查看: 241|回复: 0
[allegro15.2][4层] PIIX3测试主板(82091AA+82C42PCPL+DS12887A+74FCT3245)原理...
发表于 2020-2-28 17:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
* e' G4 b' G8 b# q% [6 Z; F2 t( b[allegro15.2][4层] PIIX3测试主板(82091AA+82C42PCPL+DS12887A+74FCT3245)原理图和pcb文件* p. n* N) g& T7 w; U- a6 B; w+ h
5 I# ]' X' o" u2 u& R' s文件描述:0 C$ m1 a# V/ A, ]+ T* r2 @4 G% M
1. 作品用途:PIIX3测试主板
/ I9 g2 W" {4 U; j( A2. 软件版本:allegro15.2: D5 J" c$ D) Q% Y# Y; u
3. 层数:4层4 P& l0 T/ A, o! R& J# J
4. 用到的主要芯片:82091AA+82C42PCPL+DS12887A+74FCT3245
4 R) e9 W3 H/ U( r5. pcb尺寸: 异形
' T9 J# n% w  h
7 x7 D4 O1 N5 Y( m作品截图如下:
* ^* W; x0 m: ?7 x1 p* s顶层截图:
- X8 d. ~% D. t' V底层截图:
& c5 n' _& E$ P- ^* q4 D
( M3 e& w6 V% w全层截图:
+ ~! W: n& r$ b, Q
- y" l% d6 a8 o; WBOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
805CAP_NP-0.1UF,5%0.1ufDISCRETE118C1; C25; C31; C37; C54; C56; C57; C59; C60; C68; C69; C70; C72; C74; C82; C83; C84; C85; C91; C92; C93; C94; C96; C97; C105; C106; C107; C109; C110; C111; C112; C113; C116; C117; C120; C130; C142; C144; C147; C149; C152; C156; C159; C160; C162; C166; C167; C169; C173; C174; C177; C179; C185; C188; C190; C191; C195; C196; C198; C199; C202; C208; C210; C213; C218; C221; C222; C224; C225; C226; C227; C228; C229; C230; C234; C235; C236; C237; C239; C240; C243; C246; C250; C257; C259; C260; C262; C264; C268; C270; C274; C275; C276; C277; C279; C280; C281; C282; C283; C286; C287; C288; C290; C295; C296; C297; C300; C303; C305; C307; C312; C313; C316; C318; C319; C320; C322; C332
805CAP_NP-470PF,5%470pfDISCRETE11C2; C3; C4; C6; C23; C34; C35; C36; C73; C75; C323
805CAP_NP-50PF,5%50pfDISCRETE4C5; C27; C29; C30
805CAPACITOR_NON_POL-180PF180PFDISCRETE17C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C33
805CAP_NP-0.01UF,5%0.01ufDISCRETE23C24; C32; C65; C86; C115; C119; C131; C145; C168; C170; C180; C186; C194; C209; C211; C220; C233; C238; C249; C266; C273; C278; C294
805CAP_NP-0.001UF,5%0.001ufDISCRETE34C26; C55; C58; C61; C71; C76; C104; C108; C114; C143; C146; C148; C187; C197; C201; C212; C214; C223; C244; C248; C251; C258; C263; C267; C269; C284; C285; C289; C301; C306; C309; C310; C321; C325
805CAP_NP-100PF,5%100pfDISCRETE16C38; C39; C40; C41; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53
805CAP_NP-0.022UF,5%0.022ufDISCRETE3C118; C232; C311
805CAP_NP-1UF,5%1ufDISCRETE4C304; C315; C329; C330
805CAP_NP-4.7NF,5%4.7nfDISCRETE1C314
805CAP_NP-0.22UF,5%0.22ufDISCRETE1C326
805CAP_NP-10PF,5%10pfDISCRETE2C327; C328
805FER_BEAD-1.5NH1.5nhDISCRETE5L1; L8; L9; L10; L11
805FER_BEAD-1.25NH1.25nhDISCRETE2L4; L5
805RESISTOR-8.2K8.2KDISCRETE1R1
805RESISTOR-220220DISCRETE1R2
805R-00DISCRETE9R3; R4; R6; R21; R22; R23; R31; R34; R35
805R-150150DISCRETE3R5; R114; R115
805R-10K10KDISCRETE11R7; R9; R10; R13; R15; R18; R20; R100; R102; R111; R113
805R-220220DISCRETE10R8; R26; R28; R29; R30; R55; R72; R92; R98; R99
805R-8.2K8.2kDISCRETE1R11
805R-1K1kDISCRETE3R12; R67; R101
805R-100100DISCRETE6R14; R25; R42; R45; R69; R71
805R-4.7K4.7KDISCRETE5R16; R56; R73; R93; R96
805R-2020DISCRETE2R17; R70
805R-330330DISCRETE4R19; R48; R52; R59
805R-200200DISCRETE3R24; R41; R68
805RESISTOR-3.3K3.3KDISCRETE2R27; R33
805R-3333DISCRETE4R32; R78; R94; R112
805R-2222DISCRETE11R36; R37; R38; R39; R40; R46; R47; R54; R74; R75; R77
805RESISTOR-2222DISCRETE9R43; R44; R76; R79; R80; R81; R82; R83; R106
805R-4747DISCRETE5R49; R50; R51; R57; R63
805RESISTOR-3333DISCRETE9R53; R84; R85; R86; R87; R88; R103; R104; R105
805RESISTOR-10K10KDISCRETE2R58; R66
805R-240240DISCRETE4R60; R62; R64; R65
805RDIFF_100100DISCRETE3R61; R95; R108
805RESISTOR-2.2K2.2KDISCRETE1R91
805RESISTOR-100100DISCRETE1R97
805R-15K15KDISCRETE3R107; R109; R110
805R-1010DISCRETE2R116; R117
1206CAP_NP_1206-1UF,10%1ufDISCRETE58C67; C77; C78; C80; C87; C88; C89; C90; C100; C102; C121; C122; C123; C124; C125; C126; C127; C128; C129; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C151; C153; C154; C155; C161; C163; C164; C171; C172; C175; C176; C181; C182; C189; C192; C193; C203; C204; C205; C206; C207; C215; C216; C217; C231; C255; C261; C291; C299
1206RESISTOR_1206-6868DISCRETE2R89; R90
1210INDUCTOR-1.5UH1.5uhDISCRETE1L14
1812FER_BEAD_1812-1NH1nhDISCRETE6L2; L3; L6; L7; L12; L13
CAPDBL_COATEDD_DCAP_NP_COATEDD-100UF,5%100ufDISCRETE6C63; C103; C178; C256; C292; C298
CAPDBL_POL_4MM_BCAP_POL-10UF10ufDISCRETE1C272
CAP_POL_CCAP-22UF22ufDISCRETE33C28; C62; C64; C66; C79; C81; C95; C98; C99; C101; C150; C157; C158; C165; C183; C184; C200; C219; C241; C242; C245; C247; C252; C253; C254; C265; C271; C293; C302; C308; C317; C324; C331
CON2_3K2HEADER_3IO1J40
CON3_4K24_HEADERIO2J38; J41
CON6USUSB_CON_0_0IO2J3; J4
CON6_X156_1KEYPIHEADER_6IO3J18; J20; J21
CON17_STK_MDIN9HEADER_17IO1J6
CON20MFHEADER_10X2IO1J19
CON22STK_DB9M_PLHEADER_22IO1J7
CON27_DB25F_PLDB25_NEWIO1J5
CON30_SH_X5HEADER_15X2IO1J28
CON33_SH_34K5FLP_CONIO1J23
CON39_SH_40K20HEADER_20X2IO2J26; J27
CON40_SL_VRM8DC2DC_CONNIO1J22
CON98_ISA_ALPHACON_ISA16BIO3J8; J9; J10
CON120_PCI_ALPHAPCI_CON__2IO4J12; J13; J14; J15
DIP24_600DS12887AIC1U31
DIP32_60028F001BX_TIC1U1
F2817FUSEDISCRETE3F1; F2; F3
JB6JMP_3X2IO1JB1
JB8JMP_4X2IO1JB2
JP2JUMPERIO2J11; J33
JP2HEADER_2IO6J16; J17; J29; J34; J39; J42
JP3JMP_3PIO10J1; J2; J24; J25; J30; J31; J32; J35; J36; J37
MH157X376_8VIA_UHOLEIC9MH1; MH2; MH3; MH4; MH5; MH6; MH7; MH8; MH9
PLC4482C42PCPLIC1U2
QFP100_65MM_30X282091AAIC1U7
QFP208_5MMDBX_0_6IC1U13
QFP208_5MMPIIX3IC1U17
QFP208_5MMPMC_0_6IC1U27
RBL8_3216RP4R-4.7K4.7kDISCRETE6RP1; RP83; RP109; RP116; RP122; RP126
RBL8_3216RP4R-1K1KDISCRETE8RP2; RP4; RP5; RP7; RP9; RP10; RP16; RP111
RBL8_3216RP4R-3333DISCRETE14RP3; RP6; RP8; RP73; RP79; RP84; RP85; RP103; RP113; RP117; RP127; RP128; RP129; RP155
RBL8_3216RP4R-10K10KDISCRETE27RP11; RP12; RP13; RP14; RP17; RP21; RP22; RP31; RP38; RP39; RP44; RP49; RP56; RP62; RP76; RP81; RP86; RP94; RP101; RP105; RP110; RP112; RP130; RP141; RP142; RP145; RP148
RBL8_3216RP4R-2222DISCRETE9RP15; RP131; RP132; RP133; RP134; RP135; RP136; RP137; RP138
RBL8_3216RP4R-2.7K2.7KDISCRETE9RP18; RP19; RP23; RP72; RP75; RP77; RP78; RP80; RP156
RBL8_3216RP4R-6868DISCRETE67RP24; RP25; RP26; RP27; RP28; RP29; RP32; RP33; RP34; RP35; RP36; RP37; RP40; RP41; RP42; RP43; RP45; RP46; RP47; RP48; RP50; RP51; RP52; RP53; RP54; RP55; RP57; RP58; RP59; RP60; RP61; RP63; RP64; RP65; RP66; RP67; RP68; RP69; RP70; RP71; RP74; RP89; RP90; RP91; RP92; RP93; RP95; RP96; RP97; RP98; RP99; RP100; RP107; RP108; RP115; RP119; RP120; RP121; RP123; RP124; RP125; RP139; RP140; RP143; RP144; RP146; RP147
RBL8_3216RP4R-5.6K5.6KDISCRETE3RP30; RP87; RP106
RBL8_3216RP4R-330330DISCRETE4RP82; RP88; RP104; RP149
RBL8_3216RP4R-1010DISCRETE2RP114; RP118
RBL8_3216RP4R-22K22KDISCRETE5RP150; RP151; RP152; RP153; RP154
SIM72SIM_PAR36IC4U9; U10; U11; U12
SOIC14_2007406IC2U3; U37
SOIC14_20074ALS08IC1U19
SOIC14_20074ALS00IC2U21; U36
SOIC14_20074LS125IC1U22
SOIC14_20074HCT14IC1U23
SOIC14_20074LS126IC1U28
SOIC14_20074F32IC1U29
SOIC14_2007407IC1U32
SOIC14_20074ALS74IC1U33
SOIC14_20074ALS04IC1U38
SOIC16_20074F174IC1U35
SOIC20_37674FCT3245IC4U14; U16; U18; U39
SOIC20_37674LS244IC1U20
SOIC20_376LVDSINIC1U24
SOIC20_376LVDSOUTIC1U25
SOIC20_37674ALS245IC1U26
SOIC28_376ICS9159_0_1IC1U34
SOP20_X368GD75232SOPIC2U5; U6
SOT23_1_2_3NPNDISCRETE1Q1
SOT23_2_1_3DIODEDISCRETE26D1; D2; D3; D4; D5; D6; D7; D8; D9; D10; D11; D12; D13; D14; D15; D16; D17; D18; D19; D20; D21; D22; D23; D24; D25; D26
TO220H_4_X100_UPLT1587IC2U8; U30
TSOP40_5MM28F002BX_TIC1U4
XT2V_HC49U_X192CRYSTALIC1Y1
ZIF387_SKT8P6_2_1IC1U15
附件:
/ j  o/ a% Q4 v- B$ E原理图和PCB文件如下:
( \' c; m9 [2 K; C# E1 h; o
游客,如果您要查看本帖隐藏内容请回复
2 c9 |# o2 K' Z  h) I. o( d
' Z1 X5 r1 U2 H0 Z6 A- V
8 H; b5 [7 m2 N+ E( ?/ t% |7 o. o7 L6 ]# z, ?3 A& ~
GMT+8, 2025-7-27 20:42 , Processed in 0.125000 second(s), 29 queries , Gzip On.
