作品名:[AD 10][2层]带开关电源的2.1声道功放板 原理图和PCB源文件
' C7 s' `) j* x4 v0 ?
2 f ` O3 c# L5 J文件描述
" J3 w" \/ A0 n! d& g ~5 S1. 作品用途:声道功放板8 K2 s3 @* Z; B2 H$ X2 a; ~1 g# c
2. 软件版本:AD 10
% [% C& N4 X$ Z3. 层数:2层板
* z1 u x- ?; `3 u- A% x4. PCB尺寸:157.1mm*80.4mm
+ ?, H, f! {3 M4 k" ? l0 \
9 q( d+ ?; K: O x3 Z6 \; x& ?作品截图如下:
. \ G; {6 I' P' T全层截图:
0 ^8 N) D! E' ]# @: I& ?
2 {! W) n d8 Z* B9 U. N
@+ O: o4 I) K1 O: m叠层信息截图如下:
- D2 C, h7 i7 g6 _8 C, `
0 |, s9 G4 Y8 A9 m4 K8 F" ?$ T f* R) T
BOM:$ x7 W/ |0 H* ^
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | B50K | BASS, VOL | VR2A | 2 | | C1, C03 | 0805 | 2 | | C01, C02, C3, C4 | CC-5-P | 4 | 204P | C2, C04 | 0805 | 2 | 104P | C5, C6, C16 | 0805 | 3 | 224K | C7 | CX-18*6 | 1 | 472J/1KV | C8 | CC-5-P | 1 | 104P | C9, C14 | CC-5-P | 2 | 471J/1KV | C10, C11 | CC-5-P | 2 | 102J/250V | C12 | CC-5-P | 1 | 222J/250V | C13 | CC-5-P | 1 | 224P | C15 | 0805 | 1 | 683P | C17 | 0805 | 1 | IN4007 | D1, D2, D3, D4 | DIODE-7 | 4 | IN4007 | D5, D10 | DIODE-LI | 2 | IN5401 | D6, D7, D8, D9 | DIODE-LI | 4 | 4.7uF/50V | E1, E2, E3, E4 | EC-2.5-5 | 4 | 1uF/50V | E5 | EC-2.5-5 | 1 | 105P | E05 | 0805 | 1 | 10uF/25V | E6 | EC-2.5-5 | 1 | 22uF/50V | E7 | EC-2.5-5 | 1 | 47uF/400V | E8 | EC-7-16 | 1 | 1000uF/25V | E9, E10 | EC-5-13 | 2 | 2200uF/25V | E11, E12 | EC-5-13 | 2 | FUSE1 | FUSE-1 | FUSE-1 | 1 | TDA2030 | IC1, IC2 | 2030 | 2 | TDA2050 | IC3 | 2030 | 1 | OPTOISO1 | IC4 | 光耦EL817 | 1 | 4558A | IC5 | SO-8 | 1 | TEL:18818 | IC6 | DIP-8 | 1 | 17MM | J1, J2, J3, J4, J11 | J1.7 | 5 | 7MM | J5, J6, J9, J10 | J0.7 | 4 | 6mm | J7, J8 | J0.6 | 2 | 2P | JP2 | PIN-2-2.54 | 1 | L*2 | L1 | L*2 | 1 | BT-1 | L2 | BT-1 | 1 | 圆形电感 | L3, L4 | L-5-8 | 2 | LED | LED1 | LED | 1 | TL431A | Q1 | TL431A | 1 | FSA07N60A | Q2 | FSA07N60A | 1 | 20K | R1, R2 | 0805 | 2 | 10K | R3, R4, R14, R15 | 0805 | 4 | 5.1K | R5, R6 | 0805 | 2 | 510 | R7, R8, R16 | 0805 | 3 | 18K | R9, R10 | 0805 | 2 | 3.3 | R11, R12, R18 | 0805 | 3 | 22K | R13 | 0805 | 1 | 33K | R17 | 0805 | 1 | 510K | R19, R20 | 1206 | 2 | 220K | R21, R22, R23 | 1206 | 3 | 100K | R24 | 0805 | 1 | 30 | R25 | 0805 | 1 | 7.5 | R26 | RES-10-L | 1 | 4.7 | R27 | 1206 | 1 | 1K | R28, R29 | R-LI | 2 | 1K | R30 | 1206 | 1 | 13K | R31 | 0805 | 1 | 1.2K | R32 | 0805 | 1 | 1K | R33 | 0805 | 1 | 4RCA | RCA1 | 4RCA-2 | 1 | 2P | RCA4 | 2P-AC | 1 | 3.3V | ZD1 | ZENER-7 | 1 | ( T5 c1 \! l0 V9 ^ @* q$ T
附件:5 ?: K. D5 Z* @
原理图和PCB源文件如下:8 j' j4 [" X' ~4 O6 ?' U( x/ e2 J
: s* D9 Z& h! U5 y9 P
: U7 g. {; G* N: ]8 L |
