查看: 219|回复: 0
[AD 10][2层]STC15电机控制板(BYT3400B/DD_0_DO-41_IN4007+L298_11_L298N_L298N+C...
发表于 2020-2-20 10:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
- `; h$ P' H7 v/ i# \* z
( k' g" p% K5 r( A) ~2 d% V
[AD 10][2层]STC15电机控制板(BYT3400B/DD_0_DO-41_IN4007+L298_11_L298N_L298N+CH340G_1_SOP16_CH340G)原理图和PCB文件
  ]0 d+ ?& K8 U6 M+ ?. E# @6 k7 u+ I) n5 i9 e3 z( W' U
文件描述$ }9 m! c4 i  L/ u8 h$ Z) F0 d' |
1. 作品用途:STC15电机控制板
5 w4 e4 V4 Y, O) t6 y2. 软件版本:AD 10
, P/ r" P$ B. z( f( m" W: m6 D3. 层数:2层板5 g$ Z* c$ g  e2 G7 o
4. 用到的主要芯片:BYT3400B/DD_0_DO-41_IN4007+L298_11_L298N_L298N+CH340G_1_SOP16_CH340G
6 \& O8 \" _6 Q- H1 e3 ^  F5. PCB尺寸:100*100 mm
* t5 f4 W5 ], T1 Z: G' @* B' S0 u/ m
作品截图如下:
5 S$ w) U) w- I4 d, ]顶层截图:
+ X7 z9 t9 U0 |
  v! i, L4 A3 n' V ' ^. J5 t& H3 m: W7 Y: H  s
底层截图:, h/ `$ d" H+ ?0 j
6 b3 p  r9 z1 a4 x4 W# ], k9 e/ Y3 x
全层截图:+ W( Q( p. Q& N6 B$ r0 P
$ A! l3 m# N* \* m2 ]" m. E/ g/ I
叠层信息截图如下:. K' b$ E3 C2 |9 l, \
9 _0 ^" I: m5 s7 m( u6 dBOM:, }9 A- Q) R0 E' _. \. d- ?/ J4 W
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
CAP NP_CAP0603_105PC1, C21CAP0603
CAP NP_CAP0603_104C2, C3, C4, C5, C7, C20, C23CAP0603
CAP NP_CAP0603_103C6CAP0603
CAP POL_3528_100UFC8, C11, C13, C17, C223528
CAP NP_CAP0603_22PFC9, C10, C19CAP0603
CAP NP_CAP0603_0.1UFC12, C14, C16, C18CAP0603
CAP POL_1_3528_100UFC153528
LED_LED0805_LEDD1, D3, D4, D5, D10, D11, D16, D17, D22, D23, D28, D29LED0805
12
BYT3400B/DD_0_DO-41_IN5817D2DO-41
BYT3400B/DD_0_DO-41_IN4007D6, D7, D8, D9, D13, D14, D15, D18, D19, D20, D21, D24, D25, D26, D27DO-41
15
BYT3400B/DD_2_DO-41_IN4007D12DO-41
HEADER 2_SIP2_HEADER 2J1, J2, J18SIP2
HEADER 11_SIP11_HEADER 11J3, J4, J5, J8SIP11
AUDIO_RJ_AUDIOJACK_AUDIO_RJJ6AUDIOJACK
HEADER 2_10_SIP4-2_54_HEADER 4J7, J19SIP4-2_54
HEADER 2_9_SIP2_HEADER 2J9, J10, J11, J12, J13, J14, J15, J16SIP2
8
HEADER 10_1_SIP4-2_54_HEADER 4J17SIP4-2_54
HEADER 10_1_SIP4-2_54_DHT11J20SIP4-2_54
POT/SM_SIP3_10KR1SIP3
R2_0603_10KR20603
R2_RES0603_10KR3RES0603
R2_RES0603_3.3KR4, R5, R6, R7, R9, R11, R19, R21, R22, R23, R24, R25, R26, R27, R28, R29, R30, R31, R32, R33, R34, R35, R36, R37, R44RES0603
25
R2_RES0603_301RR8, R10, R12, R14, R18, R40, R41RES0603
R2_RES0603_0R13RES0603
R2_RES0603_33R15, R17, R38, R39RES0603
R2_RES0603_1KR16RES0603
R2_RES0603_201RR20RES0603
R2_RES0603_4.7KR42, R43RES0603
REGMTG2_8D6
SW PUSHBUTTON-DPST_SW4-6040-PUSSW1SW4-6040-PUSH
SW PUSHBUTTON-DPST_SW4-6040-P_1SW2SW4-6040-PUSH
SW PUSHBUTTON-DPST_SW4-6040-P_2SW3SW4-6040-PUSH
SW PUSHBUTTON-DPST_SW4-6040-P_3SW4SW4-6040-PUSH
SW DIP-3_PUSH_6_SW DIP-3SW5PUSH_6
LCD12864_SIP20_LCD12864U1SIP20
STC15F2K60S2_LQFP44_LQFP44_STC1U2LQFP44
USB_1_USB_A_SH_USBU3USB_A_SH
MICRO-USB_3_USB-MINI-SMT-NUM_MIU4USB-MINI-SMT-NUM
CH340G_1_SOP16_CH340GU5SOP16
L14G2/TO_0_SB1204_2SB1204.U6SB1204
OPB700_1_DIP-4_TLP521_1U7, U8, U10, U11, U12, U13, U15, U16DIP-4
8
L298_14_L298N_L298NU9L298N
L298_11_L298N_L298NU14L298N
LCD12864_1_SIP16_1602U17SIP16
ZTA_XTAL-HC49US_12MX1XTAL-HC49US
AO3401AV1SOT-23-3L
S8050V2SOT-23A
附件:
6 G3 e/ _' e* W9 S! Z" I0 B原理图和PCB文件如下:
) a. v3 x! x% J3 {7 G$ |
游客,如果您要查看本帖隐藏内容请回复
; Y, U4 n3 f, f, b) r5 D8 \2 i* y: u; x$ y0 u
GMT+8, 2025-7-26 21:46 , Processed in 0.140625 second(s), 28 queries , Gzip On.
