M1 y: F5 H: P( l1 Y
[ 0.191366] videodev: Linux video capture interface: v2.00
* F+ q" U1 Y+ C[ 0.191479] pps_core: LinuxPPS API ver. 1 registered' [8 I. I6 n% M) f! L0 G# u/ R8 Y, P
[ 0.191487] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
# h% E9 A K* h+ D1 Y( g[ 0.191509] PTP clock support registered I! Y5 ], h' \3 y [* C3 J; M( ?" a4 O
[ 0.191543] EDAC MC: Ver: 3.0.0( h2 z/ P# P% L: t
[ 0.192488] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400, [& }9 ^! ?! b" e3 l5 h
[ 0.193094] Advanced Linux Sound Architecture Driver Initialized.# ?% ]0 d, z" c! U- O1 ]
[ 0.194183] clocksource: Switched to clocksource timer1
: O; q9 E4 T8 A[ 0.201777] NET: Registered protocol family 2
6 v: n! D9 H& F3 U& O0 f[ 0.202518] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)8 Z5 I2 t/ @; Y6 t
[ 0.202553] TCP established hash table entries: 8192 (order: 3, 32768 bytes)/ R8 J8 r7 C1 b' \% T
[ 0.202613] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
3 R3 o% V( P4 O7 Z[ 0.202686] TCP: Hash tables configured (established 8192 bind 8192)1 k* h" F, ^; w& v. e9 w1 X
[ 0.202863] UDP hash table entries: 512 (order: 1, 8192 bytes)
. v$ b. C7 Q+ T* Q, R$ C[ 0.202887] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)9 q: |8 B _- I4 h0 I' q
[ 0.203030] NET: Registered protocol family 1
& x/ F3 U& s. H y5 f5 P[ 0.203571] RPC: Registered named UNIX socket transport module.
2 i6 g, x0 ?3 r2 ?6 t$ n+ @[ 0.203584] RPC: Registered udp transport module.
: x& N' F [2 i9 |# o8 K[ 0.203589] RPC: Registered tcp transport module.
$ B3 Z" J6 i. A[ 0.203595] RPC: Registered tcp NFSv4.1 backchannel transport module.
6 X. Z: J* l6 o% V4 |" ^4 ~[ 0.206658] Initialise system trusted keyrings
' d! e% T2 ^- o3 ~[ 0.206983] workingset: timestamp_bits=14 max_order=18 bucket_order=4
6 G- y7 T+ Z2 m* j3 }* j[ 0.211092] squashfs: version 4.0 (2009/01/31) Phillip Lougher+ g- h! A8 w2 e) R0 @( d" i
[ 0.211812] NFS: Registering the id_resolver key type
6 y* i) F" z; f/ E4 N" [, l[ 0.211844] Key type id_resolver registered
! L0 c5 x, ?% W( e9 Y[ 0.211851] Key type id_legacy registered, |, P e+ H# D* a$ T) ~% T
[ 0.211888] ntfs: driver 2.1.32 [Flags: R/O].
, k$ s- X; h; y, P+ V8 ~) ~[ 0.214074] Key type asymmetric registered
! k4 W9 i: D$ g# }# M[ 0.214090] Asymmetric key parser 'x509' registered
7 G' C$ ~ X! a! u9 p P. q5 q[ 0.214153] bounce: pool size: 64 pages; d2 v5 \# O: y
[ 0.214303] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)+ b* ^- K0 |, K
[ 0.214315] io scheduler noop registered5 T9 L" A' `. V. ?2 ~/ V" Z
[ 0.214322] io scheduler deadline registered
. ^) z5 S8 g2 F[ 0.214561] io scheduler cfq registered (default)
5 N" x: c! A1 g" ] m+ r0 `[ 0.214573] io scheduler mq-deadline registered6 E6 V* y( z' D8 V- W# _
[ 0.214580] io scheduler kyber registered6 p9 z2 y4 o, v. `( w
[ 0.217064] pinctrl-single 44e10800.pinmux: 199 pins, size 796
3 W- g- o" H- }9 i( \3 i+ R[ 0.219985] pwm-backlight backlight: backlight supply power not found, using dummy regulator
0 i; S( O6 m5 @$ |6 s0 U/ K8 H[ 0.220083] pwm-backlight backlight: Linked as a consumer to regulator.08 C. Y& S4 y7 E @ h( C, k6 h
[ 0.262527] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled, i$ r& b! w. w$ _' S1 K0 L4 b: L
[ 0.265721] omap8250 44e09000.serial: No clock speed specified: using default: 48000000+ j- A1 y% {9 l1 S* i0 ~8 q
[ 0.266430] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 31, base_baud = 3000000) is a 82504 K$ e8 _4 c& m8 L6 ]4 I6 Z+ t+ Y
[ 0.974441] console [ttyS0] enabled9 o. Y. s9 c# p: e
[ 0.978495] omap8250 481a6000.serial: No clock speed specified: using default: 480000001 o9 L0 u$ d) n- W0 U
[ 0.987295] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 32, base_baud = 3000000) is a 8250% { b$ v2 `' _( \/ r+ _
[ 0.998227] omap_rng 48310000.rng: Random Number Generator ver. 20
1 G& G% L5 T3 U1 x$ l[ 1.004672] random: fast init done9 s& c2 M. p/ `3 F$ Y0 m6 F
[ 1.008295] random: crng init done7 B3 G) |/ Q' a: V' @# U& l
[ 1.013538] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator6 C' o3 Z: f" T$ D
[ 1.023064] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
B. Y5 |/ ~$ U* D; L[ 1.029983] DSS: OMAP DSS rev 2.05 E2 @/ i8 _: u
[ 1.034040] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops)
W3 H1 M3 L( r2 i[ 1.055520] brd: module loaded6 b3 ~2 U, i" X: m. f0 ?
[ 1.067137] loop: module loaded
) h2 r9 A4 o# ^5 y- m( D, P[ 1.072834] libphy: Fixed MDIO Bus: probed
. p( |. f0 [! U2 e1 I2 j[ 1.144242] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
2 I. E- n5 @/ i# A" T/ n& \[ 1.151944] davinci_mdio 4a101000.mdio: detected phy mask ffffffcf, ~7 Q9 ?/ s# n8 k
[ 1.160099] libphy: 4a101000.mdio: probed3 Z9 }, e6 f9 I7 `, S% W
[ 1.164146] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver Micrel KSZ9031 Gigabit PHY
4 ~7 D9 o& g5 @5 f. b- |[ 1.173930] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver Micrel KSZ9031 Gigabit PHY
1 L# T7 S; q& f/ i% e[ 1.184613] cpsw 4a100000.ethernet: Detected MACID = 60:64:05:67:74:a9
. q" v9 K! e/ I0 H: o& T6 ?[ 1.191281] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4$ K {4 Z9 n1 q0 z3 _
[ 1.197745] cpsw 4a100000.ethernet: ALE Table size 10246 X; z. q6 u V: {) o4 a6 J% |. w
[ 1.203022] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)6 x& x- \: ^9 n7 H* e* S
[ 1.211556] i2c /dev entries driver
, ?* G/ j# s7 W9 |[ 1.217409] sdhci: Secure Digital Host Controller Interface driver; o B% ^/ ?, M. _& z0 s$ n8 E
[ 1.223622] sdhci: Copyright(c) Pierre Ossman# U* Z5 R q$ p
[ 1.229292] omap_hsmmc 47810000.mmc: Linked as a consumer to regulator.2
* o7 i) M* F5 E( V) ?8 `# U: T! J[ 1.261850] sdhci-pltfm: SDHCI platform and OF driver helper( J2 |: s+ y1 }& l) q
[ 1.268640] ledtrig-cpu: registered to indicate activity on CPUs
' i# d$ P* t2 i[ 1.277666] NET: Registered protocol family 10
& { r! R4 V- J4 K! q- F[ 1.283483] Segment Routing with IPv6
$ {$ G# T+ O& k6 n9 ?[ 1.287416] sit: IPv6, ipv4 and MPLS over IPv4 tunneling driver. F8 x" m% R( `4 ]0 H( d2 P/ u, N
[ 1.294255] NET: Registered protocol family 17
7 a' D4 y! @/ U# G6 J[ 1.299082] Key type dns_resolver registered
& e3 ~7 C) u- I2 N$ s( [7 z[ 1.303592] omap_voltage_late_init: Voltage driver support not added+ J. b5 h' ~6 R. C
[ 1.310927] Loading compiled-in X.509 certificates
, p# t6 m J/ Y2 N& D; K[ 1.326082] GPIO line 119 (SelEMMCorNAND) hogged as output/low
: a N/ R- Q; N" y l[ 1.332715] GPIO line 136 (SelLCDorHDMI) hogged as output/high' @. M% ?: {0 v7 L, B9 A' l8 I3 I
[ 1.339299] omap-gpmc 50000000.gpmc: GPMC revision 6.01 l( W: m9 t& i; p# o
[ 1.344548] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000+ q" ~" l4 k$ p% w9 V7 g7 m% ?
[ 1.352027] nand: device found, Manufacturer ID: 0x01, Chip ID: 0xdc
- E7 ~ y! {$ {+ e+ i[ 1.358468] nand: AMD/spansion S34ML04G2
; U7 C, [- Q* K0 ?* s) z$ x5 o7 @[ 1.362412] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 128
( j, |4 E5 H O[ 1.370186] Using OMAP_ECC_BCH16_CODE_HW ECC scheme
5 h& T7 W! T% {; W" ^[ 1.375191] 10 fixed-partitions partitions found on MTD device omap2-nand.0
* O+ ^) C9 M9 O( |% G9 L1 d" q[ 1.382183] Creating 10 MTD partitions on "omap2-nand.0":
; O* X4 q$ N$ r* X[ 1.387628] 0x000000000000-0x000000040000 : "NAND.SPL"
7 b. S; |9 [8 w& G( x[ 1.393878] 0x000000040000-0x000000080000 : "NAND.SPL.backup1"
" ?( I- ]4 X$ T( ^0 m. m. Q( ][ 1.400739] 0x000000080000-0x0000000c0000 : "NAND.SPL.backup2"
8 |4 \" M$ ~+ @" r* V7 W2 u6 J[ 1.407517] 0x0000000c0000-0x000000100000 : "NAND.SPL.backup3"! u+ s6 y$ a6 ]3 c) C$ d* H
[ 1.414311] 0x000000100000-0x000000180000 : "NAND.u-boot-spl-os"0 h W: X0 {9 n7 x% q5 k" R9 v2 t
[ 1.421356] 0x000000180000-0x000000280000 : "NAND.u-boot"
! c# z7 K. D7 V8 v/ {[ 1.428107] 0x000000280000-0x0000002c0000 : "NAND.u-boot-env"
# m7 z7 j) f p& U7 m[ 1.434785] 0x0000002c0000-0x000000300000 : "NAND.u-boot-env.backup1"
' g9 c% U5 `0 C& [' l9 h7 H[ 1.442156] 0x000000300000-0x000000a00000 : "NAND.kernel"
z; @' R" p5 P$ S& C9 v, G[ 1.452172] 0x000000a00000-0x000020000000 : "NAND.file-system"
8 G5 f) |- U: ~" v1 C! Q- N3 \8 Y[ 1.770019] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz9 n: U1 C& W |' o e8 A
[ 1.777328] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz W7 l1 _. h* w7 P1 t0 l
[ 1.783306] cpu cpu0: Linked as a consumer to regulator.5
4 J& e" R g$ x' O[ 1.788843] cpu cpu0: Dropping the link to regulator.5
9 S9 [& Y4 b0 A5 T2 H! t$ U. b[ 1.794169] cpu cpu0: Linked as a consumer to regulator.5
2 L+ v/ B4 G+ }" p[ 1.800959] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22), z3 |* _4 |8 C
[ 1.809823] omap_hsmmc 48060000.mmc: Got CD GPIO
/ v; O0 [8 k0 ?! p9 f* b[ 1.814946] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.13 k8 P( {3 e1 d9 Q- m; K7 M4 s$ A7 |
[ 1.849465] hctosys: unable to open rtc device (rtc0)+ r1 j9 W. q: N/ X5 X6 ?
[ 1.861265] l4_per_cm:clk:0300:0: failed to disable* u: Y& m+ y2 E6 Z4 z
[ 1.866796] vmmcwl_fixed: disabling* i1 h- F+ E$ ^2 K8 Z
[ 1.870531] ALSA device list:
7 | D8 E* s1 o9 s[ 1.873681] No soundcards found.
, l! k% y$ J3 s8 h) C# d, u+ @[ 1.878787] Waiting for root device /dev/mmcblk0p2...
2 r1 D5 G& B2 Y, R6 p' j9 S[ 1.939410] mmc1: host does not support reading read-only switch, assuming write-enable: l; |' |1 v6 M* Q
[ 1.953780] mmc1: new high speed SDHC card at address aaaa
# A e( R- `; s+ g9 X[ 1.961863] mmcblk1: mmc1:aaaa SS08G 7.40 GiB , I- U/ ]% s3 e) s6 E$ ]
[ 1.972476] mmcblk1: p1 p2 |
