查看: 237|回复: 0
[allegro15.2][2层] WM8650平板电脑PCB-底板(不含核心板)(HT82B40R+VT6113+VT16...
发表于 2020-2-28 20:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
# y0 S3 H8 Y* g6 V: G6 C
[allegro15.2][2层] WM8650平板电脑PCB-底板(不含核心板)(HT82B40R+VT6113+VT1603A)原理图和pcb文件
% f* y# z* B) C0 ~
: r; Z8 g9 p8 v文件描述:4 c# ]7 }5 l! _) |; r) R' Z9 o' {
1. 作品用途:WM8650平板电脑PCB-底板(不含核心板)
4 s# W0 {' d1 D2. 软件版本:allegro15.2( j7 U8 j% b4 H% `+ a
3. 层数:2层
7 b) d- z9 a" k" s/ l* D- w4. 用到的主要芯片:HT82B40R+VT6113+VT1603A' V+ z" v6 R5 i/ G5 d3 T
5. pcb尺寸: 异形
) p6 k6 {$ A) O7 g, S2 p' M$ B. G$ _
作品截图如下:
8 k6 ]' G1 H9 D# `8 A' x4 D顶层截图:5 w0 ~2 `  R6 Q, m% v& n# ~5 F
; O% b# q. ^4 u底层截图:
! o+ X- n$ F0 s& {
$ ]% M# j2 G# t1 E& s4 q$ x全层截图:; S8 q1 Z8 r) s# h7 F* [4 Z1 U' y
0 q8 Z% q9 t7 mBOM:; x0 P  T' C7 u* O
Bill of Material Report (Condensed)
名称类型属性类别数量位号
BEAD0603BEAD0603MCB1608S221FBDISCRETE5FB5; FB6; FB7; FB8; FB9
BEAD0805BEAD0805MHC2012S221QBDISCRETE2FB1; FB2
BEAD0805BEAD0805MCB2012S221HBDISCRETE7FB3; FB4; FB10; FB11; FB12; FB13; FB14
CAP0603CAP06031000pFDISCRETE17C1; C2; C3; C7; C28; C38; C48; C49; C76; C77; C80; C104; C105; C106; C107; C108; C110
CAP0603CAP06031uFDISCRETE15C4; C5; C21; C22; C43; C62; C63; C64; C79; C96; C98; C119; C120; C125; C133
CAP0603CAP06030.1uFDISCRETE46C6; C8; C10; C11; C27; C29; C37; C40; C41; C42; C44; C46; C52; C53; C56; C57; C58; C60; C65; C66; C67; C68; C69; C71; C73; C83; C84; C85; C90; C92; C94; C97; C102; C109; C111; C112; C113; C114; C115; C118; C122; C124; C126; C129; C130; C132
CAP0603CAP06030.01uFDISCRETE1C20
CAP0603CAP060320pF/XDISCRETE1C30
CAP0603CAP06032200pFDISCRETE1C31
CAP0603CAP060310pFDISCRETE3C34; C47; C54
CAP0603CAP060310pF/XDISCRETE1C75
CAP0603CAP060347pF/XDISCRETE1C127
CAP0603CAP06031uF/XDISCRETE1C131
CAP0805CAP08054.7uFDISCRETE16C12; C17; C55; C59; C61; C78; C81; C82; C86; C89; C91; C93; C95; C99; C100; C101
CAP0805CAP08052.2uFDISCRETE5C16; C87; C88; C116; C117
CAP0805CAP080510uFDISCRETE16C23; C24; C25; C26; C32; C33; C35; C36; C39; C45; C50; C51; C72; C74; C103; C121
CAP1206CAP120610uF/16VDISCRETE8C9; C13; C14; C15; C18; C19; C123; C128
CAP1210CAP12100.01uF/XDISCRETE1C70
CAP3528CAP352847uFDISCRETE2CE1; CE2
CHOKE-CDRH3D16-4R7YCHOKE-CDRH3D16-4R7YSTD03015100MIO2L4; L5
CHOKE-CDRH3D28-PLCHOKE-CDRH3D28-PLSFE3015-3R3M-R-S-LFDISCRETE1L3
CHOKE-IHLP-2525CZ-01CHOKE-IHLP-2525CZ-016.8uHIC2L1; L2
CON-85201-2805CON-85201-280585201-2805IO1J13
CON-A2502_PLCON-A2502_PLCON-A2502IO1J2
CON-FFC-6210-30CON-FFC-6210-306212-30IO2J7; J16
CON-FPC-A951250-1CON-FPC-A951250-19631S-50Y913IO1J18
CON-_USB-A-SOCKET_A1D41FCON-_USB-A-SOCKET_A1D41FSUA-110EDISCRETE2J3; J4
CONN_1223-06-02-PLCONN_1223-06-02-PL1223-06-02IO1J14
DIP_JACK_PJ-328-M-PLDIP_JACK_PJ-328-M-PLPJ-328IO1J9
H1183H1183S16013LFIC1T1
HEADER1X4-100HEADER1X4-1002211S-04G/XIO1J12
JACK_PJK-114-M-PLJACK_PJK-114-M-PLPJK-114IO1J8
LED-LT8A23-51-UR96-T5LED-LT8A23-51-UR96-T5LED LAMP REDDISCRETE1LED1
LED-LT8A23-51-UR96-T5LED-LT8A23-51-UR96-T5LED LAMP GREENDISCRETE3LED2; LED3; LED4
LQFP48-19P7LQFP48-19P7VT6113_LQFPIC1U8
MIC-WM-64PCMIC-WM-64PCO422-40C1-PCD-00-L/XDISCRETE1MIC1
PAD_1X2_2_2P-PLPAD_1X2_2_2P-PL1x2-2.0/XDISCRETE2J10; J11
PIN_A-PLPIN_A-PLPIN/XDISCRETE4B1; B2; B3; B4
QFN48-19P7-THQFN48-19P7-THVT1603AIC1U10
RES0402RES0402MLVS0402E10DISCRETE8ESD1; ESD2; ESD3; ESD6; ESD9; ESD10; ESD11; ESD12
RES0402RES0402MLVS0402E10/XDISCRETE4ESD4; ESD5; ESD7; ESD8
RES0603RES060310KDISCRETE18R1; R5; R6; R7; R9; R12; R18; R21; R23; R29; R37; R55; R58; R62; R63; R64; R65; R135
RES0603RES0603100DISCRETE6R2; R3; R76; R77; R78; R79
RES0603RES0603100KDISCRETE23R4; R10; R13; R14; R16; R24; R25; R28; R35; R36; R39; R40; R41; R42; R49; R51; R52; R80; R81; R90; R97; R101; R118
RES0603RES06031KDISCRETE6R8; R85; R86; R103; R113; R114
RES0603RES0603100K/XDISCRETE1R11
RES0603RES060330K_1%DISCRETE1R15
RES0603RES0603240K_1%DISCRETE2R17; R117
RES0603RES0603510DISCRETE4R22; R108; R111; R112
RES0603RES06033KDISCRETE1R26
RES0603RES06032MDISCRETE1R27
RES0603RES060352.3K_1%DISCRETE1R30
RES0603RES06035.1MDISCRETE1R31
RES0603RES060310K_1%DISCRETE2R32; R126
RES0603RES0603453K_1%DISCRETE1R34
RES0603RES0603100K_1%DISCRETE1R38
RES0603RES06034.7KDISCRETE9R43; R100; R120; R121; R122; R123; R127; R131; R132
RES0603RES060333DISCRETE3R44; R53; R54
RES0603RES06030/XDISCRETE11R45; R48; R56; R61; R83; R87; R88; R92; R94; R104; R134
RES0603RES06030DISCRETE11R46; R50; R57; R68; R82; R84; R89; R91; R93; R95; R99
RES0603RES06031MDISCRETE2R47; R69
RES0603RES06036.2K_1%DISCRETE1R59
RES0603RES060310K/XDISCRETE4R60; R109; R110; R128
RES0603RES060349.9_1%DISCRETE4R66; R67; R70; R71
RES0603RES060375DISCRETE4R72; R73; R74; R75
RES0603RES0603226K_1%DISCRETE1R96
RES0603RES0603120K_1%DISCRETE1R98
RES0603RES06037.5K/XDISCRETE1R102
RES0603RES06037.5KDISCRETE2R105; R106
RES0603RES060315KDISCRETE1R107
RES0603RES06032.4DISCRETE2R115; R116
RES0603RES06035.9K_1%DISCRETE1R119
RES0603RES06034.7K/XDISCRETE3R124; R130; R133
RES0603RES060315K/XDISCRETE1R125
RES0603RES06036.19K_1%DISCRETE1R129
RES1206RES12060/XDISCRETE1R33
RES1210RES12100.15_1%DISCRETE2R19; R20
RN-8P4R-31P5X062RN-8P4R-31P5X062100DISCRETE4RN1; RN2; RN3; RN4
SC-82SC-82S-80860CNNB-B9LT2GIC1U2
SMD_CONN_52207-0467-PLSMD_CONN_52207-0467-PL52207-0467IO2J15; J17
SMD_EUP3472ADIR1_SOP8-PLSMD_EUP3472ADIR1_SOP8-PLEUP3472ADIR1IC1U6
SMD_PJK107-M-PLSMD_PJK107-M-PLPJK-107DISCRETE1J1
SMD_RJ45_SMT8P8C_M_PLSMD_RJ45_SMT8P8C_M_PLSMT8P8CIO1J6
SMD_RT8008PB_SOT23-5-PLSMD_RT8008PB_SOT23-5-PLAAP2408VIR1IC1U7
SMD_TP_1SMD_TP_1PLLTPIO73P3VSUS; 5V; 5VIN; EN5VIN; ENVCC; VBAT; VCC33
SMD_TP_1MMSMD_TP_1MMTestPoint_1mmIO43P3VA; RSMRST-; VIN; VPACK+
SMD_TS-A87-PLSMD_TS-A87-PLKFC-A05-03IO4SW1; SW2; SW3; SW4
SMD_VR_100K-PLSMD_VR_100K-PL10K/XDISCRETE1RV1
SMD_WM8650_IOB_120P-PLSMD_WM8650_IOB_120P-PLWM8650_CoreBoardIC1U1
SOD123SOD123RB161M-20DISCRETE2D6; D9
SOD123SOD123MMSZ5246B-TPDISCRETE1D7
SOD123SOD123MMSZ5235BDISCRETE1D8
SOD-106SOD-106RB051L-40DISCRETE2D1; D2
SOD-106SOD-106RB051L-40/XDISCRETE1D3
SOIC8-50X204SOIC8-50X204GS9435IC2Q1; Q10
SOIC8-50X204SOIC8-50X204GS4953IC1Q6
SOIC8-50X204SOIC8-50X204EUP8207-84ADIR1IC1U4
SOT23-5SOT23-5S-80829CNMC-B8OT2G/XDISCRETE1U3
SOT23-5SOT23-5EUP2571DISCRETE1U13
SOT23-6SOT23-6EUP2584DISCRETE1U12
SOT23-132SOT23-132BAT54SDISCRETE2D4; D5
SOT23-132SOT23-132AP6209-33GBDISCRETE1U5
SOT23-132SOT23-132AP1722B-33GCDISCRETE1U9
SOT23-BCESOT23-BCEMMBT3906DISCRETE1Q16
SOT23-GDSSOT23-GDSSPN7002S23RGDISCRETE8Q2; Q3; Q4; Q7; Q8; Q11; Q12; Q15
SOT23-GDSSOT23-GDSGN2305DISCRETE4Q5; Q9; Q13; Q14
SSOP48-25X378SSOP48-25X378HT82B40RIC1U11
ZWSDC0506-PLZWSDC0506-PLZWSDC0506IO1SD1
附件:& W$ \, X: ?0 V4 k! J
原理图和PCB文件如下:) P7 R' j. i/ a, o1 G; w' l
游客,如果您要查看本帖隐藏内容请回复
# h! s6 R+ _* h) M
6 T/ @+ ~' ~& r- w; u& c: Z6 R
GMT+8, 2025-7-27 20:41 , Processed in 0.156250 second(s), 28 queries , Gzip On.
