查看: 408|回复: 1
matlab好像删错东西,帮助文档用不了了!!!!!
发表于 2020-2-26 17:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本来是下载另一个软件,但是捆绑了一堆破玩意,一气之下就全删了,删完之后,用matlab的时候才发现好像帮助文档用不了了。。。是不是删错东西了?????求大神指点指点=-=
' Z% n& U( Y6 V0 Q# L, e7 @0 ^" W; ]$ X
错误使用 docsearch (line 34)
5 v; J0 Y0 w4 E  SJava exception occurred:
; G$ P% M( x5 B* y6 o; B1 ojava.lang.NullPointerException
' d% t* D  `/ o3 W! _
. p; F) c  D7 p" r3 [( Q/ G        at com.mathworks.html.UrlTransformer.transformUrl(UrlTransformer.java:15)) w) p( }8 R9 u0 J
* a0 j/ K+ R/ V+ [
        at com.mathworks.html.UrlBuildeRFactory.toUrlBuilder(UrlBuilderFactory.java:15)
$ x! B! g: m! x8 \% t4 U8 d8 u& D2 x, H
        at com.mathworks.html.UrlBuilder.fromUrl(UrlBuilder.java:87)
* F* I/ R& N5 o% e
0 _8 s& ^: ~- E% U5 X  m        at com.mathworks.help.helpui.DocRoot.buildSearchPageUrl(DocRoot.java:176)& ^: o$ k, M" f3 i
( \% b4 q" Y1 j  E1 U7 l0 R7 T3 G
        at com.mathworks.help.helpui.DocRoot.buildSearchPageUrl(DocRoot.java:163)
( Z0 V: g/ A  I8 Y% s/ G& e: l; o" L8 L/ O+ @
        at com.mathworks.mde.help.JsHelpBrowser.docSearch(JsHelpBrowser.java:197)
. S# G* E" o& I+ ~% t, X# S+ @) ?
        at com.mathworks.mlservices.MLHelpServices.docSearch(MLHelpServices.java:257)
' _! O9 k2 J! D7 N+ ?
2 G1 f& d9 r$ k4 s
6 M) {4 @6 a! l* b* E0 \: q" ?8 G& J+ y
) F% U# u3 N( y* Z7 y& ?
  E/ m' w0 ~& t
7 i% {2 f; i- I/ X
* c4 u; x; ~4 {% f! B, |
" ]9 l& ]+ E6 l! Z4 S, @
0 ^! ]; X) F# f7 Z4 z
Exception in thread "AWT-EventQueue-0": java.lang.NullPointerException
% x. @2 S4 H9 \7 @0 {        at com.mathworks.mlwidgets.help.DocConfigUrlBuilder.getUrlForDocConfig(DocConfigUrlBuilder.java:29); y6 X1 a3 _) l% n1 z
        at com.mathworks.mlwidgets.help.LightweightHelpPanel.getNavigationUrl(LightweightHelpPanel.java:268)/ o, T  j; X# Y' A4 r/ \% N6 P
        at com.mathworks.mlwidgets.help.LightweightHelpPanel.setCurrentLocation(LightweightHelpPanel.java:162)
. t# g4 `" Y5 c7 z, }        at com.mathworks.mde.help.JsHelpBrowserClient.setCurrentLocation(JsHelpBrowserClient.java:192)% f8 o# U( V2 Z" D8 m% ]
        at com.mathworks.mde.help.JsHelpBrowserClient.showClient(JsHelpBrowserClient.java:244), D# p' T; a: w
        at com.mathworks.mde.help.JsHelpBrowser$OpenInNewBrowser.openBrowser(JsHelpBrowser.java:368)
/ j) D" E! S0 u/ K        at com.mathworks.mde.help.JsHelpBrowser$JsHelpBrowserRunnable.createAndShowBrowser(JsHelpBrowser.java:320)) n/ n5 _) }: T; G% L3 w' ]
        at com.mathworks.mde.help.JsHelpBrowser$JsHelpBrowserRunnable.run(JsHelpBrowser.java:315)* w, a7 n% B- j! l" ]
        at com.mathworks.mde.help.JsHelpBrowser.doHelpBrowserTask(JsHelpBrowser.java:282)3 D9 p( `7 n: }% S/ K2 I
        at com.mathworks.mde.help.JsHelpBrowser.doHelpBrowserTask(JsHelpBrowser.java:276)
& ]) A+ y0 D# L; o! \/ i        at com.mathworks.mde.help.JsHelpBrowser.invoke(JsHelpBrowser.java:56)
) T7 b# b* ~* W1 \        at com.mathworks.mde.help.JsHelpBrowser.invoke(JsHelpBrowser.java:47)
% Y: v( l! ^/ S4 \" f        at com.mathworks.mlservices.MLHelpServices.invoke(MLHelpServices.java:41)( O) d$ m! v+ R6 p8 Q# Q
        at com.mathworks.mde.desk.MLDesktop$HelpProductPageAction.actionPerformed(MLDesktop.java:3241)
: x! @2 T! S/ X  ^4 ?5 a        at com.mathworks.mwswing.ChildAction.actionPerformed(ChildAction.java:214)
& V# d3 _1 t6 h' b8 K  u2 b& u: s( P        at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)8 L( P* k2 C7 A% a5 `) }
        at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
+ |" Q* t6 s4 y( P        at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)6 B" D' K0 X* z5 g  H
        at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
7 H8 q3 e* l; m9 {% F        at com.mathworks.toolstrip.plaf.RegularButtonUI$RegularToolstripButtonListener.mouseReleasedImpl(RegularButtonUI.java:348)2 Z- A: c7 a5 d; @9 s, G* N
        at com.mathworks.toolstrip.plaf.RegularButtonUI$RegularToolstripButtonListener.mouseReleased(RegularButtonUI.java:338)9 x! L& q; C& z% I8 U7 M
        at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)! u1 ~  R6 A% }
        at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)# y" B8 @* ^! O" O" v
        at java.awt.Component.processMouseEvent(Component.java:6539)
( ~6 C2 `! i( y4 ?$ D7 R0 s* c7 v7 Y        at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)1 w& N9 R, u3 \9 m" F5 J, F
        at com.mathworks.mwswing.MJButton.processMouseEvent(MJButton.java:350)7 |+ k! j  m7 A' I7 l
        at java.awt.Component.processEvent(Component.java:6304)- p: S; t% u: D
        at java.awt.Container.processEvent(Container.java:2239)/ ^7 n1 x9 y' @3 l, B2 K
        at java.awt.Component.dispatchEventImpl(Component.java:4889)! \1 y+ @( Q" H( y  a
        at java.awt.Container.dispatchEventImpl(Container.java:2297)$ N) ~* Z$ {+ U8 a9 p$ r
        at java.awt.Component.dispatchEvent(Component.java:4711): G( e  ]2 h6 ^
        at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)# Y" `6 n0 N, S) y& r
        at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535). C1 c. Q5 ~( w, D
        at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)/ @8 Z7 I0 u. u! ~  |
        at java.awt.Container.dispatchEventImpl(Container.java:2283)
0 F- g6 i8 [+ w4 i% Q; f) ?        at java.awt.Window.dispatchEventImpl(Window.java:2746); j6 z! q0 |5 u" W) ?5 E/ H8 W
/ J  i& ^) I6 h8 `9 d- {        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
; v- M3 a) S" o  z' o9 Y# `$ w        at java.awt.EventQueue.access$500(EventQueue.java:97); G  K" l0 I# f* W& ^$ Q
        at java.awt.EventQueue$3.run(EventQueue.java:709)+ ~5 J  {& b+ D* ]. k1 I9 x
        at java.awt.EventQueue$3.run(EventQueue.java:703)
$ o. T4 i: g) g+ ^        at java.security.AccessController.doPrivileged(Native Method)
# P8 L, G1 F  T2 I0 ?$ u4 \2 r        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74), Y6 @5 O0 j# G! K) [0 I
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)9 T5 y6 [# s' ]5 O$ n% E3 Z/ }! D
        at java.awt.EventQueue$4.run(EventQueue.java:733)% O4 x$ ~/ v' o2 ]3 [
        at java.awt.EventQueue$4.run(EventQueue.java:731)( l. D6 m9 A4 j( |) a
! j3 H' I3 j% g: H        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)6 o8 I- o. {/ A
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
/ e7 s, \2 h# e7 o        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)& d6 G4 \( f5 ~
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)6 j! H1 y( s$ S  r, i) H% \; ^& L
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)" N" F! {: z" Z
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)6 r1 y3 a" d( s/ M, \, n! m3 h0 I4 u
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
% N! S2 h! C' |7 M& q. n( w! }        at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
* R& t: D* c# s: J8 n7 g) b9 c2 D3 o1 Q6 ^- x; s, {
5 x* t. V* |/ ~0 {0 c/ [
# a; @6 {1 s/ k6 _/ @4 F" o' v# ?' C0 ]! T4 f$ w. E
' c$ d& s* S+ l5 G( A0 j这是什么玩意?help
3 w3 z& t% C& m! o! T8 `
- m, E3 \- O* t% G2 o# T2 [2 L3 _
5 s; Y- `) ?3 @, {: n6 _7 z7 O- n  G
GMT+8, 2025-11-2 12:29 , Processed in 0.171875 second(s), 24 queries , Gzip On.
