查看: 362|回复: 0
[PADS VX.2.4][2层]MONDELLO-A4B4 ES6461 工业控制板(MP1522+SDRAM64M+PJ-307H)...
发表于 2020-3-2 11:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名字:[pads  VX.2.4][2层]MONDELLO-A4B4 ES6461 工业控制板(MP1522+SDRAM64M+PJ-307H)原理图+PCB文件+ g8 D6 r/ F, j5 Q
$ Z; o1 t5 M: Q, B0 I0 j
文件描述
  b8 I$ K  {8 x" z : ^, }: `7 o# c- d
1.功能描述:工业控制板
1 [( R! ]3 R0 \; B9 I9 x ! X/ N& @" X* z) x
2.软件版本:PADS  VX.2.4
( m- q4 l  ^) O/ g6 `: E
! R" s9 `' e# L! z$ Q: i3.层数:2层板: }. ?/ _) @8 ~5 u+ w8 @6 G2 g
+ o9 P2 j) P, k, z( g* q  ^- G
4.用到的主要芯片:MP1522+SDRAM64M
& Y) e8 X9 y, i4 a; }+ W# ^
5.PCB板尺寸:135mm*122mm, w8 b; {0 N- I( N  n6 W3 f" P
; n* ]' l0 U: r7 \. U* {作品截图如下:
& c" x' ^4 o1 f
4 r& m- k- m3 T% s$ t" }, \顶层截图:8 k+ L( H8 M$ C
2 M6 e0 K6 O- ~( j; P. a
底层截图:; i( q5 ^# T$ I) O
" B& k4 K/ m7 [
全层截图:; @) y$ u9 h' |' c. G& l5 J
  {- J, L# e6 A" |' U. B5 @
叠层截图:7 l# C3 e  \, M+ O, S
BOM:
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
C10603-CAP
C20603-CAP
C30603-CAP
C40603-CAP
C50603-CAP
C60603-CAP
C70603-CAP
C80603-CAP
C90603-CAP
C10TAJAJOE
C11TAJAJOE
C120603-CAP
C130805-CAP
C14CAPUF
C150603-CAP
C16TAJAJOE
C17TAJAJOE
C180603-CAP
C190603-CAP
C200603-CAP
C21TAJAJOE
C22TAJAJOE
C23SMB-PANASONIC
C24TAJAJOE
C250603-CAP
C26TAJAJOE
C27TAJAJOE
C28TAJAJOE
C29TAJAJOE
C300603-CAP
C310603-CAP
C320603-CAP
C330603-CAP
C34TAJAJOE
C350603-CAP
C36TAJAJOE
C37TAJAJOE
C380603-CAP
C39TAJAJOE
C400603-CAP
C410603-CAP
C42SMB-PANASONIC
C430603-CAP
C440603-CAP
C450603-CAP
C460603-CAP
C470603-CAP
C480603-CAP
C490603-CAP
C500603-CAP
C510603-CAP
C52TAJAJOE
C530603-CAP
C540603-CAP
C550603-CAP
C560603-CAP
C570603-CAP
C580603-CAP
C590603-CAP
C600603-CAP
C610603-CAP
C62TAJAJOE
C63TAJAJOE
C640603-CAP
C650603-CAP
C660603-CAP
C67TAJAJOE
C680603-CAP
C690603-CAP
C700603-CAP
C710603-CAP
C720603-CAP
C730603-CAP
C740603-CAP
C75TAJAJOE
C76TAJAJOE
C770603-CAP
C780603-CAP
C790603-CAP
C800603-CAP
C810603-CAP
C820603-CAP
C830603-CAP
C84TAJAJOE
C85TAJA
C86TAJA
C87SMB-PANASONIC
C88SMB-PANASONIC
C89TAJAJOE
C900805-RES
C910805-CAP
C920805-CAP
C931206
C94SMD-PANASONIC
C950603-CAP
C960805-CAP
C971206
C98SMD-PANASONIC
C990603-CAP
C1000805-CAP
C101TAJAJOE
C1020603-CAP
C1030805-CAP
C1040603-CAP
C1050805-CAP
C1061206
C107SMD-PANASONIC
C108SMD-PANASONIC
C1090603-CAP
C1100805-CAP
C1110603-CAP
C1120805-CAP
C1130603-CAP
C1140805-CAP
C1150805-CAP
C1160805-CAP
C1170603-CAP
C1180805-CAP
C1190603-CAP
C1200805-CAP
C1210603-CAP
C1221206-CAP
C1230603-CAP
C124SMD-PANASONIC
C1250805-CAP
C1260603-CAP
C1270805-CAP
C1280603-CAP
C1290805-CAP
C1300603-CAP
C1310805-CAP
C1320603-CAP
C1330805-CAP
C1340603-CAP
C1350805-CAP
C1360603-CAP
C1370603-CAP
C1381206-CAP
C1391206-CAP
C140TAJAJOE
C1410805-CAP
C1421206
C1430805-CAP
C1440805-CAP
C1450805-CAP
C1460805-CAP
C1470603-CAP
C1480603-CAP
C149SMB-PANASONIC
C150TAJAJOE
C1510603-CAP
C1520603-CAP
C1530603-CAP
D1DIODE\SMD
D2SOT-23
D3DSS-12
D4DSS-12
D5DSS-12
D6DSS-12
D7SOT-23
D8DIODE
D9DIODE
D10DSS-12
D11DSS-12
D12DIODE
D13SOT-23
D14DIODE\SMD
D15DIODE\SMD
D16LED-SMT-0805
F1FUSE\.4
FB1L\SMD
FB2L\SMD
FB3L\SMD
FB4L\SMD
FB5L\SMD
FB6L\SMD
FB7L\SMD
FB8L\SMD
FB9L\SMD
FB10L\SMD
FB111812-IND
FB12L\SMD
FB13L\SMD
FB14L\SMD
FB15L\SMD
FB16L\SMD
IR1IR
J1PWRJACK-WITHSLOT
J2HDR4-2MM
J3PJ-307H
J4SMD-3P
JP1SIP-3P
JP2SW0603
JS1HDR6-2MM
JS2HDR2-SHRD
JS3HDR6-2MM
JS4HDR13-2MM
L1IND-SMT-SD7030
L2L\SMD
L3L\SMD
L41812-IND
L5L\SMD
L6L\SMD
L8IND-SMT-SD7030
L9IND-SMT-SD7030
P1CF_CARD
P24IN1_MSX039_LYH
P3USB-M
P4USB_MINI_5P_SMT_REV1
P5CON30P-ALT
P6CONN-FH28-60S-0.5SH(51)
P7CON30P-ALT
PO1AV_JACK4
POT1POT-3MM-SMD-TC33
Q1TRA\SMD
Q2SOT23
Q3SOT23
Q4SOT-223
Q5TO-92\LINE\OP1
Q6TO-92\LINE\OP1
Q7SOT-223
Q8TO-92\LINE\OP1
Q9SOT-23
Q10SOT-23
Q11SOT-23
Q12SOT-23
Q13SOT-23
R10603-RES
R20603-RES
R30603-RES
R40603-RES
R50603-RES
R60603-RES
R70603-RES
R80603-RES
R90603-RES
R100603-RES
R110603-RES
R120603-RES
R130603-RES
R140603-RES
R150603-RES
R160603-RES
R170603-RES
R180603-RES
R190603-RES
R200603-RES
R210603-RES
R220603-RES
R230603-RES
R240603-RES
R250603-RES
R260603-RES
R270603-RES
R280603-RES
R290603-RES
R300603-RES
R310603-RES
R320603-RES
R330603-RES
R340603-RES
R350603-RES
R360603-RES
R370603-RES
R380603-RES
R390603-RES
R400603-RES
R410805-RES
R420603-RES
R430603-RES
R440603-RES
R450603-RES
R460805-RES
R470603-RES
R480603-RES
R490603-RES
R500603-RES
R510603-RES
R520603-RES
R530603-RES
R540603-RES
R550603-RES
R560603-RES
R570603-RES
R580603-RES
R590603-RES
R600603-RES
R610603-RES
R620603-RES
R630603-RES
R640603-RES
R650603-RES
R660603-RES
R670603-RES
R680603-RES
R690603-RES
R700603-RES
R710603-RES
R720603-RES
R730603-RES
R740603-RES
R750603-RES
R760603-RES
R770603-RES
R780603-RES
R790603-RES
R800603-RES
R810603-RES
R820603-RES
R830603-RES
R840603-RES
R850603-RES
R860603-RES
R870603-RES
R880603-RES
R890603-RES
R900603-RES
R910603-RES
R920603-RES
R930603-RES
R940603-RES
R950603-RES
R960603-RES
R970603-RES
R980603-RES
R990603-RES
R1000603-RES
R1010603-RES
R1020603-RES
R1030603-RES
R1040603-RES
R1050603-RES
R1060603-RES
R1070603-RES
R1080603-RES
R1090603-RES
R1100603-RES
R1110603-RES
R1120603-RES
R1130603-RES
R1140603-RES
R1150603-RES
R1160603-RES
R1170603-RES
R1180603-RES
R1190603-RES
R1200603-RES
R1210603-RES
R1220603-RES
R1230603-RES
R1240603-RES
R1250603-RES
R1260603-RES
R1270603-RES
R1280603-RES
R1290603-RES
R1300805-RES
R1310603-RES
R1320603-RES
R1330805-RES
R1340805-RES
R1350603-RES
R1360603-RES
R1370805-RES
R1380603-RES
R1390603-RES
R1400603-RES
R1410603-RES
R1420603-RES
R1430603-RES
R1440603-RES
R1451206
R1460805-RES
R1470603-RES
R1480603-RES
R1490603-RES
R1500603-RES
R1510603-RES
R1520603-RES
R1530603-RES
R1540603-RES
R1550603-RES
R1560603-RES
R1570603-RES
R1580603-RES
R1590603-RES
R1600603-RES
R1610603-RES
R1620603-RES
R1630603-RES
R1640603-RES
R1650603-RES
R1660603-RES
9 y) V: x& G- u) E
7 j2 r* x- L! n3 M) Q3 k) e
' c" ]- m2 _8 v" i  }' K4 @ 8 J/ y1 u( i7 ?- Q% @; o7 M
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
7 t2 o/ Q) Y) T& }: e: g# g9 v8 \2 S
GMT+8, 2025-7-27 20:39 , Processed in 0.156250 second(s), 28 queries , Gzip On.
