' {1 C. ~) c0 Y4 k; c" j; Z( `( k+ g+ b) u8 W2 ~4 Y# Q
[AD 10][2层]SM903报警主机Ver3_0(74HC595+ISD1820+HT7750)原理图和PCB文件
3 W# L8 {+ C3 G: |
( u7 n1 l4 A, ]2 X) K0 b5 s0 I文件描述
# @9 S/ b1 [* B; z3 J; K5 c$ ~0 R8 D1. 作品用途:SM903报警主机Ver3_0
. ?; G/ ^; ]3 Q5 a) S1 O. R2. 软件版本:AD 105 z5 ?# [; ?9 n+ B
3. 层数:2层板
, S6 Y2 t3 Z, y/ c6 V) k4. 用到的主要芯片:74HC595+ISD1820+HT77507 b: R6 l4 w: _! M2 L- \4 C
5. PCB尺寸:116*62 mm
! Y# E" x4 P O, S9 O* J( h$ P$ r. d5 F, ~$ p) |
作品截图如下:
o- ?* [8 t! t4 _9 [, J8 i顶层截图:' y" y J6 @1 | h
0 }& |! @5 U' D& W* u I+ q9 \2 S2 Z7 _ @2 ]" ^2 X
底层截图:
/ c S% C* K: n& D9 k) r6 A
) C. W0 w0 w3 x. f' ^+ E1 z
6 h$ o& Z- g# O2 ^6 e' F全层截图:
, R8 T4 x6 T1 |
/ ?4 e% i, O2 z叠层信息截图如下:0 r5 Q* B; X" d( u9 ?6 C
( t# p! q Y6 O# D" K: R# K! `- o
BOM:
( V( P/ b/ c) c9 ?, U* eComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | BZ1 | BZ1 | 1 | 6P | C1, C2 | 0603-SMD | 2 | 3P | C3 | 0603-SMD | 1 | 4.7uF/25V | C101, C605 | 10UF/25V | 2 | 104 | C103, C104, C201, C203, C402, C505, C603, C604, C605, C702, C706, C707, C708, C902 | 0603-SMD | 14 | 102 | C105, C202, C601 | 0603-SMD | 3 | 2E104 | C301, C302 | 104/250V | 2 | 4.7uF/50V | C303 | 10UF/25V | 1 | 47PF | C403, C503 | 0603-SMD | 2 | 2E223 | C501, C502 | 103/100V | 2 | 220uF/25V | C602, C701, C709 | 220UF/25V | 3 | 220UF/16V | C703 | 100UF/25V | 1 | 100uF/25V | C901 | 10UF/25V | 1 | 315M | CY1 | CY315M | 1 | IN4007 | D101, D102, D103, D104, D301, D302, D303, D304, D701, D703 | IN400XSMD | 10 | IN4148 | D702, D704, D705, D706, D901 | 4148SMD | 5 | Comment | Designator1 | LOGO1 | 1 | Comment | Designator2 | LOGO2 | 1 | Phone In | J101, J102 | PHONE-2 | 2 | DC12V | J701 | DC0 | 1 | 5*1.2V 300mA | J702 | CON2 | 1 | BZ JACK | J703 | BZZ-CONNECT | 1 | REC | J704 | IC-REC | 1 | | J706 | SIP-8 | 1 | 100uH | L901 | L-10 | 1 | | MIC | MIC-10 | 1 | S8050 | Q1 | 8050SMD | 1 | R25+ 3356 | Q2 | 8050SMD | 1 | A92 | Q101, Q102 | 8550SMD | 2 | A42 | Q103 | 8050SMD | 1 | S9014 | Q104, Q105, Q301, Q701 | 8050SMD | 4 | 9014 | Q201, Q202 | 8050SMD | 2 | S9015 | Q702, Q703 | 8550SMD | 2 | D882 | Q704 | B772 | 1 | 2sc3356 | Q705 | 8050SMD | 1 | 27K | R1, R2 | 0603-SMD | 2 | 100K | R101, R112, R113, R206, R303, R501, R502, R507, R508, R509, R510, R511, R606, R707, R709, R716 | 0603-SMD | 16 | 4.7K | R102, R603, R706, R708 | 0603-SMD | 4 | 10K | R103, R108, R109, R201, R204, R401, R402, R403, R605, R717 | 0603-SMD | 10 | 3.3K | R104 | 0603-SMD | 1 | 120R | R105 | 0805SMD | 1 | 33K | R106, R302 | 0603-SMD | 2 | 300K | R111, R506 | 0603-SMD | 2 | 1M | R202 | 0603-SMD | 1 | 470K | R203, R301 | 0603-SMD | 2 | 2.2M | R205 | 0603-SMD | 1 | 39K | R503 | 0603-SMD | 1 | 68K | R504, R505 | 0603-SMD | 2 | 1K | R601, R704, R711, R712, R713, R714, R715 | 0603-SMD | 7 | 47K | R602 | 0603-SMD | 1 | 100R | R701 | 0805SMD | 1 | 2.2K | R705, R710, R718 | 0603-SMD | 3 | HK19F-DC5V-SHG | RE601 | RELAY-8 | 1 | HK4100F-DC5V-SHG | RE602 | RELAY-6 | 1 | | S1 | SW1 | 1 | test key | S2 | KEY1 | 1 | HT9200 | U401 | SO-8 | 1 | HT9270 | U501 | SOL-18 | 1 | ISD1820 | U601 | DIP-14 | 1 | 7150A | U701 | 7150-SOT89 | 1 | 16F73 | U702 | SOL-28 | 1 | 24C02 | U703 | SO-8 | 1 | 74HC595 | U704 | SO-16 | 1 | HT7750 | U901 | 7150-SOT89 | 1 | 3.575945 | X701 | CY | 1 | P6KE200CA | ZD101 | P6KEXXC | 1 | 附件:7 `& V& x8 M+ S+ ?9 p! ~
原理图和PCB文件如下:/ \, f% |5 H5 G' C& F
* c9 n+ q8 k9 y- i0 D+ L( S; V
& E" z% u& L6 f! }
