作品名:[AD 10][2层]基于ESP8266的WIFI 红外遥控 原理图和PCB源文件
; R' i4 C. [; z& P* \" m2 x
6 p" b/ m; i' P% d9 h( H0 p文件描述
! T H- A$ X5 b; V) `1. 作品用途:红外遥控. P3 g: [& o7 a: A3 L# M/ Y
2. 软件版本:AD 10( w" G$ `6 f9 f s8 N& k- h, n
3. 层数:2层板
' C. Z) p/ S+ z, c6 g4. 用到的主要芯片:SPX1117M3.3
8 l. s) c! e- X4 ^6 V5. PCB尺寸:53.3mm*54.3mm% o9 B& J7 M7 z6 y$ C+ l) @
; ^* I- U1 [) _
作品截图如下:
* R; e! h$ y; i- {1 ^! ^: ~顶层截图:
~: w* p8 T4 f& s' h
4 Q5 G& f" s+ n6 B* L: g; x! Z8 [; {* \2 j
底层截图:
5 x5 ^- F# @8 b; Z
/ P1 m+ X8 Z* }* b
- d6 I) ]1 U; ?+ b6 {全层截图:
6 @# o' [, B) w) }8 J( a
7 E2 C) {6 ~7 k5 L
, e* {7 v: m, e5 J: z叠层信息截图如下:
1 j( A6 Q; q# z
6 @) l6 l6 L. h' H
9 W/ Q& S7 U8 Y/ DBOM:% p i8 M- C, f
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 100uF | C1, C2, C12 | CASE-A_3216 | 3 | 0.1uF | C3, C11, C13, C16, C20 | C0603 | 5 | 10uF/10V | C4, C5, C17, C18 | C0603 | 4 | 0.1U | C6, C7, C19, C21 | C0603 | 4 | 10UF | C8 | R0603 | 1 | 22PF | C9, C10 | C0603 | 2 | 0.1uF | C14 | R0603 | 1 | 10UF/10V | C15 | R0603 | 1 | 10uF | C22, C24 | C0603 | 2 | 104 | C23, C25 | C0603 | 2 | DSK34 | D1, D4 | SOD-123 | 2 | Diode 1N4148 | D2 | SOD323 | 1 | LED0 | D3, DS1, DS2 | LED0603 | 3 | D? | D5 | LED0603 | 1 | green | D6 | LED0603 | 1 | LED0 | DS3 | 5MM LED | 1 | SMD0805-050 | F1 | F0805 | 1 | BLUE | LED1 | LED0603 | 1 | Header 9 | P1 | microUSB | 1 | Header 2 | P2 | HDR1X2 | 1 | 8550 | Q1, Q2 | SOT-23 | 2 | S8050 | Q3 | SOT-23 | 1 | 1k | R1, R3, R6, R28, R33, R34 | R0603 | 6 | 0 | R2, R4, R23, R26 | R0603 | 4 | 10K | R5, R7, R8, R9, R10, R11, R12, R13, R14, R22, R25, R31, R35 | R0603 | 13 | 470 | R15, R17, R19 | R0603 | 3 | 100 | R16, R36 | R0603 | 2 | 0(NC) | R18, R20, R21 | R0603 | 3 | 47k | R24 | R0603 | 1 | 300 | R29 | R0603 | 1 | 2k | R30 | R0603 | 1 | 1.2K | R32 | R0603 | 1 | 贴片按键 | S1 | KEY-S | 1 | SPX1117M3.3 | U1 | SOT223 | 1 | HS0038 | U2 | HS0038A2 | 1 | ESP_12 | U3 | ESP_12 | 1 | 74HC4053 | U5 | SOIC-16_150mil | 1 | CH340B | U6 | SOIC-16_150mil | 1 | stc12c2052ad | u4 | DIP-20 | 1 | TP4056 | U7 | TP4056 | 1 | XTAL | Y1 | XTAL-D | 1 | ; |! \, }* H- R/ T
附件:4 v4 W' g, U# Y+ d+ A7 ~3 B
原理图和PCB源文件如下:. M) {$ f) a& A. l+ U' F3 t2 r
4 P& ~3 q1 }" j, X3 e* n
* }0 |( ]1 ] ]: N& o- ^. Z |
