查看: 567|回复: 3
[allegro15.2][6层] 开发板(VS100RX+IP175D+H7019FNL+EP91H0 )原理图和pcb文件
发表于 2020-2-28 18:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
; ~% C8 T- `6 x- i* r
[allegro15.2][6层] 开发板(VS100RX+IP175D+H7019FNL+EP91H0 )原理图和pcb文件1 r; R) n' o4 @2 L% t; U
) J" s9 n# B( P; ?. J0 x
文件描述:( m3 O; l* k1 j4 X
1. 作品用途:VS100RX+IP175D+H7019FNL+EP91H0 PCB8 j) `' S% B1 s" V8 t: ?0 w& l' O
2. 软件版本:allegro15.2& ^1 z9 G# U; U
3. 层数:6层
  @2 G2 q0 z) h2 ?; r$ F4. 用到的主要芯片:VS100RX+IP175D+H7019FNL+EP91H0
8 y3 R7 f& v7 v% b& I6 |5. pcb尺寸: 5507*3112 MIL
9 [- O8 ^8 x4 H% V( b; T& e" p+ _# D" y5 ^% B7 A
作品截图如下:* G& d, }1 x! \& M9 S  v- X2 v
顶层截图:5 F" V+ L1 G( m2 e
- s$ y6 T( ]* s0 i# e, S
底层截图:
& Q/ y( r% j5 X) u & }7 K* I8 }$ `$ W
全层截图:4 R1 e. M- K7 ?% [, {* L
7 g( [! X* t: t0 ~% u! I
BOM:
" W: c7 Q, D6 G+ w) f7 N, n
Bill of Material Report (Condensed)
名称类型属性类别数量位号
5X7OSC8/SM_0_5X7_125MHZ CMOS125MHz CMOSIC1X1
6X11CAPACITOR POL_6X11_NI_10UF/100VNI_10uF/100VIC1C500
402CAP NP_0402_100NF100nFIC118C2; C3; C4; C5; C6; C7; C8; C9; C22; C23; C26; C29; C45; C46; C48; C49; C50; C51; C53; C54; C55; C56; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C119; C122; C123; C124; C125; C126; C128; C129; C130; C131; C132; C133; C134; C135; C136; C140; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C155; C158; C159; C163; C164; C165; C177; C502; C503; C505; C506; C507; C702; C801; C802; C808; C809; C811; C812; C813; C815; C816
402CAP NP_0402_10NF/100V10nF/100VIC2C14; C15
402CAP NP_0402_NINIIC4C16; C17; C162; C178
402CAP NP_0402_10NF10nFIC2C19; C21
402CAP NP_0402_390PF390pFIC10C24; C25; C27; C28; C30; C31; C34; C35; C170; C171
402CAP NP_0402_15PF15pFIC2C42; C43
402CAP NP_0402_470NF470nFIC2C117; C137
402CAP NP_0402_1NF1nFIC2C121; C141
402CAP NP_0402_3.3NF3.3nFIC1C156
402CAP NP_0402_220PF220pFIC1C160
402CAP NP_0402_33NF33nFIC1C161
402CAP NP_0402_22NF22nFIC1C179
402CAP NP_0402_NI_180PFNI_180pFIC1C803
402CAP NP_0402_100PF100pFIC1C806
402R_0402_1K1KIC31R1; R2; R5; R6; R7; R32; R35; R39; R40; R41; R42; R80; R109; R134; R508; R509; R510; R511; R512; R513; R514; R515; R516; R532; R806; R808; R809; R810; R819; R832; R837
402R_0402_49R949R9IC33R10; R11; R12; R13; R14; R15; R16; R17; R43; R44; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R61; R62; R64; R65; R137; R138; R139; R140; R811; R812; R813; R814; R828
402R_0402_4.53K4.53KIC1R18
402R_0402_NINIIC21R19; R23; R75; R76; R77; R112; R115; R116; R119; R121; R123; R143; R144; R145; R147; R159; R160; R827; R830; R835; R836
402R_0402_75R75RIC3R20; R22; R805
402R_0402_100R100RIC2R21; R148
402R_0402_100K100KIC7R24; R26; R129; R800; R801; R815; R817
402R_0402_4.02K4.02KIC1R25
402R_0402_27K27KIC1R27
402R_0402_1.62K1.62KIC2R28; R29
402R_0402_402R402RIC1R30
402R_0402_1.7K1.7KIC2R31; R34
402R_0402_200R200RIC1R33
402R_0402_0R0RIC15R38; R69; R72; R73; R74; R85; R111; R113; R114; R118; R120; R122; R127; R133; R136
402R_0402_220R220RIC9R45; R56; R86; R87; R88; R89; R90; R141; R142
402R_0402_4.7K4.7KIC10R67; R68; R78; R79; R81; R92; R93; R94; R95; R96
402R_0402_NCNCIC1R82
402R_0402_6.19K6.19KIC1R83
402R_0402_499R499RIC3R91; R156; R157
402R_0402_20K20KIC1R124
402R_0402_2.5K2.5KIC1R126
402R_0402_10K10KIC5R128; R821; R822; R829; R833
402R_0402_49.9K49.9KIC2R130; R831
402R_0402_5K5KIC2R131; R132
402R_0402_5.6K5.6KIC1R135
402R_0402_2.49K2.49KIC1R146
402R_0402_1.1K1.1KIC1R158
402R_0402_NI_1KNI_1KIC2R523; R816
402R_0402_NI_392RNI_392RIC1R802
402R_0402_5R15R1IC2R803; R804
402R_0402_392R392RIC1R807
402R_0402_33R33RIC2R818; R834
402R_0402_39K39KIC1R820
402R_0402_137R137RIC1R838
603BEAD_0603_FERRITE 120R/2AFerrite 120R/2AIC1B800
603TRISIL_BIDIR_0603_PGB1010603-MRPGB1010603-MRIC2ESD2; ESD3
603R_0603_100R100RIC2R110; R117
603R_0603_10R10RIC1R125
603R_0603_NI_0RNI_0RIC2R524; R525
603R_0603_NINIIC4R528; R529; R530; R531
0603_LEDLED_0603_LED_LEDLEDIC8D5; D6; D7; D8; D9; D13; D14; D803
0603_LEDLED_0603_LED_NI_LEDNI_LEDIC1D22
805BEAD_0805_FERRITE 600RFerrite 600RIC2B801; B802
805CAP NP_0805_4.7UF4.7uFIC2C10; C11
805CAP NP_0805_2.2UF2.2uFIC1C12
805CAP NP_0805_NI_100NF/63VNI_100nF/63VIC1C501
805CAP NP_0805_10UF10uFIC3C800; C810; C814
805CAP NP_0805_1UF1uFIC2C804; C805
805INDUCTOR_0805_BLM21PG600SN1BLM21PG600SN1IC1FB1
805INDUCTOR_0805_10UH10uHIC2L1; L800
805R_0805_100R100RIC1R155
100874479787210_1008_NI_74479787210NI_74479787210IC1FB3
1206CAP NP_1206_100NF/50V100nF/50VIC3C13; C38; C39
1206CAP NP_1206_1NF/2KV1nF/2KVIC1C18
1812CAP NP_1812_10NF/1.5KV10nF/1.5KVIC2C700; C701
1812R_1812_NINIIC2R825; R826
744273TRAN_HM33_0_744273_744273801744273801IC1CM500
744273TRAN_HM33_0_744273_NI_744273801NI_744273801IC1CM501
AG6100-SIMAG6100_AG6100-SIM_NI_AG6100NI_Ag6100IC1PSE1
AG9605-SIMAG9605-2BR_AG9605-SIM_AG9605-2BAg9605-2BRIC1PD1
BGA-268VS100-SNK_BGA-268_VS100RXVS100RXIC1U1
CASE-BCAPACITOR POL_CASE-B_100UF100uFIC13C1; C20; C44; C47; C52; C66; C120; C138; C142; C172; C504; C718; C807
CASE-BCAP POL_CASE-B_100UF100uFIC4C116; C127; C153; C154
CASE-BCAP POL_CASE-B_22UF22uFIC2C118; C139
CASE-BCAP POL_CASE-B_47UF47uFIC1C157
CASE-DCAP POL_CASE-D_470UF470uFIC2C67; C181
CON-HDMI-19HDMI_A_0_CON-HDMI-19_HDMI_AHDMI_AIC1J2
CONPWRCONN JACK PWR_0_CONPWR_NI_PWR JNI_PWR JACKIC1J11
DIPSW8-SMD-MSW DIP-8/SM_DIPSW8-SMD-M_SW DIPSW DIP-8/SMIC1SW500
DO1608CINDUCTOR_DO1608C_NINIIC4L622; L623; L624; L625
FIDUCIALHEADER 1_FIDUCIAL_FIDFIDIC8FD1; FD2; FD3; FD4; FD5; FD6; FD7; FD8
H7001NL_80MILH7001NL_H7001NL_80MIL_H7019FNLH7019FNLIC1TR1
HC49_USCRYSTAL_HC49_US_25MHZ25MHZIC1Y1
HOLE43PTEST POINT_HOLE43P_TPTPIC8TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP800
IRM0101PL-IRM0101-3_IRM0101_PL-IRM0101PL-IRM0101-3IC1IR1
LEDIRTXLED_1_LEDIRTX_NI_LED_IRNI_LED_IRIC1D801
LED_TH_90LED_0_LED_TH_90_LEDLEDIC4D1; D2; D3; D11
MH126PTEST POINT_MH126P_MHMHIC4MH1; MH2; MH3; MH4
PQFP-128175C_DEMO_MII_0_PQFP-128_IP175DIP175DIC1U8
QSOP-16MAX8505EEE_QSOP-16_MAX8505EEEMAX8505EEEIC1REG3
RCLAMP0524PRCLAMP0524_0_RCLAMP0524P_RCLAMPRclamp0524IC5U3; U4; U6; U803; U804
RJ45X8_PCONN RECT 8_0_RJ45X8_P_RJ45RJ45IC1J3
RJ00812RJ45_TRNS_0_RJ00812_RJ45_TRNSRJ45_TRNSIC1J6
SJ1-3515-SMTPHONOJACK STEREO-15_2_SJ1-3515-CONN 3.5MM SWIC4J13; J501; J502; J503
SOIC-14EP91H0_SOP14_SOIC-14_EP91H0EP91H0IC1U801
SOIJ-SOIC-825LC512-I-SN_SOIJ-SOIC-8_M95M02M95M02-DRMN6TPIC1U7
SON2X2-6-EPTPS60151DRVT_SON2X2-6-EP_TPS601TPS60151DRVTIC1U2
SOT23-5AD820/SO_0_SOT23-5_ADCMP600BRJZADCMP600BRJZIC2U9; U800
SOT23-5NC7SZ14/SOT23_SOT23-5_NC7S14M5XNC7S14M5XIC2U11; U13
SOT23-5NC7S08/SOT23_0_SOT23-5_NC7SZ08MNC7SZ08M5XIC1U12
SOT23-5NC7SZ32/SOT23_0_SOT23-5_NC7SZ32NC7SZ32M5XIC2U802; U806
SOT23-5NC7SZ384/SOT23_0_SOT23-5_NC7SZ1NC7SZ126M5XIC1U805
SOT-23MMBT2907A/SOT_0_SOT-23_MMBT2907MMBT2907AIC1Q2
SOT-23DS1818-10_SOT-23_DS1818-10DS1818-10IC1U5
SOT-23-SMALLBAT54C/SOT_0_SOT-23-SMALL_BAT54BAT54CIC4D4; D12; D800; D802
SOT-23-SMALLMMBT2222A/SOT_2_SOT-23-SMALL_MMMMBT2222AIC1Q1
SWSM_INDINDUCTOR_SWSM_IND_1UH/3A1uH/3AIC3L6; L7; L611
TDFN-EP-10MAX1556ETB_TDFN-EP-10_MAX1556ETMAX1556ETBIC2REG1; REG2
TPSMDT POINT S_TPSMD_TPSMDTPSMDIC12TP1; TP8; TP16; TP700; TP701; TP702; TP801; TP802; TP803; TP804; TP805; TP806
TSSOP-1474HC74_0_TSSOP-14_MM74HC74AMTCMM74HC74AMTCIC1U807
TSSOP-16MAX3232_2_TSSOP-16_MAX3232CUEMAX3232CUEIC1U22
TSW-105HEADER 5X2_TSW-105_HEADER 5X2MHEADER 5X2MIC1J504
TSW-105-SCONN RCPT 5_TSW-105-S_NI_HEADERNI_HEADER 5IC1J500
VLF4012AINDUCTOR_VLF4012A_3.3UH/1.2A3.3uH/1.2AIC4L2; L3; L4; L5
附件:
9 R9 n4 _( N. e, i原理图和PCB文件如下:- s: R/ Y7 R8 K  S
游客,如果您要查看本帖隐藏内容请回复
8 t1 }: {) ?: N  {7 n0 C: E" K' w, U# s3 i. N2 I+ \( G
发表于 2021-12-2 22:12 | 只看该作者
感觉好高尚大气。
“来自电巢APP”
发表于 2022-1-6 15:36 | 只看该作者
不错,我看看
1 {% b7 N7 _$ S; q
GMT+8, 2025-10-12 19:17 , Processed in 0.171875 second(s), 27 queries , Gzip On.
