查看: 375|回复: 0
[PADS VX.2.4][4层] 基于STI7015高清机顶盒原理图+PCB文件
发表于 2020-2-24 12:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名字:[pads  VX.2.4][4层] 基于STI7015高清机顶盒原理图+PCB文件% ?2 t& b: v2 N1 k5 y4 p3 F
3 i+ Q" X" o- h$ B+ c4 G" y0 _
文件描述+ B$ a- n9 ]$ U7 H( b
4 T/ H7 J1 i9 _, z+ Y
1.功能描述:高清机顶盒原理图+PCB文件/ {+ r+ s6 x/ c+ o7 Y9 K# C
3 f! P* t. G% G$ L* B7 o7 B. Y
2.软件版本:PADS  VX.2.4; {; Y5 _6 v5 q  t7 X
+ V; X$ I% u- ^6 M8 d0 Y3.层数:4层板/ O& C7 f1 Q+ N' J: U$ Y
3 c" ^5 L+ Y+ o- q" H0 |+ M
4.用到的主要芯片:STI7015
% v, n5 N* s! g; A" K9 q5.PCB板尺寸:异形! O/ i' u% F# h5 D
5 X5 s9 [2 _9 O% Y作品截图如下:
0 V3 }' L7 U2 Y
: a8 ?/ m' @, {  ^4 M顶层截图:5 r( n* P1 d3 j' {! P: i9 y8 a
2 H$ `5 ]& s0 w* N
底层截图:3 J  \2 b: r9 C* \1 c" F3 t0 @- `
) X% W& V* P, `7 U, u9 \全层截图:
6 H! ~( _7 E) h# A   u+ A0 D2 z, a5 q; G6 V  o
叠层截图:, F+ @# U7 x+ U  `- y
BOM:
REFDESCOMP_DEVICE_TYPECOMP_VALUE
位号类型属性
C8STB-C0805
C9STB-C0805
C10STB-C0402
C11STB-C0402
C12STB-C0402
C13STB-C0402
C14STB-C0402
C26STB-ECS6.3
C67STB-C0402
C68STB-C0805
C70STB-C0402
C74STB-C0402
C125STB-C0402
C154STB-C0402
C155STB-C0805
C161STB-C0402
C162STB-C0805
C164STB-C0402
C165STB-C0402
C166STB-C0402
C167STB-C0402
C168STB-C0402
C170STB-C0402
C171STB-C0805
C214STB-C0402
C255STB-C0805
C457STB-C0805
C458STB-C0805
C459STB-C0402
C460STB-C0402
C461STB-C0402
CA1STB-C0402
CA2STB-C0402
CA3STB-C0402
CA4STB-C0603
CA5STB-C0603
CA6STB-C0402
CA8STB-C0603
CA9STB-C0402
CA10STB-C0402
CA11STB-C0402
CA12STB-C0402
CA18STB-C0402
CA19STB-C0402
CA20STB-C0402
CA21STB-C0402
CA22STB-C0402
CA24STB-C0402
CA28STB-C0805
CD1STB-C0805
CD2STB-C0603
CD3STB-ECS6.3
CD4STB-C0805
CD5STB-C0603
CD6STB-C0402
CD7STB-C0402
CD8STB-C0402
CD9STB-C0603
CD10STB-C0402
CD12STB-C0805
CD13STB-C0805
CD14STB-ECS6.3
CD15STB-C0805
CD16STB-C0805
CD17STB-C0402
CD18STB-C0603
CK1STB-C0402
CK2STB-C0402
CK3STB-C0402
CL1STB-C0402100N
CL2STB-C0402100N
CL3STB-C0603
CL4STB-C0402100N
CL5STB-C040210N
CL6STB-C040210N
CL7STB-C040210N
CL8STB-C040210N
CL9STB-C040210N
CL10STB-C040210N
CL11STB-C040210N
CL12STB-C0402100N
CL13STB-C0402100N
CL14STB-C0402100N
CL15STB-C0402100N
CL16STB-C040210N
CL17STB-C040210N
CL18STB-C040210N
CL19STB-C040210N
CL20STB-C040210N
CL21STB-C040210N
CL22STB-C040210N
CL23STB-C040210N
CL24STB-C0402100N
CL25STB-C0402100N
CL26STB-C0603
CL27STB-C0603
CL28STB-C0603
CM60STB-C0402
CM61STB-C0402
CN2STB-7+15PIN-FEMALE-DIP90
CON1STB-CON6-2.0
CON8STB-USB-H1
CON9STB-HDMI-SMD
CON13STB-HEADER2X5-2.54
CP3STB-C0402
CP4STB-C0402
CP5STB-C0402
CP6STB-C0402
CP9STB-C0402
CP10STB-C0402
CP11STB-C0402100N
CP12STB-C0402100N
CP13STB-C0402100N
CP14STB-C0402100N
CP15STB-C0402
CP16STB-C0402
CP17STB-C0402
CP18STB-C0402
CS1STB-C0402
CS3STB-C0402
CS4STB-C0402
CS9STB-C0402
CS10STB-C0402
CS16STB-C0402
CS17STB-C0402
CS18STB-C0402
CS26STB-C0805
CSA1STB-C0402
CSA2STB-C0402
CSA3STB-C0402
CSA4STB-C0402
CSA5STB-C0402
CSA6STB-C0402
CSA7STB-C0402
CSA8STB-C0402
CSA9STB-C0402
CSA10STB-C0402
CSA11STB-C0402
CSA12STB-C0402
CSA13STB-C0805
CSA15STB-C0402
CSA17STB-C0402
CSA18STB-C0402
CSA19STB-C0402
CSA20STB-C0402
CSA21STB-C0402
CSA22STB-C0402
CSA25STB-C0402
CT1STB-C0402
CT2STB-C0402
CT3STB-C0402
CT4STB-C0402
CT5STB-C0402
CT6STB-C0402
CT7STB-C0402
CT8STB-C0402
CT9STB-C0805
CT10STB-C0402
CT11STB-C0402
CT12STB-C0402
CT13STB-C0402
CT14STB-C0402
CT16STB-C0402
CT17STB-C0402
CT18STB-C0402
CT28STB-C0805
CT38STB-C0402
CT45STB-C0805
CT47STB-C0805
CT58STB-C0402
CT60STB-C0402
CT61STB-C0402
CT62STB-C0402
CT64STB-C0402
CT65STB-C0402
CT68STB-C0402
CT69STB-C0402
CT70STB-C0402
CT71STB-C0805
CT72STB-C0402
CT73STB-C0402
CT74STB-C0402
CT76STB-C0402
CT77STB-C0805
CT78STB-C0402
CT79STB-C0402
CT81STB-C0402
CT82STB-C0805
CT83STB-C0402
CT84STB-C0402
CT85STB-C0402
CT86STB-C0402
CT87STB-C0402
CT89STB-C0402
CT90STB-C0402
CT91STB-C0805
CT92STB-C0805
CT98STB-C0402
CT99STB-C0402
CU7STB-C0402
CU8STB-C0402
CU11STB-C0402
CU12STB-C0402
CU13STB-C0402
CU22STB-C0402
CU25STB-C0402
CU31STB-C0402
CU34STB-C0805
CU35STB-C0805
CU36STB-C0402
CU37STB-ECS6.3
CU39STB-ECS6.3
CU40STB-C0805
CU41STB-C0805
CU42STB-C0402
CU43STB-ECS6.3
CU44STB-C0805
CU45STB-C0805
CU46STB-C0402
CU47STB-C0402
CU48STB-C0402
CU49STB-ECS6.3
CU50STB-C0402
CU53STB-C0402
CU54STB-C0402
CU55STB-C0402
CU56STB-C0402
CU57STB-C0402
CU58STB-C0402
CU59STB-C0402
CU60STB-C0402
CU61STB-C0402
CU66STB-C0805
CU68STB-C0805
CU88STB-C0805
CV16STB-C0402
D1STB-DIODE1206
D5SMA
D7LED-0805
D10STB-DIODE-SMA
D11STB-SOT23-3
EC66STB-C0805
EC101STB-ECS6.3
EJ1STB-KRJ-109BNL
EL1STB-C080510U,6.3V
EL2STB-C080510U,6.3V
EL3STB-C0805
EV2STB-C0805
EV8STB-ECS6.3
EV9STB-ECS6.3
F1STB-F1812
FB2STB-B0603
FB3STB-B0603
FB4STB-B0603
FB5STB-B0603
FB6STB-B0603
FB20STB-B0805
FV11STB-B0603
H1STB-HOLE3.5B
H3STB-HOLE3.5A
H4STB-HOLE3.5B
H5STB-MARK
H6STB-MARK
H7STB-MARKHOLE
H8STB-MARKMark .
H9STB-MARKMark .
H10STB-MARK
H17STB-MARK
H18STB-MARK
H19STB-HOLE3.5C
ICM2STB-TSOP48
J1STB-PJ313B
J4POWER_JACK3
J6STB-CON4-2.0
J15STB-SPDIF-B
L37IND-0503
LA2STB-B0603
LP1STB-B0805
LP2STB-B0805
LP4STB-B0805
LP5STB-B0805
LP6STB-B0805
LS2STB-B0603
LSA2STB-B0603
LSA3STB-B0603
LSA4STB-B0603
LSA6STB-B0603
LSA7STB-B0603
LSA8STB-B0603
LSA9STB-B0603
LSA10STB-B0603
LSA11STB-B0603
LSA12STB-B0603
LSA13STB-B0603
LSA16STB-F1812
LSA17STB-B0805
LSA18STB-B0805
LSA21STB-B0603
LT11STB-B0805
LT12STB-B0805
LT13STB-B0805
LT14STB-B0805
LT15STB-B0805
LT16STB-B0805
LT17STB-B0805
LT18STB-B0805
LT25STB-B0805
LT27STB-B0805
LT28STB-B0805
LU4IND-SR0805
LU5IND-SR0805
LU6IND-SR0805
LU15STB-B0805
LU16STB-B0805
LU17STB-B0805
LU18STB-B0805
LU19STB-B0805
NF1STB-8P4R-0402
NF2STB-8P4R-0402
NF3STB-8P4R-0402
NF4STB-8P4R-0402
Q18STB-SOT23-BEC
QU3STB-SOT23-BEC
R1STB-R0402
R2STB-R0402
R4STB-R0402
R5STB-R0402
R6STB-R0402
R10STB-R0402
R11STB-R0402
R13STB-R0402
R16STB-R0402
R17STB-R0402
R18STB-R0402
R19STB-R0402
R20STB-R0402
R21STB-R0402
R22STB-R0402
R23STB-R0402
R24STB-R0402
R42STB-R0603
R47STB-R0402
R49STB-R0402
R51STB-R0402
R53STB-R0402
R55STB-R0402
R56STB-R0402
R57STB-R0402
R58STB-R0402
R59STB-R0402
R65STB-R0402
R66STB-R0402
R67STB-R0402
R68STB-R0402
R69STB-R0402
R70STB-R0402
R74STB-R0402
R75STB-R0402
R79STB-R0402
R80STB-R0402
R81STB-R0402
R82STB-R0402
R83STB-R0402
R84STB-R0402
R85STB-R0402
R117STB-R0402
R119STB-R0402
R120STB-R0402
R121STB-R0402
R124STB-R0402
R125STB-R0402
R154STB-R0402
R155STB-R0402
R156STB-R0402
R208STB-R0402
R224STB-R0402
R244STB-R0402
R549STB-R0402
R550STB-R0402
RA3STB-R0402
RA5STB-R0402
RA6STB-R0402
RA7STB-R0402
RA8STB-R0402
RA28STB-R0402
RA29STB-R0402
RA39STB-R0402
RA40STB-R0402
RA42STB-R0402
RA43STB-R0402
RA44STB-R0402
RA45STB-R0402
RA46STB-R0402
RA47STB-R0402
RA48STB-R0402
RA49STB-R0402
  R2 |$ r0 k- ~9 M* ]9 f: \
9 g3 ^' a% Q/ ?1 N. z
; p( y1 N  Z% K/ k, Z" ~, x
8 t5 _' r0 Q" ~) d. ^6 e6 l1 b$ f
附件:
原理图和PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
游客,如果您要查看本帖隐藏内容请回复
# j& x3 q1 I" D, O
GMT+8, 2025-7-27 08:36 , Processed in 0.140625 second(s), 28 queries , Gzip On.
