作品名字:[pads VX.2.4][4层] MTK6260Demo板原理图+PCB文件分享
: u/ c( s0 O8 `0 J/ \+ q/ [
7 s7 x& T7 a0 F5 h/ T& A% `文件描述
5 ]9 }. D; E% h: z$ ~ / w2 O# X6 v, X" l: s
1.功能描述:Demo板原理图+PCB
5 V( D) a5 @8 Z* n1 n 1 i! d, n+ ]4 w! D ]5 t# T8 P
2.软件版本:PADS VX.2.4! P! N! [' T- Z
/ f* e7 C- ~3 b& x% r9 [. q
3.层数:4层板
$ H# N. I4 f$ F
$ L9 @ } P" U) O4.用到的主要芯片:MTK6260
8 ~# G* U. R/ A" T# j- F5.PCB板尺寸:99mm*145mm
/ S6 `' J- f0 A1 z" Y. _ # ? k0 `. D' \7 w* @1 W( `4 v2 S
作品截图如下:
& k O7 |! M8 ^" B8 \0 @ " N" L1 ]' C2 u: ~$ V& G7 c
顶层截图:' u' i( S* n5 u
# `2 D4 ]) D; q" ?$ f5 |
底层截图:
. y- P1 A5 w1 o- V2 [+ }
# u; o* w* |3 G. v# @6 a3 {" X+ N* Y
全层截图:
5 O0 K4 o) h7 }4 V
) a) y8 U8 Y5 v; O
叠层截图:
% i5 `9 G* b v; HBOM: REFDES | COMP_DEVICE_TYPE | COMP_VALUE | 位号 | 类型 | 属性 | ANT2G300 | PAD_1.0X1.2 | GSM ANT | ANT501 | PAD/SMD/1.8X4 | ANT / 1.8mmX4mm / KRF1S2001R | ANT502 | PAD/SMD/1.8X4 | ANT / 1.8mmX4mm / KRF1S2001R | ANT503 | PAD/SMD/1.8X4 | ANT / 1.8mmX4mm / KRF1S2001R | ANT600 | PAD/SMD/7.1X3.9 | NC_ANT / 3.9mmX7.1mm | ANTFM300 | PAD/SMD/1.8X4 | ANTENNA_FM_FPC | B400 | B0603 | 220ohm@100MHZ | B401 | B0603 | 220ohm@100MHZ | B402 | B0402 | 120ohm@100MHZ | B403 | B0402 | 120ohm@100MHZ | B404 | B0402 | 120ohm@100MHZ | B800 | B0402 | 75ohm@100MHZ | B1000 | B0603 | 220ohm@100MHZ | B1001 | B0402 | 75ohm@100MHZ | B1002 | B0402 | 120ohm@100MHZ | B1003 | B0402 | 120ohm@100MHZ | B1004 | B0402 | 120ohm@100MHZ | B1005 | B0402 | 120ohm@100MHZ | B1006 | B0603 | 220ohm@100MHZ | C112 | C0805 | 22uF | C201 | C0603 | 4.7uF | C202 | C0603 | 4.7uF | C203 | C0603 | 4.7uF | C205 | C0603 | 2.2uF | C206 | C0402 | 1uF | C207 | C0402 | 1uF | C208 | C0402 | 1uF | C209 | C0402 | 1uF | C210 | C0402 | 1uF | C212 | C0402 | 1uF | C213 | C0402 | 10pF | C214 | C0402 | 1uF | C215 | C0402 | 1uF | C216 | C0603 | 2.2uF | C217 | C0402 | 330pF | C218 | C0402 | 1uF | C219 | C0402 | 1uF | C220 | C0402 | 1uF | C221 | C0402 | 1uF | C222 | C0402 | 1uF | C223 | C0402 | 1uF | C224 | C0402 | 1uF | C225 | C0402 | 1uF | C226 | C0402 | 1uF | C229 | C0402 | 1uF | C230 | C0603 | 1uF/25V | C231 | C0603 | 1uF/25V | C300 | C0402 | 1uF | C301 | C0402 | 1uF | C303 | C0402 | 22pF | C304 | C0402 | 0.1uF | C305 | C0805 | 22uF | C306 | C0402 | 220pF | C307 | C0402 | 22pF | C308 | C0402 | 22pF | C309 | C0402 | 22pF | C310 | C0402 | NM | C311 | C0402 | NM | C312 | C0402 | 22pF | C313 | C0402 | 22pF | C314 | C0402 | NM | C315 | C0402 | NM | C316 | C0402 | 1pF | C317 | C0402 | 22pF | C318 | C0402 | NM | C319 | C0402 | NM | C320 | C0402 | 10pF | C321 | C0402 | 3.3pF | C322 | C0402 | 2.7pF | C400 | C0402 | 0.1uF | C401 | C0402 | 0.1uF | C402 | C0402 | 33pF | C403 | C0402 | 100pF | C404 | C0402 | 33pF | C405 | C0603 | 10uF | C406 | C0402 | 33pF | C407 | C0402 | 100pF | C408 | C0402 | 33pF | C409 | C0402 | 0.1uF | C410 | C0402 | 0.1uF | C411 | C0402 | 100pF | C412 | C0603 | 10uF | C413 | C0402 | 33pF | C414 | C0402 | 33pF | C415 | C0805 | 22uF | C416 | C0805 | 22uF | C417 | C0402 | 33pF | C418 | C0402 | 33pF | C500 | C0402 | 1uF | C501 | C0402 | 1uF | C502 | C0402 | 1uF | C503 | C0402 | 1uF | C504 | C0402 | 1uF | C505 | C0402 | 1uF | C506 | C0402 | 1uF | C507 | C0402 | 0.1uF | C508 | C0402 | 0.1uF | C509 | C0402 | 0.1uF | C510 | C0402 | 0.1uF | C511 | C0402 | 10pF | C512 | C0402 | 1nF | C513 | C0603 | 4.7uF | C514 | C0603 | 4.7uF | C515 | C0603 | 4.7uF | C516 | C0603 | 4.7uF | C517 | C0402 | 2.2pF | C518 | C0402 | NM | C519 | C0402 | 10pF | C520 | C0402 | 1uF | C521 | C0402 | 18pF | C522 | C0402 | 18pF | C523 | C0402 | NM | C524 | C0402 | 8.2pF | C525 | C0402 | 8.2pF | C526 | C0402 | 18pF | C527 | C0402 | NM | C528 | C0402 | NM | C600 | C0402 | 0.1uF | C601 | C0402 | 0.1uF | C602 | C0402 | 0.1uF | C603 | C0402 | 0.1uF | C604 | C0402 | 1uF | C605 | C0402 | 1uF | C606 | C0402 | 1uF | C607 | C0402 | 1uF | C608 | C0402 | 100pF | C609 | C0402 | 220pF | C610 | C0402 | 390pF | C611 | C0402 | 1pF | C612 | C0402 | 0 | C613 | C0402 | 1.5pF | C700 | C0402 | 2.2uF 0402 | C701 | C0402 | 1uF | C702 | C0402 | 1uF | C703 | C0402 | 1uF | C704 | C0402 | 0.1uF | C705 | C0402 | 18pF | C706 | C0603 | 4.7uF | C707 | C0402 | 0.1uF | C711 | C0402 | 0.1uF | C712 | C0402 | 0.1uF | C800 | C0603 | 4.7uF | C801 | C0603 | 4.7uF | C802 | C0402 | 0.1uF NM | C803 | C0402 | NM | C804 | C0402 | 0.1uF | C805 | C0402 | 0.1uF | C806 | C0402 | 0.1uF | C900 | C0402 | 1uF NM | C902 | C0805 | 10uF | C903 | C0402 | 22nF | C904 | C0603 | 2.2uF | C905 | C0402 | 1uF NM | C906 | C0402 | 1uF NM | C907 | C0603 | 2.2uF | C908 | C0402 | 1uF | C909 | C0402 | 1uF | C911 | C0603 | 4.7uF | C912 | C0402 | 0.1uF | C1000 | C0402 | 0.1uF | C1001 | C0402 | 39pF | C1002 | C0402 | 0.1uF | C1003 | C0402 | 10pF | C1005 | C0402 | 5.6pF | C1006 | C0402 | 5.6pF | C1007 | C0402 | 5.6pF | C1008 | C0402 | 5.6pF | C1009 | C0402 | 1nF | C1010 | C0402 | NM | C1011 | C0402 | 33pF | C1012 | C0402 | 0.1uF | C1013 | C0402 | 1uF | C1014 | C0402 | 1uF | C1015 | C0603 | 4.7uF | C1016 | C0805 | 4.7u (0805 X5R 25V) | D200 | SOD323 | PZ3D4V2H | D600 | R0402 | ESD / ESD0P2RF-02LRH | D700 | EMD2 | Diode | D1000 | EMD2 | RB520S-30 | E300 | SLDA31-2R800G-S1 | BT ANT | H1100 | PTH_3.2 | GND | H1101 | PTH_3.2 | GND | H1102 | PTH_3.2 | GND | H1103 | PTH_3.2 | GND | J200 | BAT/SMD/KBC23S360R | KBC23S3M1PR | J300 | RF-CONNECTOR-MM8030-2600 | ECT818000291 | J401 | MW09_IO | 12PIN IO CONNECTOR | J402 | MICRO_USB_5P | MICRO USB 5PF | J501 | MM8430-2600B | MM8430-2610 | J700 | PAD-1.2-1.5 | VIB | J702 | CON-SIMCARD-HMT-6150006-006B | HMT-6150006-006A | J703 | SOCKET-SIM-HMT-MICRO-H150 | ?HMT-MICRO-H150 | J704 | T-FLASH/8P/SMD/HY-TFP08-TP19-01 | MC_CON / 9 / HY-TFP08-TP19-01 | J705 | SIM_HOLD_TP_SM001_016_04_815 | SIM+MicroSD | J706 | AXK7L10227G | AXK7L10223G | J801 | KB14243110R | CON / 24 / KB14243110R_LF | J803 | TC-0103 | TC-0103 | J804 | TC-0103 | TC-0103 | J805 | TC-0103 | TC-0103 | J806 | CONN_AXK7L24227 | G10&S1 CAMERA CON | J807 | CAMERA-24 | AXK7L24227G | J808 | DF30FC-24DS-0.4V | TBD | J809 | BTB_CONN_TGK8L2410 | Z1 Camera Con | J901 | H61/SMD/FH26-61S-0.3SHW/A | CON / 61 / FH26W-61S-0.3SHW | J902 | CONN_AXK7L30227 | G10&S1 CON | J903 | G13_LCM_17PIN_0.4X2.5 | G13 LCD CON | J904 | TP_GD910AA | CON_TP | J905 | PAD_4PIN_0.4X2.5_0.8P | TP Connector | J906 | CONN_AXK7L24227 | Z1 LCD CON | J907 | CONN_AXK7L10227G | CAP_TP_TOS | J1000 | LCD_503548_1220_12PIN_1 | 503548-1220 | J1100 | TP_5PIN_1.5MM_DRILL | | J1101 | TP_5PIN_1.5MM_DRILL | | J1102 | TP_5PIN_1.5MM_DRILL | | J1103 | TP_5PIN_1.5MM_DRILL | | J1104 | TP_5PIN_1.5MM_DRILL | | J1105 | TP_5PIN_1.5MM_DRILL | | J1106 | TP_5PIN_1.5MM_DRILL | | J1107 | TP_5PIN_1.5MM_DRILL | | J1108 | TP_5PIN_1.5MM_DRILL | | J1109 | TP_5PIN_1.5MM_DRILL | | J1110 | TP_5PIN_1.5MM_DRILL | | J1111 | TP_5PIN_1.5MM_DRILL | | J1112 | TP_5PIN_1.5MM_DRILL | | J1113 | TP_5PIN_1.5MM_DRILL | | J1114 | TP_5PIN_1.5MM_DRILL | | L300 | L0402 | 0 | L301 | L0402 | 1.5nH | L302 | L0402 | NM | L303 | L0402 | NM | L304 | L0603 | 72nH | L305 | L0402 | 10nH | L311 | L0402 | NM | L312 | L0402 | NM | L400 | L0603 | 0 | L500 | L/CHOKE/SMD/LQH32C_33 | 2.2uH | L600 | L0402 | NM | L601 | L0402 | NM | L602 | L0402 | 2.0nH NM | L603 | L0402 | 8.2nH | L604 | L0402 | 68nH | L605 | L0402 | 180nH | L1000 | NR3010 | 22uH | LS400 | PAD-1.2-1.5B | REC | MK400 | PAD-1.2-1.5B | Microphone | OPT1100 | FD_MARK | OPT | OPT1101 | FD_MARK | OPT | OPT1102 | FD_MARK | OPT | Q201 | SOT23-6 | PT236T30E2 | Q202 | 2-1L1B/SMD/SSM3K35MFV | PNM723T703E0-2 | R101 | R0402 | 47K | R102 | R0402 | 10k | R103 | R0402 | NM | R104 | R0402 | NM | R105 | R0402 | 10k | R106 | R0402 | 10k | R107 | R0402 | 0 | R112 | R0402 | 1.5K | R201 | R0402 | 1K | R209 | R0805 | 0.33,1% | R210 | R0402 | 330K | R211 | R0402 | 39K | R212 | R0402 | 7.5K | R213 | R0402 | 24K | R214 | R0402 | 1K | R215 | R0603 | 0/0603 | R220 | R0402 | 0 | R225 | R0603 | 0/0603 | R226 | R0603 | 0/0603 | R227 | R0603 | 0/0603 | R228 | R0402 | NM | R300 | R0402 | 0 | R301 | R0402 | 1K | R302 | R0402 | 1K | R303 | R0402 | 1K | R304 | R0402 | 10k | R305 | R0402 | 24K | R306 | R0402 | 0 | R307 | R0402 | 0 | R308 | R0402 | 0 | R309 | R0402 | 0 | R310 | R0402 | 0 | R311 | R0402 | 0 | R312 | R0402 | 0 | R313 | R0402 | 0 | R314 | R0402 | 0 | R315 | R0402 | 0 | R320 | R0603 | 0/0603 | R330 | R0402 | 0 | R401 | R0402 | 12 | R402 | R0402 | 1K | R403 | R0402 | 1.5K | R404 | R0402 | 1.5K | R405 | R0402 | 1K | R406 | R0402 | 12 | R407 | R0402 | 1K | R408 | R0402 | 1.5K | R409 | R0402 | 1K | R410 | R0402 | 100 | R411 | R0402 | 100 | R412 | R0402 | 470k | R413 | R0402 | 1K | R414 | R0402 | 1K | R415 | R0402 | 1K | R416 | R0402 | NM | R417 | R0402 | 1K | R418 | R0402 | NM | R419 | R0402 | NM | R500 | R0603 | 0/0603 | R501 | R0402 | 0 | R502 | R0402 | 49.9 | R503 | R0402 | 10k | R504 | R0402 | 910K | R505 | R0402 | 100K | R506 | R0402 | 0 | R507 | R0402 | 0 | R508 | R0402 | NM | R509 | R0402 | 0 | R600 | R0402 | 0 | R601 | R0402 | NM | R602 | R0402 | 0 | R603 | R0402 | NM | R700 | R0402 | 0 | R701 | R0402 | 0 | R702 | R0402 | 100K | R703 | R0402 | 47K | R704 | R0402 | 47 | R705 | R0402 | 0 | R706 | R0402 | 0 | R707 | R0402 | 0 | R708 | R0402 | 0 | R709 | R0402 | 0 | R710 | R0402 | 0 | R711 | R0402 | 0 | R712 | R0402 | 0 | R713 | R0402 | 0 | R714 | R0402 | 0 | R715 | R0402 | 0 | R720 | R0402 | 0 | R721 | R0402 | 0 | R722 | R0402 | 0 | R723 | R0402 | 0 | R724 | R0402 | 0 | R800 | R0402 | 47K | R801 | R0402 | 47K | R802 | R0402 | 0 | R803 | R0402 | 0 | R804 | R0402 | 0 | R805 | R0402 | 1K | R806 | R0402 | 1K | R807 | R0402 | 1K | R808 | R0402 | 10k | R809 | R0402 | 1K | R810 | R0402 | 10k | R811 | R0402 | 1K | R900 | R0402 | 0 | R901 | R0402 | 4.7K NM | R902 | R0402 | 0 | R903 | R0402 | NM | R904 | 0402-3P(1-2) | 0R/ 0402-3P(1-2) | R905 | 0402-3P(1-2) | 100K / 0402-3P(1-2) | R906 | R0402 | 0 | R907 | R0402 | 0 | R908 | R0402 | 10k | R909 | R0402 | 10k | R1000 | R0402 | 0 | R1001 | R0402 | NM | R1002 | R0402 | 0 | R1005 | R0402 | NM | R1006 | R0402 | NM | R1007 | R0402 | 82 | R1008 | R0402 | 0 | R1101 | R0402 | NM | R1102 | R0402 | 10k | R1103 | R0402 | NM | R1104 | R0402 | 10k | SW802 | SW/3P/SMD/EVQQ0C03K | KEY / EVQQ0C03K | T600 | TP_0..8MM | EXT_INT | T601 | TP_0..8MM | EXT_INT | TP1 | TP_0..8MM | EXT_INT | TP2 | TP_0..8MM | EXT_INT | TP27 | TP_0..8MM | EXT_INT | TP28 | TP_0..8MM | EXT_INT | TP29 | TP_0..8MM | EXT_INT | TP100 | TP_0..8MM | EXT_INT | TP103 | TP_0..8MM | EXT_INT | TP201 | TP_0.8MM | EXT_INT | TP300 | TP_0..8MM | EXT_INT | TP301 | TP_0..8MM | EXT_INT | TP302 | TP_0..8MM | EXT_INT | TP303 | TP_0..8MM | EXT_INT | TP401 | TP_0..8MM | EXT_INT | TP402 | TP_0..8MM | EXT_INT | TP403 | TP_0..8MM | EXT_INT | TP404 | TP_0..8MM | EXT_INT | TP501 | TP_0..8MM | EXT_INT |
# |, J' W: O: d, J
: l& ] @: M- `/ W1 M# H+ x- r% g ?+ ~ `6 m7 w: v, Q8 w
8 ~' R9 M/ c. g) d$ }+ ~附件:
) `$ z) c# a# F* L; o |
